[mapguide-commits] r5124 - in trunk/Tools/Maestro:
Maestro/LoginForm Maestro/ResourceEditors MaestroAPI
MaestroAPI/Generated MaestroAPI/RuntimeClasses
svn_mapguide at osgeo.org
Wed Sep 8 09:59:53 EDT 2010
Author: jng
Date: 2010-09-08 13:59:53 +0000 (Wed, 08 Sep 2010)
New Revision: 5124
Added:
trunk/Tools/Maestro/MaestroAPI/ReservedChar.cs
trunk/Tools/Maestro/Maestro/LoginForm/OSGeo.MapGuide.Maestro.LoginForm.csproj
trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs
trunk/Tools/Maestro/MaestroAPI/Generated/MapDefinition-1.0.0.cs
trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs
Fix #1424: Use a non-printable character (NUL) as the path separator
Modified: trunk/Tools/Maestro/Maestro/LoginForm/OSGeo.MapGuide.Maestro.LoginForm.csproj
--- trunk/Tools/Maestro/Maestro/LoginForm/OSGeo.MapGuide.Maestro.LoginForm.csproj 2010-09-08 05:22:48 UTC (rev 5123)
+++ trunk/Tools/Maestro/Maestro/LoginForm/OSGeo.MapGuide.Maestro.LoginForm.csproj 2010-09-08 13:59:53 UTC (rev 5124)
@@ -3,7 +3,7 @@
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
- <ProductVersion>9.0.30729</ProductVersion>
+ <ProductVersion>9.0.21022</ProductVersion>
<SchemaVersion>2.0</SchemaVersion>
<ProjectGuid>{4B79021A-5117-4894-BBC0-39452E4F40E3}</ProjectGuid>
<OutputType>Library</OutputType>
@@ -75,12 +75,15 @@
<ItemGroup>
<EmbeddedResource Include="FormLogin.resx">
<DependentUpon>FormLogin.cs</DependentUpon>
+ <SubType>Designer</SubType>
</EmbeddedResource>
<EmbeddedResource Include="HttpLoginCtrl.resx">
<DependentUpon>HttpLoginCtrl.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="LocalNativeLoginCtrl.resx">
<DependentUpon>LocalNativeLoginCtrl.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="Strings\FormLogin.resx">
<Generator>ResXFileCodeGenerator</Generator>
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs 2010-09-08 05:22:48 UTC (rev 5123)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs 2010-09-08 13:59:53 UTC (rev 5124)
@@ -157,15 +157,15 @@
int index = m_map.LayerGroups.IndexOf((OSGeo.MapGuide.MaestroAPI.MapLayerGroupType)trvLayerGroups.SelectedNode.Tag);
if (index >= 0)
- string new_folder_path = m_map.LayerGroups[index].GetFullPath("/", m_map) + "/";
- string prev_folder_path = new_folder_path.Substring(0, new_folder_path.Length - args.NewName.Length - 1) + args.PreviousName + "/";
+ string new_folder_path = m_map.LayerGroups[index].GetFullPath(ReservedChar.PATH_SEPARATOR, m_map) + ReservedChar.PATH_SEPARATOR;
+ string prev_folder_path = new_folder_path.Substring(0, new_folder_path.Length - args.NewName.Length - 1) + args.PreviousName + ReservedChar.PATH_SEPARATOR;
for (int i = 0; i < m_map.Layers.Count; i++)
- if (m_map.Layers[i].Group == args.PreviousName && m_map.Layers[i].GetFullPath("/", m_map) == null)
+ if (m_map.Layers[i].Group == args.PreviousName && m_map.Layers[i].GetFullPath(ReservedChar.PATH_SEPARATOR, m_map) == null)
m_map.Layers[i].Group = args.NewName;
for (int i = 0; i < m_map.LayerGroups.Count; i++)
- if (m_map.LayerGroups[i].Group == args.PreviousName && m_map.LayerGroups[i].GetFullPath("/", m_map) == null)
+ if (m_map.LayerGroups[i].Group == args.PreviousName && m_map.LayerGroups[i].GetFullPath(ReservedChar.PATH_SEPARATOR, m_map) == null)
m_map.LayerGroups[i].Group = args.NewName;
m_editor.HasChanged();
@@ -227,7 +227,7 @@
ArrayList toRemove = new ArrayList();
foreach(OSGeo.MapGuide.MaestroAPI.MapLayerGroupType group in unmapped)
- TreeNodeCollection parent = FindParentNode(group.GetFullPath("/", m_map));
+ TreeNodeCollection parent = FindParentNode(group.GetFullPath(ReservedChar.PATH_SEPARATOR, m_map));
if (parent != null)
TreeNode tn = new TreeNode(group.Name, m_editor.ResourceEditorMap.FolderIcon, m_editor.ResourceEditorMap.FolderIcon);
@@ -258,7 +258,8 @@
tn.Tag = layer;
tn.ImageIndex = tn.SelectedImageIndex = 0;
- TreeNodeCollection parent = FindParentNode(layer.GetFullPath("/", m_map));
