[mapguide-commits] r5409 - in trunk/Installer: . Bootstrapper
Custom/apache_actions Custom/iis_actions FdoRegUtil
Installers/MapGuide Libraries/MapGuide Server
Libraries/MapGuide Web Extensions
Support/Web/x64/Apache2/conf Support/Web/x64/Php
Support/Web/x86/Apache2/conf Support/Web/x86/Php
svn_mapguide at osgeo.org
Sat Nov 27 06:32:05 EST 2010
Author: jng
Date: 2010-11-27 03:32:05 -0800 (Sat, 27 Nov 2010)
New Revision: 5409
Added:
trunk/Installer/Bootstrapper/vcredist_x64.exe
trunk/Installer/Bootstrapper/vcredist_x86.exe
trunk/Installer/InstallerPreReq.sln
trunk/Installer/InstallerWix.sln
Removed:
trunk/Installer/Bootstrapper/Bootstrap-x64.proj
trunk/Installer/Bootstrapper/Bootstrap-x86.proj
trunk/Installer/Installer.sln
trunk/Installer/Bootstrapper/Setup.nsi
trunk/Installer/Custom/apache_actions/StdAfx.h
trunk/Installer/Custom/apache_actions/apache_actions.cpp
trunk/Installer/Custom/iis_actions/CustomAction.cpp
trunk/Installer/Custom/iis_actions/stdafx.h
trunk/Installer/FdoRegUtil/
trunk/Installer/Installers/MapGuide/MapGuide.wxs
trunk/Installer/Libraries/MapGuide Server/FDO.wxs
trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf
trunk/Installer/Support/Web/x64/Php/php.ini
trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf
trunk/Installer/Support/Web/x86/Php/php.ini
trunk/Installer/build.bat
trunk/Installer/build64.bat
This submission includes the following changes:
- Fix #1540: Post 2.2 installer breakage.
- Update FDO file references to match FDO 3.6 distribution
- Fix #1426: Externalize references to isapi_MapAgent.dll and php5isapi.dll to make updating easier in the future
- Fix #1532: Enable the php_gd2.dll PHP extension to prevent breaking the new QuickPlot functionality
- Fix #1411: Make the Installer buildable with VS express
- Split Installer.sln into custom action (InstallerPreReq.sln) and Wix (InstallerWix.sln) to workaround the homogeneous solution limitation of VS express
- Update build.bat and build64.bat with new version numbers and the split solutions
- Rewrite the Apache custom action using C++ standard libraries, removing the MFC dependency. Fix httpd.conf to conform to the updated actions
- Remove the use of CComPtr in the IIS custom action (as this is an ATL class and ATL is not included in VS express)
- Remove the VS bootstrapper (not included in VS express). Update the NSIS installer to include the bootstrapping logic for installing the VC runtime if not installed.
- Fix #1280: Change version number to 2.3
Deleted: trunk/Installer/Bootstrapper/Bootstrap-x64.proj
--- trunk/Installer/Bootstrapper/Bootstrap-x64.proj 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Bootstrapper/Bootstrap-x64.proj 2010-11-27 11:32:05 UTC (rev 5409)
@@ -1,15 +0,0 @@
-<Project ToolsVersion="3.5" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <ItemGroup>
- <BootstrapperFile Include="Microsoft.Visual.C++.9.0.x64" />
- </ItemGroup>
- <Target Name="BuildBootstrapper">
- <GenerateBootstrapper
- ApplicationFile="$(TargetFile)"
- ApplicationName="MapGuide Open Source"
- BootstrapperItems="@(BootstrapperFile)"
- CopyComponents="true"
- ComponentsLocation="Relative"
- Culture="$(Culture)"
- OutputPath="..\Output\$(Culture)" />
- </Target>
-</Project>
Deleted: trunk/Installer/Bootstrapper/Bootstrap-x86.proj
--- trunk/Installer/Bootstrapper/Bootstrap-x86.proj 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Bootstrapper/Bootstrap-x86.proj 2010-11-27 11:32:05 UTC (rev 5409)
@@ -1,15 +0,0 @@
- <ItemGroup>
- <BootstrapperFile Include="Microsoft.Visual.C++.9.0.x86" />
- </ItemGroup>
- </Target>
-</Project>
Modified: trunk/Installer/Bootstrapper/Setup.nsi
--- trunk/Installer/Bootstrapper/Setup.nsi 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Bootstrapper/Setup.nsi 2010-11-27 11:32:05 UTC (rev 5409)
@@ -1,9 +1,9 @@
!ifdef MAXCOMPRESSION
-SetCompressor /FINAL /SOLID lzma
-SetCompressorDictSize 64
+;SetCompressor /FINAL /SOLID lzma
+;SetCompressorDictSize 64
-FileBufSize 256
+;FileBufSize 256
!endif
@@ -35,18 +35,55 @@
FunctionEnd
Section Main
+ SetOutPath $TEMP
+ SetOverwrite On
+ Push $R0
+ ClearErrors
+; http://social.msdn.microsoft.com/Forums/en-US/vcgeneral/thread/639e2cfd-bb61-425b-a087-a2442df23402
+!if ${CPU} = "x64"
+ SetRegView 64
+ ReadRegDword $R0 HKLM "SOFTWARE\Microsoft\DevDiv\VC\Servicing\9.0\RED\1033" "SP"
+ IfErrors InstallVSRedist BeginInstall
+!else
+ SetRegView 32
+ ; Reg key for 32-bit OS
+ IfErrors CheckWow32Registry BeginInstall
+CheckWow32Registry:
+ SetRegView 64
+ ; Reg key for 64-bit OS (WoW32)
+!endif
+InstallVSRedist:
+ MessageBox MB_OK "Installing VS redist"
+!if ${CPU} = "x64"
+ File /r "${INSTALLER_OUTPUT}\vcredist_x64.exe"
+ ExecWait '"$OUTDIR\vcredist_x64.exe" /q:a"'
+!else
+ File /r "${INSTALLER_OUTPUT}\vcredist_x86.exe"
+ ExecWait '"$OUTDIR\vcredist_x86.exe" /q:a'
+!endif
+BeginInstall:
+ MessageBox MB_OK "Begin main installation"
Banner::show /NOUNLOAD "Extracting files. Please Wait"
Banner::getWindow /NOUNLOAD
- SetOutPath $TEMP
- SetOverwrite On
File "${INSTALLER_OUTPUT}\${OUTNAME}.msi"
- File "${INSTALLER_OUTPUT}\setup.exe"
+ Banner::destroy
+ ; Run the MGOS installer
+ ExecWait '"msiexec" /i "$OUTDIR\${OUTNAME}.msi"'
+ ; Delete the MGOS installer and any other extracted after completion
+ Delete "$OUTDIR\${OUTNAME}.msi"
!if ${CPU} = "x64"
- File /r "${INSTALLER_OUTPUT}\vcredist_x64"
+ Delete "$OUTDIR\vcredist_x64.exe"
!else
- File /r "${INSTALLER_OUTPUT}\vcredist_x86"
+ Delete "$OUTDIR\vcredist_x86.exe"
!endif
- Banner::destroy
- ExecWait '"$OUTDIR\setup.exe"'
SectionEnd
\ No newline at end of file
Added: trunk/Installer/Bootstrapper/vcredist_x64.exe
(Binary files differ)
Property changes on: trunk/Installer/Bootstrapper/vcredist_x64.exe
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Installer/Bootstrapper/vcredist_x86.exe
Property changes on: trunk/Installer/Bootstrapper/vcredist_x86.exe
Modified: trunk/Installer/Custom/apache_actions/StdAfx.h
--- trunk/Installer/Custom/apache_actions/StdAfx.h 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Custom/apache_actions/StdAfx.h 2010-11-27 11:32:05 UTC (rev 5409)
@@ -14,7 +14,11 @@
// Insert your headers here
#define WIN32_LEAN_AND_MEAN // Exclude rarely-used stuff from Windows headers
-#include <afxwin.h>
+// Windows Header Files:
+#include <windows.h>
+#include <tchar.h>
+#include <strsafe.h>
+#include <msiquery.h>
// TODO: reference additional headers your program requires here
Modified: trunk/Installer/Custom/apache_actions/apache_actions.cpp
--- trunk/Installer/Custom/apache_actions/apache_actions.cpp 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Custom/apache_actions/apache_actions.cpp 2010-11-27 11:32:05 UTC (rev 5409)
@@ -26,22 +26,46 @@
#include "stdafx.h"
#include "apache_actions.h"
+#include <string>
+#include <vector>
+#include <iostream>
+#include <istream>
+#include <ostream>
+#include <iterator>
+#include <sstream>
+#include <algorithm>
+#include <fstream>
#define NULL_CHAR '\0'
-void ConvertToApachePath(char * str);
+void Tokenize(const std::string& str, std::vector<std::string>& tokens, const std::string& delimiters);
+void FindAndReplace(std::string& str, const std::string& find, const std::string& replace);
-* Name : ConverToApachePath
-* Description : Converts a path to a apache-friendly format
-* Parameters : str
-* Return : none
- for(unsigned int i = 0; i < strlen(str); i++)
+ // Skip delimiters at beginning.
