[mapguide-commits] r5416 - trunk/MgDev
svn_mapguide at osgeo.org
Tue Nov 30 03:22:25 EST 2010
Author: jng
Date: 2010-11-30 00:22:25 -0800 (Tue, 30 Nov 2010)
New Revision: 5416
trunk/MgDev/build.bat
trunk/MgDev/build64.bat
Externalize dbxml and db version numbers in build.bat
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat 2010-11-30 08:21:57 UTC (rev 5415)
+++ trunk/MgDev/build.bat 2010-11-30 08:22:25 UTC (rev 5416)
@@ -55,6 +55,9 @@
rem ==================================================
SET MG_DEV=%CD%
SET MG_OEM=%MG_DEV%\Oem
+rem DBXML seems to change frequently enough that we should externalize this information
+SET MG_OEM_DBXML=dbxml
+SET MG_OEM_DB=db-4.8.26
SET MG_COMMON=%MG_DEV%\Common
SET MG_SERVER=%MG_DEV%\Server
SET MG_WEB=%MG_DEV%\Web
@@ -374,8 +377,8 @@
echo [install]: Server - WMS
%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wms" "%MG_OUTPUT_SERVER%\wms" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Server - DBXML
-copy /Y "%MG_OEM%\dbxml-2.3.10\db-4.5.20\build_windows\Release\*.exe" "%MG_OUTPUT_SERVER%\bin"
-copy /Y "%MG_OEM%\dbxml-2.3.10\bin\*.exe" "%MG_OUTPUT_SERVER%\bin"
+copy /Y "%MG_OEM%\%MG_OEM_DBXML%\%MG_OEM_DB%\build_windows\%TYPEBUILD%32\*.exe" "%MG_OUTPUT_SERVER%\bin"
+copy /Y "%MG_OEM%\%MG_OEM_DBXML%\bin\*.exe" "%MG_OUTPUT_SERVER%\bin"
echo [install]: Server - RepositoryAdmin
%XCOPY% "%MG_SERVER%\RepositoryAdmin" "%MG_OUTPUT_SERVER%\RepositoryAdmin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: CsMap Dictionaries
Modified: trunk/MgDev/build64.bat
--- trunk/MgDev/build64.bat 2010-11-30 08:21:57 UTC (rev 5415)
+++ trunk/MgDev/build64.bat 2010-11-30 08:22:25 UTC (rev 5416)
@@ -57,6 +57,9 @@
SET MG_DEV=%CD%
@@ -400,8 +403,8 @@
%XCOPY% "%MG_SERVER%\bin\%TYPEBUILD%\wms" "%MG_OUTPUT_SERVER%\wms" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
-copy /Y "%MG_OEM%\dbxml-2.3.10\db-4.5.20\build_windows\%TYPEBUILD%\*.exe" "%MG_OUTPUT_SERVER%\bin"
-copy /Y "%MG_OEM%\dbxml-2.3.10\bin64\*.exe" "%MG_OUTPUT_SERVER%\bin"
+copy /Y "%MG_OEM%\%MG_OEM_DBXML%\%MG_OEM_DB%\build_windows\%TYPEBUILD%64\*.exe" "%MG_OUTPUT_SERVER%\bin"
+copy /Y "%MG_OEM%\%MG_OEM_DBXML%\bin64\*.exe" "%MG_OUTPUT_SERVER%\bin"
%XCOPY% "%MG_SERVER%\RepositoryAdmin" "%MG_OUTPUT_SERVER%\RepositoryAdmin" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
More information about the mapguide-commits
