[mapguide-commits] r4988 - in
trunk/Tools/Maestro/Maestro/FusionEditor: . Strings
svn_mapguide at osgeo.org
Thu Jul 1 23:23:13 EDT 2010
Author: jng
Date: 2010-07-02 03:23:12 +0000 (Fri, 02 Jul 2010)
New Revision: 4988
trunk/Tools/Maestro/Maestro/FusionEditor/ApplicationDefinitionEditor.cs
trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.Designer.cs
trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.resx
Fix #1389: Port web layout preview logic to fusion editor.
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/ApplicationDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/ApplicationDefinitionEditor.cs 2010-07-02 02:31:42 UTC (rev 4987)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/ApplicationDefinitionEditor.cs 2010-07-02 03:23:12 UTC (rev 4988)
@@ -131,6 +131,9 @@
UpdateDisplay();
+ private string sessionPreviewUrl;
+ private string libraryPreviewUrl;
public void UpdateDisplay()
try
@@ -741,10 +744,35 @@
public bool Preview()
- ShowInBrowser_Click(null, null);
+ //ShowInBrowser_Click(null, null);
+ SaveSessionCopy();
+ DoPreview(sessionPreviewUrl);
return true;
+ private void SaveLibraryCopy()
+ m_editor.CurrentConnection.SaveResourceAs(m_appDef, m_editor.ResourceId);
+ private void SaveSessionCopy()
+ m_editor.CurrentConnection.SaveResourceAs(m_appDef, m_appDef.ResourceId);
+ private void DoPreview(string url)
+ try
+ m_editor.OpenUrl(url);
+ catch (Exception ex)
+ m_editor.SetLastException(ex);
+ MessageBox.Show(this, String.Format(Strings.ApplicationDefinitionEditor.BrowserLaunchError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
private void ApplicationDefinitionEditor_Load(object sender, System.EventArgs e)
@@ -1065,11 +1093,19 @@
private void TemplateURL_TextChanged(object sender, System.EventArgs e)
- if (m_editor.Existing)
- browserURL.Text = ((OSGeo.MapGuide.MaestroAPI.HttpServerConnection)m_editor.CurrentConnection).BaseURL + TemplateURL.Text + "?ApplicationDefinition=" + System.Web.HttpUtility.UrlEncode(m_appDef.ResourceId);
- else
- browserURL.Text = "";
+ if (m_editor.Existing)
+ //browserURL.Text = ((OSGeo.MapGuide.MaestroAPI.HttpServerConnection)m_editor.CurrentConnection).BaseURL + TemplateURL.Text + "?ApplicationDefinition=" + System.Web.HttpUtility.UrlEncode(m_appDef.ResourceId);
+ var htcon = (OSGeo.MapGuide.MaestroAPI.HttpServerConnection)m_editor.CurrentConnection;
+ sessionPreviewUrl = htcon.BaseURL + TemplateURL.Text + "?ApplicationDefinition=" + System.Web.HttpUtility.UrlEncode(m_appDef.ResourceId) + "&Session=" + htcon.SessionID;
+ libraryPreviewUrl = htcon.BaseURL + TemplateURL.Text + "?ApplicationDefinition=" + System.Web.HttpUtility.UrlEncode(m_editor.ResourceId);
+ browserURL.Text = libraryPreviewUrl;
+ else
+ browserURL.Text = "";
if (m_isUpdating)
return;
@@ -1160,6 +1196,33 @@
private void ShowInBrowser_Click(object sender, System.EventArgs e)
+ if (m_editor.IsModified)
+ var result = MessageBox.Show(Strings.ApplicationDefinitionEditor.UnsavedLayoutPreview, string.Empty, MessageBoxButtons.YesNoCancel);
+ //Yes = Save changes then preview
+ //No = Preview original (without unsaved changes)
+ //Cancel = Abort Preview
+ if (result == DialogResult.Cancel)
+ return;
+ if (result == DialogResult.Yes)
+ SaveLibraryCopy();
+ //HACK: There is no formal interface to unset the editor's dirty state
+ //Dirty state is simply indicated by the asterisk on the editor's tab
+ //so remove the asterisk.
+ var page = this.Parent as TabPage;
+ if (page != null && page.Text.EndsWith(" *"))
+ page.Text = page.Text.Substring(0, page.Text.Length - 2);
+ m_editor.UpdateResourceStates();
+ DoPreview(libraryPreviewUrl);
try
m_editor.CurrentConnection.SaveResourceAs(m_appDef, m_tempResource);
@@ -1189,7 +1252,7 @@
string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
MessageBox.Show(this, String.Format(Strings.ApplicationDefinitionEditor.BrowserLaunchError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
private void AddMapButton_Click(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.Designer.cs 2010-07-02 02:31:42 UTC (rev 4987)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.Designer.cs 2010-07-02 03:23:12 UTC (rev 4988)
@@ -113,5 +113,14 @@
return ResourceManager.GetString("SeperatorMarker", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The Application Definition has unsaved changes. If you do not save, the original version of the Application Definition will be shown. Save first before viewing?.
+ /// </summary>
+ internal static string UnsavedLayoutPreview {
+ get {
+ return ResourceManager.GetString("UnsavedLayoutPreview", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.resx
--- trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.resx 2010-07-02 02:31:42 UTC (rev 4987)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/Strings/ApplicationDefinitionEditor.resx 2010-07-02 03:23:12 UTC (rev 4988)
@@ -141,4 +141,8 @@
<value>- Seperator -</value>
<comment>The text displayed in the tree when a seperator is inserted</comment>
</data>
+ <data name="UnsavedLayoutPreview" xml:space="preserve">
+ <value>The Application Definition has unsaved changes. If you do not save, the original version of the Application Definition will be shown. Save first before viewing?</value>
+ <comment>en "View in browser" is clicked with unsaved changes</comment>
+ </data>
</root>
\ No newline at end of file
More information about the mapguide-commits