+ std::string::size_type lastPos = str.find_first_not_of(delimiters, 0);
+ // Find first "non-delimiter".
+ std::string::size_type pos = str.find_first_of(delimiters, lastPos);
+ while (std::string::npos != pos || std::string::npos != lastPos)
+ // Found a token, add it to the vector.
+ tokens.push_back(str.substr(lastPos, pos - lastPos));
+ // Skip delimiters. Note the "not_of"
+ lastPos = str.find_first_not_of(delimiters, pos);
+ // Find next "non-delimiter"
+ pos = str.find_first_of(delimiters, lastPos);
+ size_t pos = 0;
+ while ((pos = str.find(find, pos)) != std::string::npos)
- if(str[i] == '\\')
- str[i] = '/';
+ str.replace(pos, find.length(), replace);
+ pos += replace.length();
@@ -127,101 +151,64 @@
UINT __stdcall
UpdatePhpIni(MSIHANDLE hMSI)
- DWORD dwDataLen = MAX_BUFFER;
- WCHAR wszCustomActionData[MAX_BUFFER + 1] = L"";
- CHAR szCustomActionData[MAX_BUFFER];
- CHAR szPhpDir[MAX_BUFFER];
+ // Method overview:
+ // We extract the value of the MSI property "CustomActionData" which will
+ // be of the form:
+ // [PHPLOCATION];[WEBSERVERTYPE];[WEBTEMPLOCATION]
+ // With this, we update php.ini as follows:
+ // replace %MG_WEB_PHP% with [PHPLOCATION]
+ // replace %MG_WEB_TEMP% with [WEBTEMPLOCATION]
+ // if [WEBSERVERTYPE] == "2" replace "; cgi.force_redirect = 1" with "cgi.force_redirect = 0"
- CHAR szWebTempDir[MAX_BUFFER];
- CHAR szWebServerType[MAX_BUFFER];
- CHAR szFile[MAX_BUFFER];
- CHAR szFind[MAX_BUFFER];
- CHAR szReplace[MAX_BUFFER];
- int nLen;
+ CHAR szCustomActionData[MAX_BUFFER];
+ DWORD dwDataLen = MAX_BUFFER;
- // retrieve the CustomActionData
- dwDataLen = MAX_BUFFER;
- MsiGetPropertyW(hMSI, L"CustomActionData", wszCustomActionData, &dwDataLen);
+ MsiGetProperty(hMSI, "CustomActionData", szCustomActionData, &dwDataLen);
- nLen = WideCharToMultiByte(CP_ACP, 0, wszCustomActionData, dwDataLen, szCustomActionData, MAX_BUFFER, NULL, NULL);
- szCustomActionData[nLen] = NULL_CHAR;
+ std::string szMsiData = szCustomActionData;
+ std::vector<std::string> tokens;
+ Tokenize(szMsiData, tokens, ";");
- szPhpDir[0] = NULL_CHAR;
- szWebServerType[0] = NULL_CHAR;
+ if (tokens.size() == 3)
+ std::string szPhpDir = tokens[0];
+ std::string szWebType = tokens[1];
+ std::string szTmpDir = tokens[2];
- //::MessageBoxW(NULL, wszCustomActionData, L"CustomActionData", MB_OK);
+ std::string szFileName = szPhpDir + "php.ini";
+ const char* szFile = szFileName.c_str();
- //[PHPLOCATION];[WEBSERVERTYPE];[WEBTEMPLOCATION]
- char * tok = strtok(szCustomActionData, ";");
- //[PHPLOCATION]
- if(tok)
- strcpy(szPhpDir, tok);
- tok = strtok(NULL, ";");
- //[WEBSERVERTYPE]
- if(tok)
+ if (FileExists(szFile))
- strcpy(szWebServerType, tok);
- //[WEBTEMPLOCATION]
- if(tok)
- strcpy(szWebTempDir, tok);
+ std::ifstream fin(szFile);
- // create the file path to php.ini
- strcpy(szFile, szPhpDir);
- strcat(szFile, "php.ini");
+ std::string buffer;
+ std::string line;
+ while(!fin.eof())
+ std::getline(fin, line);
- //::MessageBox(NULL, szFile, "Test", MB_OK);
+ FindAndReplace(line, "%MG_WEB_PHP%", szPhpDir);
+ FindAndReplace(line, "%MG_WEB_TEMP%", szTmpDir);
+ if (strcmp(szWebType.c_str(), "2") == 0)
+ FindAndReplace(line, "; cgi.force_redirect = 1", "cgi.force_redirect = 0");
- if( FileExists(szFile) )
- //::MessageBoxW(NULL, L"File found", L"Test", MB_OK);
- // Opening the file to read and write.
- CFile cfInFile(szFile, CFile::modeRead);
- DWORD dwFileLen = cfInFile.GetLength();
+ buffer += line + "\n";
+ fin.close();
- // Read the entire contents of the file.
- char *szBuff = new char[dwFileLen + 1];
- cfInFile.Read(szBuff, dwFileLen);
- szBuff[dwFileLen] = NULL_CHAR; // Add ending null to buffer.
- cfInFile.Close();
- // Creating a CString object to store the contents and help
- // us to add the desired configuration.
- CString csBuff(szBuff);
- strcpy(szFind,"%MG_WEB_PHP%");
- csBuff.Replace(szFind,szPhpDir);
- strcpy(szFind,"%MG_WEB_TEMP%");
- csBuff.Replace(szFind,szWebTempDir);
- if ( strcmp(szWebServerType,"2") == 0 )
- strcpy(szFind,"; cgi.force_redirect = 1");
- strcpy(szReplace,"cgi.force_redirect = 0");
- csBuff.Replace(szFind,szReplace);
+ std::ofstream fout(szFile);
+ fout << buffer;
+ fout.close();
- CFile cfOutFile(szFile, CFile::modeWrite);
- // Write and modify the contents.
