[mapguide-commits] r4962 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jun 18 16:34:19 EDT 2010
Author: waltweltonlair
Date: 2010-06-18 20:34:19 +0000 (Fri, 18 Jun 2010)
New Revision: 4962
   trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
   trunk/MgDev/Common/Stylization/SE_LineBuffer.h
Submit fix from Dan (reviewed by me) for ticket #1383.
The submission exposes an internal API on SE_LineBuffer to retrieve an arc definition:
    SE_LineBuffer::GetEllipseDefinition(int index)
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp	2010-06-17 19:05:44 UTC (rev 4961)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp	2010-06-18 20:34:19 UTC (rev 4962)
@@ -305,6 +305,55 @@
+SE_EllipseDef* SE_LineBuffer::GetEllipseDefinition(int index)
+    SE_LB_SegType* endseg = m_segs + m_nsegs;
+    SE_LB_SegType* curseg = m_segs;
+    SE_EllipseDef*  arc_def = NULL; // output
+    int             arc_idx = 0;    // elliptical arcs counter
+    int src_idx = 0;
+    // Locate the arc start in the array of points
+    while (curseg != endseg && arc_idx <= index)
+        switch (*curseg++)
+        case SegType_MoveTo:
+        case SegType_LineTo:
+            src_idx += 2;
+            break;
+        case SegType_EllipticalArc:
+                if (arc_idx == index)
+                    // Arc found
+                    arc_def = new SE_EllipseDef;
+                    arc_def->cx = m_pts[src_idx++];
+                    arc_def->cy = m_pts[src_idx++];
+                    arc_def->rx = m_pts[src_idx++];
+                    arc_def->ry = m_pts[src_idx++];
+                    arc_def->sAng = m_pts[src_idx++];
+                    arc_def->eAng = m_pts[src_idx++];
+                    arc_def->rot = m_pts[src_idx++];
+                    arc_def->xf = m_xf;
+                else
+                    src_idx += 7;   // continue
+                arc_idx++;
+            break;
+    return arc_def;
 void SE_LineBuffer::Transform(const SE_Matrix& xform, double tolerance)
     if (m_xf_bounds)
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.h
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.h	2010-06-17 19:05:44 UTC (rev 4961)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.h	2010-06-18 20:34:19 UTC (rev 4962)
@@ -26,6 +26,20 @@
 class SE_BufferPool;
+// Ellipse definition
+struct SE_EllipseDef
+    double cx;    // X center
+    double cy;    // Y center
+    double rx;    // major radius
+    double ry;    // minor radius
+    double sAng;  // start angle
+    double eAng;  // start angle
+    double rot;   // rotation
+    SE_Matrix xf; // scale matrix
 class SE_LineBuffer
 friend class SE_BufferPool;
@@ -71,6 +85,18 @@
     STYLIZATION_API SE_LineBuffer* Clone(bool keepPool = true);
+    // Retrieve the elliptical arc parameters
+    //   index - the index of the arc in the symbol, zero-based
+    // E.g. for a buffer with:
+    //     M L L M A0 M A1
+    //     M=MoveTo, L=LineTo, A=ArcTo
+    // GetEllipseDefinition would return arc segment A0 for index=0,
+    // and arc segment A1 for index=1.
+    // Caller has to check for NULL and delete the returned object.
+    STYLIZATION_API SE_EllipseDef* GetEllipseDefinition(int index);
 private:
     SE_Bounds* GetSEBounds(RS_Bounds& bounds);
     void PopulateXFBuffer();
More information about the mapguide-commits mailing list
