[mapguide-commits] r4709 - in sandbox/adsk/2.2gp/Doc:
external_topics samples/phpsamples
samples/phpsamples/analyzing_features
samples/phpsamples/custom_output
samples/phpsamples/digitizing_features
samples/phpsamples/interacting_with_layers
samples/phpsamples/modifying_maps_and_layers
samples/phpsamples/working_with_feature_data
svn_mapguide at osgeo.org
Fri Mar 26 16:32:35 EDT 2010
Author: brucedechant
Date: 2010-03-26 16:32:34 -0400 (Fri, 26 Mar 2010)
New Revision: 4709
sandbox/adsk/2.2gp/Doc/external_topics/FeatureService_provider.h
sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/createbuffer.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/createmapimage.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/emap.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/eplot.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/multiplot.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/property_report.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/clear_lines.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/draw_line.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/main.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/listselection.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
Fix for trac ticket 1292 - Update to PHP 5.3
http://trac.osgeo.org/mapguide/ticket/1292
Notes:
- Update samples
- Change API GetMessage() to GetExceptionMessage() due to PHP conflict
Modified: sandbox/adsk/2.2gp/Doc/external_topics/FeatureService_provider.h
--- sandbox/adsk/2.2gp/Doc/external_topics/FeatureService_provider.h 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/external_topics/FeatureService_provider.h 2010-03-26 20:32:34 UTC (rev 4709)
@@ -730,7 +730,7 @@
The constructor takes a provider name, a file handle, and an
MgByteReader containing the provider capabilities. The
provider name is obtained from \link MgFeatureService::GetFeatureProviders MgFeatureService::GetFeatureProviders\endlink.
- The provider capabilities is obtained from
+ The provider capabilities is obtained from
\link MgFeatureService::GetCapabilities MgFeatureService::GetCapabilities\endlink.
The file handle is for logging.
</p>
@@ -761,7 +761,7 @@
$this->queryTopology();
$this->queryGeometry();
} catch (Exception $e) {
- $msg = $e->GetMessage();
+ $msg = $e->GetExceptionMessage();
fwrite($logFileHandle, "ProviderCapabilities PHP Exception: $msg\\n");
@@ -1154,7 +1154,7 @@
function supportsGetMeasureUnits() {
return $this->supportsGetMeasureUnits;
var $supportsSQLCommand = FALSE;
function supportsSQLCommand() {
return $this->supportsSQLCommand;
@@ -2182,4 +2182,4 @@
</pre>
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/createbuffer.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/createbuffer.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/createbuffer.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -1,6 +1,6 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
// Copyright (C) 2004-2010 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
@@ -156,8 +156,8 @@
// Add buffer features to the temporary feature source.
// Create multiple concentric buffers to show area.
- // If the stylization for the layer draws the features
- // partially transparent, the concentric rings will be
+ // If the stylization for the layer draws the features
+ // partially transparent, the concentric rings will be
// progressively darker towards the center.
// The stylization is set in the layer template file, which
// is used in function CreateBufferLayer().
@@ -191,11 +191,11 @@
catch (MgException $e)
- echo '<p>' . $e->GetMessage() . '</p>';
+ echo '<p>' . $e->GetExceptionMessage() . '</p>';
echo '<p>' . $e->GetDetails() . '</p>';
<p>The buffer has been created.</p>
</body>
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -139,7 +139,7 @@
// Check each layer in the selection.
for ($i = 0; $i < $selectedLayers->GetCount(); $i++)
// Only check selected features in the Parcels layer.
@@ -150,7 +150,7 @@
echo 'Marking all parcels inside the buffer that are of type "MFG"';
// Create a filter containing the IDs of the selected features on this layer
$layerClassName = $layer->GetFeatureClassName();
@@ -184,7 +184,7 @@
$mergedGeometries = $geometryFactory->CreateMultiGeometry($inputGeometries);
// Create a buffer from the merged geometries
$bufferDist = $srs->ConvertMetersToCoordinateSystemUnits($bufferRingSize);
$bufferGeometry = $mergedGeometries->Buffer($bufferDist, $srsMeasure);
@@ -209,7 +209,7 @@
$parcelMarkerCommands = new MgFeatureCommandCollection();
while ($featureReader->ReadNext())
$byteReader = $featureReader->GetGeometry('SHPGEOM');
$geometry = $agfReaderWriter->Read($byteReader);
@@ -218,7 +218,7 @@
// Create an insert command for this parcel.