- DWORD dwNewLength = csBuff.GetLength();
- cfOutFile.SeekToBegin();
- cfOutFile.Write(csBuff, dwNewLength);
- cfOutFile.SetLength(dwNewLength);
- cfOutFile.Close();
return ERROR_SUCCESS;
@@ -241,269 +228,144 @@
UINT __stdcall
UpdateApacheConfig(MSIHANDLE hMSI)
+ // Extract the value of the MSI property: CustomActionData
+ // The value is of the form: [WEBEXTENSIONSLOCATION];[APACHE_API_TYPE];[APACHE_PORT];[APACHELOCATION];[PHPLOCATION];[WEBROOTLOCATION];[VIRTUALDIR]
+ // Then in [APACHELOCATION]\conf\httpd.conf, perform the following replacements:
+ // %MG_WEB_ROOT% for [WEBROOTLOCATION]
+ // %MG_WEB_PORT% for [APACHE_PORT]
+ // %MG_WEB_PHP% for [PHPLOCATION]
+ // %MG_WEB_APACHE% for [APACHELOCATION]
+ // %MG_VIRTUAL_DIR% for [VIRTUALDIR]
+ // %MG_INCLUDE_TOMCAT% for "Include conf/tomcat.conf" if java config otherwise
+ // "#Uncomment to enable the Java API\n#Include conf/tomcat.conf"
+ // %MG_PHP_API% for "#" if java config otherwise ""
+ // %MG_JAVA_API% for "" if java config otherwise "#"
+ // If java config perform the following additional replacements in the
+ // file [APACHELOCATION]\conf\tomcat.conf
- CHAR szInstallDir[MAX_BUFFER];
- CHAR szApacheDir[MAX_BUFFER];
- CHAR szWebDir[MAX_BUFFER];
- CHAR szVirtualDir[MAX_BUFFER];
- CHAR szApiType[MAX_BUFFER];
- CHAR szServerPort[MAX_BUFFER];
- bool bJava = false;
- int nLen;
- szInstallDir[0] = NULL_CHAR;
- szApacheDir[0] = NULL_CHAR;
- szWebDir[0] = NULL_CHAR;
- szApiType[0] = NULL_CHAR;
- szServerPort[0] = NULL_CHAR;
- //[WEBEXTENSIONSLOCATION];[APACHE_API_TYPE];[APACHE_PORT];[APACHELOCATION];[PHPLOCATION];[WEBROOTLOCATION]
- if(tok)
+ if (tokens.size() == 7)
- strcpy(szInstallDir, tok);
- //[APACHE_API_TYPE]
- if(tok)
- strcpy(szApiType, tok);
- //[APACHE_PORT]
- if(tok)
- strcpy(szServerPort, tok);
- //[APACHELOCATION]
- if(tok)
- strcpy(szApacheDir, tok);
- //[PHPLOCATION]
- if(tok)
- //[WEBROOTLOCATION]
- if(tok)
- strcpy(szWebDir, tok);
- //[VIRTUALDIR]
- if(tok)
- strcpy(szVirtualDir, tok);
+ std::string szWebExtDir = tokens[0];
+ std::string szApiType = tokens[1];
+ std::string szPortNo = tokens[2];
+ std::string szApacheDir = tokens[3];
+ std::string szPhpDir = tokens[4];
+ std::string szWebRootDir = tokens[5];
+ std::string szVirtualDir = tokens[6];
- bJava = ( strcmp(szApiType,"JAVA") == 0 );
+ //Apach-ify these paths
+ FindAndReplace(szWebExtDir, "\\", "/");
+ FindAndReplace(szPhpDir, "\\", "/");
+ FindAndReplace(szWebRootDir, "\\", "/");
+ FindAndReplace(szApacheDir, "\\", "/");
- ConvertToApachePath(szInstallDir);
- ConvertToApachePath(szPhpDir);
- ConvertToApachePath(szWebDir);
- ConvertToApachePath(szApacheDir);
+ //Strip trailing slashes if there is one
+ std::string::size_type pos = szWebExtDir.find_last_of("/");
+ if (pos != std::string::npos && pos == szWebExtDir.length() - 1)
+ szWebExtDir.erase(pos);
- // The directory will have a fwd slash, so the last char should be null-terminated
- szApacheDir[strlen(szApacheDir)-1] = NULL_CHAR;
+ pos = szPhpDir.find_last_of("/");
+ if (pos != std::string::npos && pos == szPhpDir.length() - 1)
+ szPhpDir.erase(pos);
- // create the file path to http.conf
- strcpy(szFile, szApacheDir);
- strcat(szFile, "\\conf\\httpd.conf");
+ pos = szWebRootDir.find_last_of("/");
+ if (pos != std::string::npos && pos == szWebRootDir.length() - 1)
+ szWebRootDir.erase(pos);
- //::MessageBoxW(NULL, L"httpd.conf found", L"Test", MB_OK);
+ pos = szApacheDir.find_last_of("/");
+ if (pos != std::string::npos && pos == szApacheDir.length() - 1)
+ szApacheDir.erase(pos);
- //CHAR msg[20];
- //sprintf(msg, "Length: %d", dwFileLen);
- //::MessageBox(NULL, msg, "Test", MB_OK);
+ std::string szFileName = szApacheDir + "\\conf\\httpd.conf";
+ const char* szHttpdConf = szFileName.c_str();
+ bool bJava = (strcmp(szApiType.c_str(), "JAVA") == 0);
- szBuff[dwFileLen] = '\0'; // Add ending null to buffer.
+ if (FileExists(szHttpdConf))
+ std::ifstream fin(szHttpdConf);
+ std::string line;
+ while(!fin.eof())
- cfInFile.Close();
- //::MessageBoxW(NULL, L"read httpd.conf contents", L"Test", MB_OK);
+ //Process this line
+ FindAndReplace(line, "%MG_WEB_ROOT%", szWebRootDir);
+ FindAndReplace(line, "%MG_WEB_PORT%", szPortNo);
+ FindAndReplace(line, "%MG_WEB_APACHE%", szApacheDir);
+ FindAndReplace(line, "%MG_VIRTUAL_DIR%", szVirtualDir);
+ if (bJava)
+ FindAndReplace(line, "%MG_INCLUDE_TOMCAT%", "Include conf/tomcat.conf");
+ FindAndReplace(line, "%MG_PHP_API%", "#");
+ FindAndReplace(line, "%MG_JAVA_API%", "");
+ else
+ FindAndReplace(line, "%MG_INCLUDE_TOMCAT%", "#Uncomment to enable the Java API\n#Include conf/tomcat.conf");
+ FindAndReplace(line, "%MG_PHP_API%", "");
+ FindAndReplace(line, "%MG_JAVA_API%", "#");
- // Replace %MG_WEB_ROOT%
- strcpy(szFind,"%MG_WEB_ROOT%");
- strcpy(szReplace, szWebDir);
+ fin.close();
+ std::ofstream fout(szHttpdConf);
+ fout << buffer;
+ fout.close();
- //::MessageBox(NULL, TEXT("Replace MG_WEB_ROOT"), TEXT("Test"), MB_OK);
+ szFileName = szApacheDir + "\\conf\\tomcat.conf";
+ const char* szTomcatConf = szFileName.c_str();
- // Replace %MG_WEB_PORT%
- strcpy(szFind,"%MG_WEB_PORT%");
- strcpy(szReplace, szServerPort);
+ if (FileExists(szTomcatConf))
+ std::ifstream fin(szTomcatConf);
+ std::string line;
+ while(!fin.eof())
- //::MessageBox(NULL, TEXT("Replace MG_WEB_PORT"), TEXT("Test"), MB_OK);
- // Replace %MG_WEB_PHP%
- strcpy(szReplace, szPhpDir);
+ fin.close();
- //::MessageBox(NULL, TEXT("Replace MG_WEB_PHP"), TEXT("Test"), MB_OK);
- // Replace %MG_WEB_APACHE%
- strcpy(szFind,"%MG_WEB_APACHE%");
- strcpy(szReplace, szApacheDir);
- csBuff.Replace(szFind, szReplace);
- //::MessageBox(NULL, TEXT("Replace MG_WEB_APACHE"), TEXT("Test"), MB_OK);
- // Replace %MG_VIRTUAL_DIR%
- strcpy(szFind, "%MG_VIRTUAL_DIR%");
- strcpy(szReplace, szVirtualDir);
- //::MessageBox(NULL, TEXT("Replace MG_VIRTUAL_DIR"), TEXT("Test"), MB_OK);
- // If java, then include the tomcat configuration
- strcpy(szFind, "%MG_INCLUDE_TOMCAT%");
- csBuff.Replace(szFind, bJava ? "Include conf/tomcat.conf" : "#Uncomment to enable the Java API\n#Include conf/tomcat.conf");
- //::MessageBox(NULL, TEXT("Set Tomcat"), TEXT("Test"), MB_OK);
- // Toggle PHP API section
- strcpy(szFind, "%MG_PHP_API%");
- strcpy(szReplace, bJava ? "#" : "");
- //::MessageBox(NULL, TEXT("Toggle PHP API"), TEXT("Test"), MB_OK);
- // Toggle Java API section
- strcpy(szFind, "%MG_JAVA_API%");
- strcpy(szReplace, bJava ? "" : "#");
- //::MessageBox(NULL, TEXT("Toggle Java API"), TEXT("Test"), MB_OK);
- //::MessageBoxW(NULL, L"httpd.conf updated", L"Test", MB_OK);
+ std::ofstream fout(szTomcatConf);
+ fout << buffer;
+ fout.close();
- //Check if the tomcat.conf file was included in httpd.conf, if so we need to do placeholder substitution there too.
