[mapguide-commits] r4498 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Fri Jan 8 17:19:53 EST 2010
Author: brucedechant
Date: 2010-01-08 17:19:53 -0500 (Fri, 08 Jan 2010)
New Revision: 4498
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
Notes:
- Added missing TRACE log entries
- Cleaned up exception handling
- Added missing exception handling
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2010-01-08 20:09:45 UTC (rev 4497)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2010-01-08 22:19:53 UTC (rev 4498)
@@ -90,7 +90,7 @@
MgServerGetFeatureProviders msgfp;
return msgfp.GetFeatureProviders();
@@ -196,9 +196,16 @@
MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::TestConnection()");
+ bool result = false;
+ MG_FEATURE_SERVICE_TRY()
MgServerFeatureConnection msfc(providerName, connectionString);
+ result = msfc.IsConnectionOpen();
- return msfc.IsConnectionOpen();
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.TestConnection")
+ return result;
@@ -216,9 +223,16 @@
MgServerFeatureConnection msfc(resource);
+ return result;
@@ -285,7 +299,7 @@
Ptr<MgFeatureSchemaCollection> schemas;
- MG_TRY()
if (NULL == resource)
@@ -302,7 +316,7 @@
MgServerDescribeSchema msds;
schemas = msds.DescribeSchema(resource, schemaName, classNames);
- MG_CATCH_AND_THROW(L"MgServerFeatureService.DescribeSchema");
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.DescribeSchema");
return schemas.Detach();
@@ -327,7 +341,7 @@
STRING schemaXml;
- MG_TRY()
@@ -344,7 +358,7 @@
schemaXml = msds.DescribeSchemaAsXml(resource, schemaName, classNames);
- MG_CATCH_AND_THROW(L"MgServerFeatureService.DescribeSchemaAsXml");
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.DescribeSchemaAsXml");
return schemaXml;
@@ -399,7 +413,7 @@
Ptr<MgFeatureReader> reader;
- MG_TRY()
@@ -416,7 +430,7 @@
MgServerSelectFeatures mssf;
reader = (MgFeatureReader*)mssf.SelectFeatures(resource, className, options, false);
- MG_CATCH_AND_THROW(L"MgServerFeatureService.SelectFeatures")
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.SelectFeatures")
return reader.Detach();
@@ -517,8 +531,16 @@
MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::SelectAggregate()");
+ Ptr<MgDataReader> reader;
- return (MgDataReader*)mssf.SelectFeatures(resource, className, options, true);
+ reader = (MgDataReader*)mssf.SelectFeatures(resource, className, options, true);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.SelectAggregate");
+ return reader.Detach();
@@ -642,10 +664,20 @@
/// MgFdoException
MgTransaction* MgServerFeatureService::BeginTransaction( MgResourceIdentifier* resource )
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::BeginTransaction()");
+ Ptr<MgTransaction> transaction;
MgServerFeatureTransactionPool* transactionPool = MgServerFeatureTransactionPool::GetInstance();
CHECKNULL(transactionPool, L"MgServerFeatureService.BeginTransaction");
- return transactionPool->CreateTransaction(resource);
+ transaction = transactionPool->CreateTransaction(resource);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.BeginTransaction")
+ return transaction.Detach();
@@ -889,7 +921,7 @@
Ptr<MgSpatialContextReader> reader;
- MG_TRY()
@@ -905,7 +937,7 @@
MgServerGetSpatialContexts msgsc;
reader = msgsc.GetSpatialContexts(resource);
- MG_CATCH_AND_THROW(L"MgServerFeatureService.GetSpatialContexts")
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.GetSpatialContexts")
@@ -1118,6 +1150,12 @@
MgByteReader* MgServerFeatureService::DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::DescribeWfsFeatureType()");
+ Ptr<MgByteReader> byteReader;
STRING schemaName;
Ptr<MgStringCollection> schemaNames = new MgStringCollection();
Ptr<MgStringCollection> classNames = new MgStringCollection();
@@ -1206,7 +1244,11 @@
