[mapguide-commits] r4505 - in trunk/MgDev: . BuildTools/CC.Net Common Common/CoordinateSystem Common/Foundation/Exception Common/Geometry/CoordinateSystem Common/Geometry/GeometryConsoleTest Common/MapGuideCommon/Services Common/PlatformBase/Data Common/PlatformBase/Ser
Tom Fukushima tom.fukushima at autodesk.com
Mon Jan 11 10:07:50 EST 2010
-----Original Message-----
From: svn_mapguide at osgeo.org [mailto:svn_mapguide at osgeo.org]
Sent: January-08-10 11:00 PM
To: mapguide-commits at lists.osgeo.org
Subject: r4505 - in trunk/MgDev: . BuildTools/CC.Net Common Common/CoordinateSystem Common/Foundation/Exception Common/Geometry/CoordinateSystem Common/Geometry/GeometryConsoleTest Common/MapGuideCommon/Services Common/PlatformBase/Data Common/PlatformBase/Serv...
Author: waltweltonlair
Date: 2010-01-09 01:00:06 -0500 (Sat, 09 Jan 2010)
New Revision: 4505
   trunk/MgDev/BuildTools/CC.Net/ccnet.config
   trunk/MgDev/Common/Common.sln
   trunk/MgDev/Common/CoordinateSystem/CoordSysEnvVariable.h
   trunk/MgDev/Common/CoordinateSystem/CoordSysGridGeneric.cpp
   trunk/MgDev/Common/CoordinateSystem/CoordSysGridGeneric.h
   trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp
   trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.h
   trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp
   trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.h
   trunk/MgDev/Common/CoordinateSystem/CoordSysMgrsMajorRegion.cpp
   trunk/MgDev/Common/CoordinateSystem/CoordSysMgrsMajorRegion.h
   trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.cpp
   trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.h
   trunk/MgDev/Common/Foundation/Exception/GridDensityException.cpp
   trunk/MgDev/Common/Foundation/Exception/GridDensityException.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridGeneric.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h
   trunk/MgDev/Common/Geometry/GeometryConsoleTest/GeometryConsoleTest.cpp
   trunk/MgDev/Common/Geometry/GeometryConsoleTest/GeometryConsoleTest.vcproj
   trunk/MgDev/Common/Geometry/GeometryConsoleTest/ReadMe.txt
   trunk/MgDev/Common/Geometry/GeometryConsoleTest/stdafx.cpp
   trunk/MgDev/Common/Geometry/GeometryConsoleTest/stdafx.h
   trunk/MgDev/Common/Geometry/GeometryConsoleTest/targetver.h
   trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.h
   trunk/MgDev/Common/PlatformBase/Data/Margin.cpp
   trunk/MgDev/Common/PlatformBase/Data/Margin.h
   trunk/MgDev/Common/PlatformBase/Data/Size2D.cpp
   trunk/MgDev/Common/PlatformBase/Data/Size2D.h
   trunk/MgDev/Common/PlatformBase/Services/FileFeatureSourceParams.cpp
   trunk/MgDev/Common/PlatformBase/Services/FileFeatureSourceParams.h
   trunk/MgDev/Common/PlatformBase/Services/Parameter.cpp
   trunk/MgDev/Common/PlatformBase/Services/Parameter.h
   trunk/MgDev/Common/PlatformBase/Services/ParameterCollection.cpp
   trunk/MgDev/Common/PlatformBase/Services/ParameterCollection.h
   trunk/MgDev/Common/PlatformBase/Services/ParameterDirection.h
   trunk/MgDev/Common/Stylization/TransformMesh.cpp
   trunk/MgDev/Common/Stylization/TransformMesh.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ASNMP/agent/Makefile.asnmp_agent.bmak
   trunk/MgDev/Oem/ACE/ACE_wrappers/Makefile.bmak
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/ETCL/Makefile.ACE_ETCL.bmak
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/ETCL/Makefile.ACE_ETCL_Parser.bmak
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/ETCL/Makefile.bmak
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/Makefile.ACE.bmak
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/Makefile.bmak
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/Monitor_Control/Makefile.bmak
   trunk/MgDev/Oem/dbxml-2.3.10/dbxml/build_windows/copyFiles7_win64.bat
   trunk/MgDev/Oem/dbxml-2.3.10/dbxml/build_windows/installProj_win64.bat
   trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/icons.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/ie6.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/ie7.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/index.html
   trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/jxtheme.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/jxtheme.uncompressed.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/icons.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/ie6.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/ie7.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/jxtheme.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/jxtheme.uncompressed.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/icons.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/ie6.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/ie7.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/jxtheme.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/jxtheme.uncompressed.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/ApplicationDefinition.xml
   trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/icons.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/ie6.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/ie7.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/jxtheme.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/jxtheme.uncompressed.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/icons.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/ie6.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/ie7.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/jxtheme.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/jxtheme.uncompressed.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/icons.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/ie6.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/ie7.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/jxtheme.css
   trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/jxtheme.uncompressed.css
   trunk/MgDev/Server/src/Services/Feature/OpApplySchema.cpp
   trunk/MgDev/Server/src/Services/Feature/OpApplySchema.h
   trunk/MgDev/Server/src/Services/Feature/ServerApplySchema.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerApplySchema.h
   trunk/MgDev/Server/src/Services/Resource/OpGetResourceContents.cpp
   trunk/MgDev/Server/src/Services/Resource/OpGetResourceContents.h
   trunk/MgDev/Server/src/UnitTesting/TestTransformMesh.cpp
   trunk/MgDev/Server/src/UnitTesting/TestTransformMesh.h
   trunk/MgDev/UnitTest/TestData/FeatureService/SDF/Empty.FeatureSource
   trunk/MgDev/UnitTest/TestData/PrintLayout/MapViewportSample1.xml
   trunk/MgDev/UnitTest/TestData/ResourceService/TEST.LayerDefinition
   trunk/MgDev/Web/src/DotNetApi/AssemblyInfo.cs
   trunk/MgDev/Web/src/DotNetApi/Foundation/AssemblyInfo.cs
   trunk/MgDev/Web/src/DotNetApi/Foundation/FoundationDotNetApi.vcproj
   trunk/MgDev/Web/src/DotNetApi/Foundation/FoundationMakefile
   trunk/MgDev/Web/src/DotNetApi/Foundation/ManagedException.cs
   trunk/MgDev/Web/src/DotNetApi/Geometry/AssemblyInfo.cs
   trunk/MgDev/Web/src/DotNetApi/Geometry/GeometryDotNetApi.vcproj
   trunk/MgDev/Web/src/DotNetApi/Geometry/GeometryMakefile
   trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/AssemblyInfo.cs
   trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/Localizer.cs
   trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonDotNetApi.vcproj
   trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile
   trunk/MgDev/Web/src/DotNetApi/PlatformBase/AssemblyInfo.cs
   trunk/MgDev/Web/src/DotNetApi/PlatformBase/PlatformBaseDotNetApi.vcproj
   trunk/MgDev/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile
   trunk/MgDev/Web/src/DotNetApi/Web/AssemblyInfo.cs
   trunk/MgDev/Web/src/DotNetApi/Web/WebDotNetApi.vcproj
   trunk/MgDev/Web/src/DotNetApi/Web/WebMakefile
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApi.rc
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApi.vcproj
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationConstants.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom/MgBatchPropertyCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom/MgPropertyCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom/MgStringCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApi.rc
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApi.vcproj
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryConstants.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgCoordinateCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgCurvePolygonCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgCurveRingCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgCurveSegmentCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgCurveStringCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgGeometryCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgLineStringCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgLinearRingCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgPointCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryCustom/MgPolygonCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApi.rc
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApi.vcproj
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonConstants.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonCustom/MgMapPlotCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApi.rc
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApi.vcproj
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseConstants.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgClassDefinitionCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgColor
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgFeatureCommandCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgFeatureSchemaCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgIntCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgLayerCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgLayerGroupCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgMapCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgPropertyDefinitionCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgReadOnlyLayerCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgResourceIdentifier
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseCustom/MgStringPropertyCollection
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/InitializeWebTier.i
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApi.rc
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApi.vcproj
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebConstants.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebCustom/empty
   trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.vcproj
   trunk/MgDev/Web/src/mapadmin/index.html
   trunk/MgDev/Web/src/mapagent64/mapagent.fcgi
   trunk/MgDev/build.bat
   trunk/MgDev/csmap_excludes.txt
   trunk/MgDev/debug_excludes.txt
   trunk/MgDev/dotnet_excludes.txt
   trunk/MgDev/java_excludes.txt
   trunk/MgDev/mapagent_excludes.txt
   trunk/MgDev/php_excludes.txt
   trunk/MgDev/release_excludes.txt
   trunk/MgDev/svn_excludes.txt
   trunk/MgDev/updateversion.vbs
The svn:eol-style attribute should be set to native for all files.
More information about the mapguide-commits mailing list
