[mapguide-commits] r5235 - trunk/MgDev/Web/src/HttpHandler
svn_mapguide at osgeo.org
Sat Oct 2 05:38:14 EDT 2010
Author: liuar
Date: 2010-10-02 09:38:13 +0000 (Sat, 02 Oct 2010)
New Revision: 5235
trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.h
Ticket #1421 OGC WFS 1.1.0 Support
15. Following two test cases:[[BR]]
Test wfs:wfs-1.1.0-Basic-GetFeature-tc47.2 (s0002/d1e35145_1/d1e740_1/d1e25225_1/d1e6254_1)
Assertion: IIf a request is unrecognizable or the service cannot process the request, a valid exception report must be returned.
Test wfs:wfs-1.1.0-Basic-GetFeature-tc47.1 (s0002/d1e35145_1/d1e740_1/d1e25225_1/d1e6249_1)
If clients specify invalid feature class or feature property, MapGuide will generate an FDO exception and send it to clients. However, what the client expected is an WFS exception. I wrappered the FDO exception with WFS exception and make sure the client could get the proper error messages.
Modified: trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2010-10-02 06:25:43 UTC (rev 5234)
+++ trunk/MgDev/Web/src/HttpHandler/HttpWfsGetFeature.cpp 2010-10-02 09:38:13 UTC (rev 5235)
@@ -23,6 +23,37 @@
#include "OgcFramework.h"
#include "OgcWfsServer.h"
+// MgException* or derivative //
+// | MgOgcWfsException::kpsz... //
+// | | OgcServer& //
+#define CATCH_MGEXCEPTION_HANDLE_AS_OGC(mg_exception_type,ogc_exception_code,ogc_server) \
+ catch (mg_exception_type* e) { \
+ STRING sReport = e->GetExceptionMessage(); \
+ ogc_server.ServiceExceptionReportResponse( \
+ MgOgcWfsException(MgOgcWfsException::ogc_exception_code, \
+ sReport.c_str() )); \
+ Ptr<MgByteReader> capabilities = responseStream.Stream().GetReader(); \
+ hResult->SetResultObject(capabilities, capabilities->GetMimeType()); \
+ e->Release(); \
+// MgOgcWfsException::kpsz... //
+// | OgcServer& //
+#define CATCH_ANYTHING_HANDLE_AS_OGC(ogc_exception_code,ogc_server) \
+ catch (...) { \
+ MgOgcWfsException(MgOgcWfsException::kpszInternalError, \
+ _("Unexpected exception was thrown. No additional details available.")));\
HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpWfsGetFeature)
/// <summary>
@@ -95,14 +126,20 @@
// Create the WFS Server object and respond to the request
MgOgcWfsServer wfsServer(requestParams, responseStream);
- wfsServer.ProcessRequest(this);
- // Obtain the response byte reader
- Ptr<MgByteReader> responseReader = responseStream.Stream().GetReader();
+ try
+ wfsServer.ProcessRequest(this);
- // Set the result
- hResult->SetResultObject(responseReader, responseReader->GetMimeType());
+ // Obtain the response byte reader
+ Ptr<MgByteReader> responseReader = responseStream.Stream().GetReader();
+ // Set the result
+ hResult->SetResultObject(responseReader, responseReader->GetMimeType());
+ CATCH_MGEXCEPTION_HANDLE_AS_OGC(MgException,kpszInternalError,wfsServer)
+ CATCH_ANYTHING_HANDLE_AS_OGC(pszInternalError,wfsServer)
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpWfsGetFeature.Execute")
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.h
--- trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.h 2010-10-02 06:25:43 UTC (rev 5234)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.h 2010-10-02 09:38:13 UTC (rev 5235)
@@ -19,6 +19,7 @@
#define _OgcWfsServer_h
#include "OgcServer.h"
+#include "OgcWfsException.h"
#include "WfsFeatureDefinitions.h"
#include "WfsFeatures.h"
More information about the mapguide-commits