+ var path = layer.GetFullPath(ReservedChar.PATH_SEPARATOR, m_map);
+ TreeNodeCollection parent = FindParentNode(path);
if (parent == null)
layer.Group = "";
@@ -337,7 +338,7 @@
if (fullpath == null)
return null;
- string[] path = fullpath.Split('/');
+ string[] path = fullpath.Split(Char.Parse(ReservedChar.PATH_SEPARATOR));
TreeNodeCollection nodes = trvLayerGroups.Nodes;
bool found = true;
for(int i = 0; i < path.Length - 1; i++)
@@ -1272,11 +1273,11 @@
if (index >= 0)
- string folder_path = m_map.LayerGroups[index].GetFullPath("/", m_map) + "/";
+ string folder_path = m_map.LayerGroups[index].GetFullPath(ReservedChar.PATH_SEPARATOR, m_map) + ReservedChar.PATH_SEPARATOR;
- string path = m_map.Layers[i].GetFullPath("/", m_map);
+ string path = m_map.Layers[i].GetFullPath(ReservedChar.PATH_SEPARATOR, m_map);
if (path.StartsWith(folder_path))
m_map.Layers.RemoveAt(i);
@@ -1286,7 +1287,7 @@
- string path = m_map.LayerGroups[i].GetFullPath("/", m_map);
+ string path = m_map.LayerGroups[i].GetFullPath(ReservedChar.PATH_SEPARATOR, m_map);
m_map.LayerGroups.RemoveAt(i);
@@ -2543,13 +2544,13 @@
List<MaestroAPI.MapLayerType> layers = new List<OSGeo.MapGuide.MaestroAPI.MapLayerType>();
List<MaestroAPI.MapLayerGroupType> groups = new List<OSGeo.MapGuide.MaestroAPI.MapLayerGroupType>();
- string grouppath = g.GetFullPath("/", m_map) + "/";
+ string grouppath = g.GetFullPath(ReservedChar.PATH_SEPARATOR, m_map) + ReservedChar.PATH_SEPARATOR;
bool hasInvisible = false;
foreach (MaestroAPI.MapLayerType l in m_map.Layers)
- string lpath = l.GetFullPath("/", m_map);
+ string lpath = l.GetFullPath(ReservedChar.PATH_SEPARATOR, m_map);
if (lpath != null && lpath.StartsWith(grouppath))
layers.Add(l);
@@ -2560,7 +2561,7 @@
foreach (MaestroAPI.MapLayerGroupType lg in m_map.LayerGroups)
- string lpath = lg.GetFullPath("/", m_map);
+ string lpath = lg.GetFullPath(ReservedChar.PATH_SEPARATOR, m_map);
groups.Add(lg);
Modified: trunk/Tools/Maestro/MaestroAPI/Generated/MapDefinition-1.0.0.cs
--- trunk/Tools/Maestro/MaestroAPI/Generated/MapDefinition-1.0.0.cs 2010-09-08 05:22:48 UTC (rev 5123)
+++ trunk/Tools/Maestro/MaestroAPI/Generated/MapDefinition-1.0.0.cs 2010-09-08 13:59:53 UTC (rev 5124)
@@ -612,17 +612,15 @@
if (m_parent == null)
return null;
- string s = this.GetFullPath("/", m_parent);
+ string s = this.GetFullPath(ReservedChar.PATH_SEPARATOR, m_parent);
MapLayerTypeCollection layers = new MapLayerTypeCollection();
foreach(MapLayerType ml in m_parent.Layers)
- if (ml.GetFullPath("/", m_parent).StartsWith(s))
+ if (ml.GetFullPath(ReservedChar.PATH_SEPARATOR, m_parent).StartsWith(s))
layers.Add(ml);
return layers;
/// <remarks/>
Modified: trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-09-08 05:22:48 UTC (rev 5123)
+++ trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-09-08 13:59:53 UTC (rev 5124)
@@ -299,6 +299,7 @@
<Compile Include="RequestBuilder.cs">
<SubType>Code</SubType>
</Compile>
+ <Compile Include="ReservedChar.cs" />
<Compile Include="ResourceIdentifier.cs" />
<Compile Include="RuntimeClasses\RuntimeMap.cs">
Added: trunk/Tools/Maestro/MaestroAPI/ReservedChar.cs
--- trunk/Tools/Maestro/MaestroAPI/ReservedChar.cs (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/ReservedChar.cs 2010-09-08 13:59:53 UTC (rev 5124)
@@ -0,0 +1,30 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI
+ public static class ReservedChar
+ public static readonly string PATH_SEPARATOR = Char.ConvertFromUtf32(0);
Modified: trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs
--- trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs 2010-09-08 05:22:48 UTC (rev 5123)
+++ trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs 2010-09-08 13:59:53 UTC (rev 5124)
@@ -655,10 +655,10 @@
return null;
RuntimeMapLayerCollection layers = new RuntimeMapLayerCollection();
foreach(RuntimeMapLayer ml in m_parent.Layers)
layers.Add(ml);
return layers;
More information about the mapguide-commits