- strcat(szFile, "\\conf\\tomcat.conf");
- if(FileExists(szFile))
- //::MessageBoxW(NULL, L"tomcat.conf found", L"Test", MB_OK);
- cfInFile.Close();
- strcpy(szFile, szInstallDir);
- strcat(szFile, "Tomcat\\conf\\Catalina\\localhost\\mapguide.xml");
- cfInFile.Close();
- //CString csWebDir(szWebDir);
- //csWebDir.Replace("\\", "/");
Modified: trunk/Installer/Custom/iis_actions/CustomAction.cpp
--- trunk/Installer/Custom/iis_actions/CustomAction.cpp 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Custom/iis_actions/CustomAction.cpp 2010-11-27 11:32:05 UTC (rev 5409)
@@ -21,7 +21,7 @@
char szMsg[256];
PBYTE pbBuffer = NULL;
- CComPtr<IMSAdminBase> pIMeta;
+ IMSAdminBase* pIMeta = NULL;
hr = WcaInitialize(hInstall, "PopulateWebSites");
ExitOnFailure(hr, "Failed to initialize");
@@ -103,11 +103,17 @@
WcaLog(LOGMSG_STANDARD, "Finalizing");
sprintf(szMsg, "Final error code: %d", er);
WcaLog(LOGMSG_STANDARD, szMsg);
+ if (pIMeta)
+ pIMeta->Release();
+ pIMeta = NULL;
if (pbBuffer)
delete pbBuffer;
pbBuffer = NULL;
+ CoUninitialize();
if (hDb)
MsiCloseHandle(hDb);
return WcaFinalize(er);
Modified: trunk/Installer/Custom/iis_actions/stdafx.h
--- trunk/Installer/Custom/iis_actions/stdafx.h 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Custom/iis_actions/stdafx.h 2010-11-27 11:32:05 UTC (rev 5409)
@@ -14,7 +14,6 @@
-#include "atlBase.h"
#include <initguid.h>
#include "iadmw.h"
#include "iiscnfg.h"
Property changes on: trunk/Installer/FdoRegUtil
Modified: svn:ignore
- Release
+ Release
Release64
*.user
*.ncb
Deleted: trunk/Installer/Installer.sln
--- trunk/Installer/Installer.sln 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Installer.sln 2010-11-27 11:32:05 UTC (rev 5409)
@@ -1,132 +0,0 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
-Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "Installers", "Installers", "{27ADF4E3-77AC-4645-B1BC-9408943D19D3}"
-EndProject
-Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "Libraries", "Libraries", "{D2A5CB4A-4494-4083-9FBE-64ED543F8FBD}"
-EndProject
-Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "MapGuide Server", "Libraries\MapGuide Server\MapGuide Server.wixproj", "{715E2D88-E822-4A9A-A5A2-DBB71CD9B320}"
-EndProject
-Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "MapGuide", "Installers\MapGuide\MapGuide.wixproj", "{12C62F60-6F52-4112-84AB-0FA8ED44EE77}"
-EndProject
-Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "MapGuide Web Extensions", "Libraries\MapGuide Web Extensions\MapGuide Web Extensions.wixproj", "{D41D53C4-433E-47B5-B663-E79B5569EE22}"
- ProjectSection(ProjectDependencies) = postProject
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E} = {03FD713E-15EB-453E-AFDF-21F8DB45C11E}
- EndProjectSection
-EndProject
-Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "CS Map", "Libraries\CS Map\CS Map.wixproj", "{01313DB9-2AAF-4791-9B81-69BCE3194531}"
-EndProject
-Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = "Custom Actions", "Custom Actions", "{9AB6202A-055B-49E8-9623-986202F0EAD8}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "apache_actions", "Custom\apache_actions\apache_actions.vcproj", "{03FD713E-15EB-453E-AFDF-21F8DB45C11E}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "iis_actions", "Custom\iis_actions\iis_actions.vcproj", "{13697B62-C1CD-47EF-9D9B-39F5B01693BB}"
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Mixed Platforms = Debug|Mixed Platforms
- Debug|Win32 = Debug|Win32
- Debug|x64 = Debug|x64
- Debug|x86 = Debug|x86
- Release|Mixed Platforms = Release|Mixed Platforms
- Release|Win32 = Release|Win32
- Release|x64 = Release|x64
- Release|x86 = Release|x86
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|Mixed Platforms.ActiveCfg = Debug|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|Mixed Platforms.Build.0 = Debug|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|Win32.ActiveCfg = Debug|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|x64.ActiveCfg = Debug|x64
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|x64.Build.0 = Debug|x64
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|x86.ActiveCfg = Debug|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|x86.Build.0 = Debug|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|Mixed Platforms.ActiveCfg = Release|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|Mixed Platforms.Build.0 = Release|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|Win32.ActiveCfg = Release|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|x64.ActiveCfg = Release|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|x64.Build.0 = Release|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|x86.ActiveCfg = Release|x86
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|x86.Build.0 = Release|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|Mixed Platforms.ActiveCfg = Debug|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|Mixed Platforms.Build.0 = Debug|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|Win32.ActiveCfg = Debug|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|x64.ActiveCfg = Debug|x64
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|x64.Build.0 = Debug|x64
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|x86.ActiveCfg = Debug|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|x86.Build.0 = Debug|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|Mixed Platforms.ActiveCfg = Release|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|Mixed Platforms.Build.0 = Release|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|Win32.ActiveCfg = Release|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|x64.ActiveCfg = Release|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|x64.Build.0 = Release|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|x86.ActiveCfg = Release|x86
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|x86.Build.0 = Release|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|Mixed Platforms.ActiveCfg = Debug|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|Mixed Platforms.Build.0 = Debug|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|Win32.ActiveCfg = Debug|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|x64.ActiveCfg = Debug|x64
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|x64.Build.0 = Debug|x64
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|x86.ActiveCfg = Debug|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|x86.Build.0 = Debug|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|Mixed Platforms.ActiveCfg = Release|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|Mixed Platforms.Build.0 = Release|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|Win32.ActiveCfg = Release|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|x64.ActiveCfg = Release|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|x64.Build.0 = Release|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|x86.ActiveCfg = Release|x86
- {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|x86.Build.0 = Release|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|Mixed Platforms.ActiveCfg = Debug|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|Mixed Platforms.Build.0 = Debug|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|Win32.ActiveCfg = Debug|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|x64.ActiveCfg = Debug|x64
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|x64.Build.0 = Debug|x64
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|x86.ActiveCfg = Debug|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|x86.Build.0 = Debug|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|Mixed Platforms.ActiveCfg = Release|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|Mixed Platforms.Build.0 = Release|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|Win32.ActiveCfg = Release|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|x64.ActiveCfg = Release|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|x64.Build.0 = Release|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|x86.ActiveCfg = Release|x86
