[mapguide-commits] r4694 - in trunk/Installer: .
	Custom/apache_actions Installers/MapGuide
	Installers/MapGuide/Lang Libraries/MapGuide Web Extensions
	Libraries/MapGuide Web Extensions/Lang Support/Web/Apache2/conf
    svn_mapguide at osgeo.org
    Thu Mar 25 08:33:32 EDT 2010
Author: jng
Date: 2010-03-25 08:33:29 -0400 (Thu, 25 Mar 2010)
New Revision: 4694
   trunk/Installer/Custom/apache_actions/apache_actions.cpp
   trunk/Installer/Custom/apache_actions/apache_actions.vcproj
   trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl
   trunk/Installer/Installers/MapGuide/Lang/MapGuide_es-ES.wxl
   trunk/Installer/Installers/MapGuide/MapGuide.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl
   trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_es-ES.wxl
   trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs
   trunk/Installer/Support/Web/Apache2/conf/httpd.conf
   trunk/Installer/Support/Web/Apache2/conf/tomcat.conf
   trunk/Installer/build.bat
This submission includes the following changes that should make side-by-side installation with previous versions of MGOS easier:
- Add viewer API shortcut to installer
- Default start menu folder is now "MapGuide Open Source 2.2"
- build.bat now defines a custom registry root, that is passed as the wix variable: MgRegKey
- Make the virtual directory name configurable from the installer. This completes ticket #1297
   - Add the %MG_VIRTUAL_DIR% placeholder to httpd.conf and tomcat.conf
- Make MgHttpHandler.dll load first in tomcat.conf, this allowed the 2.2 Apache service to start and co-exist with a 2.1 Apache service.
- Fix some IIS virtual directories which were hardcoded to "mapguide" and not using the VIRTUALDIR property
- Make the product ID an auto-generated value, instead of a static GUID. This allows this installer to be installed on a machine which already has an existing MGOS 2.1 installation. Otherwise, MSI will assume the product is already installed.
Modified: trunk/Installer/Custom/apache_actions/apache_actions.cpp
--- trunk/Installer/Custom/apache_actions/apache_actions.cpp	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Custom/apache_actions/apache_actions.cpp	2010-03-25 12:33:29 UTC (rev 4694)
@@ -248,6 +248,7 @@
 	CHAR    szApacheDir[MAX_BUFFER];
 	CHAR    szPhpDir[MAX_BUFFER];
 	CHAR    szWebDir[MAX_BUFFER];
+	CHAR	szVirtualDir[MAX_BUFFER];
 	CHAR    szApiType[MAX_BUFFER];
 	CHAR    szServerPort[MAX_BUFFER];
 	CHAR    szFile[MAX_BUFFER];
@@ -305,7 +306,13 @@
 		if(tok)
 			strcpy(szWebDir, tok);
+			tok = strtok(NULL, ";");
+		//[VIRTUALDIR]
+		if(tok)
+			strcpy(szVirtualDir, tok);
 	bJava = ( strcmp(szApiType,"JAVA") == 0 );
@@ -363,6 +370,11 @@
 		strcpy(szReplace, szApacheDir);
 		csBuff.Replace(szFind, szReplace);
+		// Replace %MG_VIRTUAL_DIR%
+		strcpy(szFind, "%MG_VIRTUAL_DIR%");
+		strcpy(szReplace, szVirtualDir);
+		csBuff.Replace(szFind, szReplace);
 		// If java, then include the tomcat configuration
 		strcpy(szFind, "%MG_INCLUDE_TOMCAT%");
 		csBuff.Replace(szFind, bJava ? "Include conf/tomcat.conf" : "#Uncomment to enable the Java API\n#Include conf/tomcat.conf");
@@ -388,6 +400,7 @@
 		cfOutFile.Close();
+	//Check if the tomcat.conf file was included in httpd.conf, if so we need to do placeholder substitution there too.
 	strcpy(szFile, szApacheDir);
 	strcat(szFile, "\\conf\\tomcat.conf");
@@ -410,6 +423,11 @@
 		csBuff.Replace(szFind,szReplace);
 		CFile cfOutFile(szFile, CFile::modeWrite);
 		// Write and modify the contents.
