[mapguide-commits] r5002 - in sandbox/maestro-3.0: Generated
Maestro.Base Maestro.Editors Maestro.Editors/MapDefinition
Maestro.Editors/Properties Maestro.Editors/Resources
OSGeo.MapGuide.MaestroAPI/Feature
OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Wed Jul 7 09:10:28 EDT 2010
Author: jng
Date: 2010-07-07 13:10:28 +0000 (Wed, 07 Jul 2010)
New Revision: 5002
Added:
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Resources/folder--minus.png
sandbox/maestro-3.0/Maestro.Editors/Resources/folder--plus.png
sandbox/maestro-3.0/Maestro.Editors/Resources/layer--minus.png
sandbox/maestro-3.0/Maestro.Editors/Resources/layer--plus.png
sandbox/maestro-3.0/Maestro.Editors/Resources/layer.png
sandbox/maestro-3.0/Maestro.Editors/Resources/layers-stack-arrange-back.png
sandbox/maestro-3.0/Maestro.Editors/Resources/layers-stack-arrange.png
sandbox/maestro-3.0/Generated/ApplicationDefinition-1.0.0.designer.cs
sandbox/maestro-3.0/Generated/LayerDefinition-1.0.0.designer.cs
sandbox/maestro-3.0/Generated/LoadProcedure-1.0.0.designer.cs
sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs
sandbox/maestro-3.0/Generated/SelectAggregate-1.0.0.designer.cs
sandbox/maestro-3.0/Generated/SymbolDefinition-1.0.0.designer.cs
sandbox/maestro-3.0/Generated/WebLayout-1.0.0.designer.cs
sandbox/maestro-3.0/Maestro.Base/Workbench.cs
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
This submission includes the following changes:
- Implement GetSpatialExtent() for LayerDefinition
- Fix BackgroundColor property in MapDefinition
- More work on the MapDefinition editor
- Map properties section is now entirely data-bound.
- Can now modify properties of layers and groups (and trigger dirty state change)
- Fix a boatload of warnings related to redundant generated INotifyPropertyChanged code.
Modified: sandbox/maestro-3.0/Generated/ApplicationDefinition-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/ApplicationDefinition-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Generated/ApplicationDefinition-1.0.0.designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -1410,14 +1410,14 @@
- public event System.ComponentModel.PropertyChangedEventHandler PropertyChanged;
+ //public event System.ComponentModel.PropertyChangedEventHandler PropertyChanged;
- public virtual void OnPropertyChanged(string info) {
- System.ComponentModel.PropertyChangedEventHandler handler = this.PropertyChanged;
- if ((handler != null)) {
- handler(this, new System.ComponentModel.PropertyChangedEventArgs(info));
+ //public virtual void OnPropertyChanged(string info) {
+ // System.ComponentModel.PropertyChangedEventHandler handler = this.PropertyChanged;
+ // if ((handler != null)) {
+ // handler(this, new System.ComponentModel.PropertyChangedEventArgs(info));
#region Serialize/Deserialize
/// <summary>
@@ -1612,14 +1612,14 @@
/// <summary>
@@ -2027,14 +2027,14 @@
/// <summary>
@@ -2208,14 +2208,14 @@
/// <summary>
@@ -2495,14 +2495,14 @@
/// <summary>
Modified: sandbox/maestro-3.0/Generated/LayerDefinition-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/LayerDefinition-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Generated/LayerDefinition-1.0.0.designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -58,14 +58,14 @@
/// <summary>
@@ -558,14 +558,14 @@
/// <summary>
@@ -2654,14 +2654,14 @@
/// <summary>
@@ -3551,14 +3551,14 @@
/// <summary>
@@ -3837,14 +3837,14 @@
/// <summary>
@@ -4418,14 +4418,14 @@
/// <summary>
@@ -4643,14 +4643,14 @@
/// <summary>
@@ -5125,14 +5125,14 @@
/// <summary>
@@ -6955,14 +6955,14 @@
/// <summary>
@@ -9960,14 +9960,14 @@
/// <summary>
@@ -10326,14 +10326,14 @@
/// <summary>
Modified: sandbox/maestro-3.0/Generated/LoadProcedure-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/LoadProcedure-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Generated/LoadProcedure-1.0.0.designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -36,14 +36,14 @@
/// <summary>
@@ -424,14 +424,14 @@
/// <summary>
@@ -2033,14 +2033,14 @@
/// <summary>
@@ -2298,14 +2298,14 @@
/// <summary>
@@ -2523,14 +2523,14 @@
/// <summary>
@@ -2734,14 +2734,14 @@
/// <summary>
Modified: sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -12,6 +12,8 @@
using System.Xml.Schema;
using System.ComponentModel;
using System.IO;
+ using OSGeo.MapGuide.MaestroAPI;
+ using System.Drawing;
/// <summary>
@@ -216,7 +218,7 @@
private Box2DType extentsField;
[EditorBrowsable(EditorBrowsableState.Never)]
- private byte[] backgroundColorField;
+ private Color backgroundColorField;
private string metadataField;
@@ -286,20 +288,21 @@
- [System.Xml.Serialization.XmlElementAttribute(DataType="hexBinary")]
- public byte[] BackgroundColor {
+ [System.Xml.Serialization.XmlElementAttribute("BackgroundColor")]
+ public string BackgroundColorAsHtml {
get {
- return this.backgroundColorField;
+ return Utility.SerializeHTMLColor(this.backgroundColorField, true);
set {
+ var c = Utility.ParseHTMLColor(value);
if ((this.backgroundColorField != null)) {
- if ((backgroundColorField.Equals(value) != true)) {
- this.backgroundColorField = value;
+ if ((backgroundColorField.Equals(c) != true)) {
+ this.backgroundColorField = c;
this.OnPropertyChanged("BackgroundColor");
else {
@@ -1102,14 +1105,14 @@
/// <summary>
@@ -1609,14 +1612,14 @@
/// <summary>
@@ -1811,14 +1814,14 @@
/// <summary>
Modified: sandbox/maestro-3.0/Generated/SelectAggregate-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/SelectAggregate-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Generated/SelectAggregate-1.0.0.designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -277,14 +277,14 @@
/// <summary>
@@ -1508,14 +1508,14 @@
/// <summary>
Modified: sandbox/maestro-3.0/Generated/SymbolDefinition-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/SymbolDefinition-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Generated/SymbolDefinition-1.0.0.designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -59,14 +59,14 @@
/// <summary>
@@ -411,14 +411,14 @@
/// <summary>
@@ -775,14 +775,14 @@
/// <summary>
@@ -3340,14 +3340,14 @@
/// <summary>
@@ -4139,14 +4139,14 @@
/// <summary>
@@ -5529,14 +5529,14 @@
/// <summary>
@@ -5737,14 +5737,14 @@
/// <summary>
Modified: sandbox/maestro-3.0/Generated/WebLayout-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/WebLayout-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Generated/WebLayout-1.0.0.designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -460,14 +460,14 @@
/// <summary>
@@ -1673,14 +1673,14 @@
/// <summary>
@@ -1875,14 +1875,14 @@
/// <summary>
@@ -2078,14 +2078,14 @@
/// <summary>
@@ -2506,14 +2506,14 @@
/// <summary>
@@ -2722,14 +2722,14 @@
/// <summary>
@@ -2903,14 +2903,14 @@
/// <summary>
@@ -3084,14 +3084,14 @@
/// <summary>
@@ -3265,14 +3265,14 @@
/// <summary>
@@ -4176,14 +4176,14 @@
/// <summary>
@@ -4372,14 +4372,14 @@
/// <summary>
@@ -4855,14 +4855,14 @@
/// <summary>
@@ -5036,14 +5036,14 @@
/// <summary>
@@ -5344,14 +5344,14 @@
/// <summary>
@@ -6015,14 +6015,14 @@
/// <summary>
@@ -6196,14 +6196,14 @@
/// <summary>
@@ -6399,14 +6399,14 @@
/// <summary>
@@ -6602,14 +6602,14 @@
/// <summary>
@@ -6889,14 +6889,14 @@
/// <summary>