- {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|x86.Build.0 = Release|x86
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|Mixed Platforms.ActiveCfg = Debug|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|Mixed Platforms.Build.0 = Debug|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|Win32.ActiveCfg = Debug|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|Win32.Build.0 = Debug|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|x64.ActiveCfg = Debug|x64
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|x64.Build.0 = Debug|x64
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|x86.ActiveCfg = Debug|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|Mixed Platforms.ActiveCfg = Release|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|Mixed Platforms.Build.0 = Release|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|Win32.ActiveCfg = Release|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|Win32.Build.0 = Release|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|x64.ActiveCfg = Release|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|x64.Build.0 = Release|Win32
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|x86.ActiveCfg = Release|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|Mixed Platforms.ActiveCfg = Debug|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|Mixed Platforms.Build.0 = Debug|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|Win32.ActiveCfg = Debug|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|Win32.Build.0 = Debug|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|x64.ActiveCfg = Debug|x64
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|x64.Build.0 = Debug|x64
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|x86.ActiveCfg = Debug|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|Mixed Platforms.ActiveCfg = Release|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|Mixed Platforms.Build.0 = Release|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|Win32.ActiveCfg = Release|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|Win32.Build.0 = Release|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|x64.ActiveCfg = Release|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|x64.Build.0 = Release|Win32
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|x86.ActiveCfg = Release|Win32
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
- GlobalSection(NestedProjects) = preSolution
- {12C62F60-6F52-4112-84AB-0FA8ED44EE77} = {27ADF4E3-77AC-4645-B1BC-9408943D19D3}
- {715E2D88-E822-4A9A-A5A2-DBB71CD9B320} = {D2A5CB4A-4494-4083-9FBE-64ED543F8FBD}
- {D41D53C4-433E-47B5-B663-E79B5569EE22} = {D2A5CB4A-4494-4083-9FBE-64ED543F8FBD}
- {01313DB9-2AAF-4791-9B81-69BCE3194531} = {D2A5CB4A-4494-4083-9FBE-64ED543F8FBD}
- {03FD713E-15EB-453E-AFDF-21F8DB45C11E} = {9AB6202A-055B-49E8-9623-986202F0EAD8}
- {13697B62-C1CD-47EF-9D9B-39F5B01693BB} = {9AB6202A-055B-49E8-9623-986202F0EAD8}
- EndGlobalSection
-EndGlobal
Added: trunk/Installer/InstallerPreReq.sln
--- trunk/Installer/InstallerPreReq.sln (rev 0)
+++ trunk/Installer/InstallerPreReq.sln 2010-11-27 11:32:05 UTC (rev 5409)
@@ -0,0 +1,45 @@
+Microsoft Visual Studio Solution File, Format Version 10.00
+# Visual C++ Express 2008
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "apache_actions", "Custom\apache_actions\apache_actions.vcproj", "{03FD713E-15EB-453E-AFDF-21F8DB45C11E}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "iis_actions", "Custom\iis_actions\iis_actions.vcproj", "{13697B62-C1CD-47EF-9D9B-39F5B01693BB}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FdoRegUtil", "FdoRegUtil\FdoRegUtil.vcproj", "{F671A5C4-A796-4CF4-A71F-97B0265B4FBE}"
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Win32 = Debug|Win32
+ Debug|x64 = Debug|x64
+ Release|Win32 = Release|Win32
+ Release|x64 = Release|x64
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|Win32.Build.0 = Debug|Win32
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|x64.ActiveCfg = Debug|Win32
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Debug|x64.Build.0 = Debug|Win32
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|Win32.ActiveCfg = Release|Win32
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|Win32.Build.0 = Release|Win32
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|x64.ActiveCfg = Release|Win32
+ {03FD713E-15EB-453E-AFDF-21F8DB45C11E}.Release|x64.Build.0 = Release|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|Win32.ActiveCfg = Debug|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|Win32.Build.0 = Debug|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|x64.ActiveCfg = Debug|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Debug|x64.Build.0 = Debug|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|Win32.ActiveCfg = Release|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|Win32.Build.0 = Release|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|x64.ActiveCfg = Release|Win32
+ {13697B62-C1CD-47EF-9D9B-39F5B01693BB}.Release|x64.Build.0 = Release|Win32
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Debug|Win32.Build.0 = Debug|Win32
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Debug|x64.ActiveCfg = Debug|x64
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Debug|x64.Build.0 = Debug|x64
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Release|Win32.ActiveCfg = Release|Win32
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Release|Win32.Build.0 = Release|Win32
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Release|x64.ActiveCfg = Release|x64
+ {F671A5C4-A796-4CF4-A71F-97B0265B4FBE}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
Added: trunk/Installer/InstallerWix.sln
--- trunk/Installer/InstallerWix.sln (rev 0)
+++ trunk/Installer/InstallerWix.sln 2010-11-27 11:32:05 UTC (rev 5409)
@@ -0,0 +1,38 @@
+# Visual Studio 2008
+Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "CS Map", "Libraries\CS Map\CS Map.wixproj", "{01313DB9-2AAF-4791-9B81-69BCE3194531}"
+EndProject
+Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "MapGuide Server", "Libraries\MapGuide Server\MapGuide Server.wixproj", "{715E2D88-E822-4A9A-A5A2-DBB71CD9B320}"
+EndProject
+Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "MapGuide Web Extensions", "Libraries\MapGuide Web Extensions\MapGuide Web Extensions.wixproj", "{D41D53C4-433E-47B5-B663-E79B5569EE22}"
+EndProject
+Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "MapGuide", "Installers\MapGuide\MapGuide.wixproj", "{12C62F60-6F52-4112-84AB-0FA8ED44EE77}"
+EndProject
+Global
+ Debug|x86 = Debug|x86
+ Release|x86 = Release|x86
+ EndGlobalSection
+ {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|x86.ActiveCfg = Debug|x86
+ {01313DB9-2AAF-4791-9B81-69BCE3194531}.Debug|x86.Build.0 = Debug|x86
+ {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|x86.ActiveCfg = Release|x86
+ {01313DB9-2AAF-4791-9B81-69BCE3194531}.Release|x86.Build.0 = Release|x86
+ {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|x86.ActiveCfg = Debug|x86
+ {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Debug|x86.Build.0 = Debug|x86
+ {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|x86.ActiveCfg = Release|x86
+ {715E2D88-E822-4A9A-A5A2-DBB71CD9B320}.Release|x86.Build.0 = Release|x86
+ {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|x86.ActiveCfg = Debug|x86
+ {D41D53C4-433E-47B5-B663-E79B5569EE22}.Debug|x86.Build.0 = Debug|x86
+ {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|x86.ActiveCfg = Release|x86
+ {D41D53C4-433E-47B5-B663-E79B5569EE22}.Release|x86.Build.0 = Release|x86
