[mapguide-commits] r5056 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Tue Jul 27 19:12:40 EDT 2010
Author: waltweltonlair
Date: 2010-07-27 23:12:39 +0000 (Tue, 27 Jul 2010)
New Revision: 5056
trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
Two fixes...
In changeset r5013 I attempted to fix a bug in SE_ExpressionBase's IsLiteral method to handle
the case of three single quotes. However, a last moment "optimization" that I did messed up
the logic. I've corrected the fix, and verified it works for strings with zero, one, two, and
In changeset r5055 I added an optimization to SE_Renderer's DrawSymbol method to not render
a text primitive if its content is empty. While that works for regular text, and it doesn't
help the case where you have a text primitive that's part of a label symbol. I've improved
the optimization so that it handles both: in SE_Text::evaluate the code now only creates the
text primitive if the content length is non-zero. Besides handling the case of empty labels,
it further improves the original optimization by not creating / allocating the render primitive
to begin with.
Modified: trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
--- trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2010-07-27 17:19:08 UTC (rev 5055)
+++ trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2010-07-27 23:12:39 UTC (rev 5056)
@@ -350,7 +350,8 @@
return false;
// move to the end of the string
- while (*str++ != L'\0');
+ while (*str != L'\0')
+ str++;
// back up one character
str--;
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2010-07-27 17:19:08 UTC (rev 5055)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2010-07-27 23:12:39 UTC (rev 5056)
@@ -423,10 +423,6 @@
SE_RenderText* tp = (SE_RenderText*)primitive;
- // skip text elements which are empty
- if (tp->content.length() == 0)
- continue;
// update the extents with this primitive's bounds
for (int j=0; j<4; ++j)
extents.add_point(primitive->bounds[j]);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2010-07-27 17:19:08 UTC (rev 5055)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2010-07-27 23:12:39 UTC (rev 5056)
@@ -300,6 +300,11 @@
if (ctx->fonte == NULL)
return NULL;
+ // don't bother creating a primitive if there's no content
+ const wchar_t* contentStr = content.evaluate(ctx->exec);
+ if (wcslen(contentStr) == 0)
+ return NULL;
SE_RenderText* ret = new SE_RenderText();
const wchar_t* sResizeCtrl = resizeControl.evaluate(ctx->exec);
@@ -311,7 +316,7 @@
ret->resizeControl = SE_ResizeControl_ResizeNone;
if(NULL != content.expression)
ret->expression = content.expression->ToString();
- ret->content = content.evaluate(ctx->exec);
+ ret->content = contentStr;
ret->position[0] = position[0].evaluate(ctx->exec);
ret->position[1] = position[1].evaluate(ctx->exec);
More information about the mapguide-commits