$properties = new MgPropertyCollection();
$properties->Add(new MgGeometryProperty('ParcelLocation', $agfReaderWriter->Write($point)));
$parcelMarkerCommands->Add(new MgInsertFeatures('ParcelMarkerClass', $properties));
@@ -245,7 +245,7 @@
$featureService->UpdateFeatures($bufferFeatureResId, $commands, false);
// Ensure that the buffer layer is visible and in the legend.
$bufferLayer->SetVisible(true);
$bufferLayer->ForceRefresh();
$bufferLayer->SetDisplayInLegend(true);
@@ -264,7 +264,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/createmapimage.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/createmapimage.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/createmapimage.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -42,14 +42,14 @@
$siteConnection->Open($userInfo);
// Create the necessary services.
$resourceService = $siteConnection->
CreateService(MgServiceType::ResourceService);
$renderingService = $siteConnection->
CreateService(MgServiceType::RenderingService);
// Open the map and get its SRS
$map = new MgMap();
$map->Open($resourceService, $mapName);
$srsWkt = $map->GetMapSRS();
@@ -73,22 +73,22 @@
// Convert the height in pixels to map units.
// Create an envelope that contains the image area to display.
$displayInInches = $imageHeight / 96;
$displayInMeters = $displayInInches * .0254;
$mapHeightInMeters = $displayInMeters * $mapScale;
$mapHeightInMapUnits = $srs->ConvertMetersToCoordinateSystemUnits($mapHeightInMeters);
$envelopeOffsetY = $mapHeightInMapUnits / 2;
$envelopeOffsetX = $imageWidth / $imageHeight * $envelopeOffsetY;
- $envelope = new MgEnvelope($mapCenterX - $envelopeOffsetX,
- $mapCenterY - $envelopeOffsetY, $mapCenterX + $envelopeOffsetX,
+ $envelope = new MgEnvelope($mapCenterX - $envelopeOffsetX,
+ $mapCenterY - $envelopeOffsetY, $mapCenterX + $envelopeOffsetX,
$mapCenterY + $envelopeOffsetY);
// Render the image and send it to the browser.
- $byteReader = $renderingService->RenderMap($map, $selection,
+ $byteReader = $renderingService->RenderMap($map, $selection,
$envelope, $imageWidth, $imageHeight, $color, 'PNG');
header("Content-type: " . $byteReader->GetMimeType() );
$buffer = '';
@@ -99,7 +99,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/emap.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/emap.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/emap.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -63,7 +63,7 @@
- $result = $e->GetMessage() . "<br><br>" . $e->GetDetails();
+ $result = $e->GetExceptionMessage() . "<br><br>" . $e->GetDetails();
header('Content-Type: text/html');
header('Content-Length: ' . strlen($result));
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/eplot.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/eplot.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/eplot.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -69,7 +69,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/multiplot.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/multiplot.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/multiplot.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -86,7 +86,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/property_report.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/property_report.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/custom_output/property_report.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -81,7 +81,7 @@
$queryOptions->SetFilter($selectionString);
$featureReader = $featureService->SelectFeatures($layerFeatureResource, $layerClassName, $queryOptions);
- // Create the report details using the first selected parcel. Position the image so the
+ // Create the report details using the first selected parcel. Position the image so the
// centroid of the selected parcel is in the center of the map.
