[mapguide-commits] r4994 - trunk/MgDev/Server/src/Wms
svn_mapguide at osgeo.org
Tue Jul 6 21:46:35 EDT 2010
Author: liuar
Date: 2010-07-07 01:46:35 +0000 (Wed, 07 Jul 2010)
New Revision: 4994
Added:
trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
Ticket http://trac.osgeo.org/mapguide/ticket/1392
1. Update the OgcWmsService.config.awd
(1)Add WMS 1.3.0 as new supported versions.
(2)Define a new item "RS_CRS.xml" as reference system in WMS 1.3.0
(3)Define a new item "Enum.item.CRS", a replacement of "Enum.item.SRS", used in WMS 1.3.0
2. Add a template file 1.3.0.xml.awd for WMS 1.3.0
(1)Update some keywords which are defined in 1.3.0 specification. For example: SRS -> CRS
(2)Define a new item "EX_GeographicBoundingBox", a replacement of "LatLonBoundingBox", defined in WMS 1.3.0 specification. And some relevant items are also updated.
Added: trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
--- trunk/MgDev/Server/src/Wms/1.3.0.xml.awd (rev 0)
+++ trunk/MgDev/Server/src/Wms/1.3.0.xml.awd 2010-07-07 01:46:35 UTC (rev 4994)
@@ -0,0 +1,407 @@
+<?xml version='1.0'?>
+<Template service="WMS" version="1.3.0">
+<Definitions>
+ <!-- This defines the format of each individual layer
+ advertised by GetCapabilities -->
+ <!-- Note: Studio published the following metadata fields -->
+ <!-- Layer.Name - The canonical machine-readable name for a layer -->
+ <!-- Layer.Abstract - Free-form human readable description for the layer -->
+ <!-- Layer.Bounds - Structured XML in the form of one or more of these elements -->
+ <!-- <Bounds CRS= north= south= east= west=/> -->
+ <!-- (Note: Studio currently publishes this as plain text, which -->
+ <!-- the template engine converts to an XML fragment; future work -->
+ <!-- in Studio is expected to remedy this.) -->
+ <!-- (An example is shown below in Layer.BoundingBox.default) -->
+ <!-- Layer.Cascaded - the WMS "cascade" value, indicating whether the data came from -->
+ <!-- another server, or originated on this server -->
+ <!-- Layer.ExtendedMetadata - like Layer.Bounds, should be structured XML, but Studio -->
+ <!-- just writes it out as plain text. Format: zero or more -->
+ <!-- <Link href= type= format= /> elements. Currently not -->
+ <!-- implemented in templates. -->
+ <!-- Layer.Keywords - A comma-separated list of keywords associated with this layer. -->
+ <!-- Layer.Opaque - boolean indicating whether the layer is opaque or transparent. -->
+ <!-- Layer.Queryable - boolean indicating whether the layer supports GetFeatureInfo. -->
+ <!-- Layer.Title - The user-provided human-readable name for the layer. -->
+ <!-- Layer.NoSubsets is currently not emitted by Studio, its value is defaulted within -->
+ <!-- the OwsWmsService.config.awd file. -->
+ <Define item="Layer.xml">
+ <!-- Published Layer #&Layer.iteration; -->
+ <Layer queryable="&Layer.Queryable;" cascaded="&Layer.Cascaded;" noSubsets="&Layer.NoSubsets;" opaque="&Layer.Opaque;">
+ <Name>&Layer.Name;</Name>
+ <Title>&Layer.Title;</Title>
+ <?Ifdef item="Layer.Abstract"?><Abstract>&Layer.Abstract;</Abstract><?Endif?>
+ <?Ifdef item="Layer.Keywords"?>
+ <KeywordList>
+ <?EnumDelim list="&Layer.Keywords;" using="&Service.Keywords.xml;"?>
+ </KeywordList>
+ <?Endif?>
+ <?Ifdef item="Layer.Bounds"?>
+ <?Enum list="&Layer.Bounds;" item="Bounds" using="&CRS.xml;"?>
+ <?Enum list="&Layer.Bounds;" item="Bounds" using="&EX_GeographicBoundingBox.xml;"?>
+ <?Enum list="&Layer.Bounds;" item="Bounds" using="&BoundingBox.xml;"?>
+ <?Else?>
+ <?Enum list="&Layer.BoundingBox.default;" item="Bounds" using="&CRS.xml;"?>
