[mapguide-commits] r5148 - in trunk/MgDev: Common/MdfModel
Common/MdfParser Common/Schema Server/src/Services/Rendering
svn_mapguide at osgeo.org
Fri Sep 17 18:23:54 EDT 2010
Author: waltweltonlair
Date: 2010-09-17 22:23:54 +0000 (Fri, 17 Sep 2010)
New Revision: 5148
trunk/MgDev/Common/MdfModel/LengthConverter.h
trunk/MgDev/Common/MdfModel/TileWatermarkPosition.cpp
trunk/MgDev/Common/MdfModel/TileWatermarkPosition.h
trunk/MgDev/Common/MdfModel/WatermarkAppearance.cpp
trunk/MgDev/Common/MdfModel/WatermarkAppearance.h
trunk/MgDev/Common/MdfModel/WatermarkDefinition.cpp
trunk/MgDev/Common/MdfModel/WatermarkDefinition.h
trunk/MgDev/Common/MdfModel/WatermarkInstance.cpp
trunk/MgDev/Common/MdfModel/WatermarkInstance.h
trunk/MgDev/Common/MdfModel/WatermarkOffsetUnit.h
trunk/MgDev/Common/MdfModel/WatermarkPosition.cpp
trunk/MgDev/Common/MdfModel/WatermarkPosition.h
trunk/MgDev/Common/MdfModel/WatermarkXOffset.cpp
trunk/MgDev/Common/MdfModel/WatermarkXOffset.h
trunk/MgDev/Common/MdfModel/WatermarkYOffset.cpp
trunk/MgDev/Common/MdfModel/WatermarkYOffset.h
trunk/MgDev/Common/MdfModel/XYWatermarkPosition.cpp
trunk/MgDev/Common/MdfModel/XYWatermarkPosition.h
trunk/MgDev/Common/MdfParser/IOWatermarkInstance.cpp
trunk/MgDev/Common/MdfParser/IOWatermarkXOffset.cpp
trunk/MgDev/Common/MdfParser/IOWatermarkYOffset.cpp
trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
More watermark cleanup - MdfModel
* Numerous member variables were not being initialized in constructors - BAD!!
* In MdfModel, member variables should be initialized to the corresponding default property value specified in the schema!
* Never include files before stdafx.h. If precompiled headers is enabled then headers included before stdafx.h are ignored.
* Renamed some class properties to be consistent with the schema. E.g. WatermarkXOffset had a Length property but in the schema it's called Offset. Now the code also uses Offset.
* Renamed WatermarkResourceID proeprty on WatermarkInstance to just ResourceId.
* New source files should have copyrights that only reference the current year.
* Adjusted formatting to match the rest of the project.
Also cleaned up some documentation in the schema.
Modified: trunk/MgDev/Common/MdfModel/LengthConverter.h
--- trunk/MgDev/Common/MdfModel/LengthConverter.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/LengthConverter.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -33,7 +33,7 @@
Feet,
Yards,
Miles,
- Points,
+ Points
class MDFMODEL_API LengthConverter
Modified: trunk/MgDev/Common/MdfModel/TileWatermarkPosition.cpp
--- trunk/MgDev/Common/MdfModel/TileWatermarkPosition.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/TileWatermarkPosition.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
+// Copyright (C) 2010 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
@@ -34,8 +34,11 @@
// PURPOSE: Construct and initialize an instance of the TileWatermarkPosition class.
TileWatermarkPosition::TileWatermarkPosition()
- :m_horizontalPosition(NULL), m_verticalPosition(NULL)
+ this->m_tileWidth = 150.0;
+ this->m_tileHeight = 150.0;
+ this->m_horizontalPosition = NULL;
+ this->m_verticalPosition = NULL;
@@ -79,7 +82,6 @@
this->m_tileHeight = dTileHeight;
// PURPOSE: Accessor method for the HorizontalPosition property.
// The WatermarkXOffset is the type of offset used in the position of watermark.
@@ -108,7 +110,7 @@
// pXPosition - Adopted WatermarkXOffset object that is created on the heap.
// It may be NULL.
-void TileWatermarkPosition::AdoptHorizontalPosition(WatermarkXOffset *pHorizontalPosition)
+void TileWatermarkPosition::AdoptHorizontalPosition(WatermarkXOffset* pHorizontalPosition)
if (this->m_horizontalPosition != pHorizontalPosition)
@@ -157,7 +159,7 @@
// pYPosition - Adopted WatermarkYOffset object that is created on the heap.
// It may be NULL.
-void TileWatermarkPosition::AdoptVerticalPosition(WatermarkYOffset *pVerticalPosition)
+void TileWatermarkPosition::AdoptVerticalPosition(WatermarkYOffset* pVerticalPosition)
if (this->m_verticalPosition != pVerticalPosition)
@@ -179,33 +181,40 @@
-// Whether this position is the same as given one
+// Determines whether this position is the same as the supplied one.
bool TileWatermarkPosition::Equals(WatermarkPosition* another)
TileWatermarkPosition* anotherPosition = dynamic_cast<TileWatermarkPosition*>(another);
- if(!anotherPosition) return false;
+ if (!anotherPosition)
+ return false;
- if(fabs(this->m_tileWidth - anotherPosition->m_tileWidth) > doubleTolerance)
+ // check width / height
+ if (fabs(this->m_tileWidth - anotherPosition->m_tileWidth) > doubleTolerance)
return false;
- if(fabs(this->m_tileHeight - anotherPosition->m_tileHeight) > doubleTolerance)
+ if (fabs(this->m_tileHeight - anotherPosition->m_tileHeight) > doubleTolerance)
return false;
- if(!this->m_horizontalPosition)
+ // check horizontal position
+ if (!this->m_horizontalPosition)
- if(anotherPosition->m_horizontalPosition) return false;
+ if (anotherPosition->m_horizontalPosition)
+ return false;
- else if(!this->m_horizontalPosition->Equals(anotherPosition->m_horizontalPosition))
+ else if (!this->m_horizontalPosition->Equals(anotherPosition->m_horizontalPosition))
return false;
- if(!this->m_verticalPosition)
+ // check vertical position
+ if (!this->m_verticalPosition)
- return !anotherPosition->m_verticalPosition;
+ if (anotherPosition->m_verticalPosition)
+ return false;
- else
- return this->m_verticalPosition->Equals(anotherPosition->m_verticalPosition);
+ else if (!this->m_verticalPosition->Equals(anotherPosition->m_verticalPosition))
+ return false;
+ // all checks passed
+ return true;
#ifdef _WIN32
Modified: trunk/MgDev/Common/MdfModel/TileWatermarkPosition.h
--- trunk/MgDev/Common/MdfModel/TileWatermarkPosition.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/TileWatermarkPosition.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -28,10 +28,10 @@
// DESCRIPTION:
// The TileWatermarkPosition class is one concrete implementation of WatermarkPosition.