$featureReader->ReadNext();
@@ -91,7 +91,7 @@
$centroid = $featureGeometry->GetCentroid();
$mapCenterX = $centroid->GetCoordinate()->GetX();
$mapCenterY = $centroid->GetCoordinate()->GetY();
$owner = $featureReader->GetString('RNAME');
$address = $featureReader->GetString('RPROPAD');
$billingAddress = $featureReader->GetString('RBILAD');
@@ -105,7 +105,7 @@
$selectionEncoded = urlencode($xmlSelection);
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/clear_lines.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/clear_lines.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/clear_lines.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -19,11 +19,11 @@
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
<title>Clear Lines</title>
<meta http-equiv="content-style-type" content="text/css">
<link href="../styles/globalStyles.css" rel="stylesheet" type="text/css">
<link href="../styles/otherStyles.css" rel="stylesheet" type="text/css">
- <meta http-equiv="content-script-type" content="text/javascript">
+ <meta http-equiv="content-script-type" content="text/javascript">
<script language="javascript" type="text/javascript">
function OnPageLoad()
@@ -33,39 +33,39 @@
</head>
<body onLoad="OnPageLoad()">
- <?php
- require_once('../common/common.php');
+ <?php
+ require_once('../common/common.php');
try
// Basic initialization
MgInitializeWebTier($webconfigFilePath);
// Get the information passed from the viewer
$sessionId = ($_SERVER['REQUEST_METHOD'] == "POST")?$_POST['SESSION']: $_GET['SESSION'];
$mapName = ($_SERVER['REQUEST_METHOD'] == "POST")?$_POST['MAPNAME']: $_GET['MAPNAME'];
// Get the user information using the session id
- // and set up a connection to the site server
+ // and set up a connection to the site server
$userInfo = new MgUserInformation($sessionId);
$siteConnection = new MgSiteConnection();
// Get an instance of the required service(s)
- $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
- $featureSourceName = "Session:$sessionId//TemporaryLines.FeatureSource";
+ $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
+ $featureSourceName = "Session:$sessionId//TemporaryLines.FeatureSource";
$resourceID = new MgResourceIdentifier($featureSourceName);
$resourceService->DeleteResource($resourceID);
echo "<script language=\"javascript\" type=\"text/javascript\"> \n";
- echo " alert(\" " . $e->GetMessage() . " \"); \n";
+ echo " alert(\" " . $e->GetExceptionMessage() . " \"); \n";
echo "</script> \n";
</body>
</html>
\ No newline at end of file
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/draw_line.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/draw_line.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/digitizing_features/draw_line.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -19,7 +19,7 @@
<head>
<title>Draw a Line</title>
@@ -35,9 +35,9 @@
<?php
- require_once($webExtensionsDirectory . 'www/mapviewerphp/layerdefinitionfactory.php');
+ require_once($webExtensionsDirectory . 'www/mapviewerphp/layerdefinitionfactory.php');
require_once('../modifying_maps_and_layers/layer_functions.php');
// Get the parameters passed in from the task pane
$args = ($_SERVER['REQUEST_METHOD'] == "POST")?$_POST: $_GET;
$x0 = $args['x0'];
@@ -46,209 +46,209 @@
$y1 = $args['y1'];
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
try
// Basic initialization needs to be done every time.
// Get the session information passed from the viewer.
// Get the user information using the session id,
- // and set up a connection to the site server.
+ // and set up a connection to the site server.
- // Get an instance of the required service(s).
+ // Get an instance of the required service(s).
- $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
+ $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
// Open the map
$map = new MgMap();
$layerName = "Lines";
$layerLegendLabel = "New Lines";
$groupName = "Analysis";
- $groupLegendLabel = "Analysis";
+ $groupLegendLabel = "Analysis";
// Does the temporary feature source already exist?
// If not, create it
$resourceIdentifier = new MgResourceIdentifier($featureSourceName);
$featureSourceExists = DoesResourceExist($resourceIdentifier, $resourceService);
- if (! $featureSourceExists)
+ if (! $featureSourceExists)
// Create a temporary feature source to draw the lines on
- // Create a feature class definition for the new feature