+ {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|x86.ActiveCfg = Debug|x86
+ {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Debug|x86.Build.0 = Debug|x86
+ {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|x86.ActiveCfg = Release|x86
+ {12C62F60-6F52-4112-84AB-0FA8ED44EE77}.Release|x86.Build.0 = Release|x86
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs 2010-11-27 11:32:05 UTC (rev 5409)
@@ -49,14 +49,14 @@
<Property Id="APACHE_PORT" Secure="yes" Value="8008" />
<Property Id="APACHE_VERSION" Secure="yes" Value="2.2.11" />
<Property Id="PHP_VERSION" Secure="yes" Value="5.3.2" />
- <Property Id="MG_VERSION_MAJOR_MINOR" Secure="yes" Value="2.2" />
+ <Property Id="MG_VERSION_MAJOR_MINOR" Secure="yes" Value="2.3" />
<!-- Server Port Settings -->
<Property Id="MG_ADMIN_PORT" Secure="yes" Value="2810" />
<Property Id="MG_CLIENT_PORT" Secure="yes" Value="2811" />
<Property Id="MG_SITE_PORT" Secure="yes" Value="2812" />
<!-- Used by FdoRegUtil.exe -->
- <Property Id="FDO_VERSION" Secure="yes" Value="3.5.0.0" />
- <Property Id="FDO_VERSION_SMALL" Secure="yes" Value="3.5" />
+ <Property Id="FDO_VERSION" Secure="yes" Value="3.6.0.0" />
+ <Property Id="FDO_VERSION_SMALL" Secure="yes" Value="3.6" />
These are currently static, though there is opportunity in the future for these
@@ -445,7 +445,6 @@
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="FdoArcSdeProviderFeature" Order="3">1</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="FdoKingOracleProviderFeature" Order="4">1</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="FdoMySqlProviderFeature" Order="5">1</Publish>
- <Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="FdoPostGisProviderFeature" Order="6">1</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="FdoPostgreSqlProviderFeature" Order="7">1</Publish>
<!-- If Apache, or IIS and the .Net Framework is not installed, set feature default for the ASPX viewer to not install -->
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="WebExtMapViewerASPXFeature" Order="7">(MGWEB_CONFIG="APACHE") OR (MGWEB_CONFIG="IIS" AND NOT NETFRAMEWORK20)</Publish>
@@ -677,8 +676,7 @@
<Custom Action="FdoRegMySqlCmd" After="FdoRegOdbcCmd">&FdoMySqlProviderFeature>2</Custom>
<Custom Action="FdoRegGdalCmd" After="FdoRegMySqlCmd">&FdoGdalProviderFeature>2</Custom>
<Custom Action="FdoRegOgrCmd" After="FdoRegGdalCmd">&FdoOgrProviderFeature>2</Custom>
- <Custom Action="FdoRegPostGisCmd" After="FdoRegOgrCmd">&FdoPostGisProviderFeature>2</Custom>
- <Custom Action="FdoRegPostgreSqlCmd" After="FdoRegPostGisCmd">&FdoPostgreSqlProviderFeature>2</Custom>
+ <Custom Action="FdoRegPostgreSqlCmd" After="FdoRegOgrCmd">&FdoPostgreSqlProviderFeature>2</Custom>
<Custom Action="FdoRegOracleCmd" After="FdoRegPostgreSqlCmd">&FdoKingOracleProviderFeature>2</Custom>
<Custom Action="FdoRegSqlServerCmd" After="FdoRegOracleCmd">&FdoSqlServerSpatialProviderFeature>2</Custom>
<Custom Action="FdoRegSltCmd" After="FdoRegSqlServerCmd">&FdoSltProviderFeature>2</Custom>
@@ -693,8 +691,7 @@
<Custom Action="FdoRegMySql" After="FdoRegOdbc">&FdoMySqlProviderFeature>2</Custom>
<Custom Action="FdoRegGdal" After="FdoRegMySql">&FdoGdalProviderFeature>2</Custom>
<Custom Action="FdoRegOgr" After="FdoRegGdal">&FdoOgrProviderFeature>2</Custom>
- <Custom Action="FdoRegPostGis" After="FdoRegOgr">&FdoPostGisProviderFeature>2</Custom>
- <Custom Action="FdoRegPostgreSql" After="FdoRegPostGis">&FdoPostgreSqlProviderFeature>2</Custom>
+ <Custom Action="FdoRegPostgreSql" After="FdoRegOgr">&FdoPostgreSqlProviderFeature>2</Custom>
<Custom Action="FdoRegOracle" After="FdoRegPostgreSql">&FdoKingOracleProviderFeature>2</Custom>
<Custom Action="FdoRegSqlServer" After="FdoRegOracle">&FdoSqlServerSpatialProviderFeature>2</Custom>
<Custom Action="FdoRegSlt" After="FdoRegSqlServer">&FdoSltProviderFeature>2</Custom>
@@ -709,8 +706,7 @@
<Custom Action="FdoUnRegMySqlCmd" After="FdoUnRegOdbcCmd">&FdoMySqlProviderFeature=2</Custom>
<Custom Action="FdoUnRegGdalCmd" After="FdoUnRegMySqlCmd">&FdoGdalProviderFeature=2</Custom>
<Custom Action="FdoUnRegOgrCmd" After="FdoUnRegGdalCmd">&FdoOgrProviderFeature=2</Custom>
- <Custom Action="FdoUnRegPostGisCmd" After="FdoUnRegOgrCmd">&FdoPostGisProviderFeature=2</Custom>
- <Custom Action="FdoUnRegPostgreSqlCmd" After="FdoUnRegPostGisCmd">&FdoPostgreSqlProviderFeature=2</Custom>
+ <Custom Action="FdoUnRegPostgreSqlCmd" After="FdoUnRegOgrCmd">&FdoPostgreSqlProviderFeature=2</Custom>
<Custom Action="FdoUnRegOracleCmd" After="FdoUnRegPostgreSqlCmd">&FdoKingOracleProviderFeature=2</Custom>
<Custom Action="FdoUnRegSqlServerCmd" After="FdoUnRegOracleCmd">&FdoSqlServerSpatialProviderFeature=2</Custom>
<Custom Action="FdoUnRegSltCmd" After="FdoUnRegSqlServerCmd">&FdoSltProviderFeature=2</Custom>
@@ -725,8 +721,7 @@
<Custom Action="FdoUnRegMySql" After="FdoUnRegOdbc">&FdoMySqlProviderFeature=2</Custom>
<Custom Action="FdoUnRegGdal" After="FdoUnRegMySql">&FdoGdalProviderFeature=2</Custom>
<Custom Action="FdoUnRegOgr" After="FdoUnRegGdal">&FdoOgrProviderFeature=2</Custom>
- <Custom Action="FdoUnRegPostGis" After="FdoUnRegOgr">&FdoPostGisProviderFeature=2</Custom>
- <Custom Action="FdoUnRegPostgreSql" After="FdoUnRegPostGis">&FdoPostgreSqlProviderFeature=2</Custom>
+ <Custom Action="FdoUnRegPostgreSql" After="FdoUnRegOgr">&FdoPostgreSqlProviderFeature=2</Custom>
<Custom Action="FdoUnRegOracle" After="FdoUnRegPostgreSql">&FdoKingOracleProviderFeature=2</Custom>
<Custom Action="FdoUnRegSqlServer" After="FdoUnRegOracle">&FdoSqlServerSpatialProviderFeature=2</Custom>
<Custom Action="FdoUnRegSlt" After="FdoUnRegSqlServer">&FdoSltProviderFeature=2</Custom>
Modified: trunk/Installer/Libraries/MapGuide Server/FDO.wxs
--- trunk/Installer/Libraries/MapGuide Server/FDO.wxs 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Libraries/MapGuide Server/FDO.wxs 2010-11-27 11:32:05 UTC (rev 5409)
@@ -19,7 +19,6 @@
<CustomAction Execute="immediate" Id="FdoRegMySqlCmd" Property="FdoRegMySql" Value="[FdoReg] -r "OSGeo.MySQL.[FDO_VERSION_SMALL]" "!(loc.MySqlProvider)" "!(loc.MySqlProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\MySQLProvider.dll"" />
<CustomAction Execute="immediate" Id="FdoRegGdalCmd" Property="FdoRegGdal" Value="[FdoReg] -r "OSGeo.Gdal.[FDO_VERSION_SMALL]" "!(loc.GdalProvider)" "!(loc.GdalProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\GRFPProvider.dll"" />
<CustomAction Execute="immediate" Id="FdoRegOgrCmd" Property="FdoRegOgr" Value="[FdoReg] -r "OSGeo.OGR.[FDO_VERSION_SMALL]" "!(loc.OgrProvider)" "!(loc.OgrProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\OGRProvider.dll"" />
- <CustomAction Execute="immediate" Id="FdoRegPostGisCmd" Property="FdoRegPostGis" Value="[FdoReg] -r "OSGeo.PostGIS.[FDO_VERSION_SMALL]" "!(loc.PostGisProvider)" "!(loc.PostGisProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\PostGISProvider.dll"" />
<CustomAction Execute="immediate" Id="FdoRegPostgreSqlCmd" Property="FdoRegPostgreSql" Value="[FdoReg] -r "OSGeo.PostgreSQL.[FDO_VERSION_SMALL]" "!(loc.PostgreSqlProvider)" "!(loc.PostgreSqlProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\PostgreSQLProvider.dll"" />
<CustomAction Execute="immediate" Id="FdoRegOracleCmd" Property="FdoRegOracle" Value="[FdoReg] -r "King.Oracle.[FDO_VERSION_SMALL]" "!(loc.KingOracleProvider)" "!(loc.KingOracleProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\KingOracleProvider.dll"" />
<CustomAction Execute="immediate" Id="FdoRegSqlServerCmd" Property="FdoRegSqlServer" Value="[FdoReg] -r "OSGeo.SQLServerSpatial.[FDO_VERSION_SMALL]" "!(loc.SqlServerProvider)" "!(loc.SqlServerProviderDesc)" "[FDO_VERSION]" "[FDO_VERSION]" ".\SQLServerSpatialProvider.dll"" />
@@ -34,7 +33,6 @@
<CustomAction Id="FdoRegMySql" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoRegGdal" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoRegOgr" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
