[mapguide-commits] r4673 - in sandbox/rfc71: mapviewerjava
mapviewernet mapviewerphp viewerfiles
svn_mapguide at osgeo.org
Thu Mar 18 04:06:20 EDT 2010
Author: jng
Date: 2010-03-18 04:06:18 -0400 (Thu, 18 Mar 2010)
New Revision: 4673
sandbox/rfc71/mapviewerjava/getselectedfeatures.jsp
sandbox/rfc71/mapviewernet/getselectedfeatures.aspx
sandbox/rfc71/mapviewerphp/getselectedfeatures.php
sandbox/rfc71/viewerfiles/ajaxmappane.templ
#1053: Changes to support locale
- Pass a LOCALE parameter to getselectedfeatures.xxx
- Format feature reader values using this locale (from LOCALE, or GetDefaultLocale() if there is none). For .net it forbids the use of neutral cultures, so in the case of a neutral culture (eg. "en" instead of "en-US") fall back to CultureInfo.InvariantCulture
- Add JsonEscape() all 3 impls. This calls EscapeForHtml() and does additional escaping of backslashes.
Modified: sandbox/rfc71/mapviewerjava/getselectedfeatures.jsp
--- sandbox/rfc71/mapviewerjava/getselectedfeatures.jsp 2010-03-17 20:00:50 UTC (rev 4672)
+++ sandbox/rfc71/mapviewerjava/getselectedfeatures.jsp 2010-03-18 08:06:18 UTC (rev 4673)
@@ -18,7 +18,8 @@
String mapName;
String sessionId;
- String locale;
+ String localeCode;
+ Locale locale;
class SelectionSet
@@ -143,31 +144,31 @@
switch(propType)
case MgPropertyType.Boolean:
- value = reader.GetBoolean(propName) + "";
+ value = String.format(locale, "%s", reader.GetBoolean(propName));
break;
case MgPropertyType.Byte:
- value = reader.GetByte(propName) + "";
+ value = String.format(locale, "%d", reader.GetByte(propName));
break;
case MgPropertyType.DateTime:
- value = GetDateTimeString(reader.GetDateTime(propName));
+ value = GetDateTimeString(reader.GetDateTime(propName)); // yyyy-mm-dd is enforced regardless of locale
break;
case MgPropertyType.Single:
- value = reader.GetSingle(propName) + "";
+ value = String.format(locale, "%f", reader.GetSingle(propName));
break;
case MgPropertyType.Double:
- value = reader.GetDouble(propName) + "";
+ value = String.format(locale, "%f", reader.GetDouble(propName));
break;
case MgPropertyType.Int16:
- value = reader.GetInt16(propName) + "";
+ value = String.format(locale, "%d", reader.GetInt16(propName));
break;
case MgPropertyType.Int32:
- value = reader.GetInt32(propName) + "";
+ value = String.format(locale, "%d", reader.GetInt32(propName));
break;
case MgPropertyType.Int64:
- value = reader.GetInt64(propName) + "";
+ value = String.format(locale, "%d", reader.GetInt64(propName));
break;
case MgPropertyType.String:
- value = EscapeForHtml(reader.GetString(propName));
+ value = JsonEscape(reader.GetString(propName)); // string content is arbitrary
break;
default: //NOT PRESENTABLE IN PROPERTY GRID
value = "";
@@ -178,7 +179,6 @@
static String GetDateTimeString(MgDateTime value) throws MgException
- //TODO: Use current culture to determine date format?
