[mapguide-commits] r5295 - in trunk/MgDev/Common: CoordinateSystem
Geometry
svn_mapguide at osgeo.org
Tue Oct 19 12:32:00 EDT 2010
Author: brucedechant
Date: 2010-10-19 09:32:00 -0700 (Tue, 19 Oct 2010)
New Revision: 5295
Added:
trunk/MgDev/Common/CoordinateSystem/CriticalSection.cpp
trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.cpp
trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.h
trunk/MgDev/Common/CoordinateSystem/CriticalSection.h
trunk/MgDev/Common/Geometry/Geometry.vcproj
trunk/MgDev/Common/Geometry/Makefile.am
Fix for trac ticket 1463 - Access to the CsMap coordinate system dictionary files is not correctly protected by the Mg API
http://trac.osgeo.org/mapguide/ticket/1463
Notes:
- Moves the CriticalClass into a separate source file
Submitted on behalf of Andr?\195?\169 Barth
Added: trunk/MgDev/Common/CoordinateSystem/CriticalSection.cpp
--- trunk/MgDev/Common/CoordinateSystem/CriticalSection.cpp (rev 0)
+++ trunk/MgDev/Common/CoordinateSystem/CriticalSection.cpp 2010-10-19 16:32:00 UTC (rev 5295)
@@ -0,0 +1,83 @@
+#ifdef _WIN32
+# include <Windows.h>
+#else
+# include <pthread.h>
+# ifndef __bsdi__
+# include <semaphore.h>
+# endif
+#endif
+#include "CriticalSection.h"
+#ifdef _WIN32
+ CRITICAL_SECTION CritSect;
+#else //LINUX
+ pthread_mutex_t CritSect;
+ pthread_mutexattr_t CritSectAttributes;
+#endif
+//declare the "global" instance of our CustomCriticalSection object we're using throughout the whole process
+CustomCriticalSection CriticalClass;
+CustomCriticalSection::CustomCriticalSection()
+ m_bInitialized = false;
+ Initialize();
+#ifdef _WIN32
+CustomCriticalSection::~CustomCriticalSection()
+ ::DeleteCriticalSection(&CritSect);
+void CustomCriticalSection::Initialize()
+ if(!m_bInitialized)
+ m_bInitialized = true;
+ ::InitializeCriticalSection(&CritSect);
+void CustomCriticalSection::Enter()
+ ::EnterCriticalSection(&CritSect);
+void CustomCriticalSection::Leave()
+ ::LeaveCriticalSection(&CritSect);
+#else //LINUX
+ pthread_mutex_destroy(&CritSect);
+ pthread_mutexattr_init(&CritSectAttributes);
+ pthread_mutexattr_settype(&CritSectAttributes, PTHREAD_MUTEX_RECURSIVE);
+ pthread_mutex_init(&CritSect, &CritSectAttributes);
+ pthread_mutexattr_destroy(&CritSectAttributes);
+ pthread_mutex_lock(&CritSect);
+ pthread_mutex_unlock(&CritSect);
+#endif //_WIN32
Property changes on: trunk/MgDev/Common/CoordinateSystem/CriticalSection.cpp
___________________________________________________________________
Added: svn:eol-style
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CriticalSection.h
--- trunk/MgDev/Common/CoordinateSystem/CriticalSection.h 2010-10-19 06:23:47 UTC (rev 5294)
+++ trunk/MgDev/Common/CoordinateSystem/CriticalSection.h 2010-10-19 16:32:00 UTC (rev 5295)
@@ -18,120 +18,24 @@
#ifndef CRITICALSECTION_H_
#define CRITICALSECTION_H_
-#ifndef _WIN32
-# include <pthread.h>
-# ifndef __bsdi__
-# include <semaphore.h>
-# endif
-#endif
+#include "SmartCriticalClass.h"
-// Critical Section Class
class CustomCriticalSection
public:
+ CustomCriticalSection();
+ ~CustomCriticalSection();
- CustomCriticalSection()
- m_bInitialized = false;
- Initialize();
+ void Initialize();
-#ifdef _WIN32
+ void Enter();
+ void Leave();
- ~CustomCriticalSection()
- ::DeleteCriticalSection(&m_CritSect);
- void Initialize()
- if(!m_bInitialized)
- m_bInitialized = true;
- ::InitializeCriticalSection(&m_CritSect);
- void Enter()
- ::EnterCriticalSection(&m_CritSect);
- void Leave()
- ::LeaveCriticalSection(&m_CritSect);
private:
- CRITICAL_SECTION m_CritSect;
-#else //LINUX
- pthread_mutex_destroy(&m_CritSect);
- void Initialize()
- pthread_mutexattr_init(&m_attributes);
- pthread_mutexattr_settype(&m_attributes, PTHREAD_MUTEX_RECURSIVE);
- pthread_mutex_init(&m_CritSect, &m_attributes);
- pthread_mutexattr_destroy(&m_attributes);
- void Enter()