- <CustomAction Id="FdoRegPostGis" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoRegPostgreSql" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoRegOracle" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoRegSqlServer" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
@@ -49,7 +47,6 @@
<CustomAction Execute="immediate" Id="FdoUnRegMySqlCmd" Property="FdoUnRegMySql" Value="[FdoReg] -u "OSGeo.MySQL.[FDO_VERSION_SMALL]"" />
<CustomAction Execute="immediate" Id="FdoUnRegGdalCmd" Property="FdoUnRegGdal" Value="[FdoReg] -u "OSGeo.Gdal.[FDO_VERSION_SMALL]"" />
<CustomAction Execute="immediate" Id="FdoUnRegOgrCmd" Property="FdoUnRegOgr" Value="[FdoReg] -u "OSGeo.OGR.[FDO_VERSION_SMALL]"" />
- <CustomAction Execute="immediate" Id="FdoUnRegPostGisCmd" Property="FdoUnRegPostGis" Value="[FdoReg] -u "OSGeo.PostGIS.[FDO_VERSION_SMALL]"" />
<CustomAction Execute="immediate" Id="FdoUnRegPostgreSqlCmd" Property="FdoUnRegPostgresSql" Value="[FdoReg] -u "OSGeo.PostgreSQL.[FDO_VERSION_SMALL]"" />
<CustomAction Execute="immediate" Id="FdoUnRegOracleCmd" Property="FdoUnRegOracle" Value="[FdoReg] -u "King.Oracle.[FDO_VERSION_SMALL]"" />
<CustomAction Execute="immediate" Id="FdoUnRegSqlServerCmd" Property="FdoUnRegSqlServer" Value="[FdoReg] -u "OSGeo.SQLServerSpatial.[FDO_VERSION_SMALL]"" />
@@ -64,7 +61,6 @@
<CustomAction Id="FdoUnRegMySql" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoUnRegGdal" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoUnRegOgr" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
- <CustomAction Id="FdoUnRegPostGis" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoUnRegPostgreSql" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoUnRegOracle" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<CustomAction Id="FdoUnRegSqlServer" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
@@ -92,8 +88,8 @@
<!-- FDO Core -->
<Component Id="FdoCoreCompnent" Win64="$(var.Win64)" Guid="90F4CB26-524F-499B-AA22-BD17036B167D">
<File Id="FdoRegUtil" Checksum="yes" Source="$(var.MgSource)\Server\FDO\FdoRegUtil.exe" />
- <File Id="FdoBoostDateTime" Checksum="yes" Source="$(var.MgSource)\Server\FDO\boost_date_time-vc90-mt-1_34_1.dll" />
- <File Id="FdoBoostThread" Checksum="yes" Source="$(var.MgSource)\Server\FDO\boost_thread-vc90-mt-1_34_1.dll" />
+ <File Id="FdoBoostDateTime" Checksum="yes" Source="$(var.MgSource)\Server\FDO\boost_date_time-vc90-mt-1_42.dll" />
+ <File Id="FdoBoostThread" Checksum="yes" Source="$(var.MgSource)\Server\FDO\boost_thread-vc90-mt-1_42.dll" />
<File Id="FdoExpressionEngine" Checksum="yes" Source="$(var.MgSource)\Server\FDO\ExpressionEngine.dll" />
<File Id="FdoCore" Checksum="yes" Source="$(var.MgSource)\Server\FDO\FDO.dll" />
<File Id="FdoCommon" Checksum="yes" Source="$(var.MgSource)\Server\FDO\FDOCommon.dll" />
@@ -101,10 +97,10 @@
<File Id="FdoMessage" Checksum="yes" Source="$(var.MgSource)\Server\FDO\FDOMessage.dll" />
<File Id="FdoSpatial" Checksum="yes" Source="$(var.MgSource)\Server\FDO\FDOSpatial.dll" />
<File Id="FdoOWS" Checksum="yes" Source="$(var.MgSource)\Server\FDO\OWS.dll" />
- <File Id="GdalLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\gdal16.dll" />
- <File Id="XalanLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\Xalan-C_1_7_0.dll" />
- <File Id="XalanMessagesLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\XalanMessages_1_7_0.dll" />
- <File Id="XercesLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\xerces-c_2_5_0.dll" />
+ <File Id="GdalLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\gdal17.dll" />
+ <File Id="XalanLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\Xalan-C_1_11.dll" />
+ <File Id="XalanMessagesLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\XalanMessages_1_11.dll" />
+ <File Id="XercesLib" Checksum="yes" Source="$(var.MgSource)\Server\FDO\xerces-c_3_1.dll" />
<!-- Generic RDBMS -->
<File Id="RdbmsMsg" Checksum="yes" Source="$(var.MgSource)\Server\FDO\RdbmsMsg.dll" />
<File Id="RdbmsOverrides" Checksum="yes" Source="$(var.MgSource)\Server\FDO\RdbmsOverrides.dll" />
@@ -142,12 +138,6 @@
<Component Id="FdoOgrProviderComponent" Win64="$(var.Win64)" Guid="7FB890D4-8824-478E-83F6-E14DF2A3F949">
<File Id="OgrProvider" Checksum="yes" Source="$(var.MgSource)\Server\FDO\OGRProvider.dll" />
</Component>
- <!-- PostGIS (legacy) Provider -->
- <Component Id="FdoPostGisProviderComponent" Win64="$(var.Win64)" Guid="1D51342F-3ECC-4053-8475-F70333B4B22D">
- <File Id="PostGisMessage" Checksum="yes" Source="$(var.MgSource)\Server\FDO\PostGISMessage.dll" />
- <File Id="PostGisOverrides" Checksum="yes" Source="$(var.MgSource)\Server\FDO\PostGISOverrides.dll" />
- <File Id="PostGisProvider" Checksum="yes" Source="$(var.MgSource)\Server\FDO\PostGISProvider.dll" />
- </Component>
<!-- PostGIS (new) Provider -->
<Component Id="FdoPostgreSqlProviderComponent" Win64="$(var.Win64)" Guid="550B6CA0-10F8-444B-B51B-8569FF23B8C2">
<File Id="PostgreSqlOverrides" Checksum="yes" Source="$(var.MgSource)\Server\FDO\PostgreSQLOverrides.dll" />
@@ -208,9 +198,6 @@
<Feature Id="FdoOgrProviderFeature" Title="!(loc.OgrProvider)" Level="1" Description="!(loc.OgrProviderDesc)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local">
<ComponentRef Id="FdoOgrProviderComponent" />
</Feature>
- <Feature Id="FdoPostGisProviderFeature" Title="!(loc.PostGisProvider)" Level="1" Description="!(loc.PostGisProviderDesc)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local">
- <ComponentRef Id="FdoPostGisProviderComponent" />
- </Feature>
<Feature Id="FdoPostgreSqlProviderFeature" Title="!(loc.PostgreSqlProvider)" Level="1" Description="!(loc.PostgreSqlProviderDesc)" AllowAdvertise="no" TypicalDefault="install" InstallDefault="local">
<ComponentRef Id="FdoPostgreSqlProviderComponent" />
</Feature>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs 2010-11-27 11:32:05 UTC (rev 5409)
@@ -9,6 +9,10 @@
<?define Win64 = "no" ?>
<?define PlatformProgramFilesFolder = "ProgramFilesFolder" ?>
<?endif ?>
+ <!-- isapi_MapAgent.dll -->
+ <?define FCGI_MAP = "[!file_MAPAGENTFILES_100]" ?>
+ <!-- php5isapi.dll -->
+ <?define PHP_MAP = "[!file_PHPFILES_43]" ?>
<Fragment>
<Property Id="FRAMEWORKDIR">
<RegistrySearch
@@ -59,7 +63,7 @@
<iis:WebVirtualDir Id="IIS5MapGuideVDir" Alias="[VIRTUALDIR]" Directory="WEBROOTLOCATION" WebSite="IISDefaultWebSite">
<iis:WebDirProperties Id="IIS5MapGuideDocuments" DefaultDocuments="index.php,index.html,index.htm,default.aspx,index.aspx,default.htm,default.html" AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no"/>
<iis:WebApplication Id="IIS5MapGuideWebApp" Name="[VIRTUALDIR]">
- <iis:WebApplicationExtension Extension="php" Script="yes" Verbs="GET,POST" CheckPath="no" Executable="[!file_PHPFILES_42]" />
+ <iis:WebApplicationExtension Extension="php" Script="yes" Verbs="GET,POST" CheckPath="no" Executable="$(var.PHP_MAP)" />
</iis:WebApplication>
<iis:WebVirtualDir Id="IIS5MapAgentVDir" Alias="mapagent" Directory="dir_mapagent_0" >
<iis:WebDirProperties Id="IIS5MapAgentProperties" DefaultDocuments="index.html" AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no"/>
@@ -70,8 +74,8 @@
<iis:WebError ErrorCode="401" SubCode="4" />
<iis:WebError ErrorCode="401" SubCode="5" />
<iis:WebApplication Id="IIS5MapAgentWebApp" Name="mapagent" >
- <iis:WebApplicationExtension Extension="fcgi" Script="yes" Verbs="GET,POST" CheckPath="no" Executable="[!file_MAPAGENTFILES_98]" />
+ <iis:WebApplicationExtension Extension="fcgi" Script="yes" Verbs="GET,POST" CheckPath="no" Executable="$(var.FCGI_MAP)" />
</iis:WebVirtualDir>
<iis:WebVirtualDir Id="IIS5MapAdminVDir" Alias="mapadmin" Directory="dir_mapadmin_0" >
@@ -115,13 +119,13 @@
<Condition>MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#6"</Condition>
<CreateFolder />
<iis:WebAppPool Id="IIS6MapGuideAppPool" Name="[APP_POOL_NAME]" />