+ // Create a feature class definition for the new feature
// source
$classDefinition = new MgClassDefinition();
$classDefinition->SetName("Lines");
$classDefinition->SetDescription("Lines to display.");
$geometryPropertyName="SHPGEOM";
$classDefinition->
- SetDefaultGeometryPropertyName( $geometryPropertyName);
+ SetDefaultGeometryPropertyName( $geometryPropertyName);
// Create an identify property
$identityProperty = new MgDataPropertyDefinition("KEY");
$identityProperty->SetDataType(MgPropertyType::Int32);
$identityProperty->SetAutoGeneration(true);
- $identityProperty->SetReadOnly(true);
+ $identityProperty->SetReadOnly(true);
// Add the identity property to the class definition
$classDefinition->GetIdentityProperties()->
Add($identityProperty);
$classDefinition->GetProperties()->Add($identityProperty);
// Create a name property
$nameProperty = new MgDataPropertyDefinition("NAME");
- $nameProperty->SetDataType(MgPropertyType::String);
+ $nameProperty->SetDataType(MgPropertyType::String);
// Add the name property to the class definition
$classDefinition->GetProperties()->Add($nameProperty);
// Create a geometry property
- $geometryProperty = new
- MgGeometricPropertyDefinition($geometryPropertyName);
+ $geometryProperty = new
+ MgGeometricPropertyDefinition($geometryPropertyName);
$geometryProperty->
- SetGeometryTypes(MgFeatureGeometricType::Surface);
+ SetGeometryTypes(MgFeatureGeometricType::Surface);
// Add the geometry property to the class definition
- $classDefinition->GetProperties()->Add($geometryProperty);
+ $classDefinition->GetProperties()->Add($geometryProperty);
// Create a feature schema
- $featureSchema = new MgFeatureSchema("SHP_Schema",
+ $featureSchema = new MgFeatureSchema("SHP_Schema",
"Line schema");
// Add the feature schema to the class definition
- $featureSchema->GetClasses()->Add($classDefinition);
+ $featureSchema->GetClasses()->Add($classDefinition);
// Create the feature source
$wkt = $map->GetMapSRS();
- $sdfParams = new MgCreateSdfParams("spatial context",
- $wkt, $featureSchema);
- $featureService->CreateFeatureSource($resourceIdentifier,
- $sdfParams);
+ $sdfParams = new MgCreateSdfParams("spatial context",
+ $wkt, $featureSchema);
+ $featureService->CreateFeatureSource($resourceIdentifier,
+ $sdfParams);
// Add the line to the feature source
$batchPropertyCollection = new MgBatchPropertyCollection();
$propertyCollection = MakeLine("Line A", $x0, $y0, $x1, $y1);
$batchPropertyCollection->Add($propertyCollection);
// Add the batch property collection to the feature source
- $cmd = new MgInsertFeatures($layerName, $batchPropertyCollection);
+ $cmd = new MgInsertFeatures($layerName, $batchPropertyCollection);
$featureCommandCollection = new MgFeatureCommandCollection();
$featureCommandCollection->Add($cmd);
// Execute the "add" commands
- $featureService->UpdateFeatures($resourceIdentifier, $featureCommandCollection, false);
+ $featureService->UpdateFeatures($resourceIdentifier, $featureCommandCollection, false);
$layerExists = DoesLayerExist($layerName, $map);
if (! $layerExists )
- // Create a new layer which uses that feature source
+ // Create a new layer which uses that feature source
// Create a line rule to stylize the lines
$ruleLegendLabel = 'Lines Rule';
$filter = '';
$color = 'FF0000FF';
$factory = new LayerDefinitionFactory();
$lineRule = $factory->CreateLineRule($ruleLegendLabel, $filter, $color);
// Create a line type style
$lineTypeStyle = $factory->CreateLineTypeStyle($lineRule);
// Create a scale range
$minScale = '0';
$maxScale = '1000000000000';
- $lineScaleRange = $factory->CreateScaleRange($minScale, $maxScale, $lineTypeStyle);
+ $lineScaleRange = $factory->CreateScaleRange($minScale, $maxScale, $lineTypeStyle);
// Create the layer definiton
$featureName = 'SHP_Schema:Lines';
$geometry = 'SHPGEOM';
$layerDefinition = $factory->CreateLayerDefinition($featureSourceName, $featureName, $geometry, $lineScaleRange);
// Add the layer to the map
$newLayer = add_layer_definition_to_map($layerDefinition, $layerName, $layerLegendLabel, $sessionId, $resourceService, $map);
// Add the layer to a layer group
add_layer_to_group($newLayer,$groupName, $groupLegendLabel, $map);
// Turn on the visibility of this layer.
// (If the layer does not already exist in the map, it will be visible by default when it is added.
// But if the user has already run this script, he or she may have set the layer to be invisible.)