Modified: trunk/Installer/Custom/apache_actions/apache_actions.vcproj
--- trunk/Installer/Custom/apache_actions/apache_actions.vcproj	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Custom/apache_actions/apache_actions.vcproj	2010-03-25 12:33:29 UTC (rev 4694)
@@ -49,7 +49,7 @@
 				Name="VCCLCompilerTool"
 				Optimization="2"
 				InlineFunctionExpansion="1"
-				PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;APACHE_ACTIONS_EXPORTS"
+				PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;APACHE_ACTIONS_EXPORTS;_CRT_SECURE_NO_WARNINGS"
 				StringPooling="true"
 				RuntimeLibrary="0"
 				EnableFunctionLevelLinking="true"
Modified: trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl
--- trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Installers/MapGuide/Lang/MapGuide_en-US.wxl	2010-03-25 12:33:29 UTC (rev 4694)
@@ -41,12 +41,14 @@
     <String Id="ApacheConfigDlg_Title">Bundled Configuration Settings</String>
     <String Id="ApacheConfigDlg_Description">Set up the development environment</String>
-    <String Id="ApacheConfigDlg_PortNo">Web Server Port Number:</String>
-    <String Id="ApacheConfigDlg_DevEnv">Development Environment:</String>
+    <String Id="ApacheConfigDlg_PortNo">Web Server Port Number</String>
+    <String Id="ApacheConfigDlg_DevEnv">Development Environment</String>
+    <String Id="ApacheConfigDlg_VDirName">Virtual Directory Name</String>
     <String Id="IISLangConfigDlg_Title">IIS Configuration Settings</String>
     <String Id="IISLangConfigDlg_Description">Set up the development environment</String>
-    <String Id="IISLangConfigDlg_DevEnv">Development Environment:</String>
+    <String Id="IISLangConfigDlg_DevEnv">Development Environment</String>
+    <String Id="IISLangConfigDlg_VDirName">Virtual Directory Name</String>
     <String Id="IIS6ConfigDlg_Title">IIS 6.0 Configuration</String>
     <String Id="IIS6ConfigDlg_Description">Configure IIS 6.0 Settings</String>
Modified: trunk/Installer/Installers/MapGuide/Lang/MapGuide_es-ES.wxl
--- trunk/Installer/Installers/MapGuide/Lang/MapGuide_es-ES.wxl	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Installers/MapGuide/Lang/MapGuide_es-ES.wxl	2010-03-25 12:33:29 UTC (rev 4694)
@@ -41,12 +41,14 @@
     <String Id="ApacheConfigDlg_Title">Paquete de ajustes de configuración</String>
     <String Id="ApacheConfigDlg_Description">Configure el entorno de desarrollo</String>
-    <String Id="ApacheConfigDlg_PortNo">número de puerto del servidor web:</String>
-    <String Id="ApacheConfigDlg_DevEnv">Entorno de desarrollo:</String>
+    <String Id="ApacheConfigDlg_PortNo">número de puerto del servidor web</String>
+    <String Id="ApacheConfigDlg_DevEnv">Entorno de desarrollo</String>
+    <String Id="ApacheConfigDlg_VDirName">Nombre del directorio virtual</String>
     <String Id="IISLangConfigDlg_Title">Ajustes de configuración de IIS</String>
     <String Id="IISLangConfigDlg_Description">Configure el entorno de desarrollo</String>
-    <String Id="IISLangConfigDlg_DevEnv">Entorno de desarrollo:</String>
+    <String Id="IISLangConfigDlg_DevEnv">Entorno de desarrollo</String>
+    <String Id="IISLangConfigDlg_VDirName">Nombre del directorio virtual</String>
     <String Id="IIS6ConfigDlg_Title">Configuración de IIS 6.0</String>