- <iis:WebServiceExtension Id="IIS6PhpWebServiceExt" Allow="yes" Description="MapGuide PHP ISAPI Extension" File="[!file_PHPFILES_42]" />
- <iis:WebServiceExtension Id="IIS6MapGuideWebServiceExt" Allow="yes" Description="MapGuide MapAgent ISAPI Extension" File="[!file_MAPAGENTFILES_98]" />
+ <iis:WebServiceExtension Id="IIS6PhpWebServiceExt" Allow="yes" Description="MapGuide PHP ISAPI Extension" File="$(var.PHP_MAP)" />
+ <iis:WebServiceExtension Id="IIS6MapGuideWebServiceExt" Allow="yes" Description="MapGuide MapAgent ISAPI Extension" File="$(var.FCGI_MAP)" />
<iis:WebVirtualDir Id="IIS6MapGuideVDir" Alias="[VIRTUALDIR]" Directory="WEBROOTLOCATION" WebSite="IISDefaultWebSite" >
<iis:WebDirProperties Id="IIS6MapGuideDocuments" DefaultDocuments="index.php,index.html,index.htm,default.aspx,index.aspx,default.htm,default.html" AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no" />
<iis:MimeMap Id="IIS6JsonMimeType" Type="application/json" Extension =".json" />
<iis:WebApplication Id="IIS6MapGuideWebApp" Name="[VIRTUALDIR]" WebAppPool="IIS6MapGuideAppPool" >
<iis:WebVirtualDir Id="IIS6MapAgentVDir" Alias="mapagent" Directory="dir_mapagent_0" >
<iis:WebDirProperties Id="IIS6MapAgentProperties" DefaultDocuments="index.html" AnonymousAccess="yes" BasicAuthentication="no" WindowsAuthentication="no" />
@@ -132,8 +136,8 @@
<iis:WebApplication Id="IIS6MapAgentWebApp" Name="mapagent" WebAppPool="IIS6MapGuideAppPool">
<iis:WebVirtualDir Id="IIS6MapAdminVDir" Alias="mapadmin" Directory="dir_mapadmin_0" >
Modified: trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf 2010-11-27 11:32:05 UTC (rev 5409)
@@ -120,16 +120,16 @@
#Listen 12.34.56.78:80
Listen %MG_WEB_PORT%
-LoadFile "%MG_WEB_PHP%php5ts.dll"
-LoadFile "%MG_WEB_PHP%ACE.dll"
-LoadFile "%MG_WEB_PHP%MgHttpHandler.dll"
-LoadFile "%MG_WEB_PHP%MgFoundation.dll"
-LoadFile "%MG_WEB_PHP%MgGeometry.dll"
-LoadFile "%MG_WEB_PHP%MgMapGuideCommon.dll"
-LoadFile "%MG_WEB_PHP%MgMdfModel.dll"
-LoadFile "%MG_WEB_PHP%MgMdfParser.dll"
-LoadFile "%MG_WEB_PHP%MgPlatformBase.dll"
-LoadFile "%MG_WEB_PHP%MgWebApp.dll"
+LoadFile "%MG_WEB_PHP%/php5ts.dll"
+LoadFile "%MG_WEB_PHP%/ACE.dll"
+LoadFile "%MG_WEB_PHP%/MgHttpHandler.dll"
+LoadFile "%MG_WEB_PHP%/MgFoundation.dll"
+LoadFile "%MG_WEB_PHP%/MgGeometry.dll"
+LoadFile "%MG_WEB_PHP%/MgMapGuideCommon.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfModel.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfParser.dll"
+LoadFile "%MG_WEB_PHP%/MgPlatformBase.dll"
+LoadFile "%MG_WEB_PHP%/MgWebApp.dll"
# Dynamic Shared Object (DSO) Support
Modified: trunk/Installer/Support/Web/x64/Php/php.ini
--- trunk/Installer/Support/Web/x64/Php/php.ini 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Support/Web/x64/Php/php.ini 2010-11-27 11:32:05 UTC (rev 5409)
@@ -628,7 +628,7 @@
;extension=php_exif.dll
;extension=php_fdf.dll
;extension=php_filepro.dll
-;extension=php_gd2.dll
+extension=php_gd2.dll
;extension=php_gettext.dll
;extension=php_ifx.dll
;extension=php_iisfunc.dll
Modified: trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf 2010-11-27 11:32:05 UTC (rev 5409)
Modified: trunk/Installer/Support/Web/x86/Php/php.ini
--- trunk/Installer/Support/Web/x86/Php/php.ini 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/Support/Web/x86/Php/php.ini 2010-11-27 11:32:05 UTC (rev 5409)
@@ -628,7 +628,7 @@
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/build.bat 2010-11-27 11:32:05 UTC (rev 5409)
@@ -44,10 +44,10 @@
SET CPUTYPE=x86
SET TYPEBUILD=Release
SET CULTURE=en-US
-SET INSTALLER_VERSION_MAJOR_MINOR_REV=2.2.0
+SET INSTALLER_VERSION_MAJOR_MINOR_REV=2.3.0
SET INSTALLER_NAME=MapGuideOpenSource-%INSTALLER_VERSION_MAJOR_MINOR_REV%-Trunk-%CULTURE%-%TYPEBUILD%-%CPUTYPE%
SET INSTALLER_VERSION=%INSTALLER_VERSION_MAJOR_MINOR_REV%.0
-SET INSTALLER_TITLE="MapGuide Open Source 2.2 Trunk (%TYPEBUILD%)"
+SET INSTALLER_TITLE="MapGuide Open Source 2.3 Trunk (%TYPEBUILD%)"
SET MG_REG_KEY=Software\OSGeo\MapGuide\%INSTALLER_VERSION_MAJOR_MINOR_REV%
SET MG_SOURCE=%CD%\..\MgDev\%TYPEBUILD%
SET MG_SOURCE_INC=
@@ -58,7 +58,7 @@
rem MapGuide Installer vars
rem ==================================================
SET INSTALLER_DEV=%CD%
-SET INSTALLER_OUTPUT=%INSTALLER_DEV%\Output\%CULTURE%\%TYPEBUILD%
+SET INSTALLER_OUTPUT=%INSTALLER_DEV%\Output\%CULTURE%
SET INSTALLER_DEV_SUPPORT=%INSTALLER_DEV%\Support
SET INSTALLER_DEV_BOOTSTRAP=%INSTALLER_DEV%\Bootstrapper
@@ -71,7 +71,7 @@
SET NSIS=%CD%\Support\NSIS
SET PARAFFIN=%CD%
-SET PATH=%PATH%;%PARAFFIN%;%NSIS%
+SET PATH=%PATH%;%PARAFFIN%;%NSIS%;%WIX%\bin\
rem MSBuild Settings
@@ -150,9 +150,9 @@
:get_conf
SET TYPEBUILD=%2
-SET INSTALLER_OUTPUT=%CD%\Installers\MapGuide\bin\%TYPEBUILD%
-SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
-SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /t:Clean %MSBUILD_VERBOSITY%
+REM SET INSTALLER_OUTPUT=%CD%\Installers\MapGuide\bin\%TYPEBUILD%
+SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /p:Platform=Win32 %MSBUILD_VERBOSITY% %MSBUILD_LOG%
+SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /p:Platform=Win32 /t:Clean %MSBUILD_VERBOSITY%
IF NOT ""=="%MG_SOURCE_INC%" SET MG_SOURCE_INC=%MG_SOURCE%
@@ -190,25 +190,10 @@
if "%TYPEACTION%"=="regen" goto regen
:clean
-echo [clean]: FdoRegUtil
-pushd %INSTALLER_FDO_REG_UTIL%
-%MSBUILD_CLEAN% FdoRegUtil.vcproj
-popd
-echo [clean]: CS-Map
-pushd "%INSTALLER_DEV_CSMAP%"
-%MSBUILD_CLEAN% "CS Map.wixproj"
-popd
-echo [clean]: MapGuide Server
-pushd "%INSTALLER_DEV_MGSERVER%"
-%MSBUILD_CLEAN% "MapGuide Server.wixproj"
-popd
-echo [clean]: MapGuide Web
-pushd "%INSTALLER_DEV_MGWEB%"
-%MSBUILD_CLEAN% "MapGuide Web Extensions.wixproj"
-popd
+echo [clean]: Installer Pre-Reqs
+%MSBUILD_CLEAN% InstallerPreReq.sln
-%MSBUILD_CLEAN% Installer.sln
-popd
+%MSBUILD_CLEAN% InstallerWix.sln
goto quit
:prepare
@@ -216,9 +201,8 @@
if not exist "%MG_SOURCE%\Server" goto error_mg_server_not_found
if not exist "%MG_SOURCE%\Web" goto error_mg_web_not_found
if not exist "%MG_SOURCE%\CS-Map" goto error_mg_csmap_not_found
-echo [prepare] FdoRegUtil.exe
-%MSBUILD% FdoRegUtil.vcproj
+echo [prepare] Installer Pre-Requisites
+%MSBUILD% InstallerPreReq.sln
copy %INSTALLER_FDO_REG_UTIL%\%TYPEBUILD%\FdoRegUtil.exe %MG_SOURCE%\Server\FDO
popd
rem copy support files into server and web directories
@@ -398,15 +382,14 @@
goto quit
:build
-echo [build]: Installer
SET RUN_BUILD=%MSBUILD% /p:OutputName=%INSTALLER_NAME%;MgCulture=%CULTURE%;MgTitle=%INSTALLER_TITLE%;MgVersion=%INSTALLER_VERSION%;MgRegKey=%MG_REG_KEY%;MgPlatform=%CPUTYPE%
if not ""=="%MG_SOURCE_INC%" set RUN_BUILD=%RUN_BUILD%;MgSource=%MG_SOURCE_INC%
-set RUN_BUILD=%RUN_BUILD% Installer.sln
-%RUN_BUILD%
+echo [build]: Installer
+%RUN_BUILD% InstallerWix.sln
if "%errorlevel%"=="1" goto error
pushd "%INSTALLER_DEV_BOOTSTRAP%"
-echo [bootstrap]: Creating
-%MSBUILD% /p:TargetFile=%INSTALLER_NAME%.msi Bootstrap-x86.proj
+echo [bootstrap]: Copying vcredist
+copy /Y vcredist_x86.exe "%INSTALLER_OUTPUT%\vcredist_x86.exe"
popd
if "%MAX_COMPRESSION%"=="YES" goto build_max_compress
Modified: trunk/Installer/build64.bat
--- trunk/Installer/build64.bat 2010-11-27 05:16:58 UTC (rev 5408)
+++ trunk/Installer/build64.bat 2010-11-27 11:32:05 UTC (rev 5409)
@@ -45,10 +45,10 @@
SET CONFIGURATION=Release
SET PLATFORM=x64
SET CULTURE=en-US
SET INSTALLER_NAME=MapGuideOpenSource-%INSTALLER_VERSION_MAJOR_MINOR_REV%-Trunk-%CULTURE%-%TYPEBUILD%-%PLATFORM%
SET MG_SOURCE_INC=
@@ -239,9 +239,8 @@
popd
@@ -421,15 +420,14 @@
goto quit
:build
SET RUN_BUILD=%MSBUILD% /p:OutputName=%INSTALLER_NAME%;MgCulture=%CULTURE%;MgTitle=%INSTALLER_TITLE%;MgVersion=%INSTALLER_VERSION%;MgRegKey=%MG_REG_KEY%;MgPlatform=%PLATFORM%
-%RUN_BUILD%
-%MSBUILD% /p:TargetFile=%INSTALLER_NAME%.msi Bootstrap-x64.proj
+copy /Y vcredist_x64.exe "%INSTALLER_OUTPUT%\vcredist_x64.exe"
popd
More information about the mapguide-commits
