[mapguide-commits] r5130 - in sandbox/rfc94/Common:
CoordinateSystem Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Mon Sep 13 04:43:18 EDT 2010
Author: baertelchen
Date: 2010-09-13 08:43:18 +0000 (Mon, 13 Sep 2010)
New Revision: 5130
sandbox/rfc94/Common/CoordinateSystem/CoordSysCategory.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysEnum.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCategory.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.h
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp
sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.h
sandbox/rfc94/Common/CoordinateSystem/MentorDictionary.h
sandbox/rfc94/Common/CoordinateSystem/namestruct.cpp
sandbox/rfc94/Common/CoordinateSystem/namestruct.h
sandbox/rfc94/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
Due to the changes done in namestruct.cpp and namestruct.h where the char(s) are no longer held in a statically initialized array but the memory is dynamically allocated, clients must no longer have accessed TNameStruct.name directly. I haven't yet updated the code in CoordSysCategory*.* what yielded to heap corruptions because code there did set the name field directly. Set the name field private and added a new = operator so that clients can still set the field to the appropriate value.
Also added the new method "CreateTransformation" to the CoordSysGeodeticTransformDef class - this allows for creating a specific geodetic transformation (forward and inverse) without having CS Map determining the best transformation to use. It used to do that based on a source and target datum. This behavior will stay, of course. There shouldn't be any changes for existing API clients.
Remarks:
There're some changes not yet submitted from CS_Map; mainly headers.
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysCategory.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysCategory.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysCategory.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -46,7 +46,7 @@
char * CCoordinateSystemCategory::Name()
- return m_categoryName.name;
+ return const_cast<char*>(m_categoryName.Name());
//Saves the object to a file. Purpose of the ulMinSize parameter:
@@ -102,7 +102,7 @@
// 5. Blank space (if ulMinSize > size)
//Name.
- CS_fwrite(m_categoryName.name, sizeof(m_categoryName.name), 1, pFile);
+ CS_fwrite(m_categoryName.Name(), sizeof(char), knMaxCategoryNameLen, pFile);
//Size.
CS_fwrite(reinterpret_cast<char *>(&ulSize), sizeof(ulSize), 1, pFile);
@@ -114,7 +114,7 @@
CSystemNameList::const_iterator iter;
for (iter=m_listCoordinateSystemNames.begin(); iter!=m_listCoordinateSystemNames.end(); iter++)
- CS_fwrite((*iter).name, sizeof((*iter).name), 1, pFile);
+ CS_fwrite((*iter).Name(), sizeof(char), cs_KEYNM_DEF, pFile);
//Blank space, if needed
@@ -131,7 +131,7 @@
CSystemName dummy(/*NOXLATE*/"fnord");
for (UINT32 i=0; i<ulDiff; i++)
- CS_fwrite(dummy.name, sizeof(dummy.name), 1, pFile);
+ CS_fwrite(dummy.Name(), sizeof(char), cs_KEYNM_DEF, pFile);
@@ -185,13 +185,20 @@
//Name.
- size_t nRead=CS_fread(m_categoryName.name, sizeof(m_categoryName.name), 1, pFile);
- if (1!=nRead)
+ char tempCharBuffer[knMaxCategoryNameLen] = { '\0' };
+ const size_t expectedReadCount = sizeof(tempCharBuffer) / sizeof(char);
+ size_t nRead=CS_fread(tempCharBuffer, sizeof(char), expectedReadCount, pFile);
+ if (expectedReadCount != nRead)
+ _ASSERT(0 == nRead); //otherwise something else is going on here...
//we reached the end of the file
throw new MgFileIoException(L"MgCoordinateSystemCategory.LoadFromFstream", __LINE__, __WFILE__, NULL, L"", NULL);
+ //copy the category name into our [m_categoryName] TNameStruct
+ m_categoryName = tempCharBuffer;
//Size.
UINT32 ulSize;
nRead=CS_fread(reinterpret_cast<char *>(&ulSize), sizeof(ulSize), 1, pFile);
@@ -213,18 +220,23 @@
+ char keyNameBuffer[cs_KEYNM_DEF] = { '\0' };
+ const size_t expectedBufferCountRead = sizeof(keyNameBuffer) / sizeof(char);
//Coordinate system names.