@@ -7087,14 +7087,14 @@
/// <summary>
@@ -7310,14 +7310,14 @@
/// <summary>
@@ -7521,14 +7521,14 @@
/// <summary>
Modified: sandbox/maestro-3.0/Maestro.Base/Workbench.cs
--- sandbox/maestro-3.0/Maestro.Base/Workbench.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Base/Workbench.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -331,7 +331,6 @@
break;
case ViewRegion.Floating:
throw new NotImplementedException();
- break;
case ViewRegion.Dialog:
break;
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-07-07 13:10:28 UTC (rev 5002)
@@ -3,7 +3,7 @@
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
- <ProductVersion>9.0.30729</ProductVersion>
+ <ProductVersion>9.0.21022</ProductVersion>
<SchemaVersion>2.0</SchemaVersion>
<ProjectGuid>{5AD2CDBA-952E-4148-98A1-31D2E0D540D5}</ProjectGuid>
<OutputType>Library</OutputType>
@@ -324,6 +324,18 @@
<Compile Include="LoadProcedure\ShpTransformationCtrl.Designer.cs">
<DependentUpon>ShpTransformationCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="MapDefinition\GroupPropertiesCtrl.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="MapDefinition\GroupPropertiesCtrl.Designer.cs">
+ <DependentUpon>GroupPropertiesCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="MapDefinition\LayerPropertiesCtrl.cs">
+ </Compile>
+ <Compile Include="MapDefinition\LayerPropertiesCtrl.Designer.cs">
+ <DependentUpon>LayerPropertiesCtrl.cs</DependentUpon>
+ </Compile>
<Compile Include="MapDefinition\MapDefinitionEditorCtrl.cs">
</Compile>
@@ -593,6 +605,14 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="MapDefinition\GroupPropertiesCtrl.resx">
+ <SubType>Designer</SubType>
+ </EmbeddedResource>
+ <EmbeddedResource Include="MapDefinition\LayerPropertiesCtrl.resx">
<EmbeddedResource Include="MapDefinition\MapDefinitionEditorCtrl.resx">
<DependentUpon>MapDefinitionEditorCtrl.cs</DependentUpon>
@@ -808,6 +828,27 @@
<None Include="Resources\server.png" />
</ItemGroup>
<ItemGroup>
+ <None Include="Resources\folder--minus.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\folder--plus.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\layer--minus.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\layer--plus.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\layers-stack-arrange.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\layers-stack-arrange-back.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\layer.png" />
+ </ItemGroup>
+ <ItemGroup>
<Folder Include="DrawingSource\Preview\" />
<Folder Include="FeatureSource\Providers\Rdbms\" />
<Folder Include="LayerDefinition\Geometry\" />
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -0,0 +1,168 @@
+namespace Maestro.Editors.MapDefinition
+ partial class GroupPropertiesCtrl
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.chkSelectable = new System.Windows.Forms.CheckBox();
+ this.chkExpanded = new System.Windows.Forms.CheckBox();
+ this.chkLegendVisible = new System.Windows.Forms.CheckBox();
+ this.chkVisible = new System.Windows.Forms.CheckBox();
+ this.txtLegendLabel = new System.Windows.Forms.TextBox();
+ this.txtName = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.label1 = new System.Windows.Forms.Label();
+ this.groupBox1.SuspendLayout();
+ this.SuspendLayout();
+ // groupBox1
+ this.groupBox1.Controls.Add(this.chkSelectable);
+ this.groupBox1.Controls.Add(this.chkExpanded);
+ this.groupBox1.Controls.Add(this.chkLegendVisible);
+ this.groupBox1.Controls.Add(this.chkVisible);
+ this.groupBox1.Controls.Add(this.txtLegendLabel);
+ this.groupBox1.Controls.Add(this.txtName);
+ this.groupBox1.Controls.Add(this.label2);
+ this.groupBox1.Controls.Add(this.label1);
+ this.groupBox1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.groupBox1.Location = new System.Drawing.Point(0, 0);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(400, 187);
+ this.groupBox1.TabIndex = 0;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Layer Group Properties";
+ // chkSelectable
+ this.chkSelectable.AutoSize = true;
+ this.chkSelectable.Location = new System.Drawing.Point(18, 103);
+ this.chkSelectable.Name = "chkSelectable";
+ this.chkSelectable.Size = new System.Drawing.Size(240, 17);
+ this.chkSelectable.TabIndex = 15;
+ this.chkSelectable.Text = "Features on the layer are selectable (if visible)";
+ this.chkSelectable.UseVisualStyleBackColor = true;
+ this.chkSelectable.CheckedChanged += new System.EventHandler(this.ForceUpdate);
+ // chkExpanded
+ this.chkExpanded.AutoSize = true;
+ this.chkExpanded.Location = new System.Drawing.Point(18, 150);
+ this.chkExpanded.Name = "chkExpanded";
+ this.chkExpanded.Size = new System.Drawing.Size(228, 17);
+ this.chkExpanded.TabIndex = 14;
+ this.chkExpanded.Text = "Layer is expanded in the legend (if themed)";
+ this.chkExpanded.UseVisualStyleBackColor = true;
+ this.chkExpanded.CheckedChanged += new System.EventHandler(this.ForceUpdate);
+ // chkLegendVisible
+ this.chkLegendVisible.AutoSize = true;
+ this.chkLegendVisible.Location = new System.Drawing.Point(18, 126);
+ this.chkLegendVisible.Name = "chkLegendVisible";
+ this.chkLegendVisible.Size = new System.Drawing.Size(183, 17);
+ this.chkLegendVisible.TabIndex = 13;
+ this.chkLegendVisible.Text = "Layer is shown in the map legend";
+ this.chkLegendVisible.UseVisualStyleBackColor = true;
+ this.chkLegendVisible.CheckedChanged += new System.EventHandler(this.ForceUpdate);
+ // chkVisible
+ this.chkVisible.AutoSize = true;
+ this.chkVisible.Location = new System.Drawing.Point(18, 80);
+ this.chkVisible.Name = "chkVisible";
+ this.chkVisible.Size = new System.Drawing.Size(141, 17);
+ this.chkVisible.TabIndex = 12;
+ this.chkVisible.Text = "Layer is visible at startup";
+ this.chkVisible.UseVisualStyleBackColor = true;
+ this.chkVisible.CheckedChanged += new System.EventHandler(this.ForceUpdate);
+ // txtLegendLabel
+ this.txtLegendLabel.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtLegendLabel.Location = new System.Drawing.Point(107, 45);
+ this.txtLegendLabel.Name = "txtLegendLabel";
+ this.txtLegendLabel.Size = new System.Drawing.Size(277, 20);
+ this.txtLegendLabel.TabIndex = 11;
+ this.txtLegendLabel.TextChanged += new System.EventHandler(this.ForceUpdate);
+ // txtName
+ this.txtName.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtName.Location = new System.Drawing.Point(107, 19);
+ this.txtName.Name = "txtName";
+ this.txtName.Size = new System.Drawing.Size(277, 20);
+ this.txtName.TabIndex = 10;
+ this.txtName.TextChanged += new System.EventHandler(this.ForceUpdate);
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(15, 48);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(72, 13);
+ this.label2.TabIndex = 9;
+ this.label2.Text = "Legend Label";
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(15, 22);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(35, 13);
+ this.label1.TabIndex = 8;
+ this.label1.Text = "Name";
+ // GroupPropertiesCtrl
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.groupBox1);
+ this.Name = "GroupPropertiesCtrl";
+ this.Size = new System.Drawing.Size(400, 187);
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.CheckBox chkSelectable;
