[mapguide-commits] r5060 - trunk/Tools/Maestro/MaestroAPI
svn_mapguide at osgeo.org
Fri Jul 30 07:46:03 EDT 2010
Author: jng
Date: 2010-07-30 11:46:03 +0000 (Fri, 30 Jul 2010)
New Revision: 5060
trunk/Tools/Maestro/MaestroAPI/ConnectionFactory.cs
trunk/Tools/Maestro/MaestroAPI/ConnectionProviderRegistry.cs
Possible fix for #1370: Use System.Data.Common.DbConnectionStringBuilder to construct/de-construct connection strings as this can take into account reserved characters which would've tripped up the connection creation with our previous approach
Modified: trunk/Tools/Maestro/MaestroAPI/ConnectionFactory.cs
--- trunk/Tools/Maestro/MaestroAPI/ConnectionFactory.cs 2010-07-29 13:13:00 UTC (rev 5059)
+++ trunk/Tools/Maestro/MaestroAPI/ConnectionFactory.cs 2010-07-30 11:46:03 UTC (rev 5060)
@@ -19,23 +19,16 @@
/// <returns></returns>
public static ServerConnectionI CreateHttpConnection(Uri hosturl, string sessionid, string locale, bool allowUntestedVersion)
+ System.Data.Common.DbConnectionStringBuilder builder = new System.Data.Common.DbConnectionStringBuilder();
+ builder[HttpServerConnection.PARAM_URL] = hosturl.ToString();
+ builder[HttpServerConnection.PARAM_SESSION] = sessionid;
+ builder[HttpServerConnection.PARAM_UNTESTED] = allowUntestedVersion;
string connStr = string.Empty;
- if (string.IsNullOrEmpty(locale))
+ if (!string.IsNullOrEmpty(locale))
- connStr = string.Format("{0}={1};{2}={3};{4}={5}",
- HttpServerConnection.PARAM_URL, hosturl.ToString(),
- HttpServerConnection.PARAM_SESSION, sessionid,
- HttpServerConnection.PARAM_UNTESTED, allowUntestedVersion);
+ builder[HttpServerConnection.PARAM_LOCALE] = locale;
- else
- connStr = string.Format("{0}={1};{2}={3};{4}={5};{6}={7}",
- HttpServerConnection.PARAM_LOCALE, locale,
- return ConnectionProviderRegistry.CreateConnection("Maestro.Http", connStr);
+ return ConnectionProviderRegistry.CreateConnection("Maestro.Http", builder.ToString());
/// <summary>
@@ -49,25 +42,17 @@
public static ServerConnectionI CreateHttpConnection(Uri hosturl, string username, string password, string locale, bool allowUntestedVersion)
- string connStr = string.Empty;
+ builder[HttpServerConnection.PARAM_USERNAME] = username;
+ builder[HttpServerConnection.PARAM_PASSWORD] = password;
- HttpServerConnection.PARAM_USERNAME, username,
- HttpServerConnection.PARAM_PASSWORD, password,
- else
- connStr = string.Format("{0}={1};{2}={3};{4}={5};{6}={7};{8}={9}",
/// <summary>
@@ -80,23 +65,15 @@
public static ServerConnectionI CreateLocalNativeConnection(string configFile, string username, string password, string locale)
+ builder[LocalNativeConnection.PARAM_CONFIG] = configFile;
+ builder[LocalNativeConnection.PARAM_USERNAME] = username;
+ builder[LocalNativeConnection.PARAM_PASSWORD] = password;
- LocalNativeConnection.PARAM_CONFIG, configFile,
- LocalNativeConnection.PARAM_USERNAME, username,
- LocalNativeConnection.PARAM_PASSWORD, password);
+ builder[LocalNativeConnection.PARAM_LOCALE] = locale;
- else
- LocalNativeConnection.PARAM_PASSWORD, password,
- LocalNativeConnection.PARAM_LOCALE, locale);
- return ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative", connStr);
+ return ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative", builder.ToString());
/// <summary>
@@ -106,7 +83,9 @@
public static ServerConnectionI CreateLocalNativeConnection(string sessionid)
- return ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative", LocalNativeConnection.PARAM_SESSION + "=" + sessionid);
+ builder[LocalNativeConnection.PARAM_SESSION] = sessionid;
+ return ConnectionProviderRegistry.CreateConnection("Maestro.LocalNative", sessionid);
Modified: trunk/Tools/Maestro/MaestroAPI/ConnectionProviderRegistry.cs
--- trunk/Tools/Maestro/MaestroAPI/ConnectionProviderRegistry.cs 2010-07-29 13:13:00 UTC (rev 5059)
+++ trunk/Tools/Maestro/MaestroAPI/ConnectionProviderRegistry.cs 2010-07-30 11:46:03 UTC (rev 5060)
@@ -78,16 +78,14 @@
private static NameValueCollection ParseConnectionString(string connectionString)
+ builder.ConnectionString = connectionString;
NameValueCollection values = new NameValueCollection();
- string[] tokens = connectionString.Split(';');
- foreach (string tok in tokens)
+ foreach (string key in builder.Keys)
- string[] nameValue = tok.Split('=');
- if (nameValue.Length == 2)
- values.Add(nameValue[0], nameValue[1]);
+ values.Add(key, builder[key].ToString());
return values;
More information about the mapguide-commits