- // It will repeat the source both in X and Y dimension. Tile is the unit of repeat.
+ // It will repeat the source both in X and Y dimension. Tile is the unit of repeat.
// Within tile it uses X-Y as the position of watermark.
-class MDFMODEL_API TileWatermarkPosition: public WatermarkPosition
+ class MDFMODEL_API TileWatermarkPosition: public WatermarkPosition
public:
// Construction, destruction, initialization.
@@ -51,13 +51,13 @@
// Property: HorizontalPosition
const WatermarkXOffset* GetHorizontalPosition() const;
WatermarkXOffset* GetHorizontalPosition();
- void AdoptHorizontalPosition(WatermarkXOffset *pHorizontalPosition);
+ void AdoptHorizontalPosition(WatermarkXOffset* pHorizontalPosition);
WatermarkXOffset* OrphanHorizontalPosition();
// Property: VerticalPosition
const WatermarkYOffset* GetVerticalPosition() const;
WatermarkYOffset* GetVerticalPosition();
- void AdoptVerticalPosition(WatermarkYOffset *pVerticalPosition);
+ void AdoptVerticalPosition(WatermarkYOffset* pVerticalPosition);
WatermarkYOffset* OrphanVerticalPosition();
virtual bool Equals(WatermarkPosition* another);
@@ -71,15 +71,15 @@
private:
// Hidden TileWatermarkPosition copy constructor and assignment operator.
- TileWatermarkPosition(const TileWatermarkPosition&);
- TileWatermarkPosition& operator=(const TileWatermarkPosition&);
+ TileWatermarkPosition(const TileWatermarkPosition&);
+ TileWatermarkPosition& operator=(const TileWatermarkPosition&);
// Data members
// See corresponding properties for descriptions
- double m_tileWidth;
- double m_tileHeight;
- WatermarkXOffset* m_horizontalPosition;
- WatermarkYOffset* m_verticalPosition;
+ double m_tileWidth;
+ double m_tileHeight;
+ WatermarkXOffset* m_horizontalPosition;
+ WatermarkYOffset* m_verticalPosition;
static const double doubleTolerance;
Modified: trunk/MgDev/Common/MdfModel/WatermarkAppearance.cpp
--- trunk/MgDev/Common/MdfModel/WatermarkAppearance.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkAppearance.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -21,8 +21,8 @@
// WatermarkAppearance class is to define the appearance of watermark.
+#include "stdafx.h"
#include <cmath>
-#include "stdafx.h"
#include "WatermarkAppearance.h"
using namespace MDFMODEL_NAMESPACE;
@@ -34,6 +34,8 @@
WatermarkAppearance::WatermarkAppearance()
+ this->m_transparency = 0.0;
+ this->m_rotation = 0.0;
@@ -44,8 +46,8 @@
-// Returns the transparency (0 - 100). O means totally opaque. 100 means totally
-// transparent.
+// Returns the transparency (0 - 100). Zero means fully opaque, and 100
+// means fully transparent.
double WatermarkAppearance::GetTransparency() const
@@ -53,18 +55,23 @@
-// Set the transparency (0 - 100). O means totally opaque. 100 means totally
-// transparent. If the parameter is more than 100, treat it as 100. If the
-// parameter is less than 0, treat it as 0.
+// Set the transparency (0 - 100). Zero means fully opaque, and 100
+// means fully transparent. If the parameter is more than 100, treat it
+// as 100. If the parameter is less than 0, treat it as 0.
void WatermarkAppearance::SetTransparency(const double& dTransparency)
- this->m_transparency = (dTransparency > 100) ? 100 : (dTransparency < 0 ? 0 : dTransparency);
+ if (dTransparency > 100.0)
+ this->m_transparency = 100.0;
+ else if (dTransparency < 0.0)
+ else
+ this->m_transparency = dTransparency;
-// Returns the rotation (0 - 360). O means no rotation. 90 means rotating 90 degree
-// anticlockwise. 360 should be the same as 0 as it turns a whole circle.
+// Returns the rotation (0 - 360). Zero means no rotation, while 90 means
+// rotating 90 degrees anticlockwise.
double WatermarkAppearance::GetRotation() const
@@ -72,21 +79,28 @@
-// Set the rotation (0 - 360). O means no rotation. 90 means rotating 90 degree
-// If the parameter is more than 360, treat it as 360. If the
+// Set the rotation (0 - 360). Zero means no rotation, while 90 means
+// rotating 90 degrees anticlockwise. If the parameter is more than 360,
+// treat it as 360. If the parameter is less than 0, treat it as 0.
void WatermarkAppearance::SetRotation(const double& dRotation)
- this->m_rotation = (dRotation > 360) ? 360 : (dRotation < 0 ? 0 : dRotation);
+ if (dRotation > 360.0)
+ this->m_rotation = 360.0;
+ else if (dRotation < 0.0)
+ else
+ this->m_rotation = dRotation;
+// Determines whether this appearance is the same as the supplied one.
bool WatermarkAppearance::Equals(WatermarkAppearance* another)
- return another
- && fabs(this->m_transparency - another->m_transparency) < doubleTolerance
- && fabs(this->m_rotation - another->m_rotation) < doubleTolerance;
+ return another &&
+ fabs(this->m_transparency - another->m_transparency) < doubleTolerance &&
+ fabs(this->m_rotation - another->m_rotation) < doubleTolerance;
#ifdef _WIN32
Modified: trunk/MgDev/Common/MdfModel/WatermarkAppearance.h
--- trunk/MgDev/Common/MdfModel/WatermarkAppearance.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkAppearance.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -26,7 +26,7 @@
// DESCRIPTION:
// The WatermarkAppearance class is to define the appearance of watermark.