+ private System.Windows.Forms.CheckBox chkExpanded;
+ private System.Windows.Forms.CheckBox chkLegendVisible;
+ private System.Windows.Forms.CheckBox chkVisible;
+ private System.Windows.Forms.TextBox txtLegendLabel;
+ private System.Windows.Forms.TextBox txtName;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.Label label1;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -0,0 +1,46 @@
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
+ public partial class GroupPropertiesCtrl : UserControl
+ private GroupPropertiesCtrl()
+ InitializeComponent();
+ public event EventHandler GroupChanged;
+ public GroupPropertiesCtrl(MapLayerGroupType group)
+ : this()
+ group.PropertyChanged += new PropertyChangedEventHandler(OnGroupChanged);
+ txtName.DataBindings.Add("Text", group, "Name");
+ txtLegendLabel.DataBindings.Add("Text", group, "LegendLabel");
+ chkExpanded.DataBindings.Add("Checked", group, "ExpandInLegend");
+ chkLegendVisible.DataBindings.Add("Checked", group, "ShowInLegend");
+ chkVisible.DataBindings.Add("Checked", group, "Visible");
+ void OnGroupChanged(object sender, PropertyChangedEventArgs e)
+ var handler = this.GroupChanged;
+ if (handler != null)
+ handler(this, EventArgs.Empty);
+ void ForceUpdate(object sender, EventArgs e)
+ ((Control)sender).DataBindings[0].WriteValue();
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx 2010-07-07 13:10:28 UTC (rev 5002)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -0,0 +1,168 @@
+ partial class LayerPropertiesCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ // groupBox1
+ this.groupBox1.Size = new System.Drawing.Size(417, 188);
+ this.groupBox1.Text = "Layer Properties";
+ // chkSelectable
+ this.chkSelectable.Location = new System.Drawing.Point(21, 106);
+ this.chkSelectable.TabIndex = 7;
+ // chkExpanded
+ this.chkExpanded.Location = new System.Drawing.Point(21, 153);
+ this.chkExpanded.TabIndex = 6;
+ this.chkLegendVisible.Location = new System.Drawing.Point(21, 129);
+ this.chkLegendVisible.TabIndex = 5;
+ // chkVisible
+ this.chkVisible.Location = new System.Drawing.Point(21, 83);
+ this.chkVisible.TabIndex = 4;
+ // txtLegendLabel
+ this.txtLegendLabel.Location = new System.Drawing.Point(110, 48);
+ this.txtLegendLabel.Size = new System.Drawing.Size(285, 20);
+ this.txtLegendLabel.TabIndex = 3;
+ // txtName
+ this.txtName.Location = new System.Drawing.Point(110, 22);
+ this.txtName.Size = new System.Drawing.Size(285, 20);
+ this.txtName.TabIndex = 2;
+ // label2
+ this.label2.Location = new System.Drawing.Point(18, 51);
+ this.label2.TabIndex = 1;
+ // label1
+ this.label1.Location = new System.Drawing.Point(18, 25);
+ this.label1.TabIndex = 0;
+ // LayerPropertiesCtrl
+ this.Name = "LayerPropertiesCtrl";
+ this.Size = new System.Drawing.Size(417, 188);
+ #endregion
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -0,0 +1,45 @@
+using System;
+using System.Data;
+using System.Text;
+ public partial class LayerPropertiesCtrl : UserControl
+ private LayerPropertiesCtrl()
+ public event EventHandler LayerChanged;
+ public LayerPropertiesCtrl(MapLayerType layer) : this()
+ layer.PropertyChanged += new PropertyChangedEventHandler(OnLayerChanged);
+ txtName.DataBindings.Add("Text", layer, "Name");
+ txtLegendLabel.DataBindings.Add("Text", layer, "LegendLabel");
+ chkExpanded.DataBindings.Add("Checked", layer, "ExpandInLegend");
+ chkLegendVisible.DataBindings.Add("Checked", layer, "ShowInLegend");
+ chkVisible.DataBindings.Add("Checked", layer, "Visible");
+ chkSelectable.DataBindings.Add("Checked", layer, "Selectable");
+ void OnLayerChanged(object sender, PropertyChangedEventArgs e)
+ var handler = this.LayerChanged;
Added: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.resx 2010-07-07 13:10:28 UTC (rev 5002)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -28,23 +28,47 @@
/// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MapLayersSectionCtrl));
this.tabControl1 = new System.Windows.Forms.TabControl();
this.TAB_GROUP = new System.Windows.Forms.TabPage();
+ this.trvLayersGroup = new Aga.Controls.Tree.TreeViewAdv();
+ this.NODE_GROUP_ICON = new Aga.Controls.Tree.NodeControls.NodeIcon();
+ this.NODE_GROUP_TEXT = new Aga.Controls.Tree.NodeControls.NodeTextBox();
this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.toolStripButton1 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton2 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripButton3 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton4 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripButton5 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton6 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator3 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripButton7 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton8 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripButton21 = new System.Windows.Forms.ToolStripButton();
this.TAB_DRAWING_ORDER = new System.Windows.Forms.TabPage();
- this.TAB_BASE_LAYERS = new System.Windows.Forms.TabPage();
- this.trvLayersGroup = new Aga.Controls.Tree.TreeViewAdv();
+ this.trvLayerDrawingOrder = new Aga.Controls.Tree.TreeViewAdv();
+ this.NODE_DRAW_ICON = new Aga.Controls.Tree.NodeControls.NodeIcon();
+ this.NODE_DRAW_TEXT = new Aga.Controls.Tree.NodeControls.NodeTextBox();
this.toolStrip2 = new System.Windows.Forms.ToolStrip();
- this.trvLayerDrawingOrder = new Aga.Controls.Tree.TreeViewAdv();
- this.toolStrip3 = new System.Windows.Forms.ToolStrip();
- this.trvBaseLayers = new Aga.Controls.Tree.TreeViewAdv();
+ this.toolStripButton9 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton10 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator5 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripButton11 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton12 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator6 = new System.Windows.Forms.ToolStripSeparator();
+ this.toolStripButton13 = new System.Windows.Forms.ToolStripButton();
+ this.toolStripButton14 = new System.Windows.Forms.ToolStripButton();
this.splitter1 = new System.Windows.Forms.Splitter();
this.propertiesPanel = new System.Windows.Forms.Panel();
this.contentPanel.SuspendLayout();
this.tabControl1.SuspendLayout();
this.TAB_GROUP.SuspendLayout();
+ this.toolStrip1.SuspendLayout();
this.TAB_DRAWING_ORDER.SuspendLayout();
- this.TAB_BASE_LAYERS.SuspendLayout();
+ this.toolStrip2.SuspendLayout();
// contentPanel
@@ -58,7 +82,6 @@
this.tabControl1.Controls.Add(this.TAB_GROUP);
this.tabControl1.Controls.Add(this.TAB_DRAWING_ORDER);
- this.tabControl1.Controls.Add(this.TAB_BASE_LAYERS);
this.tabControl1.Dock = System.Windows.Forms.DockStyle.Left;
this.tabControl1.Location = new System.Drawing.Point(0, 0);
this.tabControl1.Name = "tabControl1";
@@ -73,19 +96,168 @@
this.TAB_GROUP.Location = new System.Drawing.Point(4, 22);
this.TAB_GROUP.Name = "TAB_GROUP";
this.TAB_GROUP.Padding = new System.Windows.Forms.Padding(3);
- this.TAB_GROUP.Size = new System.Drawing.Size(324, 257);
+ this.TAB_GROUP.Size = new System.Drawing.Size(318, 266);
this.TAB_GROUP.TabIndex = 0;
this.TAB_GROUP.Text = "Layers by Group";
this.TAB_GROUP.UseVisualStyleBackColor = true;
