[mapguide-commits] r4545 - sandbox/adsk/2.2gp/Common/Renderers
svn_mapguide at osgeo.org
Thu Jan 21 13:58:53 EST 2010
Author: stevedang
Date: 2010-01-21 13:58:51 -0500 (Thu, 21 Jan 2010)
New Revision: 4545
sandbox/adsk/2.2gp/Common/Renderers/AGGRenderer.cpp
sandbox/adsk/2.2gp/Common/Renderers/Renderers.vcproj
sandbox/adsk/2.2gp/Common/Renderers/agg_context.h
Fix #1249: Map with 50 base text layers consumes much Memory.
Submitted on behalf of Walt. Traian and I have reviewed the changes. With this fix, the MG Server performance has been remarkably improved.
Modified: sandbox/adsk/2.2gp/Common/Renderers/AGGRenderer.cpp
--- sandbox/adsk/2.2gp/Common/Renderers/AGGRenderer.cpp 2010-01-21 18:09:05 UTC (rev 4544)
+++ sandbox/adsk/2.2gp/Common/Renderers/AGGRenderer.cpp 2010-01-21 18:58:51 UTC (rev 4545)
@@ -1411,12 +1411,19 @@
if (NULL == font)
return;
- // Don't draw the text if height > 16384 pixels, since memory usage when
- // evaluating the glyphs will get too large. 16394 pixels should be
- // more than enough (e.g. this allows 13" high text on a 1200dpi device).
+ // Don't draw the text if height > 16384 pixels, since performance will be
+ // poor. 16394 pixels should be more than enough (e.g. this allows 13" high
+ // text on a 1200dpi device).
if (height > 16384.0)
return;
+ // For the best performance we want to cache images of glyphs as much as
+ // possible. But when the font height gets large the memory size of the
+ // cached images starts to become an issue, especially if many different
+ // glyphs get cached. So when height > 1024 switch to caching glyph outlines,
+ // since memory use is then independent of height (at least for scalable fonts).
+ agg::glyph_rendering glyph_type = (height > 1024.0)? agg::glyph_ren_outline : agg::glyph_ren_agg_gray8;
bool font_changed = false;
if (cxt->last_font != font)
@@ -1427,24 +1434,36 @@
DWFCore::DWFString::EncodeUTF8(font->m_filename.c_str(), lenf * sizeof(wchar_t), futf8, lenbytesf);
// load the font
- bool res = cxt->feng.load_font(futf8, 0, agg::glyph_ren_agg_gray8);
+ bool res = cxt->feng.load_font(futf8, 0, glyph_type);
cxt->feng.char_map(FT_ENCODING_UNICODE);
if (!res)
return;
cxt->last_font = font;
+ cxt->last_glyph_type = glyph_type;
font_changed = true;
+ else if (cxt->last_glyph_type != glyph_type)
+ // reload the font using the new glyph caching type - since the
+ // font was previously loaded this call is fast
+ bool res = cxt->feng.load_font(cxt->feng.name(), 0, glyph_type);
+// cxt->feng.char_map(FT_ENCODING_UNICODE); // this should not be necessary
+ if (!res)
+ return;
+// font_changed = true; // this should not be necessary
if (font_changed || cxt->last_font_height != height)
cxt->feng.height(height);
cxt->last_font_height = height;
-// double width = cxt->feng.width();
agg::trans_affine mtx;
mtx *= agg::trans_affine_rotation(angleRad);
// mtx *= agg::trans_affine_skewing(-0.4, 0);
@@ -1470,18 +1489,43 @@
#endif
unsigned int* p = text;
- while (*p)
+ if (glyph_type == agg::glyph_ren_agg_gray8)
- const agg::glyph_cache* glyph = cxt->fman.glyph(*p++);
+ while (*p)
+ const agg::glyph_cache* glyph = cxt->fman.glyph(*p++);
+ cxt->fman.add_kerning(&x, &y);
+ cxt->fman.init_embedded_adaptors(glyph, x, y);
