[mapguide-commits] r5278 - trunk/MgDev/Server/src/Wms
svn_mapguide at osgeo.org
Tue Oct 12 22:32:42 EDT 2010
Author: liuar
Date: 2010-10-12 19:32:42 -0700 (Tue, 12 Oct 2010)
New Revision: 5278
trunk/MgDev/Server/src/Wms/1.1.1.xml.awd
trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
Ticket #1462 New CRSs cannot be supported in WMS service
All published layer headers use SRS to indicate the coordinate system which is a standard of WMS 1.1.0. But WMS 1.3.0 uses CRS to define the coordinate system.
Because there's no CRS defined in the published layer header, parent layer's CRS will be used as all children layers' CRS, which is EPSG:4326.
I update all the CRS to SRS in the template file Server/src/Wms/1.3.0.xml.awd for the backward compatibility issue.
This submission also fixes a test failure for OGC CITE WMS 1.1.0. I update the refer of the DTD which is required by OGC.
Modified: trunk/MgDev/Server/src/Wms/1.1.1.xml.awd
--- trunk/MgDev/Server/src/Wms/1.1.1.xml.awd 2010-10-13 02:09:06 UTC (rev 5277)
+++ trunk/MgDev/Server/src/Wms/1.1.1.xml.awd 2010-10-13 02:32:42 UTC (rev 5278)
@@ -132,7 +132,7 @@
<Define item="GetCapabilities.xml">
<!DOCTYPE WMT_MS_Capabilities SYSTEM
- "http://schemas.opengis.net/wms/1.1.1/capabilities_1_1_1.dtd"
+ "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
Modified: trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
--- trunk/MgDev/Server/src/Wms/1.3.0.xml.awd 2010-10-13 02:09:06 UTC (rev 5277)
+++ trunk/MgDev/Server/src/Wms/1.3.0.xml.awd 2010-10-13 02:32:42 UTC (rev 5278)
@@ -58,7 +58,7 @@
<!-- This pair of definitions works around a current limitation that -->
<!-- <?If...?><?Endif?> cannot be nested. -->
<Define item="EX_GeographicBoundingBox.xml">
- <?Translate text="&Enum.item.CRS;" with="&EX_GeographicBoundingBox.translate.xml;"?>
+ <?Translate text="&Enum.item.SRS;" with="&EX_GeographicBoundingBox.translate.xml;"?>
</Define>
<Define item="EX_GeographicBoundingBox.translate.xml">
@@ -74,11 +74,11 @@
</Define>
<Define item="BoundingBox.xml">
- <BoundingBox CRS="&Enum.item.CRS;" minx="&Enum.item.west;" miny="&Enum.item.south;" maxx="&Enum.item.east;" maxy="&Enum.item.north;"/>
+ <BoundingBox CRS="&Enum.item.SRS;" minx="&Enum.item.west;" miny="&Enum.item.south;" maxx="&Enum.item.east;" maxy="&Enum.item.north;"/>
</Define>
<Define item="CRS.xml">
- <CRS>&Enum.item.CRS;</CRS>
+ <CRS>&Enum.item.SRS;</CRS>
</Define>
<Define item="FeatureInfo.xml">
More information about the mapguide-commits