$layerCollection = $map->GetLayers();
- if ($layerCollection->Contains($layerName))
+ if ($layerCollection->Contains($layerName))
$linesLayer =$layerCollection->GetItem($layerName);
$linesLayer->SetVisible(true);
$groupCollection = $map->GetLayerGroups();
if ($groupCollection->Contains($groupName))
$analysisGroup =$groupCollection->GetItem($groupName);
$analysisGroup->SetVisible(true);
// Save the map back to the session repository
$sessionIdName = "Session:$sessionId//$mapName.Map";
$sessionResourceID = new MgResourceIdentifier($sessionIdName);
$sessionResourceID->Validate();
$map->Save($resourceService, $sessionResourceID);
function MakeLine($name, $x0, $y0 , $x1, $y1)
$propertyCollection = new MgPropertyCollection();
$nameProperty = new MgStringProperty("NAME", $name);
$propertyCollection->Add($nameProperty);
$wktReaderWriter = new MgWktReaderWriter();
- $agfReaderWriter = new MgAgfReaderWriter();
- $geometry = $wktReaderWriter->Read("LINESTRING XY ($x0 $y0, $x1 $y1)");
- $geometryByteReader = $agfReaderWriter->Write($geometry);
+ $agfReaderWriter = new MgAgfReaderWriter();
+ $geometry = $wktReaderWriter->Read("LINESTRING XY ($x0 $y0, $x1 $y1)");
+ $geometryByteReader = $agfReaderWriter->Write($geometry);
$geometryProperty = new MgGeometryProperty("SHPGEOM", $geometryByteReader);
$propertyCollection->Add($geometryProperty);
return $propertyCollection;
function DoesResourceExist($resourceIdentifier, $resourceService)
// Returns true if the resource already exists, or false otherwise
return $resourceService->ResourceExists($resourceIdentifier);
function DoesLayerExist($layerName, $map)
// Returns true if the layer already exists, or false otherwise
- $layerCollection = $map->GetLayers();
+ $layerCollection = $map->GetLayers();
return( $layerCollection->Contains($layerName) ? true : false ) ;
</body>
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -92,7 +92,7 @@
- echo $e->GetMessage();
+ echo $e->GetExceptionMessage();
echo $e->GetDetails();
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/main.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/main.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/main.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -33,7 +33,7 @@
echo "Could not connect to the MapGuide site server. Please contact the MapGuide site administrator.";
die();
try
$sessionId = $site->CreateSession();
@@ -44,7 +44,7 @@
- echo "ERROR: " . $e->GetMessage("eng") . "\n";
+ echo "ERROR: " . $e->GetExceptionMessage("eng") . "\n";
echo $e->GetStackTrace("eng") . "\n";
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -1,4 +1,4 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
@@ -76,7 +76,7 @@
$xpath = new DOMXPath($domDocument);
$query = '//AreaRule/Filter';
// Get a list of all the <AreaRule><Filter> elements in
- // the XML.
+ // the XML.
$nodes = $xpath->query($query);
// Find the correct node and change it
foreach ($nodes as $node )
@@ -103,7 +103,7 @@
$layerDefinition = $domDocument->saveXML();
$newLayer = add_layer_definition_to_map($layerDefinition, "RecentlyBuilt", "Built after 1980", $sessionId, $resourceService, $map);
@@ -130,7 +130,7 @@
$recentlyBuiltLayer = $layerCollection->GetItem("RecentlyBuilt");
$recentlyBuiltLayer->SetVisible(true);
@@ -145,7 +145,7 @@
- $message = $e->GetMessage();
+ $message = $e->GetExceptionMessage();
$message = str_replace("\n", " ", $message);
echo " alert(\" " . $message . " \"); \n";
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -1,4 +1,4 @@
@@ -34,10 +34,10 @@
</head>
<?php
-require_once($webExtensionsDirectory . 'www/mapviewerphp/layerdefinitionfactory.php');
+require_once($webExtensionsDirectory . 'www/mapviewerphp/layerdefinitionfactory.php');
require_once('layer_functions.php');
try
@@ -60,26 +60,26 @@
// Create a line rule.
$legendLabel = '';
$filter = '';
$legendLabel, $filter, $color);
// Create a line type style.
// Create a scale range.
$minScale = '0';
- CreateScaleRange($minScale, $maxScale,
- $lineTypeStyle);
+ CreateScaleRange($minScale, $maxScale,
+ $lineTypeStyle);
// Create the layer definiton.