-class MDFMODEL_API WatermarkAppearance
+ class MDFMODEL_API WatermarkAppearance
public:
@@ -53,8 +53,8 @@
private:
// Hidden WatermarkAppearance copy constructor and assignment operator.
- WatermarkAppearance(const WatermarkAppearance&);
- WatermarkAppearance& operator=(const WatermarkAppearance&);
+ WatermarkAppearance(const WatermarkAppearance&);
+ WatermarkAppearance& operator=(const WatermarkAppearance&);
// Data members
Modified: trunk/MgDev/Common/MdfModel/WatermarkDefinition.cpp
--- trunk/MgDev/Common/MdfModel/WatermarkDefinition.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkDefinition.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -18,15 +18,19 @@
// DESCRIPTION:
// The WatermarkDefinition class implementation.
-// All the data objects in the WatermarkDefinition (Content, Appearance, Position etc)
-// are accessible. While unfettered access to all the stored objects in provided,
-// these data are still owned by the WatermarkDefinition object.
-// Methods that have a prefix of "Adopt", imply that the object passed to them
-// has to be created on the heap and the WaterDefinition object is now responsible
-// for its deletion. Methods that have a prefix of "Orphan" imply that the pointer
-// returned, points to an object on the heap and its is the caller who is responsible
-// for its deletion. Methods that have a "Get" prefix simply give access without
-// a change of ownership.
+// All the data objects in the WatermarkDefinition (Source, Appearance,
+// Position, etc.) are accessible. While unfettered access to all the stored
+// objects is provided, these data are still owned by the WatermarkDefinition
+// object.
+// * Methods that have a prefix of "Adopt" imply that the object passed
+// to them has to be created on the heap and the WaterDefinition object
+// is now responsible for their deletion.
+// * Methods that have a prefix of "Orphan" imply that the returned pointer
+// points to an object on the heap and it's the caller's responsibility
+// to delete it.
+// * Methods that have a "Get" prefix simply give access without a change
+// of ownership.
#include "stdafx.h"
@@ -38,8 +42,10 @@
// PURPOSE: Construct and initialize an instance of the WatermarkDefinition class.
WatermarkDefinition::WatermarkDefinition()
- :m_source(NULL), m_appearance(NULL), m_position(NULL)
+ this->m_source = NULL;
+ this->m_appearance = NULL;
+ this->m_position = NULL;
@@ -49,9 +55,9 @@
delete this->m_source;
delete this->m_appearance;
+ delete this->m_position;
// PURPOSE: Accessor method for the source property.
// The SymbolDefinition is the type of source content used in watermark.
@@ -80,7 +86,7 @@
// pSource - Adopted SymbolDefinition object that is created on the heap.
// It may be NULL.
-void WatermarkDefinition::AdoptSource(SymbolDefinition *pSource)
+void WatermarkDefinition::AdoptSource(SymbolDefinition* pSource)
if (this->m_source != pSource)
@@ -129,7 +135,7 @@
// pAppearance - Adopted WatermarkAppearance object that is created on the heap.
// It may be NULL.
-void WatermarkDefinition::AdoptAppearance(WatermarkAppearance *pAppearance)
+void WatermarkDefinition::AdoptAppearance(WatermarkAppearance* pAppearance)
if (this->m_appearance != pAppearance)
@@ -178,7 +184,7 @@
// pPosition - Adopted WatermarkPosition object that is created on the heap.
// It may be NULL.
-void WatermarkDefinition::AdoptPosition(WatermarkPosition *pPosition)
+void WatermarkDefinition::AdoptPosition(WatermarkPosition* pPosition)
if (this->m_position != pPosition)
Modified: trunk/MgDev/Common/MdfModel/WatermarkDefinition.h
--- trunk/MgDev/Common/MdfModel/WatermarkDefinition.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkDefinition.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -31,7 +31,7 @@
// The WatermarkDefinition class is the root document node of the MdfModel. Through its
// interface, one can get access to all the data in the WatermarkDefinition.
-class MDFMODEL_API WatermarkDefinition: public MdfRootObject
+ class MDFMODEL_API WatermarkDefinition: public MdfRootObject
public:
@@ -43,19 +43,19 @@
// Property: Source
const SymbolDefinition* GetSource() const;
SymbolDefinition* GetSource();
- void AdoptSource(SymbolDefinition *pSource);
+ void AdoptSource(SymbolDefinition* pSource);
SymbolDefinition* OrphanSource();
// Property: Appearance
const WatermarkAppearance* GetAppearance() const;
WatermarkAppearance* GetAppearance();
- void AdoptAppearance(WatermarkAppearance *pAppearance);
+ void AdoptAppearance(WatermarkAppearance* pAppearance);
WatermarkAppearance* OrphanAppearance();
// Property: Position
const WatermarkPosition* GetPosition() const;
WatermarkPosition* GetPosition();
- void AdoptPosition(WatermarkPosition *pPosition);
+ void AdoptPosition(WatermarkPosition* pPosition);
WatermarkPosition* OrphanPosition();
//#ifdef _WIN32
@@ -67,14 +67,14 @@
private:
// Hidden WatermarkDefinition copy constructor and assignment operator.
