[mapguide-commits] r5382 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Tue Nov 9 17:57:50 EST 2010
Author: brucedechant
Date: 2010-11-09 14:57:50 -0800 (Tue, 09 Nov 2010)
New Revision: 5382
trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp
trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h
Fixed an error where SQLite feature source can not be previewed.
Notes:
- MgFdoFeatureReader class does not use the FDO API in a correct manner, calling ReadNext
even in a previous call ReadNext returned false. This makes the sqlite engine to
move again to the first row creating an infinite loop.
Also in MgFdoFeatureReader ReadNext somehow compiler optimized the code making
ReadNext to be called multiple times. Fixed by avoid calling ReadNext() after
reader(s) were depleted using a flag for it.
Submitted on behalf of Romica Dascalescu
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp 2010-11-09 21:49:53 UTC (rev 5381)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp 2010-11-09 22:57:50 UTC (rev 5382)
@@ -28,11 +28,13 @@
// Class MgFdoFeatureReader
MgFdoFeatureReader::MgFdoFeatureReader() : m_currentReaderId(-1)
+ m_readerDepleted = false;
m_readerCollection = MgFdoReaderCollection::Create();
MgFdoFeatureReader::MgFdoFeatureReader(MgFdoReaderCollection *readerCollection) : m_currentReaderId(-1)
m_readerCollection = FDO_SAFE_ADDREF(readerCollection);
@@ -421,35 +423,25 @@
bool MgFdoFeatureReader::ReadNext( )
- bool retVal = false;
+ if (m_readerDepleted)
+ return false;
if (m_currentReader == NULL)
Initialize();
if (m_currentReader->ReadNext())
- retVal = true;
- else
- m_currentReaderId++;
- if (m_readerCollection->GetCount() > m_currentReaderId)
- m_currentReader = (FdoIFeatureReader*)m_readerCollection->GetItem(m_currentReaderId);
- if (m_currentReader == NULL)
- retVal = false;
- else
- retVal = m_currentReader->ReadNext();
+ return true;
- return retVal;
+ m_currentReader = NULL;
+ m_currentReaderId++;
+ if ((m_readerCollection->GetCount() > m_currentReaderId))
+ m_currentReader = static_cast<FdoIFeatureReader*>(m_readerCollection->GetItem(m_currentReaderId));
+ if (m_currentReader != NULL)
+ return this->ReadNext();
+ m_readerDepleted = true;
+ return false;
void MgFdoFeatureReader::Close( )
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h 2010-11-09 21:49:53 UTC (rev 5381)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h 2010-11-09 22:57:50 UTC (rev 5382)
@@ -92,6 +92,7 @@
FdoPtr<MgFdoReaderCollection> m_readerCollection;
FdoPtr<FdoIFeatureReader> m_currentReader;
FdoInt32 m_currentReaderId;
+ FdoBoolean m_readerDepleted;
void Initialize();
More information about the mapguide-commits
