[mapguide-commits] r4936 - in trunk/Tools/Maestro: Installer
Localization/ConvertResX/ConvertResX/Properties
Localization/da-DK/Maestro/Strings
Localization/es-ES/Maestro/Strings Maestro
Maestro/FusionEditor Maestro/LoginForm
Maestro/LoginForm/Properties Maestro/MaestroEditorInterface
Maestro/ResourceBrowser/Properties Maestro/ResourceEditors
Maestro/ResourceValidators MaestroAPI
MaestroAPI/PackageBuilder/Properties MaestroAPI/XsdGenerator
new w generics/Properties
MgCooker/MgCookerCommandline/Properties MgCooker/Properties
svn_mapguide at osgeo.org
Mon Jun 7 03:48:34 EDT 2010
Author: jng
Date: 2010-06-07 03:48:29 -0400 (Mon, 07 Jun 2010)
New Revision: 4936
trunk/Tools/Maestro/Installer/UpgradeData.wxi
trunk/Tools/Maestro/Installer/VSExpress Build.bat
trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/FormMain.da-DK.resx
trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/FormMain.es-ES.resx
trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs
trunk/Tools/Maestro/Maestro/LoginForm/HttpLoginCtrl.cs
trunk/Tools/Maestro/Maestro/LoginForm/ILoginCtrl.cs
trunk/Tools/Maestro/Maestro/LoginForm/LocalNativeLoginCtrl.cs
trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
This submission includes the following changes:
- Prepare for 2.1 Preview Release 2
- Remove test exception from login dialog. This was to test the nested message handling but was not removed in a previous submission. Oops.
- Fix #1365: Evaluate button status after switching connection mode in login dialog.
- Tweak the installer build script to use vanilla msbuild instead of WixProjBuilder.exe
Modified: trunk/Tools/Maestro/Installer/UpgradeData.wxi
--- trunk/Tools/Maestro/Installer/UpgradeData.wxi 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Installer/UpgradeData.wxi 2010-06-07 07:48:29 UTC (rev 4936)
@@ -3,7 +3,7 @@
<?define UpgradeCode="A7C2ECB3-1991-47B9-A22E-8844BB95CAE2" ?>
<!-- Remember to change product version on each install -->
- <?define ProductVersion="2.1.0.4814" ?>
+ <?define ProductVersion="2.1.0.4936" ?>
<?define Manufacturer="Open Source Geospatial Foundation" ?>
Modified: trunk/Tools/Maestro/Installer/VSExpress Build.bat
--- trunk/Tools/Maestro/Installer/VSExpress Build.bat 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Installer/VSExpress Build.bat 2010-06-07 07:48:29 UTC (rev 4936)
@@ -25,7 +25,7 @@
"%PARAFFIN_PATH%" -dir %MAESTRO_OUTPUT% -alias "%MAESTRO_OUTPUT%" -custom MAESTROBIN -dirref INSTALLLOCATION -multiple -guids incBinFiles.wxs -ext .pdb -direXclude .svn
-WixProjBuilder.exe Maestro.wixproj
+msbuild.exe /p:Configuration=%TYPEBUILD% Maestro.wixproj
rem Move in localization files and build zip
%XCOPY% "%MAESTRO_LOCALIZATION%\compiled\*" "%MAESTRO_OUTPUT%"
Modified: trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -32,5 +32,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("2.1.0.4814")]
-[assembly: AssemblyFileVersion("2.1.0.4814")]
+[assembly: AssemblyVersion("2.1.0.4936")]
+[assembly: AssemblyFileVersion("2.1.0.4936")]
Modified: trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/FormMain.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/FormMain.da-DK.resx 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/FormMain.da-DK.resx 2010-06-07 07:48:29 UTC (rev 4936)
@@ -291,4 +291,8 @@
<data name="FindReplaceTooltip" xml:space="preserve">
<value>Find any strings that match the pattern {0} and replace it with {1}</value>
</data>
+ <data name="ConfirmMultipleOpen" xml:space="preserve">
+ <value>Are you sure you want to open {0} items?</value>
+ <comment>A confirmation message that is displayed when opening multiple items for editing</comment>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/FormMain.es-ES.resx
--- trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/FormMain.es-ES.resx 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/FormMain.es-ES.resx 2010-06-07 07:48:29 UTC (rev 4936)
@@ -291,4 +291,8 @@
</data>