- pthread_mutex_lock(&m_CritSect);
- void Leave()
- pthread_mutex_unlock(&m_CritSect);
-private:
- pthread_mutex_t m_CritSect;
- pthread_mutexattr_t m_attributes;
-#endif //_WIN32
-private:
bool m_bInitialized;
-// This is used to protect library calls
-static CustomCriticalSection CriticalClass;
+//This is used to protect *all* library calls - make sure, all comilation units refer to the same instance
+extern CustomCriticalSection CriticalClass;
-class SmartCriticalClass
-public:
- SmartCriticalClass(bool bEnter):m_bEntered(bEnter)
- if (bEnter)
- CriticalClass.Enter();
- void Enter()
- m_bEntered=true;
- ~SmartCriticalClass()
- if (m_bEntered)
- CriticalClass.Leave();
-private:
- SmartCriticalClass();
- bool m_bEntered;
#endif //CRITICALSECTION_H_
Added: trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.cpp
--- trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.cpp (rev 0)
+++ trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.cpp 2010-10-19 16:32:00 UTC (rev 5295)
@@ -0,0 +1,26 @@
+//utility implementation to access the central "CriticalClass critical section"
+SmartCriticalClass::SmartCriticalClass(bool bEnter)
+ :m_bEntered(bEnter)
+ if (bEnter)
+ CriticalClass.Enter();
+SmartCriticalClass::~SmartCriticalClass()
+ if (m_bEntered)
+ CriticalClass.Leave();
+void SmartCriticalClass::Enter()
+ m_bEntered = true;
Property changes on: trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.cpp
+ native
Added: trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.h
--- trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.h (rev 0)
+++ trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.h 2010-10-19 16:32:00 UTC (rev 5295)
@@ -0,0 +1,33 @@
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef SMARTCRITICALCLASS_H_
+#define SMARTCRITICALCLASS_H_
+class SmartCriticalClass
+public:
+ SmartCriticalClass(bool bEnter);
+ ~SmartCriticalClass();
+ void Enter();
+private:
+ bool m_bEntered;
+#endif //SMARTCRITICALCLASS_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/SmartCriticalClass.h
+ native
Modified: trunk/MgDev/Common/Geometry/Geometry.vcproj
--- trunk/MgDev/Common/Geometry/Geometry.vcproj 2010-10-19 06:23:47 UTC (rev 5294)
+++ trunk/MgDev/Common/Geometry/Geometry.vcproj 2010-10-19 16:32:00 UTC (rev 5295)
@@ -3135,6 +3135,10 @@
</File>
<File
+ RelativePath="..\CoordinateSystem\CriticalSection.cpp"
+ </File>
+ <File
RelativePath="..\CoordinateSystem\CriticalSection.h"
</File>
@@ -3166,6 +3170,14 @@
RelativePath="..\CoordinateSystem\namestruct.h"
</File>
+ <File
+ RelativePath="..\CoordinateSystem\SmartCriticalClass.cpp"
+ </File>
+ <File
+ RelativePath="..\CoordinateSystem\SmartCriticalClass.h"
+ </File>
</Filter>
<File
RelativePath=".\AgfReaderWriter.cpp"
Modified: trunk/MgDev/Common/Geometry/Makefile.am
--- trunk/MgDev/Common/Geometry/Makefile.am 2010-10-19 06:23:47 UTC (rev 5294)
+++ trunk/MgDev/Common/Geometry/Makefile.am 2010-10-19 16:32:00 UTC (rev 5295)
@@ -51,7 +51,9 @@
../CoordinateSystem/CoordSysMgrs.cpp \
../CoordinateSystem/CoordSysMgrsMajorRegion.cpp \
../CoordinateSystem/CoordSysOneGrid.cpp \
- ../CoordinateSystem/namestruct.cpp
+ ../CoordinateSystem/namestruct.cpp \
+ ../CoordinateSystem/CriticalSection.cpp \
+ ../CoordinateSystem/SmartCriticalClass.cpp
include_SOURCES = \
AgfReaderWriter.cpp \
@@ -197,7 +199,9 @@
../CoordinateSystem/CoordSysMgrsZone.cpp \
- ../CoordinateSystem/CoordSysOneGrid.cpp
+ ../CoordinateSystem/CoordSysOneGrid.cpp \
noinst_HEADERS = $(include_SOURCES) \
AgfReaderWriter.h \
@@ -408,6 +412,7 @@
../CoordinateSystem/CoordSysType.h \
../CoordinateSystem/CoordSysUtil.h \
../CoordinateSystem/CriticalSection.h \
+ ../CoordinateSystem/SmartCriticalClass.h \
../CoordinateSystem/CoordSysDictionaryUtility.h \
../CoordinateSystem/CoordSysEnumInteger32.h \
../CoordinateSystem/CoordSysMathComparator.h \
More information about the mapguide-commits