     <String Id="IIS6ConfigDlg_Description">Configurar IIS 6.0 Configuración</String>
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs	2010-03-25 12:33:29 UTC (rev 4694)
@@ -5,7 +5,7 @@
   xmlns:netfx="http://schemas.microsoft.com/wix/NetFxExtension"
     <Product
-           Id="47B770BA-1591-415D-A7AE-33D4C522FCEA"
+           Id="*"
            UpgradeCode="5D9A7D8D-485E-43E0-A4C8-3582E4D80051"
            Name="$(var.MgTitle)"
            Version="$(var.MgVersion)"
@@ -275,16 +275,17 @@
-                    Web Server Port Number:
-                    _______________________
+                    Web Server Port Number:  _______________________
+                    Virtual Directory Name:  _______________________
                     ( ) PHP
                     ( ) Java
                 <Control Id="LblServerPort" Type="Text" Text="{\WixUI_Font_Title}!(loc.ApacheConfigDlg_PortNo)" X="20" Y="60" Width="120" Height="15" />
-                <Control Id="TxtServerPort" Type="Edit" Property="APACHE_PORT" X="30" Y="80" Width="120" Height="15" />
+                <Control Id="TxtServerPort" Type="Edit" Property="APACHE_PORT" X="150" Y="60" Width="120" Height="15" />
+                <Control Id="LblVdirName" Type="Text" Text="{\WixUI_Font_Title}!(loc.ApacheConfigDlg_VDirName)" X="20" Y="80" Width="120" Height="15" />
+                <Control Id="TxtVdirName" Type="Edit" Property="VIRTUALDIR" X="150" Y="80" Width="120" Height="15" />
                 <Control Id="LblDevEnv" Type="Text" Text="{\WixUI_Font_Title}!(loc.ApacheConfigDlg_DevEnv)" X="20" Y="110" Width="120" Height="15" />
                 <Control Id="RdApacheApiType" Property="APACHE_API_TYPE" Type="RadioButtonGroup" X="20" Y="130" Height="100" Width="290">
                     <RadioButtonGroup Property="APACHE_API_TYPE">
@@ -305,13 +306,16 @@
                 <Control Id="BannerBitmap" Type="Bitmap" X="0" Y="0" Width="370" Height="44" TabSkip="no" Text="!(loc.InstallDirDlgBannerBitmap)" />
                 <Control Id="BannerLine" Type="Line" X="0" Y="44" Width="370" Height="0" />
-                Set up the development environment
+                Virtual Directory Name:  __________________________________
+                Development environment:
                 ( ) PHP
                 ( ) .NET
-                <Control Id="LblDevEnv" Type="Text" Text="{\WixUI_Font_Title}!(loc.IISLangConfigDlg_DevEnv)" X="20" Y="60" Width="120" Height="15" />
-                <Control Id="RdIIsApiType" Property="IIS_API_TYPE" Type="RadioButtonGroup" Text="{\WixUI_Font_Title}!(loc.IISLangConfigDlg_DevEnv)" X="30" Y="70" Height="100" Width="290">
+                <Control Id="LblVDirName" Type="Text" Text="{\WixUI_Font_Title}!(loc.IISLangConfigDlg_VDirName)" X="20" Y="60" Width="120" Height="15" />
+                <Control Id="TxtVDirName" Type="Edit" Property="VIRTUALDIR" X="150" Y="60" Width="120" Height="15" />
+                <Control Id="LblDevEnv" Type="Text" Text="{\WixUI_Font_Title}!(loc.IISLangConfigDlg_DevEnv)" X="20" Y="80" Width="120" Height="15" />
+                <Control Id="RdIIsApiType" Property="IIS_API_TYPE" Type="RadioButtonGroup" Text="{\WixUI_Font_Title}!(loc.IISLangConfigDlg_DevEnv)" X="30" Y="90" Height="100" Width="290">
                     <RadioButtonGroup Property="IIS_API_TYPE">
