[mapguide-commits] r4626 - in sandbox/adsk/2.2gp/Web/src: PhpApi
PhpMapGuideApiEnvConfig
svn_mapguide at osgeo.org
Wed Mar 3 18:35:34 EST 2010
Author: brucedechant
Date: 2010-03-03 18:35:33 -0500 (Wed, 03 Mar 2010)
New Revision: 4626
sandbox/adsk/2.2gp/Web/src/PhpApi/PhpApi.vcproj
sandbox/adsk/2.2gp/Web/src/PhpApi/php.i
sandbox/adsk/2.2gp/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
Fix for trac ticket 1290 - Update PHP extensions to support PHP 5.3
http://trac.osgeo.org/mapguide/ticket/1290
Notes:
- Modified extension project and source code to support both PHP 5.2 and PHP 5.3
- Added missing phpinfo to both extensions
Modified: sandbox/adsk/2.2gp/Web/src/PhpApi/PhpApi.vcproj
--- sandbox/adsk/2.2gp/Web/src/PhpApi/PhpApi.vcproj 2010-03-03 14:35:05 UTC (rev 4625)
+++ sandbox/adsk/2.2gp/Web/src/PhpApi/PhpApi.vcproj 2010-03-03 23:35:33 UTC (rev 4626)
@@ -46,7 +46,7 @@
Name="VCCLCompilerTool"
Optimization="0"
AdditionalIncludeDirectories="..\HttpHandler;..\WebApp;..\WebSupport;..\..\..\Common\MdfModel;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Common\PlatformBase;..\..\..\Common\MapGuideCommon;..\..\..\Oem\ACE\ACE_wrappers;..\..\..\Oem\dbxml-2.3.10\xerces-c-src\src;..\..\..\Oem\php;..\..\..\Oem\php\main;..\..\..\Oem\php\TSRM;..\..\..\Oem\php\Zend;..\..\..\Oem\php\ext\w32api"
- PreprocessorDefinitions="WIN32;_DEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP"
+ PreprocessorDefinitions="WIN32;_DEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_USE_32BIT_TIME_T"
MinimalRebuild="true"
ExceptionHandling="2"
BasicRuntimeChecks="3"
@@ -207,7 +207,7 @@
Optimization="2"
- PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP"
+ PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_USE_32BIT_TIME_T"
RuntimeLibrary="2"
WarningLevel="3"
Modified: sandbox/adsk/2.2gp/Web/src/PhpApi/php.i
--- sandbox/adsk/2.2gp/Web/src/PhpApi/php.i 2010-03-03 14:35:05 UTC (rev 4625)
+++ sandbox/adsk/2.2gp/Web/src/PhpApi/php.i 2010-03-03 23:35:33 UTC (rev 4626)
@@ -165,6 +165,11 @@
typedef char* CHAR_PTR_NOCOPY;
+%pragma(php) phpinfo=
+" php_info_print_table_start();\n"\
+" php_info_print_table_row(2, \"MapGuideApi\", \"enabled\");\n"\
+" php_info_print_table_end();"
// Global functions
Modified: sandbox/adsk/2.2gp/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
--- sandbox/adsk/2.2gp/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp 2010-03-03 14:35:05 UTC (rev 4625)
+++ sandbox/adsk/2.2gp/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp 2010-03-03 23:35:33 UTC (rev 4626)
@@ -16,42 +16,31 @@
#pragma once
-/* PHP Extension headers */
-/* include zend win32 config first */
-#ifdef _WIN64
-//#include "zend_config.w64.h" // x64 configuration doesn't exist yet
-#else
-#include "zend_config.w32.h"
-#endif
-/* include standard header */
+/* PHP Extension headers */
#include "php.h"
+#include "ext/standard/info.h"
-#include <windows.h>
#pragma warning(disable: 4996)
#define GETENV GetEnvironmentVariable
#define SETENV SetEnvironmentVariable
-wchar_t g_phpPath[MAX_PATH] = L"";
BOOL PrepareServerPath()
+ wchar_t phpPath[MAX_PATH] = L"";