+ // trvLayersGroup
+ this.trvLayersGroup.BackColor = System.Drawing.SystemColors.Window;
+ this.trvLayersGroup.BorderStyle = System.Windows.Forms.BorderStyle.None;
+ this.trvLayersGroup.DefaultToolTipProvider = null;
+ this.trvLayersGroup.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.trvLayersGroup.DragDropMarkColor = System.Drawing.Color.Black;
+ this.trvLayersGroup.LineColor = System.Drawing.SystemColors.ControlDark;
+ this.trvLayersGroup.Location = new System.Drawing.Point(3, 28);
+ this.trvLayersGroup.Model = null;
+ this.trvLayersGroup.Name = "trvLayersGroup";
+ this.trvLayersGroup.NodeControls.Add(this.NODE_GROUP_ICON);
+ this.trvLayersGroup.NodeControls.Add(this.NODE_GROUP_TEXT);
+ this.trvLayersGroup.SelectedNode = null;
+ this.trvLayersGroup.Size = new System.Drawing.Size(312, 235);
+ this.trvLayersGroup.TabIndex = 1;
+ this.trvLayersGroup.Text = "treeViewAdv1";
+ this.trvLayersGroup.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseDoubleClick);
+ this.trvLayersGroup.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseClick);
+ // NODE_GROUP_ICON
+ this.NODE_GROUP_ICON.DataPropertyName = "Icon";
+ this.NODE_GROUP_ICON.LeftMargin = 1;
+ this.NODE_GROUP_ICON.ParentColumn = null;
+ this.NODE_GROUP_ICON.ScaleMode = Aga.Controls.Tree.ImageScaleMode.Clip;
+ // NODE_GROUP_TEXT
+ this.NODE_GROUP_TEXT.DataPropertyName = "Text";
+ this.NODE_GROUP_TEXT.IncrementalSearchEnabled = true;
+ this.NODE_GROUP_TEXT.LeftMargin = 3;
+ this.NODE_GROUP_TEXT.ParentColumn = null;
// toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.toolStripButton1,
+ this.toolStripButton2,
+ this.toolStripSeparator1,
+ this.toolStripButton3,
+ this.toolStripButton4,
+ this.toolStripSeparator2,
+ this.toolStripButton5,
+ this.toolStripButton6,
+ this.toolStripSeparator3,
+ this.toolStripButton7,
+ this.toolStripButton8,
+ this.toolStripSeparator4,
+ this.toolStripButton21});
this.toolStrip1.Location = new System.Drawing.Point(3, 3);
this.toolStrip1.Name = "toolStrip1";
- this.toolStrip1.Size = new System.Drawing.Size(318, 25);
+ this.toolStrip1.Size = new System.Drawing.Size(312, 25);
this.toolStrip1.TabIndex = 0;
this.toolStrip1.Text = "toolStrip1";
+ // toolStripButton1
+ this.toolStripButton1.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton1.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
+ this.toolStripButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton1.Name = "toolStripButton1";
+ this.toolStripButton1.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton1.Text = "toolStripButton1";
+ // toolStripButton2
+ this.toolStripButton2.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton2.Image = global::Maestro.Editors.Properties.Resources.folder__minus;
+ this.toolStripButton2.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton2.Name = "toolStripButton2";
+ this.toolStripButton2.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton2.Text = "toolStripButton2";
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ this.toolStripSeparator1.Size = new System.Drawing.Size(6, 25);
+ // toolStripButton3
+ this.toolStripButton3.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton3.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.toolStripButton3.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton3.Name = "toolStripButton3";
+ this.toolStripButton3.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton3.Text = "toolStripButton3";
+ // toolStripButton4
+ this.toolStripButton4.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton4.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
+ this.toolStripButton4.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton4.Name = "toolStripButton4";
+ this.toolStripButton4.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton4.Text = "toolStripButton4";
+ // toolStripSeparator2
+ this.toolStripSeparator2.Name = "toolStripSeparator2";
+ this.toolStripSeparator2.Size = new System.Drawing.Size(6, 25);
+ // toolStripButton5
+ this.toolStripButton5.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton5.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
+ this.toolStripButton5.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton5.Name = "toolStripButton5";
+ this.toolStripButton5.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton5.Text = "toolStripButton5";
+ // toolStripButton6
+ this.toolStripButton6.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton6.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
+ this.toolStripButton6.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton6.Name = "toolStripButton6";
+ this.toolStripButton6.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton6.Text = "toolStripButton6";
+ // toolStripSeparator3
+ this.toolStripSeparator3.Name = "toolStripSeparator3";
+ this.toolStripSeparator3.Size = new System.Drawing.Size(6, 25);
+ // toolStripButton7
+ this.toolStripButton7.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton7.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange;
+ this.toolStripButton7.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton7.Name = "toolStripButton7";
+ this.toolStripButton7.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton7.Text = "toolStripButton7";
+ // toolStripButton8
+ this.toolStripButton8.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton8.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange_back;
+ this.toolStripButton8.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton8.Name = "toolStripButton8";
+ this.toolStripButton8.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton8.Text = "toolStripButton8";
+ // toolStripSeparator4
+ this.toolStripSeparator4.Name = "toolStripSeparator4";
+ this.toolStripSeparator4.Size = new System.Drawing.Size(6, 25);
+ // toolStripButton21
+ this.toolStripButton21.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton21.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton21.Image")));
+ this.toolStripButton21.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton21.Name = "toolStripButton21";
+ this.toolStripButton21.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton21.Text = "toolStripButton21";
// TAB_DRAWING_ORDER
this.TAB_DRAWING_ORDER.Controls.Add(this.trvLayerDrawingOrder);
@@ -93,46 +265,11 @@
this.TAB_DRAWING_ORDER.Location = new System.Drawing.Point(4, 22);
this.TAB_DRAWING_ORDER.Name = "TAB_DRAWING_ORDER";
this.TAB_DRAWING_ORDER.Padding = new System.Windows.Forms.Padding(3);
- this.TAB_DRAWING_ORDER.Size = new System.Drawing.Size(324, 257);
+ this.TAB_DRAWING_ORDER.Size = new System.Drawing.Size(318, 266);
this.TAB_DRAWING_ORDER.TabIndex = 1;
this.TAB_DRAWING_ORDER.Text = "Layers by Drawing Order";
this.TAB_DRAWING_ORDER.UseVisualStyleBackColor = true;
- // TAB_BASE_LAYERS
- this.TAB_BASE_LAYERS.Controls.Add(this.trvBaseLayers);
- this.TAB_BASE_LAYERS.Controls.Add(this.toolStrip3);
- this.TAB_BASE_LAYERS.Location = new System.Drawing.Point(4, 22);
- this.TAB_BASE_LAYERS.Name = "TAB_BASE_LAYERS";
- this.TAB_BASE_LAYERS.Size = new System.Drawing.Size(318, 266);
- this.TAB_BASE_LAYERS.TabIndex = 2;
- this.TAB_BASE_LAYERS.Text = "Base Layer Groups";