- WatermarkDefinition(const WatermarkDefinition&);
- WatermarkDefinition& operator=(const WatermarkDefinition&);
+ WatermarkDefinition(const WatermarkDefinition&);
+ WatermarkDefinition& operator=(const WatermarkDefinition&);
// Data members
- SymbolDefinition* m_source;
- WatermarkAppearance* m_appearance;
- WatermarkPosition* m_position;
+ SymbolDefinition* m_source;
+ WatermarkAppearance* m_appearance;
+ WatermarkPosition* m_position;
END_NAMESPACE_MDFMODEL
Modified: trunk/MgDev/Common/MdfModel/WatermarkInstance.cpp
--- trunk/MgDev/Common/MdfModel/WatermarkInstance.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkInstance.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -30,16 +30,16 @@
// PARAMETERS:
// Input:
// strName - the unique WatermarkInstance name. Cannot be an empty string.
-// strWatermarkResourceID - the resource ID for the watermark definition.
+// strResourceId - the resource ID for the watermark definition.
-WatermarkInstance::WatermarkInstance(const MdfString& strName, const MdfString& strWatermarkResourceID)
-: m_strName(strName)
-, m_strWatermarkResourceID(strWatermarkResourceID)
-, m_usage(ALL)
-, m_pWatermarkDefinition(NULL)
-, m_appearanceOverride(NULL)
-, m_positionOverride(NULL)
+WatermarkInstance::WatermarkInstance(const MdfString& strName, const MdfString& strResourceId)
+ this->m_strName = strName;
+ this->m_strResourceId = strResourceId;
+ this->m_usage = All;
+ this->m_appearanceOverride = NULL;
+ this->m_positionOverride = NULL;
+ this->m_pWatermarkDefinition = NULL;
@@ -47,9 +47,9 @@
WatermarkInstance::~WatermarkInstance()
- delete this->m_pWatermarkDefinition;
delete this->m_appearanceOverride;
delete this->m_positionOverride;
+ delete this->m_pWatermarkDefinition;
@@ -64,33 +64,31 @@
// PURPOSE: Accessor to the WatermarkInstance name.
// PARAMETERS:
// Input:
-// strName - unique WatermarkInstance name that is not a blank string.
+// strName - unique WatermarkInstance name
void WatermarkInstance::SetName(const MdfString& strName)
- if (strName.length() > 0)
- this->m_strName = strName;
-// PURPOSE: Accessor for the WatermarkDefinition resourceID that this WatermarkInstance references.
+// PURPOSE: Accessor for the WatermarkDefinition resource ID that this WatermarkInstance references.
// RETURNS:
-const MdfString& WatermarkInstance::GetWatermarkResourceID() const
+const MdfString& WatermarkInstance::GetResourceId() const
- return this->m_strWatermarkResourceID;
+ return this->m_strResourceId;
// PURPOSE: Accessor to the WatermarkDefinition Uri that this WatermarkInstance references.
// PARAMETERS:
// Input:
-// strWatermarkResourceID - the watermark resourceID for this WatermarkInstance.Cannot be an empty
+// strResourceId - the watermark resource ID for this WatermarkInstance
-void WatermarkInstance::SetWatermarkResourceID(const MdfString& strWatermarkResourceID)
+void WatermarkInstance::SetResourceId(const MdfString& strResourceId)
- if (strWatermarkResourceID.length() > 0)
- this->m_strWatermarkResourceID = strWatermarkResourceID;
@@ -113,55 +111,6 @@
-// PURPOSE: Accessor method for the watermark definition property.
-// The WatermarkDefinition is the type of watermark definition.
-// RETURNS: The pointer of watermark definition.
-const WatermarkDefinition* WatermarkInstance::GetWatermarkDefinition() const
- return this->m_pWatermarkDefinition;
-WatermarkDefinition* WatermarkInstance::GetWatermarkDefinition()
-// PARAMETERS:
-// Input:
-// pWatermarkDefinition - Adopted WatermarkDefinition object that is created on the heap.
-// It may be NULL.
-void WatermarkInstance::AdoptWatermarkDefinition(WatermarkDefinition *pWatermarkDefinition)
- if (this->m_pWatermarkDefinition != pWatermarkDefinition)
- this->m_pWatermarkDefinition = pWatermarkDefinition;
-// RETURNS: The pointer to the orphaned WatermarkDefinition object. It may be NULL.
-WatermarkDefinition* WatermarkInstance::OrphanWatermarkDefinition()
- WatermarkDefinition* pRet = this->m_pWatermarkDefinition;
- this->m_pWatermarkDefinition = NULL;
- return pRet;
// PURPOSE: Accessor method for the appearance override property.
// The WatermarkAppearance is the type of appearance override in watermark instance.
// RETURNS: The pointer of watermark appearance override.
@@ -189,7 +138,7 @@
// pAppearanceOverride - Adopted WatermarkAppearance object that is created on the heap.
// It may be NULL.
-void WatermarkInstance::AdoptAppearanceOverride(WatermarkAppearance *pAppearanceOverride)
+void WatermarkInstance::AdoptAppearanceOverride(WatermarkAppearance* pAppearanceOverride)
if (this->m_appearanceOverride != pAppearanceOverride)
@@ -238,7 +187,7 @@
// It may be NULL.
-void WatermarkInstance::AdoptPositionOverride(WatermarkPosition *pPositionOverride)
+void WatermarkInstance::AdoptPositionOverride(WatermarkPosition* pPositionOverride)
if (this->m_positionOverride != pPositionOverride)
@@ -259,27 +208,87 @@
return pRet;
+// PURPOSE: Accessor method for the watermark definition property.
+// The WatermarkDefinition is the type of watermark definition.
+// RETURNS: The pointer of watermark definition.
+const WatermarkDefinition* WatermarkInstance::GetWatermarkDefinition() const
+ return this->m_pWatermarkDefinition;
+WatermarkDefinition* WatermarkInstance::GetWatermarkDefinition()
+// PARAMETERS:
+// Input:
+// pWatermarkDefinition - Adopted WatermarkDefinition object that is created on the heap.
+// It may be NULL.