+ <?Enum list="&Layer.BoundingBox.default;" item="Bounds" using="&EX_GeographicBoundingBox.xml;" ?>
+ <?Enum list="&Layer.BoundingBox.default;" item="Bounds" using="&BoundingBox.xml;" ?>
+ <?Endif?>
+ </Layer>
+ </Define>
+ <!-- An example of what can be expected in the Layer.Bounds definition -->
+ <Define item="Layer.BoundingBox.default">
+ <Bounds CRS="EPSG:4326" west="-180" south="-90" east="180" north="90"/>
+ </Define>
+ <!-- This pair of definitions works around a current limitation that -->
+ <!-- <?If...?><?Endif?> cannot be nested. -->
+ <Define item="EX_GeographicBoundingBox.xml">
+ <?Translate text="&Enum.item.CRS;" with="&EX_GeographicBoundingBox.translate.xml;"?>
+ </Define>
+ <Define item="EX_GeographicBoundingBox.translate.xml">
+ <translate from="EPSG:4326" ?>
+ <EX_GeographicBoundingBox>
+ <westBoundLongitude>&Enum.item.west;</westBoundLongitude>
+ <eastBoundLongitude>&Enum.item.east;</eastBoundLongitude>
+ <southBoundLatitude>&Enum.item.south;</southBoundLatitude>
+ <northBoundLatitude>&Enum.item.north;</northBoundLatitude>
+ </EX_GeographicBoundingBox>
+ </translate>
+ <translate></translate>
+</Define>
+ <Define item="BoundingBox.xml">
+ <BoundingBox CRS="&Enum.item.CRS;" minx="&Enum.item.west;" miny="&Enum.item.south;" maxx="&Enum.item.east;" maxy="&Enum.item.north;"/>
+ </Define>
+ <Define item="CRS.xml">
+ <CRS>&Enum.item.CRS;</CRS>
+ </Define>
+ <Define item="FeatureInfo.xml">
+ <?Ifdef item="FeatureInfo.LayerName"?>
+ <FeatureInfo layer="&FeatureInfo.LayerName;">
+ <?Else?>
+ <FeatureInfo>
+ <?Endif?>
+ <?EnumFeatureProperties using="&FeatureProperty.xml;" ?>
+ </FeatureInfo>
+ </Define>
+ <Define item="FeatureInfo.html">
+ <tr>
+ <td>
+ <table>
+ <?EnumFeatureProperties using="&FeatureProperty.html;" ?>
+ </table>
+ </td>
+ </tr>
+ </Define>
+ <Define item="FeatureInfo.text">
+ FeatureInfo:
+ <?EnumFeatureProperties using="&FeatureProperty.text;" ?>
+ </Define>
+ <Define item="FeatureProperty.xml">
+ <Property name="&FeatureProperty.Name;" value="&FeatureProperty.Value;"></Property>
+ </Define>
+ <Define item="FeatureProperty.html">
+ <tr><td class="name">&FeatureProperty.Name;</td><td>&FeatureProperty.Value;</td></tr>
+ </Define>
+ <Define item="FeatureProperty.text">
+ &FeatureProperty.Name;=&FeatureProperty.Value;
+ </Define>
+ <!-- We're currently not supporting child layers... -->
+ <Define item="Layer.Sublayers"></Define>
+ <!-- In this version, keywords are enumerated enclosed in Keyword elements -->
+ <Define item="Service.Keywords.xml"><Keyword>&Enum.item;</Keyword>
+ </Define>
+ <!-- Overrides of default Exception formats
+ specific to this version template -->
+ <Define item="Formats.Exception">
+ <item>XML</item>
+ </Define>
+ <!-- These are the supported (Get)Capabilities formats
+ for version 1.1.1. -->
+ <Define item="Formats.GetCapabilities">
+ <item>text/xml</item>
+ <item>text/html</item>
+ </Define>
+ <Define item="GetCapabilities.xml">
+ <WMS_Capabilities version="&TemplateVersion;"
+ xmlns="http://www.opengis.net/wms"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+ xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd">
+ SERVICE METADATA
+ <Service>
+ <Name>&Service.Name;</Name>
+ <Title>&Service.Title;</Title>
+ <?Ifdef item="Service.Abstract"?>
+ <Abstract>&Service.Abstract;</Abstract>
+ <?Endif?>
+ <?Ifdef item="Service.Keywords"?>
+ <KeywordList>
+ <?Enum list="&Service.Keywords;" using="&Service.Keywords.xml"?>
+ </KeywordList>
+ <?Endif?>
+ <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="&Url.OnlineResource;"></OnlineResource>
+ <ContactInformation>
+ <ContactPersonPrimary>
+ <ContactPerson>&Service.Contact.Name;</ContactPerson>