- this.TAB_BASE_LAYERS.UseVisualStyleBackColor = true;
- // trvLayersGroup
- this.trvLayersGroup.BackColor = System.Drawing.SystemColors.Window;
- this.trvLayersGroup.BorderStyle = System.Windows.Forms.BorderStyle.None;
- this.trvLayersGroup.DefaultToolTipProvider = null;
- this.trvLayersGroup.Dock = System.Windows.Forms.DockStyle.Fill;
- this.trvLayersGroup.DragDropMarkColor = System.Drawing.Color.Black;
- this.trvLayersGroup.LineColor = System.Drawing.SystemColors.ControlDark;
- this.trvLayersGroup.Location = new System.Drawing.Point(3, 28);
- this.trvLayersGroup.Model = null;
- this.trvLayersGroup.Name = "trvLayersGroup";
- this.trvLayersGroup.SelectedNode = null;
- this.trvLayersGroup.Size = new System.Drawing.Size(318, 226);
- this.trvLayersGroup.TabIndex = 1;
- this.trvLayersGroup.Text = "treeViewAdv1";
- // toolStrip2
- this.toolStrip2.Location = new System.Drawing.Point(3, 3);
- this.toolStrip2.Name = "toolStrip2";
- this.toolStrip2.Size = new System.Drawing.Size(318, 25);
- this.toolStrip2.TabIndex = 0;
- this.toolStrip2.Text = "toolStrip2";
// trvLayerDrawingOrder
this.trvLayerDrawingOrder.BackColor = System.Drawing.SystemColors.Window;
@@ -144,35 +281,110 @@
this.trvLayerDrawingOrder.Location = new System.Drawing.Point(3, 28);
this.trvLayerDrawingOrder.Model = null;
this.trvLayerDrawingOrder.Name = "trvLayerDrawingOrder";
+ this.trvLayerDrawingOrder.NodeControls.Add(this.NODE_DRAW_ICON);
+ this.trvLayerDrawingOrder.NodeControls.Add(this.NODE_DRAW_TEXT);
this.trvLayerDrawingOrder.SelectedNode = null;
- this.trvLayerDrawingOrder.Size = new System.Drawing.Size(318, 226);
+ this.trvLayerDrawingOrder.Size = new System.Drawing.Size(312, 235);
this.trvLayerDrawingOrder.TabIndex = 1;
this.trvLayerDrawingOrder.Text = "treeViewAdv1";
+ this.trvLayerDrawingOrder.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseDoubleClick);
+ this.trvLayerDrawingOrder.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseClick);
- // toolStrip3
+ // NODE_DRAW_ICON
- this.toolStrip3.Location = new System.Drawing.Point(0, 0);
- this.toolStrip3.Name = "toolStrip3";
- this.toolStrip3.Size = new System.Drawing.Size(318, 25);
- this.toolStrip3.TabIndex = 0;
- this.toolStrip3.Text = "toolStrip3";
+ this.NODE_DRAW_ICON.DataPropertyName = "Icon";
+ this.NODE_DRAW_ICON.LeftMargin = 1;
+ this.NODE_DRAW_ICON.ParentColumn = null;
+ this.NODE_DRAW_ICON.ScaleMode = Aga.Controls.Tree.ImageScaleMode.Clip;
- // trvBaseLayers
+ // NODE_DRAW_TEXT
- this.trvBaseLayers.BackColor = System.Drawing.SystemColors.Window;
- this.trvBaseLayers.BorderStyle = System.Windows.Forms.BorderStyle.None;
- this.trvBaseLayers.DefaultToolTipProvider = null;
- this.trvBaseLayers.Dock = System.Windows.Forms.DockStyle.Fill;
- this.trvBaseLayers.DragDropMarkColor = System.Drawing.Color.Black;
- this.trvBaseLayers.LineColor = System.Drawing.SystemColors.ControlDark;
- this.trvBaseLayers.Location = new System.Drawing.Point(0, 25);
- this.trvBaseLayers.Model = null;
- this.trvBaseLayers.Name = "trvBaseLayers";
- this.trvBaseLayers.SelectedNode = null;
- this.trvBaseLayers.Size = new System.Drawing.Size(318, 241);
- this.trvBaseLayers.TabIndex = 1;
- this.trvBaseLayers.Text = "treeViewAdv1";
+ this.NODE_DRAW_TEXT.DataPropertyName = "Text";
+ this.NODE_DRAW_TEXT.IncrementalSearchEnabled = true;
+ this.NODE_DRAW_TEXT.LeftMargin = 3;
+ this.NODE_DRAW_TEXT.ParentColumn = null;
+ // toolStrip2
+ this.toolStrip2.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.toolStripButton9,
+ this.toolStripButton10,
+ this.toolStripSeparator5,
+ this.toolStripButton11,
+ this.toolStripButton12,
+ this.toolStripSeparator6,
+ this.toolStripButton13,
+ this.toolStripButton14});
+ this.toolStrip2.Location = new System.Drawing.Point(3, 3);
+ this.toolStrip2.Name = "toolStrip2";
+ this.toolStrip2.Size = new System.Drawing.Size(312, 25);
+ this.toolStrip2.TabIndex = 0;
+ this.toolStrip2.Text = "toolStrip2";
+ // toolStripButton9
+ this.toolStripButton9.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton9.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.toolStripButton9.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton9.Name = "toolStripButton9";
+ this.toolStripButton9.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton9.Text = "toolStripButton3";
+ // toolStripButton10
+ this.toolStripButton10.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton10.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
+ this.toolStripButton10.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton10.Name = "toolStripButton10";
+ this.toolStripButton10.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton10.Text = "toolStripButton4";
+ // toolStripSeparator5
+ this.toolStripSeparator5.Name = "toolStripSeparator5";
+ this.toolStripSeparator5.Size = new System.Drawing.Size(6, 25);
+ // toolStripButton11
+ this.toolStripButton11.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton11.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
+ this.toolStripButton11.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton11.Name = "toolStripButton11";
+ this.toolStripButton11.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton11.Text = "toolStripButton5";
+ // toolStripButton12
+ this.toolStripButton12.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton12.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
+ this.toolStripButton12.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton12.Name = "toolStripButton12";
+ this.toolStripButton12.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton12.Text = "toolStripButton6";
+ // toolStripSeparator6
+ this.toolStripSeparator6.Name = "toolStripSeparator6";
+ this.toolStripSeparator6.Size = new System.Drawing.Size(6, 25);
+ // toolStripButton13
+ this.toolStripButton13.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton13.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange;
+ this.toolStripButton13.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton13.Name = "toolStripButton13";
+ this.toolStripButton13.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton13.Text = "toolStripButton7";
+ // toolStripButton14
+ this.toolStripButton14.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.toolStripButton14.Image = global::Maestro.Editors.Properties.Resources.layers_stack_arrange_back;
+ this.toolStripButton14.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.toolStripButton14.Name = "toolStripButton14";
+ this.toolStripButton14.Size = new System.Drawing.Size(23, 22);
+ this.toolStripButton14.Text = "toolStripButton8";
// splitter1
this.splitter1.Location = new System.Drawing.Point(326, 0);
@@ -200,10 +412,12 @@
this.tabControl1.ResumeLayout(false);
this.TAB_GROUP.ResumeLayout(false);
this.TAB_GROUP.PerformLayout();
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
this.TAB_DRAWING_ORDER.ResumeLayout(false);
this.TAB_DRAWING_ORDER.PerformLayout();
- this.TAB_BASE_LAYERS.ResumeLayout(false);
- this.TAB_BASE_LAYERS.PerformLayout();
+ this.toolStrip2.ResumeLayout(false);
+ this.toolStrip2.PerformLayout();
@@ -213,14 +427,36 @@
private System.Windows.Forms.TabControl tabControl1;
private System.Windows.Forms.TabPage TAB_GROUP;
