[mapguide-commits] r4952 - in trunk/MgDev/Server/src:
Common/Manager Core
svn_mapguide at osgeo.org
Thu Jun 17 12:46:41 EDT 2010
Author: brucedechant
Date: 2010-06-17 16:46:41 +0000 (Thu, 17 Jun 2010)
New Revision: 4952
trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
trunk/MgDev/Server/src/Common/Manager/ServerManager.h
trunk/MgDev/Server/src/Core/OperationThread.cpp
Fix for trac ticket 1354 - GetSiteInfo is returning bad values for AverageOperationTime and TotalOperationTime
http://trac.osgeo.org/mapguide/ticket/1354
Notes:
- Updated to use INT64 instead of INT32
- Fixed OperationThread recording incorrect timings
- Corrected average operation time calculation
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2010-06-17 16:35:31 UTC (rev 4951)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2010-06-17 16:46:41 UTC (rev 4952)
@@ -454,7 +454,7 @@
pProperties->Add(pProperty);
// Add the Uptime
- time_t nUptime = GetUptime();
+ INT64 nUptime = GetUptime();
pProperty = new MgInt64Property(MgServerInformationProperties::Uptime, nUptime);
@@ -479,12 +479,13 @@
// Add the TotalOperationTime
- time_t nTotalOperationTime = GetTotalOperationTime();
+ // This value needs to be returned in seconds according to the schema
+ INT64 nTotalOperationTime = GetTotalOperationTime() / 1000;
pProperty = new MgInt64Property(MgServerInformationProperties::TotalOperationTime, nTotalOperationTime);
// Add the AverageOperationTime
- time_t nAverageOperationTime = GetAverageOperationTime();
+ INT64 nAverageOperationTime = GetAverageOperationTime();
pProperty = new MgInt64Property(MgServerInformationProperties::AverageOperationTime, nAverageOperationTime);
@@ -871,12 +872,12 @@
return m_totalProcessedOperations.value();
-time_t MgServerManager::GetTotalOperationTime()
+INT64 MgServerManager::GetTotalOperationTime()
return m_totalOperationTime.value();
-void MgServerManager::IncrementOperationTime(time_t operationTime)
+void MgServerManager::IncrementOperationTime(INT64 operationTime)
m_totalOperationTime += operationTime;
@@ -1187,7 +1188,7 @@
/// EXCEPTIONS:
/// MgConnectionNotOpenException
-time_t MgServerManager::GetUptime()
+INT64 MgServerManager::GetUptime()
ACE_Time_Value upTime(0);
@@ -1197,7 +1198,7 @@
MG_CATCH_AND_THROW(L"MgServerManager.GetUptime");
- return upTime.sec();
+ return (INT64)upTime.sec();
@@ -1210,7 +1211,7 @@
/// EXCEPTIONS:
-time_t MgServerManager::GetAverageOperationTime()
+INT64 MgServerManager::GetAverageOperationTime()
double avgTime = 0.0;
@@ -1218,13 +1219,13 @@
if (GetTotalProcessedOperations() > 0)
- avgTime = ((double)(GetTotalOperationTime()) * 1000.0) / (double)(GetTotalProcessedOperations());
+ avgTime = ((double)(GetTotalOperationTime())) / (double)(GetTotalProcessedOperations());
MG_CATCH_AND_THROW(L"MgServerManager.GetAverageOperationTime")
- return time_t(avgTime);
+ return (INT64)avgTime;
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.h
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.h 2010-06-17 16:35:31 UTC (rev 4951)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.h 2010-06-17 16:46:41 UTC (rev 4952)
@@ -36,7 +36,7 @@
class MgWorkerThread;
typedef ACE_Atomic_Op<ACE_Thread_Mutex, INT32> SAFE_INT32;
-typedef ACE_Atomic_Op<ACE_Thread_Mutex, time_t> SAFE_TIME_T;
+typedef ACE_Atomic_Op<ACE_Thread_Mutex, INT64> SAFE_INT64;
class MG_SERVER_MANAGER_API MgServerManager : public MgGuardDisposable
@@ -100,9 +100,9 @@
ACE_Time_Value GetStartTime();
INT32 GetTotalReceivedOperations();
INT32 GetTotalProcessedOperations();
- time_t GetTotalOperationTime();
+ INT64 GetTotalOperationTime();
- void IncrementOperationTime(time_t operationTime);
+ void IncrementOperationTime(INT64 operationTime);
void IncrementReceivedOperations();
void IncrementProcessedOperations();
@@ -117,8 +117,8 @@
INT32 GetClientOperationsQueueCount();
INT32 GetSiteOperationsQueueCount();
- time_t GetUptime();
- time_t GetAverageOperationTime();
+ INT64 GetUptime();
+ INT64 GetAverageOperationTime();
INT64 GetTotalPhysicalMemory();
INT64 GetAvailablePhysicalMemory();
@@ -176,7 +176,7 @@
INT32 m_nSiteThreads;
ACE_Time_Value m_startTime;
- SAFE_TIME_T m_totalOperationTime; // This value is tracked in seconds
+ SAFE_INT64 m_totalOperationTime; // This value is tracked in milliseconds
SAFE_INT32 m_totalReceivedOperations;
SAFE_INT32 m_totalProcessedOperations;
Modified: trunk/MgDev/Server/src/Core/OperationThread.cpp
--- trunk/MgDev/Server/src/Core/OperationThread.cpp 2010-06-17 16:35:31 UTC (rev 4951)
+++ trunk/MgDev/Server/src/Core/OperationThread.cpp 2010-06-17 16:46:41 UTC (rev 4952)
@@ -309,7 +309,8 @@
MG_TRY()
- ACE_Time_Value operationTime(0);
+ ACE_Time_Value operationStartTime(0);
+ operationStartTime = ACE_OS::gettimeofday();
ACE_ASSERT( pData );
if ( pData )
@@ -396,6 +397,8 @@
stat = pServiceHandler->ProcessOperation();
m_timer.stop();
+ ACE_Time_Value operationTime(0);
+ operationTime = ACE_OS::gettimeofday() - operationStartTime;
m_timer.elapsed_time(operationTime);
delete pServiceHandler;
@@ -408,7 +411,10 @@
// We increment operations processed for successful operations only.
if (IMgServiceHandler::mpsDone == stat)
- time_t opTime = operationTime.sec();
+ unsigned long opTime = operationTime.msec();
pConnection->IncrementProcessedOperations();
pConnection->SetCurrentOperationTime(opTime);
More information about the mapguide-commits