                         <RadioButton Text="PHP" Value="PHP" X="25" Y="10" Width="200" Height="45" />
                         <RadioButton Text=".NET" Value="DOTNET" X="25" Y="40" Width="200" Height="45" />
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs	2010-03-25 12:33:29 UTC (rev 4694)
@@ -2,14 +2,10 @@
 <Wix xmlns="http://schemas.microsoft.com/wix/2006/wi">
 	<Fragment>
         <Binary Id="ApacheActions" SourceFile="..\..\Custom\bin\apache_actions.dll" />
-        <CustomAction Id="UpdateApacheConfig.SetValues" Property="UpdateApacheConfig" Value="[WEBEXTENSIONSLOCATION];[APACHE_API_TYPE];[APACHE_PORT];[APACHELOCATION];[PHPLOCATION];[WEBROOTLOCATION]" />
+        <CustomAction Id="UpdateApacheConfig.SetValues" Property="UpdateApacheConfig" Value="[WEBEXTENSIONSLOCATION];[APACHE_API_TYPE];[APACHE_PORT];[APACHELOCATION];[PHPLOCATION];[WEBROOTLOCATION];[VIRTUALDIR]" />
         <CustomAction Id="UpdateApacheConfig" Return="check" BinaryKey="ApacheActions" Execute="deferred"  DllEntry="UpdateApacheConfig" />
         <CustomAction Id="UpdatePhpIni.SetValues" Property="UpdatePhpIni" Value='[PHPLOCATION];2;[WEBTEMPLOCATION]' />
         <CustomAction Id="UpdatePhpIni" Return="check" BinaryKey="ApacheActions" Execute="deferred" DllEntry="UpdatePhpIni" />
-        <CustomAction Id="GetApacheDir.SetValues" Property="GetApacheDir" Value="[APACHE_VERSION]" />
-        <CustomAction Id="GetApacheDir" Return="check" BinaryKey="ApacheActions" Execute="deferred" DllEntry="GetApacheDir" />
         <CustomAction Id="RemoveApacheServiceCA" Execute="immediate" Return="ignore" FileKey="file_APACHEFILES_13" ExeCommand="-k uninstall -n "ApacheMapGuide[MG_VERSION_MAJOR_MINOR]"" />
         <CustomAction Id="InstallApacheServiceCA" Execute="deferred" Return="ignore" FileKey="file_APACHEFILES_13" ExeCommand="-k install -n "ApacheMapGuide[MG_VERSION_MAJOR_MINOR]"" />
 	</Fragment>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs	2010-03-25 12:33:29 UTC (rev 4694)
@@ -67,7 +67,7 @@
             <Component Id="IIS5PhpViewerComponent" Guid="1E56B410-1305-4406-BDFB-1252E159B746" Directory="WEBEXTENSIONSLOCATION">
                 <Condition>MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR="#5"</Condition>
                 <CreateFolder />
-                <iis:WebVirtualDir Id="IIS5PhpViewerVDir" Alias="mapguide/mapviewerajax" Directory="dir_mapviewerphp_0" WebSite="IISDefaultWebSite">
+                <iis:WebVirtualDir Id="IIS5PhpViewerVDir" Alias="[VIRTUALDIR]/mapviewerajax" Directory="dir_mapviewerphp_0" WebSite="IISDefaultWebSite">
                     <iis:WebDirProperties Id="IIS5PhpViewerDocument" DefaultDocuments="ajaxviewer.php" AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no"/>
                 </iis:WebVirtualDir>
             </Component>
@@ -76,7 +76,7 @@
             <Component Id="IIS5DotNetViewerComponent" Guid="EC460125-D5D4-4596-BD03-B8D920F02E7F" Directory="WEBEXTENSIONSLOCATION">
                 <Condition>NETFRAMEWORK20 AND MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR="#5"</Condition>
                 <CreateFolder />
-                <iis:WebVirtualDir Id="IIS5DotNetViewerVDir" Alias="mapguide/mapviewerajax" Directory="dir_mapviewernet_0" WebSite="IISDefaultWebSite">