private System.Windows.Forms.TabPage TAB_DRAWING_ORDER;
- private System.Windows.Forms.TabPage TAB_BASE_LAYERS;
private System.Windows.Forms.ToolStrip toolStrip1;
private System.Windows.Forms.Panel propertiesPanel;
private System.Windows.Forms.Splitter splitter1;
private Aga.Controls.Tree.TreeViewAdv trvLayersGroup;
private Aga.Controls.Tree.TreeViewAdv trvLayerDrawingOrder;
private System.Windows.Forms.ToolStrip toolStrip2;
- private Aga.Controls.Tree.TreeViewAdv trvBaseLayers;
- private System.Windows.Forms.ToolStrip toolStrip3;
+ private System.Windows.Forms.ToolStripButton toolStripButton1;
+ private System.Windows.Forms.ToolStripButton toolStripButton2;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
+ private System.Windows.Forms.ToolStripButton toolStripButton3;
+ private System.Windows.Forms.ToolStripButton toolStripButton4;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator2;
+ private System.Windows.Forms.ToolStripButton toolStripButton5;
+ private System.Windows.Forms.ToolStripButton toolStripButton6;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator3;
+ private System.Windows.Forms.ToolStripButton toolStripButton7;
+ private System.Windows.Forms.ToolStripButton toolStripButton8;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator4;
+ private System.Windows.Forms.ToolStripButton toolStripButton21;
+ private System.Windows.Forms.ToolStripButton toolStripButton9;
+ private System.Windows.Forms.ToolStripButton toolStripButton10;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator5;
+ private System.Windows.Forms.ToolStripButton toolStripButton11;
+ private System.Windows.Forms.ToolStripButton toolStripButton12;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator6;
+ private System.Windows.Forms.ToolStripButton toolStripButton13;
+ private System.Windows.Forms.ToolStripButton toolStripButton14;
+ private Aga.Controls.Tree.NodeControls.NodeIcon NODE_GROUP_ICON;
+ private Aga.Controls.Tree.NodeControls.NodeTextBox NODE_GROUP_TEXT;
+ private Aga.Controls.Tree.NodeControls.NodeIcon NODE_DRAW_ICON;
+ private Aga.Controls.Tree.NodeControls.NodeTextBox NODE_DRAW_TEXT;
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -25,12 +25,211 @@
using System.Text;
using Maestro.Shared.UI;
+using Aga.Controls.Tree;
+ public delegate void OpenLayerEventHandler(object sender, string layerResourceId);
[ToolboxItem(true)]
internal partial class MapLayersSectionCtrl : CollapsiblePanel, IEditorBindable
+ abstract class TreeItem<T>
+ public TreeItem(string text, Image icon, T item)
+ this.Text = text;
+ this.Icon = icon;
+ this.Tag = item;
+ public Image Icon { get; set; }
+ public string Text { get; set; }
+ public T Tag { get; set; }
+ class ScaleItem : TreeItem<IList<double>>
+ public ScaleItem(string name, IList<double> range)
+ : base(name, Properties.Resources.magnifier, range)
+ class LayerItem : TreeItem<MapLayerType>
+ public LayerItem(MapLayerType layer)
+ : base(layer.Name, Properties.Resources.layer, layer)
+ class GroupItem : TreeItem<MapLayerGroupType>
+ public GroupItem(MapLayerGroupType grp)
+ : base(grp.Name, Properties.Resources.folder_horizontal, grp)
+ class BaseLayerItem : TreeItem<BaseMapLayerType>
+ public BaseLayerItem(BaseMapLayerType layer)
+ class BaseLayerGroupItem : TreeItem<BaseMapLayerGroupCommonType>
+ public BaseLayerGroupItem(BaseMapLayerGroupCommonType group)
+ : base(group.Name, Properties.Resources.folder_horizontal, group)
+ abstract class TreeModelBase : ITreeModel
+ public abstract System.Collections.IEnumerable GetChildren(TreePath treePath);
+ public abstract bool IsLeaf(TreePath treePath);
+ public event EventHandler<TreeModelEventArgs> NodesChanged;
+ protected void OnNodesInserted(TreeModelEventArgs e)
+ var handler = this.NodesInserted;
+ handler(this, e);
+ public event EventHandler<TreeModelEventArgs> NodesInserted;
+ protected void OnNodesRemoved(TreeModelEventArgs e)
+ var handler = this.NodesRemoved;
+ handler(this, e);
+ public event EventHandler<TreeModelEventArgs> NodesRemoved;
+ protected void OnStructureChanged(TreePathEventArgs e)
+ var handler = this.StructureChanged;
+ handler(this, e);
+ public event EventHandler<TreePathEventArgs> StructureChanged;
+ class DrawOrderLayerModel : TreeModelBase
+ private OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition _map;
+ public DrawOrderLayerModel(OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition map)
+ _map = map;
+ public override System.Collections.IEnumerable GetChildren(TreePath treePath)
+ if (treePath.IsEmpty())
+ foreach (var layer in _map.MapLayer)
+ yield return new LayerItem(layer);
+ else
+ yield break;
+ public override bool IsLeaf(TreePath treePath)
+ return !treePath.IsEmpty();
+ class GroupedLayerModel : TreeModelBase
+ private Dictionary<string, List<MapLayerType>> _layersByGroup;
+ public GroupedLayerModel(OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition map)
+ _map = map;
+ _layersByGroup = new Dictionary<string, List<MapLayerType>>();
+ if (!string.IsNullOrEmpty(layer.Group))
+ if (!_layersByGroup.ContainsKey(layer.Group))
+ _layersByGroup[layer.Group] = new List<MapLayerType>();
+ _layersByGroup[layer.Group].Add(layer);
+ foreach (var group in _map.MapLayerGroup)
+ yield return new GroupItem(group);
+ else
+ var gitem = treePath.LastNode as GroupItem;
+ if (gitem != null)
+ var group = gitem.Tag;
+ foreach (var g in _map.MapLayerGroup)
+ if (g.Group == group.Name)
+ yield return new GroupItem(g);
+ if (_layersByGroup.ContainsKey(group.Name))
+ foreach (var layer in _layersByGroup[group.Name])
+ else
+ yield break;
+ var layer = treePath.LastNode as LayerItem;
+ var group = treePath.LastNode as GroupItem;
+ if (layer != null)
+ return true;
+ else if (group != null)
+ return !_layersByGroup.ContainsKey(group.Tag.Name);
+ throw new ApplicationException();
public MapLayersSectionCtrl()
@@ -43,9 +242,92 @@
service.RegisterCustomNotifier(this);
_map = (OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition)service.GetEditedResource();
+ trvLayerDrawingOrder.Model = new DrawOrderLayerModel(_map);
+ trvLayersGroup.Model = new GroupedLayerModel(_map);
public event EventHandler ResourceChanged;
+ public event OpenLayerEventHandler RequestLayerOpen;
+ private void trvLayersGroup_MouseDoubleClick(object sender, MouseEventArgs e)
+ TreeNodeAdv node = trvLayersGroup.GetNodeAt(new Point(e.X, e.Y));
+ if (node != null)
+ var layer = node.Tag as LayerItem;
+ var handler = this.RequestLayerOpen;
+ handler(this, layer.Tag.ResourceId);
+ private void trvLayerDrawingOrder_MouseDoubleClick(object sender, MouseEventArgs e)
+ TreeNodeAdv node = trvLayerDrawingOrder.GetNodeAt(new Point(e.X, e.Y));
+ if (node != null)
+ private void OnResourceChanged()
+ var handler = this.ResourceChanged;
+ private void trvLayersGroup_MouseClick(object sender, MouseEventArgs e)
+ if (node != null)
+ var group = node.Tag as GroupItem;
+ propertiesPanel.Controls.Clear();
+ var item = new LayerPropertiesCtrl(layer.Tag);
+ item.LayerChanged += (s, evt) => { OnResourceChanged(); };
+ item.Dock = DockStyle.Fill;
+ propertiesPanel.Controls.Add(item);
+ var item = new GroupPropertiesCtrl(group.Tag);
