[mapguide-commits] r5265 - in
sandbox/maestro-3.0/Maestro.ResourceValidation: . Properties
svn_mapguide at osgeo.org
Sun Oct 10 21:36:58 EDT 2010
Author: jng
Date: 2010-10-10 18:36:57 -0700 (Sun, 10 Oct 2010)
New Revision: 5265
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs
Forward-port r5264 to 3.0 sandbox
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs 2010-10-11 01:30:38 UTC (rev 5264)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs 2010-10-11 01:36:57 UTC (rev 5265)
@@ -421,6 +421,33 @@
/// <summary>
+ /// Looks up a localized string similar to Context Menu contains a reference to a command that doesn't exist: {0}.
+ /// </summary>
+ internal static string WL_NonExistentMenuCommandReference {
+ get {
+ return ResourceManager.GetString("WL_NonExistentMenuCommandReference", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Task Pane contains a reference to a command that does not exist: {0}.
+ /// </summary>
+ internal static string WL_NonExistentTaskPaneCommandReference {
+ get {
+ return ResourceManager.GetString("WL_NonExistentTaskPaneCommandReference", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Toolbar contains a reference to a command that does not exist: {0}.
+ /// </summary>
+ internal static string WL_NonExistentToolbarCommandReference {
+ get {
+ return ResourceManager.GetString("WL_NonExistentToolbarCommandReference", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Layout specifies a start view that is outside the map's initial extents.
/// </summary>
internal static string WL_StartViewOutsideExtentsWarning {
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx 2010-10-11 01:30:38 UTC (rev 5264)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx 2010-10-11 01:36:57 UTC (rev 5265)
@@ -275,6 +275,15 @@
<value>Layout does not specify a map</value>
<comment>An error message that is displayed if no map is specified in the layout</comment>
</data>
+ <data name="WL_NonExistentMenuCommandReference" xml:space="preserve">
+ <value>Context Menu contains a reference to a command that doesn't exist: {0}</value>
+ </data>
+ <data name="WL_NonExistentTaskPaneCommandReference" xml:space="preserve">
+ <value>Task Pane contains a reference to a command that does not exist: {0}</value>
+ </data>
+ <data name="WL_NonExistentToolbarCommandReference" xml:space="preserve">
+ <value>Toolbar contains a reference to a command that does not exist: {0}</value>
+ </data>
<data name="WL_StartViewOutsideExtentsWarning" xml:space="preserve">
<value>Layout specifies a start view that is outside the map's initial extents</value>
<comment>A warning message that is displayed if the layout specifies a start center point that is outside the map's specified extents</comment>
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs 2010-10-11 01:30:38 UTC (rev 5264)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs 2010-10-11 01:36:57 UTC (rev 5265)
@@ -72,6 +72,37 @@
+ //Check for command references to non-existent commands
+ foreach (UIItemType item in layout.ContextMenu.MenuItem)
+ if (item.Function == UIItemFunctionType.Command)
+ CommandItemType cmdRef = (CommandItemType)item;
+ if (!cmds.ContainsKey(cmdRef.Command))
+ issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Properties.Resources.WL_NonExistentMenuCommandReference, cmdRef.Command)));
+ foreach (UIItemType item in layout.TaskPane.TaskBar.MenuButton)
+ issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Properties.Resources.WL_NonExistentTaskPaneCommandReference, cmdRef.Command)));
+ foreach (UIItemType item in layout.ToolBar.Button)
+ issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Properties.Resources.WL_NonExistentToolbarCommandReference, cmdRef.Command)));
if (recurse)
try
More information about the mapguide-commits
