[mapguide-commits] r4680 - sandbox/adsk/2.2gp/UnitTest/WebTier/Php
svn_mapguide at osgeo.org
Mon Mar 22 12:49:37 EDT 2010
Author: brucedechant
Date: 2010-03-22 12:49:37 -0400 (Mon, 22 Mar 2010)
New Revision: 4680
sandbox/adsk/2.2gp/UnitTest/WebTier/Php/HttpRequest.php
sandbox/adsk/2.2gp/UnitTest/WebTier/Php/RunTests.php
Web tier unit test update
Notes:
- Remove the Curl call that was causing the POST request to be changed into a GET request.
Note: The Curl documentation says that this shouldn't happen, but the new Curl extension with PHP 5.3 is changing it.
- Re-enable HTTP tests now that the Curl issue has been resolved with "POST" requests
Modified: sandbox/adsk/2.2gp/UnitTest/WebTier/Php/HttpRequest.php
--- sandbox/adsk/2.2gp/UnitTest/WebTier/Php/HttpRequest.php 2010-03-22 13:39:15 UTC (rev 4679)
+++ sandbox/adsk/2.2gp/UnitTest/WebTier/Php/HttpRequest.php 2010-03-22 16:49:37 UTC (rev 4680)
@@ -60,7 +60,6 @@
curl_setopt($this->ch, CURLOPT_URL, $httpRequest);
curl_setopt($this->ch, CURLOPT_HEADER, true);
- curl_setopt($this->ch, CURLOPT_NOBODY, false);
curl_setopt($this->ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($this->ch, CURLOPT_USERPWD, "Administrator:admin");
Modified: sandbox/adsk/2.2gp/UnitTest/WebTier/Php/RunTests.php
--- sandbox/adsk/2.2gp/UnitTest/WebTier/Php/RunTests.php 2010-03-22 13:39:15 UTC (rev 4679)
+++ sandbox/adsk/2.2gp/UnitTest/WebTier/Php/RunTests.php 2010-03-22 16:49:37 UTC (rev 4680)
@@ -53,19 +53,19 @@
$testsFailed += ExecuteTest("Api", "../../TestData/ResourceService/ResourceServiceTest.dump", $testsRun, $file, $isEnterprise);
-// $testsFailed += ExecuteTest("Http", "../../TestData/ResourceService/ResourceServiceTest.dump", $testsRun, $file, $isEnterprise);
+ $testsFailed += ExecuteTest("Http", "../../TestData/ResourceService/ResourceServiceTest.dump", $testsRun, $file, $isEnterprise);
$testsFailed += ExecuteTest("Api", "../../TestData/DrawingService/DrawingServiceTest.dump", $testsRun, $file, $isEnterprise);
-// $testsFailed += ExecuteTest("Http", "../../TestData/DrawingService/DrawingServiceTest.dump", $testsRun, $file, $isEnterprise);
+ $testsFailed += ExecuteTest("Http", "../../TestData/DrawingService/DrawingServiceTest.dump", $testsRun, $file, $isEnterprise);
$testsFailed += ExecuteTest("Api", "../../TestData/FeatureService/FeatureServiceTest.dump", $testsRun, $file, $isEnterprise);
-// $testsFailed += ExecuteTest("Http", "../../TestData/FeatureService/FeatureServiceTest.dump", $testsRun, $file, $isEnterprise);
+ $testsFailed += ExecuteTest("Http", "../../TestData/FeatureService/FeatureServiceTest.dump", $testsRun, $file, $isEnterprise);
$testsFailed += ExecuteTest("Api", "../../TestData/SiteService/SiteServiceTest.dump", $testsRun, $file, $isEnterprise);
-// $testsFailed += ExecuteTest("Http", "../../TestData/SiteService/SiteServiceTest.dump", $testsRun, $file, $isEnterprise);
+ $testsFailed += ExecuteTest("Http", "../../TestData/SiteService/SiteServiceTest.dump", $testsRun, $file, $isEnterprise);
$testsFailed += ExecuteTest("Api", "../../TestData/MappingService/MappingServiceTest.dump", $testsRun, $file, $isEnterprise);
-// $testsFailed += ExecuteTest("Http", "../../TestData/MappingService/MappingServiceTest.dump", $testsRun, $file, $isEnterprise);
+ $testsFailed += ExecuteTest("Http", "../../TestData/MappingService/MappingServiceTest.dump", $testsRun, $file, $isEnterprise);
$testsFailed += ExecuteTest("Api", "../../TestData/ServerAdmin/ServerAdminTest.dump", $testsRun, $file, $isEnterprise);
More information about the mapguide-commits