+ item.GroupChanged += (s, evt) => { OnResourceChanged(); };
+ private void trvLayerDrawingOrder_MouseClick(object sender, MouseEventArgs e)
+ if (node != null)
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx 2010-07-07 13:10:28 UTC (rev 5002)
@@ -123,7 +123,23 @@
<metadata name="toolStrip2.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>116, 17</value>
</metadata>
- <metadata name="toolStrip3.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>215, 17</value>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
</metadata>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="toolStripButton21.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAgxJREFUOE+lkvtL
+ U2EYx+0PEbtpFwnBKPGKiJImGP0gYhIYs1E5GF5gIxkpA00JRSmMEF0ohMh+GaRWYlqabMVcNdS2QpaI
+ VqiDIYhk397vA6fXhCjyhYdzeM/5fp7vczkAdeL2cwho7v/wWzT1zcN+Pwhr51uY2/y41PQaF+wzKKiZ
+ QvaN58g0jyLd5KEUcQbg+84P/Cm2tncQjW3j68YWIqubCC3FcOJc478BAuGoZM6zvoRnakXEruEIjhc4
+ /g5gZop9c+voGAyLbQIfeBZxLL9BA1jzXvuGbWamuKh+GmmVbswE19A59FEBbmoAG7YbsLtm2mZmiml9
+ cvabNDwpz6YB7LYBoMXCumkJr7LOmnnHzBQ/9X2Bo2cOibm1GsBREbAQiYmw/8lnuCeWkVzcgnZlnw1j
+ 3HV/wuNXK6i/9x5Hc6wawDlTXHbLJ+LZUBQPRyKwdQdxutwl1h+NLXHh5Ht1ewBHsiwawCW57HyDAfWR
+ dvl0uhZQ1eqX8aVc7EKLqrum651ATLf9OJx5XQM4KmY0xPzZ0hFAiQJnXB0WwME0E3IsL5B17ZlADqWb
+ NYDrOepdlcysmTWWOrxqbceRWtaLk0VO1XW72D5Vckd2gMBfq8zdpmUG62NJvKM4+XyziDk24xmfWoGE
+ s1c0gHPmbrPTpHNJKOCo2G1mZs20zcwUJ5yp1AB5+8/zEwgF5GMVDxh4AAAAAElFTkSuQmCC
+</value>
+ </data>
</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -32,7 +32,7 @@
this.label3 = new System.Windows.Forms.Label();
this.groupBox2 = new System.Windows.Forms.GroupBox();
- this.SetZoom = new System.Windows.Forms.Button();
+ this.btnSetZoom = new System.Windows.Forms.Button();
this.txtUpperY = new System.Windows.Forms.TextBox();
this.label8 = new System.Windows.Forms.Label();
this.txtUpperX = new System.Windows.Forms.TextBox();
@@ -53,8 +53,8 @@
// contentPanel
+ this.contentPanel.Controls.Add(this.cmbBackgroundColor);
this.contentPanel.Controls.Add(this.btnPickCs);
- this.contentPanel.Controls.Add(this.cmbBackgroundColor);
this.contentPanel.Controls.Add(this.txtCoordinateSystem);
this.contentPanel.Controls.Add(this.txtDescription);
this.contentPanel.Controls.Add(this.groupBox2);
@@ -94,7 +94,7 @@
this.groupBox2.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
- this.groupBox2.Controls.Add(this.SetZoom);
+ this.groupBox2.Controls.Add(this.btnSetZoom);
this.groupBox2.Controls.Add(this.txtUpperY);
this.groupBox2.Controls.Add(this.label8);
this.groupBox2.Controls.Add(this.txtUpperX);
@@ -113,15 +113,16 @@
this.groupBox2.TabStop = false;
this.groupBox2.Text = "Initial map view";
- // SetZoom
+ // btnSetZoom
- this.SetZoom.Enabled = false;
- this.SetZoom.ImeMode = System.Windows.Forms.ImeMode.NoControl;
- this.SetZoom.Location = new System.Drawing.Point(403, 22);
- this.SetZoom.Name = "SetZoom";
- this.SetZoom.Size = new System.Drawing.Size(104, 48);
- this.SetZoom.TabIndex = 10;
- this.SetZoom.Text = "Set view to current layers extent";
+ this.btnSetZoom.Enabled = false;
+ this.btnSetZoom.ImeMode = System.Windows.Forms.ImeMode.NoControl;
+ this.btnSetZoom.Location = new System.Drawing.Point(403, 22);
+ this.btnSetZoom.Name = "btnSetZoom";
+ this.btnSetZoom.Size = new System.Drawing.Size(104, 48);
+ this.btnSetZoom.TabIndex = 10;
+ this.btnSetZoom.Text = "Set view to current layers extent";
+ this.btnSetZoom.Click += new System.EventHandler(this.btnSetZoom_Click);
// txtUpperY
@@ -213,6 +214,8 @@
// txtDescription
+ this.txtDescription.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
this.txtDescription.Location = new System.Drawing.Point(143, 6);
this.txtDescription.Name = "txtDescription";
this.txtDescription.Size = new System.Drawing.Size(405, 20);
@@ -220,6 +223,8 @@
// txtCoordinateSystem
+ this.txtCoordinateSystem.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
this.txtCoordinateSystem.Location = new System.Drawing.Point(143, 32);
this.txtCoordinateSystem.Name = "txtCoordinateSystem";
this.txtCoordinateSystem.ReadOnly = true;
@@ -228,6 +233,7 @@
// btnPickCs
+ this.btnPickCs.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
this.btnPickCs.Location = new System.Drawing.Point(520, 30);
this.btnPickCs.Name = "btnPickCs";
this.btnPickCs.Size = new System.Drawing.Size(28, 23);
@@ -242,7 +248,7 @@
this.cmbBackgroundColor.Location = new System.Drawing.Point(143, 58);
this.cmbBackgroundColor.Name = "cmbBackgroundColor";
this.cmbBackgroundColor.Size = new System.Drawing.Size(121, 21);
- this.cmbBackgroundColor.TabIndex = 7;
+ this.cmbBackgroundColor.TabIndex = 9;
// MapSettingsSectionCtrl
@@ -267,7 +273,7 @@
private System.Windows.Forms.TextBox txtCoordinateSystem;
private System.Windows.Forms.TextBox txtDescription;
private System.Windows.Forms.GroupBox groupBox2;
- private System.Windows.Forms.Button SetZoom;
+ private System.Windows.Forms.Button btnSetZoom;
private System.Windows.Forms.TextBox txtUpperY;
private System.Windows.Forms.Label label8;
private System.Windows.Forms.TextBox txtUpperX;
@@ -278,7 +284,7 @@
private System.Windows.Forms.Label label5;
private System.Windows.Forms.Label label4;
private System.Windows.Forms.Label label9;
+ private System.Windows.Forms.Button btnPickCs;
private Maestro.Editors.Common.ColorComboBox cmbBackgroundColor;
- private System.Windows.Forms.Button btnPickCs;
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -46,28 +46,44 @@
public void Bind(IEditorService service)
+ cmbBackgroundColor.ResetColors();
_service = service;
_service.RegisterCustomNotifier(this);
- var b = new Binding("Text", _map, "Metadata");
- b.Parse += (sender, e) =>
+ var bmeta = new Binding("Text", _map, "Metadata");
+ bmeta.Parse += (sender, e) =>
e.Value = META_START + e.Value + META_END;
- b.Format += (sender, e) =>
+ bmeta.Format += (sender, e) =>
- var str = e.Value.ToString();
- if (str.StartsWith(META_START) && str.EndsWith(META_END))
+ if (e.Value != null)
- e.Value = str.Substring(META_START.Length, str.Length - (META_START.Length + META_END.Length));
+ var str = e.Value.ToString();
+ if (str.StartsWith(META_START) && str.EndsWith(META_END))
+ e.Value = str.Substring(META_START.Length, str.Length - (META_START.Length + META_END.Length));
- txtDescription.DataBindings.Add(b);
+ txtDescription.DataBindings.Add(bmeta);
txtCoordinateSystem.DataBindings.Add("Text", _map, "CoordinateSystem");
- //TODO: Find proper binding target
- cmbBackgroundColor.DataBindings.Add("Tag", _map, "BackgroundColor");
+ //ColorComboBox requires custom databinding
+ cmbBackgroundColor.CurrentColor = _map.BackgroundColor;
+ cmbBackgroundColor.SelectedIndexChanged += (sender, e) =>
+ _map.BackgroundColor = cmbBackgroundColor.CurrentColor;
+ _map.PropertyChanged += (sender, e) =>
+ if (e.PropertyName == "BackgroundColor")
txtLowerX.DataBindings.Add("Text", _map.Extents, "MinX");
txtLowerY.DataBindings.Add("Text", _map.Extents, "MinY");
@@ -98,5 +114,10 @@
txtCoordinateSystem.DataBindings[0].WriteValue();
+ private void btnSetZoom_Click(object sender, EventArgs e)
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -292,6 +292,29 @@
+ /// <summary>
+ /// Looks up a localized string similar to Finite Display Scales.
