[mapguide-commits] r5043 - in trunk/MgDev/Server/src:
Common/Manager Services/Site
svn_mapguide at osgeo.org
Tue Jul 20 12:45:02 EDT 2010
Author: brucedechant
Date: 2010-07-20 16:45:02 +0000 (Tue, 20 Jul 2010)
New Revision: 5043
trunk/MgDev/Server/src/Common/Manager/LogManager.h
trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp
Update debugging messages.
- Added debugging for log manager macros
Modified: trunk/MgDev/Server/src/Common/Manager/LogManager.h
--- trunk/MgDev/Server/src/Common/Manager/LogManager.h 2010-07-19 20:38:27 UTC (rev 5042)
+++ trunk/MgDev/Server/src/Common/Manager/LogManager.h 2010-07-20 16:45:02 UTC (rev 5043)
@@ -200,12 +200,25 @@
operationMessage += L"false"; \
+#ifdef _DEBUG
#define MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY() \
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) %W\n"), operationMessage.c_str())); \
MG_LOG_ACCESS_ENTRY(operationMessage.c_str(), connInfoClient.c_str(), connInfoClientIp.c_str(), connInfoUserName.c_str());
+#else
+#define MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY() \
+ MG_LOG_ACCESS_ENTRY(operationMessage.c_str(), connInfoClient.c_str(), connInfoClientIp.c_str(), connInfoUserName.c_str());
+#endif
+#ifdef _DEBUG
#define MG_LOG_OPERATION_MESSAGE_ADMIN_ENTRY() \
MG_LOG_ADMIN_ENTRY(operationMessage.c_str(), connInfoClient.c_str(), connInfoClientIp.c_str(), connInfoUserName.c_str());
+#else
+#define MG_LOG_OPERATION_MESSAGE_ADMIN_ENTRY() \
+ MG_LOG_ADMIN_ENTRY(operationMessage.c_str(), connInfoClient.c_str(), connInfoClientIp.c_str(), connInfoUserName.c_str());
+#endif
#define MG_CONNECTION_INFO \
STRING connInfoClient = L""; \
STRING connInfoClientIp = L""; \
Modified: trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp
--- trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp 2010-07-19 20:38:27 UTC (rev 5042)
+++ trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp 2010-07-20 16:45:02 UTC (rev 5043)
@@ -54,12 +54,16 @@
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpAuthenticate::Execute()\n")));
- // Disabled logging this operation because it is called very often
-// MG_LOG_OPERATION_MESSAGE(L"Authenticate");
+ // Only log this operation for DEBUG builds because it is called very often
+#ifdef _DEBUG
+ MG_LOG_OPERATION_MESSAGE(L"Authenticate");
+#endif
MG_SITE_SERVICE_TRY()
-// MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+#ifdef _DEBUG
+ MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+#endif
ACE_ASSERT(m_stream != NULL);
@@ -74,14 +78,15 @@
BeginExecution();
-// MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
-// MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgUserInformation");
-// MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
-// MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgStringCollection");
-// MG_LOG_OPERATION_MESSAGE_ADD_BOOL(returnAssignedRoles);
-// MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+#ifdef _DEBUG
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgUserInformation");
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgStringCollection");
+ MG_LOG_OPERATION_MESSAGE_ADD_BOOL(returnAssignedRoles);
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+#endif
// Validate() not called here since this is the operation that performs authentication.
Ptr<MgStringCollection> assignedRoles = m_service->Authenticate(userInfo,
@@ -91,8 +96,10 @@
else
+#ifdef _DEBUG
+#endif
if (!m_argsRead)
@@ -102,18 +109,24 @@
// Successful operation
-// MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+#ifdef _DEBUG
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+#endif
MG_SITE_SERVICE_CATCH(L"MgOpAuthenticate.Execute")
if (mgException != NULL)
// Failed operation
-// MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+#ifdef _DEBUG
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+#endif
// Add admin log entry for operation
-// MG_LOG_OPERATION_MESSAGE_ADMIN_ENTRY();
+#ifdef _DEBUG
+ MG_LOG_OPERATION_MESSAGE_ADMIN_ENTRY();
+#endif
MG_SITE_SERVICE_THROW()
More information about the mapguide-commits