$featureClass = 'Library://Samples/Sheboygan/Data/'
@@ -87,16 +87,16 @@
$featureName = 'SHP_Schema:HydrographicLines';
- CreateLayerDefinition($featureClass, $featureName,
+ CreateLayerDefinition($featureClass, $featureName,
$newLayer = add_layer_definition_to_map($layerDefinition, "Hydro", "Hydro", $sessionId, $resourceService, $map);
add_layer_to_group($newLayer, "Analysis", "Analysis", $map);
@@ -107,7 +107,7 @@
$squareFootageLayer =$layerCollection->GetItem("Hydro");
$squareFootageLayer->SetVisible(true);
@@ -121,7 +121,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -1,4 +1,4 @@
@@ -32,11 +32,11 @@
</script>
</head>
-<body onLoad="OnPageLoad()">
+<body onLoad="OnPageLoad()">
<?php
try
@@ -50,8 +50,8 @@
// Open the map
$map = new MgMap();
@@ -61,46 +61,46 @@
// Create a feature source with point data.
// (The Sheboygan sample data does not contain such data,
// so we'll create it.)
// Create a feature class definition for the new feature source
$classDefinition->SetName("Points");
$classDefinition->SetDescription("Feature class with point data.");
$classDefinition->SetDefaultGeometryPropertyName("GEOM");
$classDefinition->GetIdentityProperties()->Add($identityProperty);
$geometryProperty = new MgGeometricPropertyDefinition("GEOM");
- $geometryProperty->SetGeometryTypes(MgFeatureGeometricType::Surface);
+ $geometryProperty->SetGeometryTypes(MgFeatureGeometricType::Surface);
$featureSchema = new MgFeatureSchema("PointSchema", "Point schema");
- $featureSourceName = 'Library://Samples/DevGuide/Data/points.FeatureSource';
+ $featureSourceName = 'Library://Samples/DevGuide/Data/points.FeatureSource';
$wkt = "LOCALCS[\"*XY-MT*\",LOCAL_DATUM[\"*X-Y*\",10000],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
$sdfParams = new MgCreateSdfParams("ArbitraryXY", $wkt, $featureSchema);
$featureService->CreateFeatureSource($resourceIdentifier, $sdfParams);
// We need to add some data to the sdf before using it. The spatial context
// reader must have an extent.
@@ -108,37 +108,37 @@
$geometryFactory = new MgGeometryFactory();
- // Make four points
+ // Make four points
$propertyCollection = MakePoint("Point A", -87.727, 43.748);
- unset($propertyCollection);
+ unset($propertyCollection);
$propertyCollection = MakePoint("Point B", -87.728, 43.730);
$propertyCollection = MakePoint("Point C", -87.726, 43.750);
$propertyCollection = MakePoint("Point D", -87.728, 43.750);
- $cmd = new MgInsertFeatures("Points", $batchPropertyCollection);
+ $cmd = new MgInsertFeatures("Points", $batchPropertyCollection);
// Create a mark symbol
$resourceId = 'Library://Samples/Sheboygan/'
. 'Symbols/BasicSymbols.SymbolLibrary';
@@ -146,41 +146,41 @@
$width = '24'; // unit = points
$height = '24'; // unit = points
$color = 'FFFF0000';
- $markSymbol = $factory->CreateMarkSymbol($resourceId,
- $symbolName, $width, $height, $color);
+ $markSymbol = $factory->CreateMarkSymbol($resourceId,
+ $symbolName, $width, $height, $color);
// Create a text symbol
$text = "ID";
$fontHeight="12";
$foregroundColor = 'FF000000';
- $textSymbol = $factory->CreateTextSymbol($text,
+ $textSymbol = $factory->CreateTextSymbol($text,
$fontHeight, $foregroundColor);
// Create a point rule.
$legendLabel = 'trees';
$filter = '';
- $pointRule = $factory->CreatePointRule($legendLabel,
+ $pointRule = $factory->CreatePointRule($legendLabel,
$filter, $textSymbol, $markSymbol);
// Create a point type style.
$pointTypeStyle = $factory->
CreatepointTypeStyle($pointRule);
$minScale = '0';
$pointScaleRange = $factory->CreateScaleRange(
- $minScale, $maxScale, $pointTypeStyle);
+ $minScale, $maxScale, $pointTypeStyle);
$featureName = 'PointSchema:Points';
$geometry = 'GEOM';
- CreateLayerDefinition($featureSourceName,
+ CreateLayerDefinition($featureSourceName,
$featureName, $geometry, $pointScaleRange);
$newLayer = add_layer_definition_to_map($layerDefinition, "Points", "Points of Interest", $sessionId, $resourceService, $map);
@@ -208,7 +208,7 @@
@@ -218,15 +218,15 @@
- $geometry = $wktReaderWriter->Read("POINT XY ($x $y)");
+ $geometry = $wktReaderWriter->Read("POINT XY ($x $y)");
$geometryProperty = new MgGeometryProperty("GEOM", $geometryByteReader);
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -1,4 +1,4 @@
@@ -34,10 +34,10 @@
</head>
<?php
try
@@ -47,7 +47,7 @@
$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
@@ -62,22 +62,22 @@
/// Create three area rules for three different
- // scale ranges.