for (UINT32 i=0; i<ulSize; i++)
- nRead=CS_fread(member.name, sizeof(member.name), 1, pFile);
- if (1!=nRead)
+ keyNameBuffer[0] = '\0';
+ nRead=CS_fread(keyNameBuffer, sizeof(char), expectedBufferCountRead, pFile);
+ if (expectedBufferCountRead != nRead)
+ member = keyNameBuffer;
// TODO - WORKAROUND TO SKIP BAD COORDINATE SYSTEMS IN CURRENT DICTIONARIES
- if((strcmp(member.name, "IGN63/Hiva") != 0) &&
- (strcmp(member.name, "Phoenix") != 0))
+ if((strcmp(member.Name(), "IGN63/Hiva") != 0) &&
+ (strcmp(member.Name(), "Phoenix") != 0))
m_listCoordinateSystemNames.push_back(member);
@@ -235,7 +247,7 @@
ulDiff = ulMinSize - ulSize;
if (ulDiff > 0)
- CS_fseek(pFile, CS_ftell(pFile) + ulDiff * sizeof(member.name), SEEK_SET);
+ CS_fseek(pFile, CS_ftell(pFile) + ulDiff * (sizeof(keyNameBuffer) / sizeof(char)), SEEK_SET);
if (ferror(pFile))
@@ -297,7 +309,7 @@
STRING sName;
MG_TRY()
- wchar_t *pName = Convert_Ascii_To_Wide(m_categoryName.name);
+ wchar_t *pName = Convert_Ascii_To_Wide(m_categoryName.Name());
if (!pName)
throw new MgOutOfMemoryException(L"MgCoordinateSystemCategory.GetName", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -326,7 +338,10 @@
throw new MgOutOfMemoryException(L"MgCoordinateSystemCategory.SetName", __LINE__, __WFILE__, NULL, L"", NULL);
- strcpy(m_categoryName.name, pName);
+ //assign the name to our internal [TNameStruct]
+ m_categoryName = pName;
delete [] pName;
MG_CATCH_AND_THROW(L"MgCoordinateSystemCategory.SetName")
@@ -346,7 +361,7 @@
bool CCoordinateSystemCategory::IsValid()
- return IsLegalName(m_categoryName.name);
+ return IsLegalName(m_categoryName.Name());
//Private member function which returns whether the specified string
@@ -546,7 +561,7 @@
- wchar_t *pName = Convert_Ascii_To_Wide((*iter).name); //need to delete [] pName
+ wchar_t *pName = Convert_Ascii_To_Wide((*iter).Name()); //need to delete [] pName
if (NULL == pName)
throw new MgOutOfMemoryException(L"MgCoordinateSystemCategory.GetCoordinateSystems", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -670,7 +685,7 @@
void CCoordinateSystemCategory::Clear()
- memset(m_categoryName.name, 0, knMaxCategoryNameLen);
+ m_categoryName = "\0";
m_listCoordinateSystemNames.clear();
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -330,6 +330,10 @@
if (NULL == allDictionaryEntries) //whatever happend here - the dictionay file seems to be invalid
throw new MgCoordinateSystemLoadFailedException(L"CCoordinateSystemDictionaryBase.GetEnumImp", __LINE__, __WFILE__, NULL, L"", NULL);
+ else
+ allDictionaryEntries = this->dictionaryItems;
//create our enumerator we're returning to the caller
pNew = new CCoordinateSystemEnum;
@@ -365,7 +369,7 @@
T* DICTIONARY_BASE_TEMPLATE_METHOD::NewItem()
//new() throws an exception in case allocation fails; we don't take ownership
- return new T(this->catalog);
+ return new T(this->catalog); //the callee has to incr. the ref counter, if it needs the catalog object
#endif //BUILD_DICTIONARY_BASE
\ No newline at end of file
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysEnum.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysEnum.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysEnum.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -110,7 +110,7 @@
//success
return pOutput.Detach();
- const char *kpName = (*m_iter).first.name;
+ const char *kpName = (*m_iter).first.Name();
wchar_t* pStr = Convert_Ascii_To_Wide(kpName);
if (NULL == pStr)
@@ -160,7 +160,7 @@
//success
if (IsFilteredOut(kpName))
continue;
@@ -195,11 +195,11 @@
//success
- if (IsFilteredOut((*m_iter).first.name))