+ <ContactOrganization>&Service.Contact.Organization;</ContactOrganization>
+ </ContactPersonPrimary>
+ <?Ifdef item="Service.Contact.Position"?>
+ <ContactPosition>&Service.Contact.Position;</ContactPosition>
+ <?Endif?>
+ <?Ifdef item="Service.Contact.Address.Type"?>
+ <ContactAddress>
+ <AddressType>&Service.Contact.Address.Type;</AddressType>
+ <Address>&Service.Contact.Address.Street;</Address>
+ <City>&Service.Contact.Address.City;</City>
+ <StateOrProvince>&Service.Contact.Address.StateProv;</StateOrProvince>
+ <PostCode>&Service.Contact.Address.PostCode;</PostCode>
+ <Country>&Service.Contact.Address.Country;</Country>
+ </ContactAddress>
+ <?Endif?>
+ <?Ifdef item="Service.Contact.Phone"?>
+ <ContactVoiceTelephone>&Service.Contact.Phone;</ContactVoiceTelephone>
+ <?Endif?>
+ <?Ifdef item="Service.Contact.Fax"?>
+ <ContactFacsimileTelephone>&Service.Contact.Fax;</ContactFacsimileTelephone>
+ <?Endif?>
+ <?Ifdef item="Service.Contact.Email"?>
+ <ContactElectronicMailAddress>&Service.Contact.Email;</ContactElectronicMailAddress>
+ <?Endif?>
+ </ContactInformation>
+ <Fees>&Service.Fees;</Fees>
+ <AccessConstraints>&Service.AccessConstraints;</AccessConstraints>
+ </Service>
+ SERVICE CAPABILITIES
+ <Capability>
+ <Request>
+ <GetCapabilities>
+ <?Enum list="&Formats.GetCapabilities;" using="&Format.xml;" ?>
+ <DCPType>
+ <HTTP>
+ <Get>
+ <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="&Url.GetCapabilities;?"/>
+ </Get>
+ </HTTP>
+ </DCPType>
+ </GetCapabilities>
+ <GetMap>
+ <?Enum list="&Formats.GetMap;" using="&Format.xml;" ?>
+ <DCPType>
+ <HTTP>
+ <Get>
+ <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="&Url.GetMap;?"/>
+ </Get>
+ </HTTP>
+ </DCPType>
+ </GetMap>
+ <GetFeatureInfo>
+ <?Enum list="&Formats.GetFeatureInfo;" using="&Format.xml;" ?>
+ <DCPType>
+ <HTTP>
+ <Get>
+ <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="&Url.GetFeatureInfo;?"/>
+ </Get>
+ </HTTP>
+ </DCPType>
+ </GetFeatureInfo>
+ </Request>
+ <Exception>
+ <?Enum list="&Formats.Exception;" using="&Format.xml;" ?>
+ </Exception>
+ <!-- No VendorSpecificCapabilities -->
+ <!-- No UserDefinedSymbolization -->
+ PUBLISHED LAYERS
+ <Layer>
+ <?Enum list="&ReferenceSystems;" using="&RS_CRS.xml;"?>
+ <westBoundLongitude>-180</westBoundLongitude>
+ <eastBoundLongitude>180</eastBoundLongitude>
+ <southBoundLatitude>-90</southBoundLatitude>
+ <northBoundLatitude>90</northBoundLatitude>
+ <?EnumLayers using="&Layer.xml;" ?>
+ </Layer>
+ </Capability>
+ </WMS_Capabilities>
+ </Define>
+</Definitions>
+ WMS GetCapabilities - XML as text/xml
+<Response request="GetCapabilities" content-type="text/xml">
+&GetCapabilities.xml;
+</Response>
+ WMS GetCapabilities - XML as application/vnd.ogc.wms_xml
+<Response request="GetCapabilities" content-type="application/vnd.ogc.wms_xml">
+</Response>
+ WMS GetCapabilities - HTML
+<Response request="GetCapabilities" content-type="text/html">
+<html>
+ <head>
+ <title>GetCapabilities Response for &Service.Title;</title>
+ &html.stylesheet;
+ </head>
+ <body>
+ <table border="1">
+ <tr><td class="title" colspan="2">Service Metadata - version &TemplateVersion;</td></tr>
+ <tr><td class="name">Name</td><td>&Service.Name;</td></tr>
+ <tr><td class="name">Title</td><td>&Service.Title;</td></tr>
+ <tr><td class="name">Abstract</td><td>&Service.Abstract;</td></tr>
+ <?Endif?>
+ <tr><td class="name">Keywords</td><td>
+ <?Enum list="&Service.Keywords;" using="&Format.html;"?>
+ </td></tr>
+ <?Endif?>
+ <tr><td class="name">Online Resource</td><td>&Url.OnlineResource;</td></tr>
+ <tr><td class="name">Contact Information</td><td>
