[mapguide-commits] r4569 - trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jan 30 15:04:38 EST 2010
Author: ksgeograf
Date: 2010-01-30 15:04:38 -0500 (Sat, 30 Jan 2010)
New Revision: 4569
   trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.resx
   trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/LineFeatureStyleEditor.cs
Maestro:
Fixed issue #1254.
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.cs	2010-01-30 19:32:31 UTC (rev 4568)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.cs	2010-01-30 20:04:38 UTC (rev 4569)
@@ -162,6 +162,7 @@
             this.sizeUnitsCombo.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
             this.sizeUnitsCombo.Name = "sizeUnitsCombo";
             this.sizeUnitsCombo.ValueMember = "Value";
+            this.sizeUnitsCombo.SelectedIndexChanged += new System.EventHandler(this.sizeUnitsCombo_SelectedIndexChanged);
             // UnitsTable
@@ -188,6 +189,7 @@
             this.sizeContextCombo.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
             this.sizeContextCombo.Name = "sizeContextCombo";
             this.sizeContextCombo.ValueMember = "Value";
+            this.sizeContextCombo.SelectedIndexChanged += new System.EventHandler(this.sizeContextCombo_SelectedIndexChanged);
             // SizeContextTable
@@ -290,9 +292,10 @@
 			try
-				if (m_item == null)
+                m_inUpdate = true;
+                if (m_item == null)
-					m_inUpdate = true;
 					fillStyleEditor.displayFill.Checked = false;
 					lineStyleEditor.displayLine.Checked = false;
 					return;
@@ -313,13 +316,12 @@
 				if (m_item.Stroke != null)
 					sizeUnitsCombo.SelectedValue = m_item.Stroke.Unit.ToString();
-					//sizeContextCombo.SelectedValue = st.??;
+                    sizeContextCombo.SelectedValue = m_item.Stroke.SizeContext.ToString();
 					if (m_item.Stroke.ColorAsHTML != null)
 						lineStyleEditor.colorCombo.CurrentColor = m_item.Stroke.Color;
 					lineStyleEditor.fillCombo.SelectedIndex = lineStyleEditor.fillCombo.FindString(m_item.Stroke.LineStyle);
                     lineStyleEditor.thicknessCombo.Text = m_item.Stroke.Thickness;
 				previewPicture.Refresh();
@@ -498,5 +500,21 @@
                     m_inUpdate = false;
+        private void sizeContextCombo_SelectedIndexChanged(object sender, EventArgs e)
+            if (m_inUpdate || m_item.Stroke == null)
+                return;
+            m_item.Stroke.SizeContext = (OSGeo.MapGuide.MaestroAPI.SizeContextType)Enum.Parse(typeof(OSGeo.MapGuide.MaestroAPI.SizeContextType), (string)sizeContextCombo.SelectedValue);
+        private void sizeUnitsCombo_SelectedIndexChanged(object sender, EventArgs e)
+                return;
+            m_item.Stroke.Unit = (OSGeo.MapGuide.MaestroAPI.LengthUnitType)Enum.Parse(typeof(OSGeo.MapGuide.MaestroAPI.LengthUnitType), (string)sizeUnitsCombo.SelectedValue);
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.resx	2010-01-30 19:32:31 UTC (rev 4568)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/AreaFeatureStyleEditor.resx	2010-01-30 20:04:38 UTC (rev 4569)
@@ -136,7 +136,7 @@
     <value>fillStyleEditor</value>
   </data>
   <data name="&gt;&gt;fillStyleEditor.Type" xml:space="preserve">
-    <value>OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.FillStyleEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4358, Culture=neutral, PublicKeyToken=null</value>
+    <value>OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.FillStyleEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4480, Culture=neutral, PublicKeyToken=null</value>
   </data>
   <data name="&gt;&gt;fillStyleEditor.Parent" xml:space="preserve">
     <value>groupBox2</value>
@@ -160,7 +160,7 @@
     <value>lineStyleEditor</value>
   </data>
   <data name="&gt;&gt;lineStyleEditor.Type" xml:space="preserve">
-    <value>OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.LineStyleEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4358, Culture=neutral, PublicKeyToken=null</value>
+    <value>OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.LineStyleEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4480, Culture=neutral, PublicKeyToken=null</value>
   </data>
   <data name="&gt;&gt;lineStyleEditor.Parent" xml:space="preserve">
     <value>groupBox1</value>
@@ -321,18 +321,6 @@
   <data name="previewGroup.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Left, Right</value>
   </data>
-  <data name="previewPicture.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
-    <value>Top, Left, Right</value>
-  </data>
-  <data name="previewPicture.Location" type="System.Drawing.Point, System.Drawing">
-    <value>8, 16</value>
-  </data>
-  <data name="previewPicture.Size" type="System.Drawing.Size, System.Drawing">
-    <value>282, 24</value>
-  </data>
-  <data name="previewPicture.TabIndex" type="System.Int32, mscorlib">
-    <value>0</value>
-  </data>
   <data name="&gt;&gt;previewPicture.Name" xml:space="preserve">
     <value>previewPicture</value>
   </data>
@@ -369,6 +357,30 @@
   <data name="&gt;&gt;previewGroup.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
+  <data name="previewPicture.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Left, Right</value>
+  </data>
+  <data name="previewPicture.Location" type="System.Drawing.Point, System.Drawing">
+    <value>8, 16</value>
+  </data>
+  <data name="previewPicture.Size" type="System.Drawing.Size, System.Drawing">
+    <value>282, 24</value>
+  </data>
+  <data name="previewPicture.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
+  </data>
+  <data name="&gt;&gt;previewPicture.Name" xml:space="preserve">
+    <value>previewPicture</value>
+  </data>
+  <data name="&gt;&gt;previewPicture.Type" xml:space="preserve">
+    <value>System.Windows.Forms.PictureBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;previewPicture.Parent" xml:space="preserve">
+    <value>previewGroup</value>
+  </data>
+  <data name="&gt;&gt;previewPicture.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
   <metadata name="ComboBoxDataSet.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>17, 17</value>
   </metadata>
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/LineFeatureStyleEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/LineFeatureStyleEditor.cs	2010-01-30 19:32:31 UTC (rev 4568)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/GeometryStyleEditors/LineFeatureStyleEditor.cs	2010-01-30 20:04:38 UTC (rev 4569)
@@ -139,7 +139,7 @@
 				if (st != null)
 				    sizeUnitsCombo.SelectedValue = st.Unit.ToString();
+                    sizeContextCombo.SelectedValue = st.SizeContext.ToString();
                     if (st.ColorAsHTML == null)
                         lineStyleEditor.colorCombo.CurrentColor = Color.Black;
                     else
@@ -463,8 +463,10 @@
 			if (m_inUpdate)
 				return;
-			//TODO: Where does this go?
-			if (Changed != null)
+            this.CurrentStrokeType.SizeContext = (OSGeo.MapGuide.MaestroAPI.SizeContextType)Enum.Parse(typeof(OSGeo.MapGuide.MaestroAPI.SizeContextType), (string)sizeContextCombo.SelectedValue);
+            previewPicture.Refresh();
+            lineStyles.Refresh();
+            if (Changed != null)
 				Changed(this, new EventArgs());
More information about the mapguide-commits mailing list