Ptr<MgByteSource> bs = new MgByteSource((unsigned char*)utfsch.c_str(), (INT32)utfsch.length());
bs->SetMimeType(MgMimeType::Xml);
- return bs->GetReader();
+ byteReader = bs->GetReader();
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.DescribeWfsFeatureType")
+ return byteReader.Detach();
@@ -1235,6 +1277,12 @@
MgBatchPropertyCollection* MgServerFeatureService::GetFeatures(CREFSTRING featureReader)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetFeatures()");
+ Ptr<MgBatchPropertyCollection> bpCol;
MgServerFeatureReaderPool* featPool = MgServerFeatureReaderPool::GetInstance();
CHECKNULL(featPool, L"MgServerFeatureService.GetFeatures");
@@ -1265,9 +1313,20 @@
CHECKNULL((MgFeatureSet*)featSet, L"MgServerFeatureService.GetFeatures");
- Ptr<MgBatchPropertyCollection> bpCol = featSet->GetFeatures();
+ bpCol = featSet->GetFeatures();
CHECKNULL((MgBatchPropertyCollection*)bpCol, L"MgServerFeatureService.GetFeatures");
+ MG_FEATURE_SERVICE_CATCH(L"MgServerFeatureService.GetFeatures")
+ if(NULL != mgException.p)
+ // Cleanup the reader as an exception has occured
+ CloseFeatureReader(featureReader);
+ MG_FEATURE_SERVICE_THROW()
return (bpCol->GetCount() > 0)? bpCol.Detach() : NULL;
@@ -1275,8 +1334,12 @@
bool MgServerFeatureService::CloseFeatureReader(CREFSTRING featureReader)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::CloseFeatureReader()");
bool retVal = false;
CHECKNULL(featPool, L"MgServerFeatureService.CloseFeatureReader");
@@ -1288,6 +1351,8 @@
retVal = featPool->Remove(featureReader);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.CloseFeatureReader")
return retVal;
@@ -1295,6 +1360,8 @@
MgStringCollection* MgServerFeatureService::GetSchemas( MgResourceIdentifier* resource )
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetSchemas()");
return msds.GetSchemas(resource);
@@ -1303,6 +1370,8 @@
MgStringCollection* MgServerFeatureService::GetClasses( MgResourceIdentifier* resource, CREFSTRING schemaName )
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetClasses()");
return msds.GetClasses(resource, schemaName);
@@ -1313,6 +1382,8 @@
CREFSTRING schemaName,
CREFSTRING className)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetClassDefinition()");
return msds.GetClassDefinition(resource, schemaName, className, true);
@@ -1323,6 +1394,8 @@
CREFSTRING className,
bool serialize)
return msds.GetClassDefinition(resource, schemaName, className, serialize);
@@ -1331,6 +1404,8 @@
STRING MgServerFeatureService::SchemaToXml(MgFeatureSchemaCollection* schema)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::SchemaToXml()");
return msds.SchemaToXml(schema);
@@ -1339,6 +1414,8 @@
MgFeatureSchemaCollection* MgServerFeatureService::XmlToSchema(CREFSTRING xml)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::XmlToSchema()");
return msds.XmlToSchema(xml);
@@ -1347,8 +1424,12 @@
MgByteReader* MgServerFeatureService::GetRaster(CREFSTRING reader, INT32 xSize, INT32 ySize, STRING propName)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetRaster()");
CHECKNULL(featPool, L"MgServerFeatureService.GetRaster");
@@ -1375,6 +1456,8 @@
__LINE__, __WFILE__, &arguments, L"MgReaderIdNotFound", NULL);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.GetRaster")
@@ -1382,6 +1465,12 @@
MgBatchPropertyCollection* MgServerFeatureService::GetSqlRows(CREFSTRING sqlReader)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetSqlRows()");
MgServerSqlDataReaderPool* sqlDataReaderPool = MgServerSqlDataReaderPool::GetInstance();
CHECKNULL(sqlDataReaderPool, L"MgServerFeatureService.GetSqlRows");
@@ -1407,9 +1496,20 @@
count,
MgConfigProperties::DefaultFeatureServicePropertyDataCacheSize);
- Ptr<MgBatchPropertyCollection> bpCol = sqlDataReader->GetRows(count);
+ bpCol = sqlDataReader->GetRows(count);
CHECKNULL((MgBatchPropertyCollection*)bpCol, L"MgServerFeatureService.GetSqlRows");