+                <iis:WebVirtualDir Id="IIS5DotNetViewerVDir" Alias="[VIRTUALDIR]/mapviewerajax" Directory="dir_mapviewernet_0" WebSite="IISDefaultWebSite">
                     <iis:WebDirProperties Id="IIS5DotNetViewerDocument" DefaultDocuments="ajaxviewer.aspx"  AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no" />
                     <iis:WebApplication Id="IIS5MapViewerWebApp" Name="mapviewerajax" />
@@ -125,7 +125,7 @@
             <Component Id="IIS6PhpViewerComponent" Guid="6CDC8E73-B6B1-4A2E-98E3-953C399D1D0D" Directory="WEBEXTENSIONSLOCATION">
                 <Condition>MGWEB_CONFIG="IIS" AND IIS_API_TYPE="PHP" AND IISVERSIONMAJOR="#6"</Condition>
                 <CreateFolder />
-                <iis:WebVirtualDir Id="IIS6PhpViewerVDir" Alias="mapguide/mapviewerajax" Directory="dir_mapviewerphp_0" WebSite="IISDefaultWebSite">
+                <iis:WebVirtualDir Id="IIS6PhpViewerVDir" Alias="[VIRTUALDIR]/mapviewerajax" Directory="dir_mapviewerphp_0" WebSite="IISDefaultWebSite">
                     <iis:WebDirProperties Id="IIS6PhpViewerDocument" DefaultDocuments="ajaxviewer.php"  AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no" />
             </Component>
@@ -134,7 +134,7 @@
             <Component Id="IIS6DotNetViewerComponent" Guid="357E1C68-9E29-474F-A783-6F8FD8BCEAB4" Directory="WEBEXTENSIONSLOCATION">
                 <Condition>NETFRAMEWORK20 AND MGWEB_CONFIG="IIS" AND IIS_API_TYPE="DOTNET" AND IISVERSIONMAJOR="#6"</Condition>
                 <CreateFolder />
-                <iis:WebVirtualDir Id="IIS6DotNetViewerVDir" Alias="mapguide/mapviewerajax" Directory="dir_mapviewernet_0" WebSite="IISDefaultWebSite">
+                <iis:WebVirtualDir Id="IIS6DotNetViewerVDir" Alias="[VIRTUALDIR]/mapviewerajax" Directory="dir_mapviewernet_0" WebSite="IISDefaultWebSite">
                     <iis:WebDirProperties Id="IIS6DotNetViewerDocument" DefaultDocuments="ajaxviewer.aspx"  AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no" />
                     <iis:WebApplication Id="IIS6MapViewerWebApp" Name="mapviewerajax" WebAppPool="IIS6MapGuideAppPool" />
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl
--- trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_en-US.wxl	2010-03-25 12:33:29 UTC (rev 4694)
@@ -37,7 +37,8 @@
     <String Id="WebTempFeature">Temp Directory</String>
     <String Id="WebTempFeature_Description">You may choose a location where MapGuide will store temporary files.</String>
-  <String Id="Shortcut_WebAPI">Web API Documentation</String>
+    <String Id="Shortcut_WebAPI">Web API Documentation</String>
+    <String Id="Shortcut_ViewerAPI">Viewer API Documentation</String>
     <String Id="Shortcut_SiteAdmin">MapGuide Site Administrator</String>
     <String Id="Shortcut_MapAgent">MapAgent Test Pages</String>
     <String Id="Shortcut_GetMaestro">Get MapGuide Maestro</String>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_es-ES.wxl
--- trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_es-ES.wxl	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Lang/MapGuideWebExtensions_es-ES.wxl	2010-03-25 12:33:29 UTC (rev 4694)
@@ -38,6 +38,7 @@
     <String Id="WebTempFeature_Description">Usted puede elegir un lugar donde MapGuide almacenará los archivos temporales</String>
     <String Id="Shortcut_WebAPI">Web de documentación de la API</String>
