[mapguide-commits] r5378 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Tue Nov 9 03:42:50 EST 2010
Author: hubu
Date: 2010-11-09 00:42:49 -0800 (Tue, 09 Nov 2010)
New Revision: 5378
trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h
Fix break build of GisPlatform on Linux.
1. UpdateDef should not return.
2. UpdateDef should be declared before it's invoked.
Modified: trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h
--- trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h 2010-11-08 18:22:17 UTC (rev 5377)
+++ trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h 2010-11-09 08:42:49 UTC (rev 5378)
@@ -111,20 +111,6 @@
//is the corresponding public API interface (MgCoordinateSystem
//et al).
- template <class T, class Tinterface>
- void UpdateDef(
- CSystemNameDescriptionMap *pmapSystemNameDescription,
- const char * (*key)(const T&),
- const char * (*description)(const T&),
- bool (Tinterface::*isValid)(),
- T * (*CS_Tdef)(const char *),
- int (*CS_Tupd)(T *, int),
- bool (*BuildDefFromInterface)(Tinterface *, T&),
- Tinterface *kpDef,
- bool bAlreadyExists)
- return UpdateDef(pmapSystemNameDescription, key, description, isValid, CS_Tdef, CS_Tupd, BuildDefFromInterface, kpDef, bAlreadyExists, true);
void UpdateDef(
@@ -298,6 +284,20 @@
} //for each possible result of the update
+ template <class T, class Tinterface>
+ void UpdateDef(
+ CSystemNameDescriptionMap *pmapSystemNameDescription,
+ const char * (*key)(const T&),
+ const char * (*description)(const T&),
+ bool (Tinterface::*isValid)(),
+ T * (*CS_Tdef)(const char *),
+ int (*CS_Tupd)(T *, int),
+ bool (*BuildDefFromInterface)(Tinterface *, T&),
+ Tinterface *kpDef,
+ bool bAlreadyExists)
+ UpdateDef<T, Tinterface>(pmapSystemNameDescription, key, description, isValid, CS_Tdef, CS_Tupd, BuildDefFromInterface, kpDef, bAlreadyExists, true);
//Template function for removing a def from a dictionary.
//Works for ellipsoids, datums, and coordinate systems.
More information about the mapguide-commits