+ if (IsFilteredOut((*m_iter).first.Name()))
continue;
- const char *kpDecsription = (*m_iter).second.name;
+ const char *kpDecsription = (*m_iter).second.Name();
wchar_t *pwDecsription = Convert_Ascii_To_Wide(kpDecsription);
if (NULL == pwDecsription)
@@ -229,7 +229,7 @@
//success
return;
continue;
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCategory.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCategory.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCategory.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -176,7 +176,7 @@
//get the category definition for the next name in the list
- const char *kpName = (*(m_iter)).name;
+ const char *kpName = (*(m_iter)).Name();
if (NULL == pStr)
@@ -229,7 +229,7 @@
- const char *kpName = (*m_iter).name;
+ const char *kpName = (*m_iter).Name();
continue;
@@ -270,7 +270,7 @@
//success
return;
continue;
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -111,7 +111,7 @@
//get the coordinate system name from the category
assert(IsLegalMentorName(kpName));
pstr = Convert_Ascii_To_Wide(kpName);
@@ -163,7 +163,7 @@
//success
@@ -213,7 +213,7 @@
@@ -264,7 +264,7 @@
return;
continue;
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -33,8 +33,10 @@
#include "CoordSysMacro.h" //for DEFINE_GET_SET_STRING and DEFINE_GET_SET_NUMERIC
CCoordinateSystemGeodeticPath::CCoordinateSystemGeodeticPath(MgCoordinateSystemCatalog* pCatalog)
- : pathDefinition(NULL) //don't need the catalog
+ : pathDefinition(NULL), catalog(SAFE_ADDREF(pCatalog))
+ if (NULL == pCatalog)
+ throw new MgNullArgumentException(L"CCoordinateSystemGeodeticPath.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
CCoordinateSystemGeodeticPath::~CCoordinateSystemGeodeticPath()
@@ -78,7 +80,7 @@
VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.CreateClone");
- Ptr<CCoordinateSystemGeodeticPath> clonedPath = new CCoordinateSystemGeodeticPath(NULL);
+ Ptr<CCoordinateSystemGeodeticPath> clonedPath = new CCoordinateSystemGeodeticPath(this->catalog);
clonedPath->Initialize(*this->pathDefinition);
clonedPath->pathDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.h
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.h 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPath.h 2010-09-13 08:43:18 UTC (rev 5130)
@@ -83,6 +83,7 @@
private:
cs_GeodeticPath_* pathDefinition;
+ Ptr<MgCoordinateSystemCatalog> catalog;
} //namespace CSLibrary
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -117,10 +117,10 @@
MgCoordinateSystemGeodeticPath* CCoordinateSystemGeodeticPathDictionary::NewGeodeticPath()
- CCoordinateSystemGeodeticPath* newPathItem = this->m_pDictionary->NewItem();
+ Ptr<CCoordinateSystemGeodeticPath> newPathItem = this->m_pDictionary->NewItem();
newPathItem->Reset(); //sets up the [cs_geodeticpath_] struct; it can thus be used by
- return newPathItem;
+ return newPathItem.Detach();
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -19,6 +19,7 @@
#include "CoordSysCommon.h"
#include "CriticalSection.h"
+#include "CoordSysGeodeticTransformation.h"
#include "CoordSysGeodeticTransformDefParams.h"
#include "CoordSysGeodeticAnalyticalTransformDefParams.h"
#include "CoordSysGeodeticInterpolationTransformDefParams.h"
@@ -36,8 +37,11 @@
CCoordinateSystemGeodeticTransformDef::CCoordinateSystemGeodeticTransformDef(MgCoordinateSystemCatalog* pCatalog)
- : transformationDefType(0), transformDefinition(NULL)
+ : transformationDefType(0), transformDefinition(NULL), catalog(SAFE_ADDREF(pCatalog) /* make sure, we take a count on it */)
+ //have we been passed a non-null argument?
