[mapguide-commits] r5022 - in sandbox/maestro-3.0/Maestro.Base: Properties UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jul 10 10:38:40 EDT 2010
Author: jng
Date: 2010-07-10 14:38:40 +0000 (Sat, 10 Jul 2010)
New Revision: 5022
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
   sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
Make the site explorer tooltip localization friendly
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-07-10 13:51:04 UTC (rev 5021)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-07-10 14:38:40 UTC (rev 5022)
@@ -701,6 +701,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Resource Name: {1}{0}Resource Type: {2}{0}Created: {3}{0}Last Modified: {4}{0}Owner: {5}.
+        /// </summary>
+        internal static string SITE_EXPLORER_TOOLTIP_TEMPLATE {
+            get {
+                return ResourceManager.GetString("SITE_EXPLORER_TOOLTIP_TEMPLATE", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Disconnect.
         /// </summary>
         internal static string SiteExplorer_Disconnect {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-07-10 13:51:04 UTC (rev 5021)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-07-10 14:38:40 UTC (rev 5022)
@@ -460,4 +460,7 @@
   <data name="TPL_WL_NAME" xml:space="preserve">
     <value>Web Layout</value>
   </data>
+  <data name="SITE_EXPLORER_TOOLTIP_TEMPLATE" xml:space="preserve">
+    <value>Resource Name: {1}{0}Resource Type: {2}{0}Created: {3}{0}Last Modified: {4}{0}Owner: {5}</value>
+  </data>
 </root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs	2010-07-10 13:51:04 UTC (rev 5021)
+++ sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs	2010-07-10 14:38:40 UTC (rev 5022)
@@ -181,7 +181,7 @@
             RepositoryItem item = node.Tag as RepositoryItem;
             if (item != null)
-                return string.Format("Resource Name: {1}{0}Resource Type: {2}{0}Created: {3}{0}Last Modified: {4}{0}Owner: {5}", Environment.NewLine, item.Name, item.ResourceType, item.CreatedDate, item.ModifiedDate, item.Owner);
+                return string.Format(Properties.Resources.SITE_EXPLORER_TOOLTIP_TEMPLATE, Environment.NewLine, item.Name, item.ResourceType, item.CreatedDate, item.ModifiedDate, item.Owner);
             return string.Empty;
More information about the mapguide-commits mailing list