+    <String Id="Shortcut_ViewerAPI">Visor de Documentación de la API</String>
     <String Id="Shortcut_SiteAdmin">MapGuide administrador del sitio</String>
     <String Id="Shortcut_MapAgent">MapAgent Páginas de prueba</String>
     <String Id="Shortcut_GetMaestro">Obtener MapGuide Maestro</String>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/MapGuideWebExtensions.wxs	2010-03-25 12:33:29 UTC (rev 4694)
@@ -145,6 +145,8 @@
                 <ComponentGroupRef Id="group_HELPFILES" />
                 <ComponentRef Id="ApacheWebApiShortcutComponent"/>
                 <ComponentRef Id="IISWebApiShortcutComponent"/>
+                <ComponentRef Id="ApacheViewerApiShortcutComponent"/>
+                <ComponentRef Id="IISViewerApiShortcutComponent"/>
             </Feature>
             <Feature Id="WebExtMapViewerFeature" Title="!(loc.WebExtMapViewerFeature)" Display="hidden" Level="1" Description="!(loc.WebExtMapViewerFeature_Description)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local" >
                 <ComponentGroupRef Id="group_MAPVIEWERFILES"/>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Shortcuts.wxs	2010-03-25 12:33:29 UTC (rev 4694)
@@ -3,7 +3,8 @@
      xmlns:util="http://schemas.microsoft.com/wix/UtilExtension">
   <Fragment>
     <DirectoryRef Id="ProgramMenuFolder">
-      <Directory Id="MapGuideOpenSourceMenuLocation" Name="MapGuide Open Source">
+      <!-- HACK: For some reason the MG_VERSION_MAJOR_MINOR property doesn't evaluate, so hardcode it for now -->
+      <Directory Id="MapGuideOpenSourceMenuLocation" Name="MapGuide Open Source 2.2">
         <Component Id="GenericShortcutComponent" Guid="243CE0F3-D6BC-476B-910E-6F34DA54A2E2">
           <CreateFolder />
           <RegistryKey Root="HKCU" Key="$(var.MgRegKey)\GenericShortcut">
@@ -20,7 +21,7 @@
           <util:InternetShortcut Id="ApacheWebApi"
                                  Directory="MapGuideOpenSourceMenuLocation"
                                  Name="!(loc.Shortcut_WebAPI)"
-                                 Target="http://localhost:[APACHE_PORT]/mapguide/help/index.htm" />
+                                 Target="http://localhost:[APACHE_PORT]/[VIRTUALDIR]/help/webapi/index.htm" />
           <RegistryKey Root="HKCU" Key="$(var.MgRegKey)\ApacheWebApiShortcut">
             <RegistryValue
                     Value="Installed"
@@ -28,16 +29,30 @@
                     KeyPath="yes" />
           </RegistryKey>
         </Component>
+        <Component Id="ApacheViewerApiShortcutComponent" Guid="4AABF916-33FC-440D-9D6F-8CE95F2ADE7A">
+            <Condition>MGWEB_CONFIG="APACHE"</Condition>
+            <CreateFolder />
+            <util:InternetShortcut Id="ApacheViewerApi"
+                                   Directory="MapGuideOpenSourceMenuLocation"
+                                   Name="!(loc.Shortcut_ViewerAPI)"
+                                   Target="http://localhost:[APACHE_PORT]/[VIRTUALDIR]/help/viewerapi/index.htm" />
+            <RegistryKey Root="HKCU" Key="$(var.MgRegKey)\ApacheViewerApiShortcut">
+                <RegistryValue
+                        Value="Installed"
+                        Type="string"
+                        KeyPath="yes" />
+            </RegistryKey>