// Get the location of PHP
HMODULE hModule;
- GetModuleHandleEx(0, L"php5ts.dll", &hModule);
- GetModuleFileName(hModule, g_phpPath, MAX_PATH);
- wcsrchr(g_phpPath, '\\')[0] = '\0';
- FreeLibrary(hModule);
+ hModule = GetModuleHandle(L"php5ts.dll");
+ GetModuleFileName(hModule, phpPath, MAX_PATH);
+ wcsrchr(phpPath, '\\')[0] = '\0';
+// FreeLibrary(hModule); -- DO NOT CALL FreeLibrary() when using GetModuleHandle() as the reference count is not increased
// Prepend to process PATH environment string
- wchar_t srvPath[MAX_PATH] = L"";
- wcscpy(srvPath, g_phpPath);
- wchar_t ePath[1024*4] = {0};
- wcscpy(ePath, srvPath);
+ wchar_t ePath[1024*4] = L"";
+ wcscpy(ePath, phpPath);
wcscat(ePath, L";");
DWORD dw = (DWORD)wcslen(ePath);
return (GETENV(L"PATH", &ePath[dw], sizeof(ePath)-dw) &&
@@ -73,70 +62,42 @@
ZEND_FUNCTION(LoadMgDlls);
/* compiled function list so Zend knows what's in this module */
-zend_function_entry CustomExtModule_functions[] = {
- ZEND_FE(LoadMgDlls, NULL)
+zend_function_entry MapGuideApiEnvConfig_functions[] = {
{NULL, NULL, NULL}
-PHP_MINIT_FUNCTION(CustomExtModule)
+PHP_MINIT_FUNCTION(MapGuideApiEnvConfig)
return SUCCESS;
+PHP_MSHUTDOWN_FUNCTION(MapGuideApiEnvConfig)
+ return SUCCESS;
+PHP_MINFO_FUNCTION(MapGuideApiEnvConfig)
+ php_info_print_table_start();
+ php_info_print_table_row(2, "MapGuideApiEnvConfig", "enabled");
+ php_info_print_table_end();
/* compiled module information */
-zend_module_entry CustomExtModule_module_entry = {
+zend_module_entry MapGuideApiEnvConfig_module_entry = {
STANDARD_MODULE_HEADER,
- "MapGuideApiEnvConfig Module",
- CustomExtModule_functions,
- PHP_MINIT(CustomExtModule), NULL, NULL, NULL, NULL,
- NO_VERSION_YET, STANDARD_MODULE_PROPERTIES
+ "MapGuideApiEnvConfig",
+ MapGuideApiEnvConfig_functions,
+ PHP_MINIT(MapGuideApiEnvConfig),
+ PHP_MSHUTDOWN(MapGuideApiEnvConfig),
+ NULL,
+ NULL,
+ PHP_MINFO(MapGuideApiEnvConfig),
+ NO_VERSION_YET,
+ STANDARD_MODULE_PROPERTIES
/* implement standard "stub" routine to introduce ourselves to Zend */
-ZEND_GET_MODULE(CustomExtModule)
-/* LoadMgDlls function */
-ZEND_FUNCTION(LoadMgDlls)
- long theValue = 0;
- SetDllDirectory(g_phpPath);
- // Load the dependent dlls
-#ifdef _DEBUG
- LoadLibrary(L"ACEd.dll");
- LoadLibrary(L"lib_jsond.dll");
- LoadLibrary(L"MgFoundationd.dll");
- LoadLibrary(L"MgGeometryd.dll");
- LoadLibrary(L"MgHttpHandlerd.dll");
- LoadLibrary(L"MgMapGuideCommond.dll");
- LoadLibrary(L"MgMdfModeld.dll");
- LoadLibrary(L"MgMdfParserd.dll");
- LoadLibrary(L"MgPlatformBased.dll");
- LoadLibrary(L"MgWebAppd.dll");
- LoadLibrary(L"xerces-c_2_7d.dll");
-#else
- LoadLibrary(L"ACE.dll");
- LoadLibrary(L"lib_json.dll");
- LoadLibrary(L"MgFoundation.dll");
- LoadLibrary(L"MgGeometry.dll");
- LoadLibrary(L"MgHttpHandler.dll");
- LoadLibrary(L"MgMapGuideCommon.dll");
- LoadLibrary(L"MgMdfModel.dll");
- LoadLibrary(L"MgMdfParser.dll");
- LoadLibrary(L"MgPlatformBase.dll");
- LoadLibrary(L"MgWebApp.dll");
- LoadLibrary(L"xerces-c_2_7.dll");
-#endif
- RETURN_LONG(theValue);
+ZEND_GET_MODULE(MapGuideApiEnvConfig)
More information about the mapguide-commits