return value.GetYear() + "-" + value.GetMonth() + "-" + value.GetDay();
@@ -186,13 +186,16 @@
mapName = GetParameter(request, "MAPNAME");
sessionId = GetParameter(request, "SESSION");
- locale = GetParameter(request, "LOCALE");
- if (locale == null || locale.length() == 0)
- locale = GetDefaultLocale();
+ localeCode = GetParameter(request, "LOCALE");
- static String JsonifyError(Exception ex, String locale)
+ String JsonEscape(String str)
+ return EscapeForHtml(str).replace("\\", "\\\\");
+ String JsonifyError(Exception ex)
if (ex == null)
return "";
@@ -209,19 +212,19 @@
String msg = ex.getMessage();
if (msg == null || msg.length() == 0)
- msg = MgLocalizer.GetString("SERVERERROR", locale);
+ msg = MgLocalizer.GetString("SERVERERROR", localeCode);
//Begin response
sb.append("{\"Error\":{");
//Exception message
- sb.append("\"Message\":\"" + msg + "\",");
+ sb.append("\"Message\":\"" + JsonEscape(msg) + "\",");
StringBuffer strace = new StringBuffer();
StackTraceElement[] st = ex.getStackTrace();
for (int i = 0; i < st.length; i++)
strace.append(st[i].getClassName() + "." + st[i].getMethodName() + "(" + st[i].getLineNumber() + ")\\n");
- sb.append("\"StackTrace\":\"" + strace.toString() + "\"");
+ sb.append("\"StackTrace\":\"" + JsonEscape(strace.toString()) + "\"");
//End response
sb.append("}}");
return sb.toString();
@@ -307,9 +310,14 @@
mapName = "";
sessionId = "";
- locale = "en";
+ localeCode = "";
GetParameters(request);
+ if (null == localeCode || localeCode.length() == 0)
+ localeCode = GetDefaultLocale();
+ locale = new Locale(localeCode);
try
@@ -422,12 +430,12 @@
response.addHeader("Content-Type", "application/json");
response.addHeader("X-JSON", "true");
- response.getWriter().write(JsonifyError(ex, locale));
+ response.getWriter().write(JsonifyError(ex));
catch (Exception ex)
\ No newline at end of file
Modified: sandbox/rfc71/mapviewernet/getselectedfeatures.aspx
--- sandbox/rfc71/mapviewernet/getselectedfeatures.aspx 2010-03-17 20:00:50 UTC (rev 4672)
+++ sandbox/rfc71/mapviewernet/getselectedfeatures.aspx 2010-03-18 08:06:18 UTC (rev 4673)
@@ -79,6 +79,8 @@
String mapName;
String sessionId;
+ String locale;
+ CultureInfo culture;
static NameValueCollection GetLayerPropertyMappings(MgResourceService resSvc, MgLayerBase layer)
@@ -103,31 +105,31 @@
switch(propType)
- value = reader.GetBoolean(propName).ToString();
+ value = String.Format(culture, "{0}", reader.GetBoolean(propName));
break;
- value = reader.GetByte(propName).ToString();
+ value = String.Format(culture, "{0:d}", reader.GetByte(propName));
break;
break;
- value = reader.GetSingle(propName).ToString();
+ value = String.Format(culture, "{0:f}", reader.GetSingle(propName));
break;
- value = reader.GetDouble(propName).ToString();
+ value = String.Format(culture, "{0:f}", reader.GetDouble(propName));
break;
- value = reader.GetInt16(propName).ToString();
+ value = String.Format(culture, "{0:d}", reader.GetInt16(propName));
break;
- value = reader.GetInt32(propName).ToString();
+ value = String.Format(culture, "{0:d}", reader.GetInt32(propName));
break;
- value = reader.GetInt64(propName).ToString();
+ value = String.Format(culture, "{0:d}", reader.GetInt64(propName));
break;
+ value = JsonEscape(reader.GetString(propName)); //String content is arbitrary
break;
value = "";
@@ -138,7 +140,6 @@
return String.Format("{0}-{1}-{2}", value.Year, value.Month, value.Day);
@@ -146,6 +147,7 @@
mapName = param["MAPNAME"];
sessionId = param["SESSION"];
+ locale = param["LOCALE"];
void GetRequestParameters()
@@ -156,18 +158,15 @@
GetParameters(Request.QueryString);
- static String JsonifyError(Exception ex)
- "Error" : {
- "Message" : <exception-message>,
- "StackTrace" : <exception-stack-trace>
- return String.Format("{\"Error\":{\"Message\":\"{0}\",\"StackTrace\":\"{1}\"}}", ex.Message, ex.StackTrace);
+ return EscapeForHtml(str).Replace("\\", "\\\\");
+ return "{\"Error\":{\"Message\":\"" + JsonEscape(ex.Message) + "\",\"StackTrace\":\"" + JsonEscape(ex.StackTrace) + "\"}}";
static String GetJson(SelectionSet set)
@@ -251,8 +250,20 @@
mapName = "";
sessionId = "";
+ locale = "";
GetRequestParameters();
+ if (String.IsNullOrEmpty(locale))
+ locale = GetDefaultLocale();
+ culture = CultureInfo.GetCultureInfo(locale);
+ //HACK: The default locale (en) resolves to a neutral culture, .net forbids the use of
+ //neutral cultures for formatting purposes, so default to InvariantCulture if the resolved
+ //culture is not neutral.