+ /// </summary>
+ internal static string FiniteDisplayScales {
+ get {
+ return ResourceManager.GetString("FiniteDisplayScales", resourceCulture);
+ internal static System.Drawing.Bitmap folder__minus {
+ get {
+ object obj = ResourceManager.GetObject("folder--minus", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
+ internal static System.Drawing.Bitmap folder__plus {
+ get {
+ object obj = ResourceManager.GetObject("folder--plus", resourceCulture);
internal static System.Drawing.Bitmap folder_horizontal {
get {
object obj = ResourceManager.GetObject("folder_horizontal", resourceCulture);
@@ -352,6 +375,41 @@
+ internal static System.Drawing.Bitmap layer {
+ get {
+ object obj = ResourceManager.GetObject("layer", resourceCulture);
+ internal static System.Drawing.Bitmap layer__minus {
+ get {
+ object obj = ResourceManager.GetObject("layer--minus", resourceCulture);
+ internal static System.Drawing.Bitmap layer__plus {
+ get {
+ object obj = ResourceManager.GetObject("layer--plus", resourceCulture);
+ internal static System.Drawing.Bitmap layers_stack_arrange {
+ get {
+ object obj = ResourceManager.GetObject("layers-stack-arrange", resourceCulture);
+ internal static System.Drawing.Bitmap layers_stack_arrange_back {
+ get {
+ object obj = ResourceManager.GetObject("layers-stack-arrange-back", resourceCulture);
internal static System.Drawing.Bitmap magnifier {
get {
object obj = ResourceManager.GetObject("magnifier", resourceCulture);
@@ -359,6 +417,13 @@
+ internal static System.Drawing.Bitmap MgCooker {
+ get {
+ object obj = ResourceManager.GetObject("MgCooker", resourceCulture);
internal static System.Drawing.Bitmap minus_circle {
get {
object obj = ResourceManager.GetObject("minus-circle", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-07-07 13:10:28 UTC (rev 5002)
@@ -117,22 +117,31 @@
</resheader>
- <data name="FindReplaceNothing" xml:space="preserve">
- <value>Nothing to replace</value>
- </data>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="globe--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="sql-join" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="minus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\minus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="TestConnectionNoErrors" xml:space="preserve">
+ <value>Provider reported no errors</value>
+ </data>
+ <data name="globe--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="cross-script" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\cross-script.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="sql-join-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\sql-join-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="application--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="drive-upload" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\drive-upload.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -140,21 +149,27 @@
<value>infinite</value>
<comment>A value that is displayed when the value assigned is infinite</comment>
</data>
+ <data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="magnifier" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\magnifier.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="sql-join-inner" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sql-join-inner.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="plus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\plus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="scissors-blue" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\scissors-blue.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="XmlDocIsValid" xml:space="preserve">
<value>Document is valid</value>
</data>
<data name="TransparentName" xml:space="preserve">
<value>Transparent</value>
</data>
- <data name="script--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\script--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="control-stop-square" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\control-stop-square.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -174,8 +189,8 @@
<data name="FileDownloaded" xml:space="preserve">
<value>File Downloaded</value>
</data>
- <data name="TestConnectionNoErrors" xml:space="preserve">
- <value>Provider reported no errors</value>
+ <data name="globe--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="document--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\document--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -186,12 +201,12 @@
<data name="control" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\control.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sort-number" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sort-number.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="folder_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\folder-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="arrow-090" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-090.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="FindNothing" xml:space="preserve">
<value>Could not find specified string or end of document reached</value>
</data>
@@ -204,42 +219,45 @@
<data name="table--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\table--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="layer--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="document-copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\document-copy.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="databases-relation" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\databases-relation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="cross-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\cross-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="globe--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="MoreColorsName" xml:space="preserve">
<value>More colors...</value>
</data>
+ <data name="script--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\script--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="sort-number" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\sort-number.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="tick-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\tick-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="scissors-blue" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\scissors-blue.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
- <data name="application--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\application--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="FindEmptyString" xml:space="preserve">
<value>Cannot Find an Empty String</value>
</data>
- <data name="sql-join-inner" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join-inner.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="arrow-270" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-270.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="function" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\function.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="globe--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\globe--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="sql-join-right" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\sql-join-right.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="folder--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="application--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
@@ -252,11 +270,14 @@
<data name="document--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\document--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="layer--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-090" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-090.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="cross-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\cross-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="arrow-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\arrow-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -267,8 +288,8 @@
<data name="application--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sql-join" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\sql-join.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FindReplaceNothing" xml:space="preserve">
+ <value>Nothing to replace</value>
</data>
<data name="application-export" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application-export.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -276,6 +297,9 @@
<data name="database--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\database--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="folder--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="XmlEditorCursorTemplate" xml:space="preserve">
<value>Line {0}, Column {1}</value>
</data>
@@ -285,22 +309,37 @@
<data name="sql" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\sql.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="arrow-270" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\arrow-270.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="function" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\function.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="application-import" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\application-import.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="globe--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="layers-stack-arrange" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layers-stack-arrange.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="globe--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="layers-stack-arrange-back" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layers-stack-arrange-back.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="globe--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\globe--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="layer" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="FiniteDisplayScales" xml:space="preserve">
+ <value>Finite Display Scales</value>
</data>
+ <data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
+ Ew2K9ilifrA+LDAMablFb1IM03DbMXMwj4O15VZ5iPly2Go0yzCzF0iwr4OdX3seOxK1owcunofzPPfv
+ vq77nLo6i2d44j0Xb8elgk90rO7VfN80dB13coLmyUFalCMcHjvJ+fBnHkdLu4Psty5wKhZgz9022tUw
+ 9oiHpuQy+1IG7umNnQGdfkV2bA4fq3ZtpCP+EI9u4NAM6mMJDkaDuPoj1pCGgUt/LDfiSYV4sFzGm6/g
+ zBkcGOtj/4gTm/+cNeBqvIBttIeexDDqlwqhjxX6ixVcc1/lHITawn5rwBVlVRa0x4ZoVc7i1V5JBx3p
+ nIwk4wU6rQG+e3m8ehlnMrodxaGOc+K1gS21waHRMzh6B3cepHDRrf2UHe3jp2mZXaf+hcHeRBnxeXf9
+ H4L3Z3HfnOJoyMVxtUSD+ovW55t03SnguzZNOp2xhiws6GjaPJPPXnLDn8Hnn6NvIMvl3qcEApHq2Rsp
+ SxcCUHj7QUrsTaAo0vUSi0vv5JklxCwUl0Wxuf4NE3vLGCuf1rdtii7Z7JZlASoWV1G6uslEpsjlFmvH
+ WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
+</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/folder--minus.png
(Binary files differ)
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/folder--minus.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/folder--plus.png
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/folder--plus.png
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/layer--minus.png
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/layer--minus.png
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/layer--plus.png
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/layer--plus.png
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/layer.png
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/layer.png
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/layers-stack-arrange-back.png
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/layers-stack-arrange-back.png
Added: sandbox/maestro-3.0/Maestro.Editors/Resources/layers-stack-arrange.png
Property changes on: sandbox/maestro-3.0/Maestro.Editors/Resources/layers-stack-arrange.png
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSetReader.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -213,7 +213,7 @@
public bool IsDBNull(int i)
- return m_row.IsValueNull(i);
+ return m_row.IsDBNull(i);
public object this[string name]
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -95,5 +95,27 @@
get { return true; }
+ /// <summary>
+ /// Returns the spatial extent of the data.
+ /// This is calculated by asking the underlying featuresource for the minimum rectangle that
+ /// contains all the features in the specified table. If the <paramref name="allowFallbackToContextInformation"/>
+ /// is set to true, and the query fails, the code will attempt to read this information
+ /// from the spatial context information instead.
+ /// </summary>
+ /// <param name="allowFallbackToContextInformation">True to allow reading spatial extents from the spatial context information, if the spatial query fails.</param>
+ /// <returns>The envelope for the data in the table</returns>
+ public Topology.Geometries.IEnvelope GetSpatialExtent(bool allowFallbackToContextInformation)
+ if (this.CurrentConnection == null)
+ throw new System.Exception("No server set for object");
+ if (this.Item as VectorLayerDefinitionType != null)
+ return this.CurrentConnection.FeatureService.GetSpatialExtent(this.Item.ResourceId, (this.Item as VectorLayerDefinitionType).FeatureName, (this.Item as VectorLayerDefinitionType).Geometry, allowFallbackToContextInformation);
+ else if (this.Item as GridLayerDefinitionType != null)
+ return this.CurrentConnection.FeatureService.GetSpatialExtent(this.Item.ResourceId, (this.Item as GridLayerDefinitionType).FeatureName, (this.Item as GridLayerDefinitionType).Geometry, allowFallbackToContextInformation);
+ else
+ return null;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-07-07 09:30:03 UTC (rev 5001)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-07-07 13:10:28 UTC (rev 5002)
@@ -23,9 +23,27 @@
using OSGeo.MapGuide.MaestroAPI.Resource;
using System.Xml.Serialization;
using OSGeo.MapGuide.MaestroAPI;
+using System.Drawing;
namespace OSGeo.MapGuide.ObjectModels.MapDefinition
+ partial class MapDefinitionType
+ [XmlIgnore]
+ public Color BackgroundColor
+ get
+ return this.backgroundColorField;
+ set
+ this.backgroundColorField = value;
+ OnPropertyChanged("BackgroundColor");
partial class MapDefinition : IResource
private static readonly Version RES_VERSION = new Version(1, 0, 0);
More information about the mapguide-commits