+        </Component>
         <Component Id="WebApacheShortcutComponent" Guid="2EBC8176-07C5-40A9-97F9-C3E83836637E">
           <util:InternetShortcut Id="ApacheSiteAdmin"
                                  Name="!(loc.Shortcut_SiteAdmin)"
-                                 Target="http://localhost:[APACHE_PORT]/mapguide/mapadmin/login.php" />
+                                 Target="http://localhost:[APACHE_PORT]/[VIRTUALDIR]/mapadmin/login.php" />
           <util:InternetShortcut Id="ApacheMapAgent"
                                  Name="!(loc.Shortcut_MapAgent)"
-                                 Target="http://localhost:[APACHE_PORT]/mapguide/mapagent/index.html" />
+                                 Target="http://localhost:[APACHE_PORT]/[VIRTUALDIR]/mapagent/index.html" />
           <util:InternetShortcut Id="ApacheGetMaestro"
                                  Name="!(loc.Shortcut_GetMaestro)"
@@ -55,7 +70,7 @@
           <util:InternetShortcut Id="IISWebApi"
-                                 Target="http://localhost/mapguide/help/index.htm" />
+                                 Target="http://localhost/[VIRTUALDIR]/help/webapi/index.htm" />
           <RegistryKey Root="HKCU" Key="$(var.MgRegKey)\IISWebApiShortcut">
             <RegistryValue
                     Value="Installed"
@@ -63,16 +78,30 @@
                     KeyPath="yes" />
           </RegistryKey>
         </Component>
+          <Component Id="IISViewerApiShortcutComponent" Guid="F2CCA279-4C99-48CE-9F79-7465449E2B33">
+              <Condition>MGWEB_CONFIG="IIS"</Condition>
+              <CreateFolder />
+              <util:InternetShortcut Id="IISViewerApi"
+                                     Target="http://localhost/[VIRTUALDIR]/help/viewerapi/index.htm" />
+              <RegistryKey Root="HKCU" Key="$(var.MgRegKey)\IISViewerApiShortcut">
+                  <RegistryValue
+                          Value="Installed"
+                          Type="string"
+                          KeyPath="yes" />
+              </RegistryKey>
+          </Component>
         <Component Id="WebIISShortcutComponent" Guid="F59A450A-84DE-4E2E-B942-BD416CDEBBF3">
           <util:InternetShortcut Id="IISSiteAdmin"
-                                 Target="http://localhost/mapguide/mapadmin/login.php" />
+                                 Target="http://localhost/[VIRTUALDIR]/mapadmin/login.php" />
           <util:InternetShortcut Id="IISMapAgent"
-                                 Target="http://localhost/mapguide/mapagent/index.html" />
+                                 Target="http://localhost/[VIRTUALDIR]/mapagent/index.html" />
           <util:InternetShortcut Id="IISGetMaestro"
Modified: trunk/Installer/Support/Web/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/Apache2/conf/httpd.conf	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Support/Web/Apache2/conf/httpd.conf	2010-03-25 12:33:29 UTC (rev 4694)
@@ -122,9 +122,9 @@
 LoadFile "%MG_WEB_PHP%php5ts.dll"
 LoadFile "%MG_WEB_PHP%ACE.dll"
+LoadFile "%MG_WEB_PHP%MgHttpHandler.dll"
 LoadFile "%MG_WEB_PHP%MgFoundation.dll"
 LoadFile "%MG_WEB_PHP%MgGeometry.dll"
-LoadFile "%MG_WEB_PHP%MgHttpHandler.dll"
 LoadFile "%MG_WEB_PHP%MgMapGuideCommon.dll"
 LoadFile "%MG_WEB_PHP%MgMdfModel.dll"
 LoadFile "%MG_WEB_PHP%MgMdfParser.dll"