+void WatermarkInstance::AdoptWatermarkDefinition(WatermarkDefinition* pWatermarkDefinition)
+ if (this->m_pWatermarkDefinition != pWatermarkDefinition)
+ this->m_pWatermarkDefinition = pWatermarkDefinition;
+// RETURNS: The pointer to the orphaned WatermarkDefinition object. It may be NULL.
+WatermarkDefinition* WatermarkInstance::OrphanWatermarkDefinition()
+ WatermarkDefinition* pRet = this->m_pWatermarkDefinition;
+ return pRet;
+// Determines whether this instance is the same as the supplied one.
bool WatermarkInstance::Equals(WatermarkInstance* another)
- if(!another) return false;
- if(::wcscmp(this->m_strWatermarkResourceID.c_str(),
- another->m_strWatermarkResourceID.c_str()))
+ if (!another)
return false;
- if(!this->m_appearanceOverride)
+ // check resource ID
+ if (::wcscmp(this->m_strResourceId.c_str(), another->m_strResourceId.c_str()))
+ return false;
+ // check appearance
+ if (!this->m_appearanceOverride)
- if(another->m_appearanceOverride) return false;
+ if (another->m_appearanceOverride)
+ return false;
- else if(!this->m_appearanceOverride->Equals(another->m_appearanceOverride))
+ else if (!this->m_appearanceOverride->Equals(another->m_appearanceOverride))
return false;
- if(!this->m_positionOverride)
+ // check position
+ if (!this->m_positionOverride)
- return !(another->m_positionOverride);
+ if (another->m_positionOverride)
+ return false;
- else
- return this->m_positionOverride->Equals(another->m_positionOverride);
+ else if (!this->m_positionOverride->Equals(another->m_positionOverride))
+ return false;
+ return true;
#ifdef _WIN32
Modified: trunk/MgDev/Common/MdfModel/WatermarkInstance.h
--- trunk/MgDev/Common/MdfModel/WatermarkInstance.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkInstance.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -33,7 +33,7 @@
// reference of a WatermarkDefinition object. It is the user's responsibility to ensure
// that duplicated WatermarkDefinitions are deleted.
-class MDFMODEL_API WatermarkInstance
+ class MDFMODEL_API WatermarkInstance
public:
@@ -42,7 +42,7 @@
WMS = 1,
Viewer = 2,
- ALL = WMS | Viewer
+ All = WMS | Viewer
@@ -50,39 +50,40 @@
virtual ~WatermarkInstance();
// Operations
// Property : Name
- // The name of WatermarkInstance. Must be a unique WatermarkInstance name.
+ // The name of WatermarkInstance. Must be a unique WatermarkInstance name.
const MdfString& GetName() const;
void SetName(const MdfString& strName);
- //Property : WatermarkResourceID
- // The Watermark ResourceID that this WatermarkInstance refers to for its WatermarkDefinition object
- const MdfString& GetWatermarkResourceID() const;
- void SetWatermarkResourceID(const MdfString& strWaterResourceID);
+ // Property : ResourceId
+ // The Watermark resource ID that this WatermarkInstance refers to for its WatermarkDefinition object.
+ const MdfString& GetResourceId() const;
+ void SetResourceId(const MdfString& strResourceId);
// Property: Usage
const Usage GetUsage() const;
void SetUsage(Usage usage);
- // Property : WatermarkDefinition
- // WatermarkDefinition that this WatermarkInstance refers to.
- const WatermarkDefinition* GetWatermarkDefinition() const;
- WatermarkDefinition* GetWatermarkDefinition();
- void AdoptWatermarkDefinition(WatermarkDefinition *pWatermarkDefinition);
- WatermarkDefinition* OrphanWatermarkDefinition();
// Property: AppearanceOverride
const WatermarkAppearance* GetAppearanceOverride() const;
WatermarkAppearance* GetAppearanceOverride();
- void AdoptAppearanceOverride(WatermarkAppearance *pAppearanceOverride);
+ void AdoptAppearanceOverride(WatermarkAppearance* pAppearanceOverride);
WatermarkAppearance* OrphanAppearanceOverride();
// Property: PositionOverride
const WatermarkPosition* GetPositionOverride() const;
WatermarkPosition* GetPositionOverride();
- void AdoptPositionOverride(WatermarkPosition *pPositionOverride);
+ void AdoptPositionOverride(WatermarkPosition* pPositionOverride);
WatermarkPosition* OrphanPositionOverride();
+ // Property : WatermarkDefinition
+ // WatermarkDefinition that this WatermarkInstance refers to.
+ const WatermarkDefinition* GetWatermarkDefinition() const;
+ WatermarkDefinition* GetWatermarkDefinition();
+ void AdoptWatermarkDefinition(WatermarkDefinition* pWatermarkDefinition);
+ WatermarkDefinition* OrphanWatermarkDefinition();
bool Equals(WatermarkInstance* another);
//#ifdef _WIN32
@@ -94,17 +95,17 @@
private:
// Hidden WatermarkInstance copy constructor and assignment operator.
- WatermarkInstance(const WatermarkInstance&);
- WatermarkInstance& operator=(const WatermarkInstance&);
+ WatermarkInstance(const WatermarkInstance&);
+ WatermarkInstance& operator=(const WatermarkInstance&);
// Data members
- MdfString m_strName;
- MdfString m_strWatermarkResourceID;
- Usage m_usage;
- WatermarkDefinition* m_pWatermarkDefinition;
- WatermarkAppearance* m_appearanceOverride;
- WatermarkPosition* m_positionOverride;
+ MdfString m_strName;
+ MdfString m_strResourceId;
+ Usage m_usage;
+ WatermarkAppearance* m_appearanceOverride;
+ WatermarkPosition* m_positionOverride;
+ WatermarkDefinition* m_pWatermarkDefinition;
typedef MdfOwnerCollection<WatermarkInstance> WatermarkInstanceCollection;
Modified: trunk/MgDev/Common/MdfModel/WatermarkOffsetUnit.h
--- trunk/MgDev/Common/MdfModel/WatermarkOffsetUnit.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkOffsetUnit.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -20,14 +20,14 @@
#include "MdfModel.h"
+BEGIN_NAMESPACE_MDFMODEL
-namespace MdfModel{
- namespace WatermarkOffset {
+ namespace WatermarkOffset
// DESCRIPTION:
- // The WatermarkOffsetUnit enum is to describe the content of the Unit property
- // in watermark offset.
