[mapguide-commits] r5418 - trunk/MgDev
svn_mapguide at osgeo.org
Tue Nov 30 06:32:46 EST 2010
Author: jng
Date: 2010-11-30 03:32:46 -0800 (Tue, 30 Nov 2010)
New Revision: 5418
trunk/MgDev/build_sdk.bat
Add missing files (turns out ACE and xerces need more than just headers) and MgRenderers.dll has linkage with missing gd.dll.
With some project include/linker tweaks to the previously mentioned AU snapshot sample, it builds and runs successfully using the output produced by this script!
Modified: trunk/MgDev/build_sdk.bat
--- trunk/MgDev/build_sdk.bat 2010-11-30 09:01:12 UTC (rev 5417)
+++ trunk/MgDev/build_sdk.bat 2010-11-30 11:32:46 UTC (rev 5418)
@@ -292,7 +292,6 @@
:install
:install_sdk
echo [install]: SDK
-if not exist "%MG_SDK_INC%\ACE" mkdir "%MG_SDK_INC%\ACE"
if not exist "%MG_SDK_INC%\Fdo" mkdir "%MG_SDK_INC%\Fdo"
if not exist "%MG_SDK_LIB%\Fdo" mkdir "%MG_SDK_LIB%\Fdo"
if not exist "%MG_SDK_BIN%\Fdo" mkdir "%MG_SDK_BIN%\Fdo"
@@ -305,13 +304,19 @@
copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.pdb" "%MG_SDK_BIN%"
copy /Y "%MG_OEM%\ACE\ACE_wrappers\lib\ACE.lib" "%MG_SDK_LIB%"
rem Due to hard dependency, we need the header files too
-%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.h" "%MG_SDK_INC%\ACE" /EXCLUDE:svn_excludes.txt
+%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.h" "%MG_SDK_INC%\ACE_wrappers\ACE" /EXCLUDE:svn_excludes.txt
+%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.inl" "%MG_SDK_INC%\ACE_wrappers\ACE" /EXCLUDE:svn_excludes.txt
+%XCOPY% /S "%MG_OEM%\ACE\ACE_wrappers\ace\*.cpp" "%MG_SDK_INC%\ACE_wrappers\ACE" /EXCLUDE:svn_excludes.txt
rem GEOS
copy /Y "%MG_OEM%\geos-2.2.0\VisualStudio\%TYPEBUILD%\GEOS.dll" "%MG_SDK_BIN%"
copy /Y "%MG_OEM%\geos-2.2.0\VisualStudio\%TYPEBUILD%\GEOS.pdb" "%MG_SDK_BIN%"
rem xerces
copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3_1mg.dll" "%MG_SDK_BIN%"
copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3_1mg.pdb" "%MG_SDK_BIN%"
+copy /Y "%MG_OEM%\dbxml\xerces-c-src\Build\Win32\VC9\%TYPEBUILD%\xerces-c_3mg.lib" "%MG_SDK_LIB%"
+%XCOPY% /S "%MG_OEM%\dbxml\xerces-c-src\src\*.h" "%MG_SDK_INC%\xerces" /EXCLUDE:svn_excludes.txt
+%XCOPY% /S "%MG_OEM%\dbxml\xerces-c-src\src\*.hpp" "%MG_SDK_INC%\xerces" /EXCLUDE:svn_excludes.txt
+%XCOPY% /S "%MG_OEM%\dbxml\xerces-c-src\src\*.c" "%MG_SDK_INC%\xerces" /EXCLUDE:svn_excludes.txt
echo [install]: SDK - FDO
rem FDO SDK. Copy each subdir into each respective "Fdo" subdirectory to distinguish FDO files from MG files
%XCOPY% "%MG_OEM%\FDO\bin\%TYPEBUILD%" "%MG_SDK_BIN%\Fdo"
@@ -322,6 +327,9 @@
copy /Y "%MG_COMMON%\bin\%TYPEBUILD%\*.dll" "%MG_SDK_BIN%
copy /Y "%MG_COMMON%\lib\%TYPEBUILD%\*.lib" "%MG_SDK_LIB%
copy /Y "%MG_COMMON%\bin\%TYPEBUILD%\*.pdb" "%MG_SDK_BIN%
+rem GD binary (required by Renderers)
+copy /Y "%MG_OEM%\gd\build\win32\gd\%TYPEBUILD%\gd.dll" "%MG_SDK_BIN%
+copy /Y "%MG_OEM%\gd\build\win32\gd\%TYPEBUILD%\gd.pdb" "%MG_SDK_BIN%
rem Foundation
if not exist "%MG_SDK_INC%\Foundation" mkdir "%MG_SDK_INC%\Foundation"
%XCOPY% /S "%MG_COMMON%\Foundation\*.h" "%MG_SDK_INC%\Foundation" /EXCLUDE:svn_excludes.txt
More information about the mapguide-commits