- cxt->fman.add_kerning(&x, &y);
+ agg::render_scanlines(cxt->fman.gray8_adaptor(), cxt->fman.gray8_scanline(), ren_aa_solid);
- cxt->fman.init_embedded_adaptors(glyph, x, y);
+ x += glyph->advance_x;
+ y += glyph->advance_y;
+ else
+ font_curve_type curves(cxt->fman.path_adaptor());
+ font_contour_type contour(curves);
- agg::render_scanlines(cxt->fman.gray8_adaptor(), cxt->fman.gray8_scanline(), ren_aa_solid);
+ cxt->ras.filling_rule(agg::fill_non_zero);
- x += glyph->advance_x;
- y += glyph->advance_y;
+ while (*p)
+ cxt->ras.reset();
+ cxt->ras.add_path(contour);
+ agg::render_scanlines(cxt->ras, cxt->sl, ren_aa_solid);
+ cxt->ras.filling_rule(agg::fill_even_odd);
@@ -1494,9 +1538,10 @@
RS_F_Point* res, // assumes length equals 4 points
float* offsets) // assumes length equals length of string
- // If the supplied font height is too large AGG will run out of memory. We'll
- // use a reasonable font height for measuring, and then scale the result.
- double measureHeight = rs_min(5000.0, height);
+ // If the supplied font height is too large AGG will run out of memory
+ // when it tries to cache images of the glyphs. So restrict the height
+ // to 1024 for measuring, and then scale the result if necessary.
+ double measureHeight = rs_min(1024.0, height);
double measureScale = height / measureHeight;
// load the font
@@ -1516,6 +1561,7 @@
return;
c()->last_font = font;
+ c()->last_glyph_type = agg::glyph_ren_agg_gray8;
@@ -1533,8 +1579,6 @@
c()->last_font_height = measureHeight;
-// double width = c()->feng.width();
// Do any BIDI conversion. If the offset array is supplied (i.e. for path
// text) then assume the conversion was already performed on the input string.
const RS_String* pStrToUse;
Modified: sandbox/adsk/2.2gp/Common/Renderers/Renderers.vcproj
--- sandbox/adsk/2.2gp/Common/Renderers/Renderers.vcproj 2010-01-21 18:09:05 UTC (rev 4544)
+++ sandbox/adsk/2.2gp/Common/Renderers/Renderers.vcproj 2010-01-21 18:58:51 UTC (rev 4545)
@@ -639,6 +639,10 @@
</File>
<File
+ RelativePath="..\..\Oem\agg-2.4\src\agg_vcgen_contour.cpp"
+ </File>
+ <File
RelativePath="..\..\Oem\agg-2.4\src\agg_vcgen_stroke.cpp"
</File>
Modified: sandbox/adsk/2.2gp/Common/Renderers/agg_context.h
--- sandbox/adsk/2.2gp/Common/Renderers/agg_context.h 2010-01-21 18:09:05 UTC (rev 4544)
+++ sandbox/adsk/2.2gp/Common/Renderers/agg_context.h 2010-01-21 18:58:51 UTC (rev 4545)
@@ -90,6 +90,8 @@
// font types
typedef agg::font_engine_freetype_int32 font_engine_type;
typedef agg::font_cache_manager<font_engine_type> font_manager_type;
+typedef agg::conv_curve<font_manager_type::path_adaptor_type> font_curve_type;
+typedef agg::conv_contour<font_curve_type> font_contour_type;
// alpha mask pixel format
typedef agg::renderer_base<agg::pixfmt_gray8> mg_alpha_mask_rb_type;
@@ -137,6 +139,7 @@
feng.transform(agg::trans_affine());
last_font_height = 0.0;
last_font = NULL;
+ last_glyph_type = agg::glyph_ren_agg_gray8;
// polygon clip buffer
bPolyClip = false;
@@ -197,6 +200,7 @@
double last_font_height;
const RS_Font* last_font;
agg::trans_affine last_font_transform;
+ agg::glyph_rendering last_glyph_type;
#endif
More information about the mapguide-commits