+ // The WatermarkOffsetUnit enum is to describe the content of the Unit
+ // property in watermark offset.
enum WatermarkOffsetUnit
@@ -38,5 +38,6 @@
Points
+END_NAMESPACE_MDFMODEL
#endif // WATERMARKOFFSETUNIT_H_
Modified: trunk/MgDev/Common/MdfModel/WatermarkPosition.cpp
--- trunk/MgDev/Common/MdfModel/WatermarkPosition.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkPosition.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/MdfModel/WatermarkPosition.h
--- trunk/MgDev/Common/MdfModel/WatermarkPosition.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkPosition.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -27,7 +27,7 @@
// The WatermarkPosition class is the abstract class of position.
// It doesn't contain any field inside itself.
-class MDFMODEL_API WatermarkPosition
+ class MDFMODEL_API WatermarkPosition
public:
// Destruction
@@ -35,7 +35,6 @@
virtual bool Equals(WatermarkPosition* another) = 0;
- private:
protected:
// Construction, initialization
// Default constructor is protected to make this class abstract.
Modified: trunk/MgDev/Common/MdfModel/WatermarkXOffset.cpp
--- trunk/MgDev/Common/MdfModel/WatermarkXOffset.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkXOffset.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -21,8 +21,8 @@
// WatermarkXOffset class is to define the offset of watermark at one dimension.
#include <cmath>
#include "WatermarkXOffset.h"
@@ -33,9 +33,10 @@
// PURPOSE: Construct and initialize an instance of the WatermarkXOffset class.
WatermarkXOffset::WatermarkXOffset()
-: m_unit(WatermarkOffset::Pixels)
-, m_alignment(Center)
+ this->m_offset = 0.0;
+ this->m_unit = WatermarkOffset::Points;
+ this->m_alignment = Center;
@@ -46,19 +47,19 @@
-// Get the offset length
+// Get the offset length.
-double WatermarkXOffset::GetLength() const
+double WatermarkXOffset::GetOffset() const
- return this->m_length;
+ return this->m_offset;
-// Set the offset length
+// Set the offset length.
-void WatermarkXOffset::SetLength(const double& dLength)
+void WatermarkXOffset::SetOffset(const double& dOffset)
- this->m_length = dLength;
+ this->m_offset = dOffset;
@@ -99,12 +100,15 @@
this->m_alignment = alignment;
+// Determines whether this offset is the same as the supplied one.
bool WatermarkXOffset::Equals(WatermarkXOffset* another)
- return another
- && fabs(this->m_length - another->m_length) < doubleTolerance
- && this->m_unit == another->m_unit
- && this->m_alignment == another->m_alignment;
+ return another &&
+ fabs(this->m_offset - another->m_offset) < doubleTolerance &&
+ this->m_unit == another->m_unit &&
+ this->m_alignment == another->m_alignment;
#ifdef _WIN32
Modified: trunk/MgDev/Common/MdfModel/WatermarkXOffset.h
--- trunk/MgDev/Common/MdfModel/WatermarkXOffset.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkXOffset.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -44,9 +44,9 @@
virtual ~WatermarkXOffset();
// Operations
- // Property: Length
- double GetLength() const;
- void SetLength(const double& dLength);
+ // Property: Offset
+ double GetOffset() const;
+ void SetOffset(const double& dOffset);
// Property : Unit
WatermarkOffset::WatermarkOffsetUnit GetUnit() const;
@@ -67,19 +67,18 @@
private:
// Hidden WatermarkXOffset copy constructor and assignment operator.
- WatermarkXOffset(const WatermarkXOffset&);
- WatermarkXOffset& operator=(const WatermarkXOffset&);
+ WatermarkXOffset(const WatermarkXOffset&);
+ WatermarkXOffset& operator=(const WatermarkXOffset&);
// Data members
- double m_length;
+ double m_offset;
// The meaning of the string in the Unit property.
- WatermarkOffset::WatermarkOffsetUnit m_unit;
+ WatermarkOffset::WatermarkOffsetUnit m_unit;
// The meaning of the string in the Alignment property.
- HorizontalAlignment m_alignment;
+ HorizontalAlignment m_alignment;
Modified: trunk/MgDev/Common/MdfModel/WatermarkYOffset.cpp
--- trunk/MgDev/Common/MdfModel/WatermarkYOffset.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkYOffset.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -21,8 +21,8 @@
// WatermarkYOffset class is to define the offset of watermark at one dimension.
#include <cmath>
#include "WatermarkYOffset.h"
@@ -33,9 +33,10 @@
// PURPOSE: Construct and initialize an instance of the WatermarkYOffset class.
WatermarkYOffset::WatermarkYOffset()
@@ -46,19 +47,19 @@
-double WatermarkYOffset::GetLength() const
+double WatermarkYOffset::GetOffset() const
-void WatermarkYOffset::SetLength(const double& dLength)
+void WatermarkYOffset::SetOffset(const double& dOffset)
bool WatermarkYOffset::Equals(WatermarkYOffset* another)
- return another
+ return another &&
#ifdef _WIN32
Modified: trunk/MgDev/Common/MdfModel/WatermarkYOffset.h
--- trunk/MgDev/Common/MdfModel/WatermarkYOffset.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/WatermarkYOffset.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -25,7 +25,7 @@
// DESCRIPTION:
- // The WatermarkOffest class is to define the offset in Y-axis of the watermark.
+ // The WatermarkYOffest class is to define the offset in Y-axis of the watermark.
class MDFMODEL_API WatermarkYOffset
@@ -44,9 +44,9 @@
virtual ~WatermarkYOffset();
// Operations
// Property : Unit
@@ -67,19 +67,18 @@
private:
// Hidden WatermarkYOffset copy constructor and assignment operator.
