[mapguide-commits] r4941 - in trunk/Installer: . livedvd
svn_mapguide at osgeo.org
Mon Jun 14 18:50:23 EDT 2010
Author: trevorwekel
Date: 2010-06-14 22:50:23 +0000 (Mon, 14 Jun 2010)
New Revision: 4941
Added:
trunk/Installer/livedvd/
trunk/Installer/livedvd/mglivedvdinst.sh
trunk/Installer/livedvd/mglivedvduninst.sh
Ticket #1295 - Improve build scripts for 2.2 release cycle
- Add preliminary LiveDVD installs scripts
Added: trunk/Installer/livedvd/mglivedvdinst.sh
--- trunk/Installer/livedvd/mglivedvdinst.sh (rev 0)
+++ trunk/Installer/livedvd/mglivedvdinst.sh 2010-06-14 22:50:23 UTC (rev 4941)
@@ -0,0 +1,90 @@
+#!/bin/bash
+# Copyright (C) 2010 by Autodesk, Inc.
+# This library is free software; you can redistribute it and/or
+# modify it under the terms of version 2.1 of the GNU Lesser
+# General Public License as published by the Free Software Foundation.
+# This library is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+# Lesser General Public License for more details.
+# You should have received a copy of the GNU Lesser General Public
+# License along with this library; if not, write to the Free Software
+# Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+TEMPDIR=/tmp/build_mapguide
+URL="http://download.osgeo.org/mapguide/releases/2.2.0/Beta"
+FDOVER=3.5.0-5460_i386
+MGVER=2.2.0-4898_i386
+MAESTROVER=2.0.0-4650_i386
+# Create temporary download directory
+mkdir -p ${TEMPDIR}
+pushd ${TEMPDIR}
+# Install required packages
+apt-get -y install libexpat1 libssl0.9.8 odbcinst1debian1 unixodbc libcurl3 libxslt1.1
+apt-get -y install mono-runtime libmono-winforms2.0-cil
+# Resolve CentOS 5.4 / Ubuntu 9.10 shared lib differences with symlinks
+if [ ! -e /lib/libcrypto.so.6 ]; then
+ ln -s /lib/libcrypto.so.0.9.8 /lib/libcrypto.so.6
+fi
+if [ ! -e /lib/libssl.so.6 ]; then
+ ln -s /lib/libssl.so.0.9.8 /lib/libssl.so.6
+fi
+if [ ! -e /lib/libexpat.so.0 ]; then
+ ln -s /lib/libexpat.so.1.5.2 /lib/libexpat.so.0
+fi
+if [ ! -e /usr/lib/libldap-2.3.so.0 ]; then
+ ln -s /usr/lib/libldap-2.4.so.2 /usr/lib/libldap-2.3.so.0
+fi
+if [ ! -e /usr/lib/liblber-2.3.so.0 ]; then
+ ln -s /usr/lib/liblber-2.4.so.2 /usr/lib/liblber-2.3.so.0
+fi
+if [ ! -d /var/lock/mgserver ]; then
+ mkdir /var/lock/mgserver
+fi
+# Download Ubuntu packages for FDO
+for file in core gdal kingoracle ogr postgis sdf shp sqlite wfs wms
+do
+ wget -N ${URL}/fdo-${file}_${FDOVER}.deb
+done
+# Download Ubuntu packages for MapGuide
+for file in common server webextensions httpd
+do
+ wget -N ${URL}/mapguideopensource-${file}_${MGVER}.deb
+done
+# Download Ubuntu package for Maestro
+wget -N ${URL}/mapguideopensource-maestro_${MAESTROVER}.deb
+# Install Ubuntu packages for FDO
+do
+ dpkg -E -G --install fdo-${file}_${FDOVER}.deb
+done
+# Install Ubuntu packages for MapGuide
+do
+ dpkg -E -G --install mapguideopensource-${file}_${MGVER}.deb
+done
+# Install Ubuntu Package for Maestro
+dpkg -E -G --install mapguideopensource-maestro_${MAESTROVER}.deb
+popd
Property changes on: trunk/Installer/livedvd/mglivedvdinst.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/Installer/livedvd/mglivedvduninst.sh
--- trunk/Installer/livedvd/mglivedvduninst.sh (rev 0)
+++ trunk/Installer/livedvd/mglivedvduninst.sh 2010-06-14 22:50:23 UTC (rev 4941)
@@ -0,0 +1,33 @@
+#!/bin/bash
+# Remove Ubuntu packages for MapGuide
+for file in server webextensions httpd common
+do
+ dpkg --remove mapguideopensource-${file}
+done
+# Remove Ubuntu packages for FDO
+for file in wms wfs sqlite shp sdf postgis ogr kingoracle gdal core
+do
+ dpkg --remove fdo-${file}
+done
+dpkg --remove mapguideopensource-maestro
Property changes on: trunk/Installer/livedvd/mglivedvduninst.sh
More information about the mapguide-commits