+ &Service.Contact.Name;<br/>
+ &Service.Contact.Organization<br/>
+ <?Ifdef item="Service.Contact.Position"?>&Service.Contact.Position;<br/><?Endif?>
+ &Service.Contact.Address.Street;<br/>
+ &Service.Contact.Address.City;, &Service.Contact.Address.StateProv;<br/>
+ &Service.Contact.Address.PostCode;<br/>
+ &Service.Contact.Address.Country;
+ <?Ifdef item="Service.Contact.Phone"?>Phone: &Service.Contact.Phone;<br/><?Endif?>
+ <?Ifdef item="Service.Contact.Fax"?>Fax: &Service.Contact.Fax;<br/><?Endif?>
+ <?Ifdef item="Service.Contact.Email"?>Email: &Service.Contact.Email;<br/><?Endif?>
+ </tr></td>
+ <?Endif?>
+ <tr><td class="name">Fees</td><td>&Service.Fees;</td></tr>
+ <tr><td class="name">Access Constraints</td><td>&Service.AccessConstraints;</td></tr>
+ <tr><td class="title" colspan="2">Capbilities</td></tr>
+ <tr><td class="name">GetCapabilities</td><td>
+ URL: &Url.GetCapabilities;<br/>
+ Formats:
+ <?Enum list="&Formats.GetCapability;" using="&Format.html;"?>
+ </td></tr>
+ <tr><td class="name">GetMap</td><td>
+ URL: &Url.GetMap;<br/>
+ Formats:
+ <?Enum list="&Formats.GetMap;" using="&Format.html;"?>
+ </td></tr>
+ <tr><td class="name">GetFeatureInfo</td><td>
+ URL: &Url.GetFeatureInfo;<br/>
+ Formats:
+ <?Enum list="&Formats.GetFeatureInfo;" using="&Format.html;"?>
+ </td></tr>
+ <tr><td class="title" colspan="2">Published Layers</td></tr>
+ <?EnumLayers using="&EnumLayer.html;"?>
+ </table>
+ </body>
+</html>
+</Response>
+ WMS GetFeatureInfo - XML
+<Response request="GetFeatureInfo" content-type="text/xml">
+ <FeatureInfoCollection>
+ <?EnumFeatureInfo using="&FeatureInfo.xml;" ?>
+ </FeatureInfoCollection>
+</Response>
+ WMS GetFeatureInfo - HTML
+<Response request="GetFeatureInfo" content-type="text/html">
+<html>
+<head>
+<title>GetFeatureInfo</title>
+</head>
+<body>
+<table border="1">
+ <?EnumFeatureInfo using="&FeatureInfo.html;" ?>
+</table>
+</body>
+</html>
+</Response>
+ WMS GetFeatureInfo - TEXT
+<Response request="GetFeatureInfo" content-type="text/plain">
+ <?EnumFeatureInfo using="&FeatureInfo.text;" ?>
+</Response>
+ Exception format - XML
+<Response request="Exception" content-type="text/xml">
+<ServiceExceptionReport version="&TemplateVersion;">
+ <ServiceException code="&Exception.Type;">
+ &Exception.message;
+ </ServiceException>
+</ServiceExceptionReport>
+</Response>
+</Template>
Modified: trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
--- trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-07-06 07:43:04 UTC (rev 4993)
+++ trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-07-07 01:46:35 UTC (rev 4994)
@@ -11,7 +11,7 @@
<Version number="1.0.0"/>
<Version number="1.1.0"/>
<Version number="1.1.1"/>
- <!--Version number="1.3.0"/-->
+ <Version number="1.3.0"/>
</Define>
<!-- These are edited by the Site Administration tool, though you
@@ -115,7 +115,8 @@
<!-- This is the default definition for a reference system (SRS, or CRS) -->
<Define item="RS.xml"><SRS>&Enum.item;</SRS></Define>
+ <Define item="RS_CRS.xml"><CRS>&Enum.item;</CRS></Define>
<!-- You can control the formats supported by various
WMS responses by (a) modifying these lists and
(b) adding (if necessary) the appropriate
@@ -222,6 +223,7 @@
types in a badly-formed <Bounds /> element that isn't EPSG:4326
then the whole enchilada is serious GIGO. -->
<Define item="Enum.item.SRS">EPSG:4326</Define>
+ <Define item="Enum.item.CRS">EPSG:4326</Define>
<Define item="Enum.item.north">90</Define>
<Define item="Enum.item.south">-90</Define>
<Define item="Enum.item.west">-180</Define>
More information about the mapguide-commits