- WatermarkYOffset(const WatermarkYOffset&);
- WatermarkYOffset& operator=(const WatermarkYOffset&);
+ WatermarkYOffset(const WatermarkYOffset&);
+ WatermarkYOffset& operator=(const WatermarkYOffset&);
// Data members
- double m_length;
+ double m_offset;
- VerticalAlignment m_alignment;
+ VerticalAlignment m_alignment;
Modified: trunk/MgDev/Common/MdfModel/XYWatermarkPosition.cpp
--- trunk/MgDev/Common/MdfModel/XYWatermarkPosition.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/XYWatermarkPosition.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -31,9 +31,9 @@
// PURPOSE: Construct and initialize an instance of the XYWatermarkPosition class.
XYWatermarkPosition::XYWatermarkPosition()
-: m_XPosition(NULL)
-, m_YPosition(NULL)
+ this->m_XPosition = NULL;
+ this->m_YPosition = NULL;
@@ -73,7 +73,7 @@
// It may be NULL.
-void XYWatermarkPosition::AdoptXPosition(WatermarkXOffset *pXPosition)
+void XYWatermarkPosition::AdoptXPosition(WatermarkXOffset* pXPosition)
if (this->m_XPosition != pXPosition)
@@ -122,7 +122,7 @@
// It may be NULL.
-void XYWatermarkPosition::AdoptYPosition(WatermarkYOffset *pYPosition)
+void XYWatermarkPosition::AdoptYPosition(WatermarkYOffset* pYPosition)
if (this->m_YPosition != pYPosition)
@@ -143,26 +143,35 @@
return pRet;
bool XYWatermarkPosition::Equals(WatermarkPosition* another)
XYWatermarkPosition* anotherPosition = dynamic_cast<XYWatermarkPosition*>(another);
+ return false;
- if(!this->m_XPosition)
+ // check X position
+ if (!this->m_XPosition)
- if(anotherPosition->m_XPosition) return false;
+ if (anotherPosition->m_XPosition)
+ return false;
- else if(!this->m_XPosition->Equals(anotherPosition->m_XPosition))
+ else if (!this->m_XPosition->Equals(anotherPosition->m_XPosition))
return false;
- if(!this->m_YPosition)
+ // check Y position
+ if (!this->m_YPosition)
- return !anotherPosition->m_YPosition;
+ if (anotherPosition->m_YPosition)
+ return false;
- else
- return this->m_YPosition->Equals(anotherPosition->m_YPosition);
+ else if (!this->m_YPosition->Equals(anotherPosition->m_YPosition))
+ return false;
+ return true;
#ifdef _WIN32
Modified: trunk/MgDev/Common/MdfModel/XYWatermarkPosition.h
--- trunk/MgDev/Common/MdfModel/XYWatermarkPosition.h 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfModel/XYWatermarkPosition.h 2010-09-17 22:23:54 UTC (rev 5148)
@@ -1,5 +1,5 @@
@@ -30,7 +30,7 @@
// The XYWatermarkPosition class is one concrete implementation of WatermarkPosition.
// It uses X-Y as the position of watermark.
-class MDFMODEL_API XYWatermarkPosition: public WatermarkPosition
+ class MDFMODEL_API XYWatermarkPosition: public WatermarkPosition
public:
@@ -42,13 +42,13 @@
// Property: XPosition
const WatermarkXOffset* GetXPosition() const;
WatermarkXOffset* GetXPosition();
- void AdoptXPosition(WatermarkXOffset *pXPosition);
+ void AdoptXPosition(WatermarkXOffset* pXPosition);
WatermarkXOffset* OrphanXPosition();
// Property: YPosition
const WatermarkYOffset* GetYPosition() const;
WatermarkYOffset* GetYPosition();
- void AdoptYPosition(WatermarkYOffset *pYPosition);
+ void AdoptYPosition(WatermarkYOffset* pYPosition);
WatermarkYOffset* OrphanYPosition();
@@ -62,13 +62,13 @@
private:
// Hidden XYWatermarkPosition copy constructor and assignment operator.
- XYWatermarkPosition(const XYWatermarkPosition&);
- XYWatermarkPosition& operator=(const XYWatermarkPosition&);
+ XYWatermarkPosition(const XYWatermarkPosition&);
+ XYWatermarkPosition& operator=(const XYWatermarkPosition&);
// Data members
- WatermarkXOffset* m_XPosition;
- WatermarkYOffset* m_YPosition;
+ WatermarkXOffset* m_XPosition;
+ WatermarkYOffset* m_YPosition;
Modified: trunk/MgDev/Common/MdfParser/IOWatermarkInstance.cpp
--- trunk/MgDev/Common/MdfParser/IOWatermarkInstance.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfParser/IOWatermarkInstance.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -105,7 +105,7 @@
break;
case eResourceId:
- this->m_watermark->SetWatermarkResourceID(ch);
+ this->m_watermark->SetResourceId(ch);
break;
case eUsage:
if (::wcscmp(ch, L"WMS") == 0) // NOXLATE
@@ -113,7 +113,7 @@
else if (::wcscmp(ch, L"Viewer") == 0) // NOXLATE
this->m_watermark->SetUsage(WatermarkInstance::Viewer);
else
- this->m_watermark->SetUsage(WatermarkInstance::ALL); //Treat as "ALL" if string is incorrect
+ this->m_watermark->SetUsage(WatermarkInstance::All); //Treat as "All" if string is incorrect
break;
@@ -140,7 +140,7 @@
fd << EncodeString(watermark->GetName());
fd << endStr(sName) << std::endl;
fd << tab() << startStr(sResourceId);
- fd << EncodeString(watermark->GetWatermarkResourceID());
+ fd << EncodeString(watermark->GetResourceId());
fd << endStr(sResourceId) << std::endl;
fd << tab() << startStr(sUsage);
Modified: trunk/MgDev/Common/MdfParser/IOWatermarkXOffset.cpp
--- trunk/MgDev/Common/MdfParser/IOWatermarkXOffset.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfParser/IOWatermarkXOffset.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -70,7 +70,7 @@
switch (this->m_currElemId)
case eOffset:
- this->m_XOffset->SetLength(wstrToDouble(ch));
+ this->m_XOffset->SetOffset(wstrToDouble(ch));
break;