+ if (NULL == this->catalog)
+ throw new MgNullArgumentException(L"CCoordinateSystemGeodeticTransformDef.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
CCoordinateSystemGeodeticTransformDef::~CCoordinateSystemGeodeticTransformDef()
@@ -130,7 +134,7 @@
case cs_DTCMTH_BURSA:
case cs_DTCMTH_FRAME:
case cs_DTCMTH_7PARM:
- case cs_DTCMTH_BDKUS:
+ case cs_DTCMTH_BDKAS:
transformationType = MgCoordinateSystemGeodeticTransformDefType::Analytical;
break;
@@ -178,11 +182,21 @@
*this->transformDefinition = transformDef;
+MgCoordinateSystemGeodeticTransformation* CCoordinateSystemGeodeticTransformDef::CreateTransformation(bool createInverse)
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CreateTransformation");
+ //we don't take ownership of the transformation being returned but
+ //will release [sourceDatum] and [targetDatum];
+ //new [CCoordinateSystemGeodeticTransformation] will have to ADDREF if needed
+ return new CCoordinateSystemGeodeticTransformation(this->catalog, this, createInverse);
MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDef::CreateClone()
VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CreateClone");
- Ptr<CCoordinateSystemGeodeticTransformDef> clonedTransformDef = new CCoordinateSystemGeodeticTransformDef(NULL);
+ Ptr<CCoordinateSystemGeodeticTransformDef> clonedTransformDef = new CCoordinateSystemGeodeticTransformDef(this->catalog.p);
clonedTransformDef->Initialize(*this->transformDefinition);
clonedTransformDef->transformDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2010-09-13 08:43:18 UTC (rev 5130)
@@ -85,6 +85,8 @@
virtual INT32 GetTransformDefType();
+ MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse);
//helper - don't delete
virtual bool IsEncrypted();
@@ -100,6 +102,7 @@
private:
INT32 transformationDefType;
cs_GeodeticTransform_* transformDefinition;
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -72,10 +72,10 @@
MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDefDictionary::NewGeodeticTransformationDef(INT32 transformationDefType)
- CCoordinateSystemGeodeticTransformDef* newTransformDef = this->m_pDictionary->NewItem();
+ Ptr<CCoordinateSystemGeodeticTransformDef> newTransformDef = this->m_pDictionary->NewItem();
+ newTransformDef->Reset(transformationDefType); //sets up the [cs_geodeticTransfrom_] struct and initializes it to [transformationDefType]
- newTransformDef->Reset(transformationDefType); //sets up the [cs_geodeticTransfrom_] struct and initializes it to [transformationDefType]
- return newTransformDef; //this instance is not yet initialized
+ return newTransformDef.Detach(); //this instance is not yet initialized
MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDefDictionary::GetGeodeticTransformationDef(CREFSTRING transformationName)
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -40,6 +40,23 @@
+CCoordinateSystemGeodeticTransformation::CCoordinateSystemGeodeticTransformation(MgCoordinateSystemCatalog* pCatalog, MgCoordinateSystemGeodeticTransformDef* transformationDef, bool createInversed)
+: m_pDtcprm(NULL), m_pDtSource(NULL), m_pDtTarget(NULL)
+ if (NULL == pCatalog || NULL == transformationDef)
+ throw new MgNullArgumentException(L"CCoordinateSystemGeodeticTransformation.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
+ //this->Uninitialize(); //not needed - this does release the resourced held by this instance; we haven't set anything yet
+ this->SetCatalog(pCatalog);
+ //now - setup ourselves from the [MgCoordinateSystemGeodeticTransformDef] we've been passed
+ //we'll not pass a source and a target datum to CS Map so it constructs the cs_Dtcprm_ struct
+ //but we'll do that because we already have a transformation
+ this->SetupFromTransformationDef(transformationDef, createInversed);
CCoordinateSystemGeodeticTransformation::~CCoordinateSystemGeodeticTransformation()
Uninitialize();
@@ -337,6 +354,44 @@
assert(!IsInitialized());
+//Initializes this transformation instance from an [MgCoordinateSystemGeodeticTransformDef] object;
+//That is, we don't let CS Map find the appropriate transformation based on a source and a target
+//datum but will instruct CS Map to use the transformation defition we pass to it
+void CCoordinateSystemGeodeticTransformation::SetupFromTransformationDef(MgCoordinateSystemGeodeticTransformDef* transformationDef, bool createInversed)
+ char* transformName = Convert_Wide_To_Ascii(transformationDef->GetTransformName().c_str());
+ MG_TRY()
+ //protect the call to the lib files; the calls to the [datumDictionary] below
+ //we also enter the critical section but on the same thread - i.e. no problem;
+ //putting the check here saves us from [enter, leave, enter leave]
+ SmartCriticalClass criticalSection(true);
+ //ask CS_Map for the transformation
+ cs_Dtcprm_* datumTransform = CSdtcsu1(transformName, createInversed ? cs_DTCDIR_INV : cs_DTCDIR_FWD, cs_DTCFLG_BLK_W);
+ if (NULL == datumTransform)