+ </data>
</root>
Modified: trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -45,7 +45,7 @@
// You can specify all the values or you can default the Revision and Build Numbers
// In order to sign your assembly you must specify a key to use. Refer to the
@@ -75,4 +75,4 @@
[assembly: AssemblyDelaySign(false)]
[assembly: AssemblyKeyFile("")]
[assembly: AssemblyKeyName("")]
-[assembly: AssemblyFileVersionAttribute("2.1.0.4814")]
+[assembly: AssemblyFileVersionAttribute("2.1.0.4936")]
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -122,21 +122,30 @@
loginPanel.Controls.Add(c);
- private void rdHttp_CheckedChanged(object sender, EventArgs e)
+ private void UpdateLoginControl()
- _selectedIndex = 0;
+ if (rdHttp.Checked)
+ _selectedIndex = 0;
+ else
+ _selectedIndex = 1;
SetLoginControl((Control)_controls[_selectedIndex]);
+ _controls[_selectedIndex].UpdateLoginStatus();
+ private void rdHttp_CheckedChanged(object sender, EventArgs e)
+ UpdateLoginControl();
private void rdTcpIp_CheckedChanged(object sender, EventArgs e)
- _selectedIndex = 1;
- SetLoginControl((Control)_controls[_selectedIndex]);
private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.Cancel;
private void btnOK_Click(object sender, EventArgs e)
@@ -145,11 +154,6 @@
try
- throw new Exception("Outer Message",
- new Exception("Inner Message 1",
- new Exception("Inner Message 2",
- new Exception("Inner Message 3"))));
PreferedSite ps = null;
if (_selectedIndex == 0) //HTTP
Modified: trunk/Tools/Maestro/Maestro/LoginForm/HttpLoginCtrl.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/HttpLoginCtrl.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/LoginForm/HttpLoginCtrl.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -76,7 +76,7 @@
cmbLanguage.SelectedIndex = selected;
_loading = false;
- UpdateButtonStatus();
+ UpdateLoginStatus();
public PreferedSite[] GetSites()
@@ -155,10 +155,10 @@
private void txtPassword_TextChanged(object sender, EventArgs e)
- private void UpdateButtonStatus()
+ public void UpdateLoginStatus()
if (this.Username.Trim().Length > 0 && this.Server.Trim().Length > 0)
EnableOk(this, EventArgs.Empty);
Modified: trunk/Tools/Maestro/Maestro/LoginForm/ILoginCtrl.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/ILoginCtrl.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/LoginForm/ILoginCtrl.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -28,6 +28,8 @@
string Username { get; }
string Password { get; }
+ void UpdateLoginStatus();
event EventHandler EnableOk;
event EventHandler DisabledOk;
event EventHandler CheckSavedPassword;
Modified: trunk/Tools/Maestro/Maestro/LoginForm/LocalNativeLoginCtrl.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/LocalNativeLoginCtrl.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/LoginForm/LocalNativeLoginCtrl.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -66,7 +66,7 @@
public event EventHandler CheckSavedPassword = delegate { };
- private void txtWebConfig_TextChanged(object sender, EventArgs e)
if (this.WebConfigPath.Trim().Length > 0 && File.Exists(this.WebConfigPath))
@@ -74,6 +74,11 @@
DisabledOk(this, EventArgs.Empty);
+ private void txtWebConfig_TextChanged(object sender, EventArgs e)
private void btnBrowse_Click(object sender, EventArgs e)
using (var dlg = new OpenFileDialog())
Modified: trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -32,5 +32,5 @@
Modified: trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -45,7 +45,7 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -50,5 +50,5 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
[assembly: AssemblyKeyFile("..\\..\\maestroapi.key")]
Modified: trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs 2010-06-04 21:46:25 UTC (rev 4935)
+++ trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs 2010-06-07 07:48:29 UTC (rev 4936)
@@ -48,5 +48,5 @@
// Build Number
// Revision
More information about the mapguide-commits