+ if (culture.IsNeutralCulture)
+ culture = CultureInfo.InvariantCulture; //We need a non-neutral culture
try
Modified: sandbox/rfc71/mapviewerphp/getselectedfeatures.php
--- sandbox/rfc71/mapviewerphp/getselectedfeatures.php 2010-03-17 20:00:50 UTC (rev 4672)
+++ sandbox/rfc71/mapviewerphp/getselectedfeatures.php 2010-03-18 08:06:18 UTC (rev 4673)
@@ -100,10 +100,14 @@
$mapName = "";
$sessionId = "";
- //$selText = "";
- $queryInfo = false;
+ $locale = "";
+ if (null == $locale || strlen($locale) == 0)
+ $locale = GetDefaultLocale();
+ setlocale(LC_ALL, $locale);
try
@@ -127,9 +131,6 @@
// Create the selection set
$selection = new MgSelection($map);
$selection->Open($resourceSrvc, $mapName);
- //if($selText != "") {
- // $selection->FromXml($selText);
$layers = $selection->GetLayers();
if($layers != null)
@@ -344,39 +345,39 @@
break;
case MgPropertyType::Boolean:
$tStr = "Boolean";
- $val = $fr->GetBoolean($propName);
+ $val = sprintf("%s", $fr->GetBoolean($propName));
break;
case MgPropertyType::Byte:
$tStr = "Byte";
- $val = $fr->GetByte($propName);
+ $val = sprintf("%d", $fr->GetByte($propName));
break;
case MgPropertyType::DateTime:
$tStr = "DateTime";
- $val = printDateTime($fr->GetDateTime($propName));
+ $val = printDateTime($fr->GetDateTime($propName)); // yyyy-mm-dd is enforced regardless of locale
break;
case MgPropertyType::Single:
$tStr = "Single";
- $val = $fr->GetSingle($propName);
+ $val = sprintf("%f", $fr->GetSingle($propName));
break;
case MgPropertyType::Double:
$tStr = "Double";
- $val = $fr->GetDouble($propName);
+ $val = sprintf("%f", $fr->GetDouble($propName));
break;
case MgPropertyType::Int16:
$tStr = "Int16";
- $val = $fr->GetInt16($propName);
+ $val = sprintf("%d", $fr->GetInt16($propName));
break;
case MgPropertyType::Int32:
$tStr = "Int32";
- $val = $fr->GetInt32($propName);
+ $val = sprintf("%d", $fr->GetInt32($propName));
break;
case MgPropertyType::Int64:
$tStr = "Int64";
- $val = $fr->GetInt64($propName);
+ $val = sprintf("%d", $fr->GetInt64($propName));
break;
case MgPropertyType::String:
$tStr = "String";
- $val = addslashes($fr->GetString($propName));
+ $val = JsonEscape($fr->GetString($propName)); //String content is arbitrary
break;
case MgPropertyType::Blob: //NOT PRESENTABLE IN PROPERTY GRID
$tStr = "BLOB";
@@ -430,13 +431,18 @@
function GetParameters($params)
- global $mapName, $sessionId, $selText, $queryInfo;
+ global $mapName, $sessionId, $locale;
$mapName = $params['MAPNAME'];
$sessionId = $params['SESSION'];
- //$selText = UnescapeMagicQuotes($params['selection']);
+ $locale = $params['LOCALE'];
+function JsonEscape($str)
+ return str_replace("\\", "\\\\", EscapeForHtml($str));
function JsonifyError($msg, $st)
@@ -447,7 +453,9 @@
- $json = "{\"Error\":{\"Message\":\"$msg\",\"StackTrace\":\"$st\"}}";
+ $emsg = JsonEscape($msg);
+ $est = JsonEscape($st);
+ $json = "{\"Error\":{\"Message\":\"$emsg\",\"StackTrace\":\"$est\"}}";
return $json;
Modified: sandbox/rfc71/viewerfiles/ajaxmappane.templ
--- sandbox/rfc71/viewerfiles/ajaxmappane.templ 2010-03-17 20:00:50 UTC (rev 4672)
+++ sandbox/rfc71/viewerfiles/ajaxmappane.templ 2010-03-18 08:06:18 UTC (rev 4673)
@@ -3830,7 +3830,7 @@
var mapname = GetMapName();
var session = GetSessionId();
var selRequest = CreateRequestHandler();
- var reqParams = "MAPNAME="+mapname+"&SESSION="+session+"&SEQ="+Math.random();
+ var reqParams = "MAPNAME="+mapname+"&SESSION="+session+"&LOCALE="+locale+"&SEQ="+Math.random();
selRequest.open("POST", featureRequestUrl, false);
selRequest.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
selRequest.send(reqParams);
More information about the mapguide-commits