@@ -981,17 +981,17 @@
 # MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for Java API.
-ScriptAlias /mapguide/mapagent/mapagent.fcgi "%MG_WEB_ROOT%mapagent/mapagent.fcgi"
-%MG_PHP_API%AliasMatch ^/mapguide/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
-%MG_PHP_API%AliasMatch ^/mapguide/mapviewerajax/(.*)$ "%MG_WEB_ROOT%mapviewerphp/ajaxviewer.php$1"
-%MG_PHP_API%AliasMatch ^/mapguide/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
-%MG_PHP_API%AliasMatch ^/mapguide/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%mapviewerphp/dwfviewer.php$1"
+ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%mapagent/mapagent.fcgi"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/(.*)$ "%MG_WEB_ROOT%mapviewerphp/ajaxviewer.php$1"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%mapviewerphp/dwfviewer.php$1"
 # MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
-%MG_JAVA_API%Redirect /mapguide/mapviewerajax/ http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp
-%MG_JAVA_API%Redirect /mapguide/mapviewerdwf/ http://localhost:8008/mapguide/mapviewerjava/dwfviewer.jsp
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerajax/ http://localhost:8008/%MG_VIRTUAL_DIR%/mapviewerjava/ajaxviewer.jsp
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerdwf/ http://localhost:8008/%MG_VIRTUAL_DIR%/mapviewerjava/dwfviewer.jsp
-Alias /mapguide "%MG_WEB_ROOT%"
+Alias /%MG_VIRTUAL_DIR% "%MG_WEB_ROOT%"
 <Directory "%MG_WEB_ROOT%">
   AllowOverride All
   Options All -Indexes
Modified: trunk/Installer/Support/Web/Apache2/conf/tomcat.conf
--- trunk/Installer/Support/Web/Apache2/conf/tomcat.conf	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/Support/Web/Apache2/conf/tomcat.conf	2010-03-25 12:33:29 UTC (rev 4694)
@@ -18,4 +18,4 @@
 # JkRequestLogFormat set the request format
 JkRequestLogFormat     "%w %V %T"
 # Send everything for context /examples to worker named worker1 (ajp13)
-JkMount  /mapguide/mapviewerjava/* worker1
\ No newline at end of file
+JkMount  /%MG_VIRTUAL_DIR%/mapviewerjava/* worker1
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat	2010-03-25 12:23:55 UTC (rev 4693)
+++ trunk/Installer/build.bat	2010-03-25 12:33:29 UTC (rev 4694)
@@ -43,9 +43,11 @@
 SET TYPEACTION=build
 SET TYPEBUILD=Release
 SET CULTURE=en-US
-SET INSTALLER_NAME=MapGuideOpenSource-2.2.0-Trunk-%CULTURE%-%TYPEBUILD%
-SET INSTALLER_VERSION=2.2.0.0
+SET INSTALLER_VERSION_MAJOR_MINOR_REV=2.2.0
+SET INSTALLER_NAME=MapGuideOpenSource-%INSTALLER_VERSION_MAJOR_MINOR_REV%-Trunk-%CULTURE%-%TYPEBUILD%
+SET INSTALLER_VERSION=%INSTALLER_VERSION_MAJOR_MINOR_REV%.0
 SET INSTALLER_TITLE="MapGuide Open Source 2.2 Trunk (%TYPEBUILD%)"
+SET MG_REG_KEY=Software\OSGeo\MapGuide\%INSTALLER_VERSION_MAJOR_MINOR_REV%
 SET MG_SOURCE=%CD%\..\MgDev\%TYPEBUILD%
 SET MG_SOURCE_INC=
 rem Set to NO to build installers quicker (at the expense of file size)
@@ -176,6 +178,7 @@
 echo Installer Output Directory: %INSTALLER_OUTPUT%
 echo MG Source Directory: %MG_SOURCE%
 echo Locale: %CULTURE%
+echo Registry Root: %MG_REG_KEY%
 echo ===================================================
 if "%TYPEACTION%"=="build" goto build
@@ -394,7 +397,7 @@
 :build
 echo [build]: Installer
-SET RUN_BUILD=%MSBUILD% /p:OutputName=%INSTALLER_NAME%;MgCulture=%CULTURE%;MgTitle=%INSTALLER_TITLE%;MgVersion=%INSTALLER_VERSION%
+SET RUN_BUILD=%MSBUILD% /p:OutputName=%INSTALLER_NAME%;MgCulture=%CULTURE%;MgTitle=%INSTALLER_TITLE%;MgVersion=%INSTALLER_VERSION%;MgRegKey=%MG_REG_KEY%
 if not ""=="%MG_SOURCE_INC%" set RUN_BUILD=%RUN_BUILD%;MgSource=%MG_SOURCE_INC%
 set RUN_BUILD=%RUN_BUILD% Installer.sln
 %RUN_BUILD%
More information about the mapguide-commits