+ MG_FEATURE_SERVICE_CATCH(L"MgServerFeatureService.GetSqlRows")
+ CloseSqlReader(sqlReader);
@@ -1417,8 +1517,12 @@
bool MgServerFeatureService::CloseSqlReader(CREFSTRING sqlReader)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::CloseSqlReader()");
CHECKNULL(sqlDataReaderPool, L"MgServerFeatureService.CloseSqlReader");
@@ -1430,6 +1534,8 @@
retVal = sqlDataReaderPool->Remove(sqlReader);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.CloseSqlReader")
return retVal;
@@ -1437,6 +1543,12 @@
MgBatchPropertyCollection* MgServerFeatureService::GetDataRows(CREFSTRING dataReader)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetDataRows()");
MgServerDataReaderPool* dataReaderPool = MgServerDataReaderPool::GetInstance();
CHECKNULL(dataReaderPool, L"MgServerFeatureService.GetDataRows");
@@ -1462,9 +1574,20 @@
count,
- Ptr<MgBatchPropertyCollection> bpCol = reader->GetRows(count);
+ bpCol = reader->GetRows(count);
CHECKNULL((MgBatchPropertyCollection*)bpCol, L"MgServerFeatureService.GetDataRows");
+ MG_FEATURE_SERVICE_CATCH(L"MgServerFeatureService.GetDataRows")
+ CloseDataReader(dataReader);
@@ -1472,8 +1595,12 @@
bool MgServerFeatureService::CloseDataReader(CREFSTRING dataReader)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::CloseDataReader()");
CHECKNULL(dataReaderPool, L"MgServerFeatureService.CloseDataReader");
@@ -1485,6 +1612,8 @@
retVal = dataReaderPool->Remove(dataReader);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.CloseDataReader")
return retVal;
@@ -1492,8 +1621,10 @@
void MgServerFeatureService::CreateFeatureSource(MgResourceIdentifier* resource, MgFeatureSourceParams* sourceParams)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::CreateFeatureSource()");
MgServerCreateFeatureSource msds;
- return msds.CreateFeatureSource(resource, sourceParams);
+ msds.CreateFeatureSource(resource, sourceParams);
@@ -1504,6 +1635,8 @@
MgStringCollection* classNames)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetIdentityProperties()");
return msds.GetIdentityProperties(resource, schemaName, classNames);
@@ -1551,6 +1684,8 @@
CREFSTRING wfsFilter,
INT32 maxFeatures)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetWfsFeature()");
TransformCacheMap transformCache;
@@ -1672,7 +1807,7 @@
src->SetMimeType(MgMimeType::Xml);
byteReader = src->GetReader();
- MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH_AND_THROW(fs, L"MgServerFeatureService.GetWfsFeature")
+ MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH(fs, L"MgServerFeatureService.GetWfsFeature")
TransformCache::Clear(transformCache);
@@ -1699,9 +1834,8 @@
MgServerEnumerateDataStores mseds;
return mseds.EnumerateDataStores(providerName, partialConnString);
/// \brief
/// This method returns all of the logical to physical schema mappings for
@@ -1730,18 +1864,38 @@
bool MgServerFeatureService::CommitTransaction(CREFSTRING transactionId)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::CommitTransaction()");
+ bool bResult = false;
CHECKNULL(transactionPool, L"MgServerFeatureService.CommitTransaction");
- return transactionPool->CommitTransaction(transactionId);
+ bResult = transactionPool->CommitTransaction(transactionId);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.CommitTransaction")
+ return bResult;
bool MgServerFeatureService::RollbackTransaction(CREFSTRING transactionId)
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::RollbackTransaction()");
CHECKNULL(transactionPool, L"MgServerFeatureService.RollbackTransaction");
- return transactionPool->RollbackTransaction(transactionId);
+ bResult = transactionPool->RollbackTransaction(transactionId);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureService.RollbackTransaction")
+ return bResult;
More information about the mapguide-commits