- $areaRule1 = $factory->CreateAreaRule( '1 to 800',
+ // scale ranges.
+ $areaRule1 = $factory->CreateAreaRule( '1 to 800',
'SQFT >= 1 AND SQFT < 800', 'FFFFFF00');
- $areaRule2 = $factory->CreateAreaRule( '800 to 1600',
+ $areaRule2 = $factory->CreateAreaRule( '800 to 1600',
'SQFT >= 800 AND SQFT < 1600', 'FFFFBF20');
- $areaRule3 = $factory->CreateAreaRule('1600 to 2400',
+ $areaRule3 = $factory->CreateAreaRule('1600 to 2400',
'SQFT >= 1600 AND SQFT < 2400', 'FFFF8040');
- // Create an area type style.
+ // Create an area type style.
$areaTypeStyle = $factory->CreateAreaTypeStyle(
$areaRule1 . $areaRule2 . $areaRule3);
$minScale = '0';
$maxScale = '10000';
@@ -90,12 +90,12 @@
$featureName = 'SHP_Schema:Parcels';
- $featureClass, $featureName, $geometry,
+ $featureClass, $featureName, $geometry,
$areaScaleRange);
$newLayer = add_layer_definition_to_map($layerDefinition, "SquareFootage", "Square Footage", $sessionId, $resourceService, $map);
@@ -119,7 +119,7 @@
$squareFootageLayer =$layerCollection->GetItem("SquareFootage");
@@ -132,7 +132,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -33,18 +33,18 @@
die();
try
// Define some constants
$webLayout = "Library://Samples/DevGuidePHP/modifying_maps_and_layers.WebLayout";
$title = "Modifying Maps and Layers";
@@ -57,12 +57,12 @@
</head>
<frameset rows="110,*">
<frame src="Title.php?TitleText=<?= $title ?>" name="TitleFrame" scrolling="NO" noresize>
<frame
src="/mapguide/mapviewerdwf/?
SESSION=<?= $sessionId ?>&
- WEBLAYOUT=<?= $webLayout ?>" name="ViewerFrame">
+ WEBLAYOUT=<?= $webLayout ?>" name="ViewerFrame">
</frameset>
</html>
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/listselection.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -1,4 +1,4 @@
@@ -66,7 +66,7 @@
else
$layers = 0;
// Use the following code for AJAX Viewers only.
// This does not require passing selection data via HTTP POST.
@@ -77,7 +77,7 @@
if ($layers)
$queryOptions = new MgFeatureQueryOptions();
for ($i = 0; $i < $layers->GetCount(); $i++)
@@ -121,7 +121,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -57,7 +57,7 @@
$districtQuery = new MgFeatureQueryOptions();
$districtQuery->SetFilter("Autogenerated_SDF_ID = 1");
$layer = $map->GetLayers()->GetItem('Districts');
$featureReader = $layer->SelectFeatures($districtQuery);
@@ -69,13 +69,13 @@
$districtGeometry = $agfReaderWriter->
Read($districtGeometryData);
// Create a filter to select the desired features.
// Combine a basic filter and a spatial filter.
$queryOptions->SetFilter("RNAME LIKE 'SCHMITT%'");
$queryOptions->SetSpatialFilter('SHPGEOM',
$districtGeometry,
MgFeatureSpatialOperations::Inside);
@@ -89,7 +89,7 @@
echo '<p>Properties owned by Schmitt ';
echo 'in District 1</p><p>';
$val = $featureReader->GetString('RPROPAD');
@@ -99,7 +99,7 @@
Modified: sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
--- sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2010-03-26 20:26:01 UTC (rev 4708)
+++ sandbox/adsk/2.2gp/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2010-03-26 20:32:34 UTC (rev 4709)
@@ -1,4 +1,4 @@
@@ -90,7 +90,7 @@
More information about the mapguide-commits