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticTransformation.SetupFromTransformationDef", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgCoordinateSystemDatumDictionary> datumDictionary = this->m_pCatalog->GetDatumDictionary();
+ Ptr<MgCoordinateSystemDatum> srcDatum = datumDictionary->GetDatum(transformationDef->GetSourceDatum());
+ Ptr<MgCoordinateSystemDatum> trgDatum = datumDictionary->GetDatum(transformationDef->GetTargetDatum());
+ this->m_pDtcprm = datumTransform;
+ this->m_pDtSource = srcDatum.Detach(); //m_pDtSource is no auto pointer
+ this->m_pDtTarget = trgDatum.Detach(); //m_pDtTarget is no auto pointer
+ MG_CATCH(L"CCoordinateSystemGeodeticTransformation.SetupFromTransformationDef")
+ if (NULL != transformName)
+ delete[] transformName;
+ MG_THROW()
MgCoordinateSystemDatum* CCoordinateSystemGeodeticTransformation::GetWGS84()
Modified: sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.h
--- sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.h 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/CoordSysGeodeticTransformation.h 2010-09-13 08:43:18 UTC (rev 5130)
@@ -25,6 +25,7 @@
public:
CCoordinateSystemGeodeticTransformation(MgCoordinateSystemCatalog* pCatalog, MgCoordinateSystemDatum* pSource, MgCoordinateSystemDatum *pTarget);
+ CCoordinateSystemGeodeticTransformation(MgCoordinateSystemCatalog* pCatalog, MgCoordinateSystemGeodeticTransformDef* transformationDef, bool createInversed);
virtual ~CCoordinateSystemGeodeticTransformation();
virtual void SetSourceAndTarget(MgCoordinateSystemDatum *pSource, MgCoordinateSystemDatum *pTarget);
@@ -66,6 +67,7 @@
void SetCatalog(MgCoordinateSystemCatalog* pCatalog);
bool GetDefinitionForGeodeticTransformationParameter(cs_Dtdef_& def);
MgCoordinateSystemDatum* GetWGS84();
+ void SetupFromTransformationDef(MgCoordinateSystemGeodeticTransformDef* transformationDef, bool createInversed);
protected:
//Data members
Modified: sandbox/rfc94/Common/CoordinateSystem/MentorDictionary.h
--- sandbox/rfc94/Common/CoordinateSystem/MentorDictionary.h 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/MentorDictionary.h 2010-09-13 08:43:18 UTC (rev 5130)
@@ -244,7 +244,7 @@
//it. (We can't just change the key in-place by
//modifying (*iter).first, since the key in a std::map
//pair is a const object.)
- if (0 == strcmp(keyName, (*iter).first.name))
+ if (0 == strcmp(keyName, (*iter).first.Name()))
//The key name is unchanged; we can just update
//the summary.
@@ -254,7 +254,7 @@
//The name changed (case changed only). We need
//to delete the item and re-insert it.
- assert(0 == CS_stricmp(keyName, (*iter).first.name));
+ assert(0 == CS_stricmp(keyName, (*iter).first.Name()));
try
pmapSystemNameDescription->erase(iter);
Modified: sandbox/rfc94/Common/CoordinateSystem/namestruct.cpp
--- sandbox/rfc94/Common/CoordinateSystem/namestruct.cpp 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/namestruct.cpp 2010-09-13 08:43:18 UTC (rev 5130)
@@ -62,7 +62,7 @@
name[stringLength] = '\0'; // finally, set the terminating NULL char in any case; the buffer is at least 1 char long
-//Assignment operator
+//Assignment operator; assign based on other TNameStruct
TNameStruct&
TNameStruct::operator=(const TNameStruct& other)
@@ -71,6 +71,14 @@
return *this;
+//Assignment operator; assign based on string
+TNameStruct&
+TNameStruct::operator=(const char* newName)
+ this->Init(newName);
+ return *this;
//Comparison operator (alphabetic, case-insensitive).
bool
@@ -104,4 +112,12 @@
TNameStruct::operator!=(const TNameStruct& other) const
return (_stricmp(name, other.name) != 0);
+//Returns this [TNameStruct] current char* pointer
+const char*
+TNameStruct::Name() const
+ return this->name;
Modified: sandbox/rfc94/Common/CoordinateSystem/namestruct.h
--- sandbox/rfc94/Common/CoordinateSystem/namestruct.h 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/CoordinateSystem/namestruct.h 2010-09-13 08:43:18 UTC (rev 5130)
@@ -77,13 +77,21 @@
//assignment
TNameStruct& operator=(const TNameStruct&);
- //data members
- char* name;
+ //assignment
+ TNameStruct& operator=(const char* newName);
+ //misc. methods
+ const char* Name() const;
+ void Reset();
private:
//methods
void Init(const char *kpName = NULL);
void Release();
+private:
+ //data members
+ char* name;
//This struct holds a summary of a definition (just name and description,
Modified: sandbox/rfc94/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
--- sandbox/rfc94/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h 2010-09-10 21:33:03 UTC (rev 5129)
+++ sandbox/rfc94/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h 2010-09-13 08:43:18 UTC (rev 5130)
@@ -75,7 +75,7 @@
virtual MgCoordinateSystemGeodeticTransformDef* CreateClone() = 0;
- //MgCoordinateSystemGeodeticTransformation* CreateTransformation();
+ virtual MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse) = 0;
protected:
More information about the mapguide-commits
