[mapguide-commits] r4538 - in
trunk/Tools/Maestro/MaestroAPI/Signer: . SignedVersions
svn_mapguide at osgeo.org
Fri Jan 15 15:33:56 EST 2010
Author: ksgeograf
Date: 2010-01-15 15:33:56 -0500 (Fri, 15 Jan 2010)
New Revision: 4538
Added:
trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/
trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-1.2.dll
trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-2.0.dll
trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-2.1.dll
trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/README MaestroAPI Version.txt
trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/maestroapi.key
trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/web.config
Maestro:
Added signed versions of the MapGuideDotNetApi dll's in different versions.
Also added a bindingRedirect document and a readme.
Added: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-1.2.dll
(Binary files differ)
Property changes on: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-1.2.dll
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-2.0.dll
Property changes on: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-2.0.dll
Added: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-2.1.dll
Property changes on: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/MapGuideDotNetApi-2.1.dll
Added: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/README MaestroAPI Version.txt
--- trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/README MaestroAPI Version.txt (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/README MaestroAPI Version.txt 2010-01-15 20:33:56 UTC (rev 4538)
@@ -0,0 +1,22 @@
+MaestroAPI targets MGOS 2.0 (and MGEP 2010).
+The HttpServerConnection can work with any version
+of MapGuide, but the LocalNativeConnection needs
+the correct version of MapGuideDotNetApi.dll
+Unfortunately the official MapGuideDotNetApi.dll
+has varying version numbers, and is usually not signed.
+To use the LocalNativeConnction with 1.2 or 2.1, you must
+use a signed version of MapGuideDotNetApi.dll.
+The Web.Config file shows how to add a bindingRedirect
+for a ASP.Net application, the same can be done for
+a regulat executable. Just rename Web.Config to match
+your executable, eg MyApp.exe -> MyApp.exe.config.
+If you need a special version of MapGuideDotNetApi.dll,
+eg. for a development version of MapGuide, you can
+sign the dll by issuing this command:
+..\signer.exe -k ..\..\maestroapi.key -outdir .\out -a MapGuideDotNetApi.dll
\ No newline at end of file
Added: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/maestroapi.key
Property changes on: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/maestroapi.key
Added: trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/web.config
--- trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/web.config (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Signer/SignedVersions/web.config 2010-01-15 20:33:56 UTC (rev 4538)
@@ -0,0 +1,31 @@
+<?xml version="1.0"?>
+<configuration>
+ <runtime>
+ <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
+ <dependentAssembly>
+ <assemblyIdentity name="MapGuideDotNetApi" publicKeyToken="f526c48929fda856" />
+ NOTE: href MUST be absolute, alternative is to just rename
+ the desired version of the file and replace MapGuideDotNetApi.dll
+ If you choose the rename option, remove the <codeBase> tags below,
+ but keep the <bindingRedirect>
+ <codeBase version="1.2.0.4103" href="MapGuideDotNetApi-1.2.dll"/>
+ <codeBase version="2.0.0.2308" href="MapGuideDotNetApi-2.0.dll"/>
+ <codeBase version="1.0.0.1" href="MapGuideDotNetApi-2.1.dll"/>
+ <!-- Activate MGOS 1.2, MGEP 2008 -->
+ <!-- <bindingRedirect oldVersion="2.0.0.2308" newVersion="1.2.0.4103" /> -->
+ <!-- Activate MGOS 2.0, MGEP 2009 , *default* -->
+ <!-- <bindingRedirect oldVersion="2.0.0.2308" newVersion="2.0.0.2308" /> -->
+ <!-- Activate MGOS 2.1, MGEP 2010 -->
+ <bindingRedirect oldVersion="2.0.0.2308" newVersion="1.0.0.1" />
+ </dependentAssembly>
+ </assemblyBinding>
+ </runtime>
+ </configuration>
More information about the mapguide-commits
