[mapguide-commits] r4560 - trunk/MgDev/Common/Renderers
svn_mapguide at osgeo.org
Sat Jan 30 13:42:49 EST 2010
Author: waltweltonlair
Date: 2010-01-30 13:42:48 -0500 (Sat, 30 Jan 2010)
New Revision: 4560
trunk/MgDev/Common/Renderers/AGGW2DRewriter.cpp
Fix #1257 (DWF polytriangles render poor in AGG)
Updated the DWF polytriangle handler code to call AGGRenderer::DrawScreenPolygon with
just the outline of the polytriangle.
Modified: trunk/MgDev/Common/Renderers/AGGW2DRewriter.cpp
--- trunk/MgDev/Common/Renderers/AGGW2DRewriter.cpp 2010-01-30 18:07:34 UTC (rev 4559)
+++ trunk/MgDev/Common/Renderers/AGGW2DRewriter.cpp 2010-01-30 18:42:48 UTC (rev 4560)
@@ -191,9 +191,7 @@
if (color.alpha() != 0)
AGGRenderer::DrawScreenPolygon((agg_context*)rewriter->GetW2DTargetImage(), lb, NULL, color.argb());
LineBufferPool::FreeLineBuffer(rewriter->GetBufferPool(), spLB.release());
LineBufferPool::FreeLineBuffer(rewriter->GetBufferPool(), spDstLB.release());
@@ -515,25 +513,44 @@
WT_Logical_Point* srcpts = polytriangle.points();
- LineBuffer* dstpts = rewriter->ProcessW2DPoints(file, srcpts, polytriangle.count(), true);
+ int numPoints = polytriangle.count();
+ if (numPoints <= 2)
+ return WT_Result::Success;
+ LineBuffer* dstpts = rewriter->ProcessW2DPoints(file, srcpts, numPoints, true);
std::auto_ptr<LineBuffer> spDstLB(dstpts);
if (dstpts)
- LineBuffer lb(4);
+ // # of triangles
+ // even odd
+ // 1 3 5 7 1 3 5
+ // | \ | \ | \ | or | \ | \ | \
+ // 0 2 4 6 0 2 4 6
+ LineBuffer lb(numPoints+1);
- for (int i=2; i < polytriangle.count(); i++)
- lb.MoveTo(dstpts->x_coord(i-2), dstpts->y_coord(i-2));
- lb.LineTo(dstpts->x_coord(i-1), dstpts->y_coord(i-1));
- lb.LineTo(dstpts->x_coord(i ), dstpts->y_coord(i ));
- lb.Close();
+ lb.MoveTo(dstpts->x_coord(0), dstpts->y_coord(0));
- AGGRenderer::DrawScreenPolygon((agg_context*)rewriter->GetW2DTargetImage(), &lb, NULL, color.argb());
+ // add the edge with even numbered points (lower edge in diagram above)
+ for (int i=2; i<numPoints; i += 2)
+ lb.LineTo(dstpts->x_coord(i), dstpts->y_coord(i));
- lb.Reset();
+ // add the edge with odd numbered points (upper edge in diagram above)
+ int oddMax = (numPoints % 2)? numPoints-2 : numPoints-1;
+ for (int i=oddMax; i>=1; i -= 2)
+ lb.Close();
+ AGGRenderer::DrawScreenPolygon((agg_context*)rewriter->GetW2DTargetImage(), &lb, NULL, color.argb());
More information about the mapguide-commits