case eAlignment:
@@ -107,7 +107,7 @@
inctab();
fd << tab() << startStr(sOffset);
- fd << DoubleToStr(xOffset->GetLength());
+ fd << DoubleToStr(xOffset->GetOffset());
fd << endStr(sOffset) << std::endl;
IOWatermarkOffsetUnit::Write(fd, xOffset->GetUnit());
Modified: trunk/MgDev/Common/MdfParser/IOWatermarkYOffset.cpp
--- trunk/MgDev/Common/MdfParser/IOWatermarkYOffset.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/MdfParser/IOWatermarkYOffset.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -70,7 +70,7 @@
case eOffset:
- this->m_YOffset->SetLength(wstrToDouble(ch));
+ this->m_YOffset->SetOffset(wstrToDouble(ch));
break;
case eAlignment:
@@ -107,7 +107,7 @@
inctab();
- fd << DoubleToStr(yOffset->GetLength());
+ fd << DoubleToStr(yOffset->GetOffset());
IOWatermarkOffsetUnit::Write(fd, yOffset->GetUnit());
Modified: trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd
--- trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd 2010-09-17 22:23:54 UTC (rev 5148)
@@ -15,7 +15,7 @@
</xs:element>
<xs:simpleType name="UnitType">
<xs:annotation>
- <xs:documentation>Unit for watermark</xs:documentation>
+ <xs:documentation>Unit for a watermark.</xs:documentation>
</xs:annotation>
<xs:restriction base="xs:string">
<xs:enumeration value="Inches"/>
@@ -27,7 +27,7 @@
</xs:simpleType>
<xs:simpleType name="HorizontalAlignmentType">
<xs:annotation>
- <xs:documentation>Horizontal alignment for watermark</xs:documentation>
+ <xs:documentation>Horizontal alignment for a watermark.</xs:documentation>
</xs:annotation>
<xs:enumeration value="Left"/>
@@ -37,7 +37,7 @@
</xs:simpleType>
<xs:complexType name="HorizontalPositionType">
<xs:annotation>
- <xs:documentation>Horizontal position of watermark</xs:documentation>
+ <xs:documentation>Horizontal position of a watermark.</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="Offset" type="xs:double" default="0">
@@ -59,7 +59,7 @@
</xs:complexType>
<xs:simpleType name="VerticalAlignmentType">
<xs:annotation>
- <xs:documentation>Vertical alignment for watermark</xs:documentation>
+ <xs:documentation>Vertical alignment for a watermark.</xs:documentation>
</xs:annotation>
<xs:enumeration value="Top"/>
@@ -69,7 +69,7 @@
</xs:simpleType>
<xs:complexType name="VerticalPositionType">
<xs:annotation>
- <xs:documentation>Vertical position of watermark</xs:documentation>
+ <xs:documentation>Vertical position of a watermark.</xs:documentation>
</xs:annotation>
<xs:sequence>
@@ -79,7 +79,7 @@
</xs:element>
<xs:element name="Unit" type="UnitType" default="Points">
<xs:annotation>
- <xs:documentation>Vertical for horizontal offset</xs:documentation>
+ <xs:documentation>Unit for vertical offset</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="Alignment" type="VerticalAlignmentType" default="Center">
@@ -91,7 +91,7 @@
</xs:complexType>
<xs:complexType name="PositionType" abstract="true">
<xs:annotation>
- <xs:documentation>Abstract position type for watermark.</xs:documentation>
+ <xs:documentation>Abstract position type for a watermark.</xs:documentation>
</xs:annotation>
<xs:sequence>
</xs:sequence>
@@ -150,12 +150,12 @@
</xs:complexType>
<xs:complexType name="WatermarkAppearanceType">
<xs:annotation>
- <xs:documentation>Appearance of watermark</xs:documentation>
+ <xs:documentation>Appearance of a watermark.</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="Transparency" minOccurs="0" default="0">
<xs:annotation>
- <xs:documentation>The transparency of watermark (0 -100). The default value is 0 (opaque).</xs:documentation>
+ <xs:documentation>The transparency of a watermark (0 -100). The default value is 0 (opaque).</xs:documentation>
</xs:annotation>
<xs:simpleType>
<xs:restriction base="xs:double">
@@ -166,7 +166,7 @@
</xs:element>
<xs:element name="Rotation" minOccurs="0" default="0">
<xs:annotation>
- <xs:documentation>The rotation of watermark (0-360). The default value is 0</xs:documentation>
+ <xs:documentation>The rotation of a watermark (0-360), in degrees. The default value is 0</xs:documentation>
</xs:annotation>
<xs:simpleType>
@@ -179,7 +179,7 @@
</xs:complexType>
<xs:complexType name="WatermarkDefinitionType">
<xs:annotation>
- <xs:documentation>Watermark definition contains content and position of watermark</xs:documentation>
+ <xs:documentation>Watermark definition contains content and position of watermark.</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="WatermarkSource">
@@ -203,18 +203,18 @@
</xs:element>
<xs:element name="Appearance" type="WatermarkAppearanceType">
<xs:annotation>
- <xs:documentation>The appearance of watermark.</xs:documentation>
+ <xs:documentation>The appearance of the watermark.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="Position">
<xs:annotation>
- <xs:documentation>Position of watermark</xs:documentation>
+ <xs:documentation>The position of the watermark</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:choice>
<xs:element name="XYPosition" type="XYPositionType">
<xs:annotation>
- <xs:documentation>A X-Y position</xs:documentation>
+ <xs:documentation>X-Y position</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="TilePosition" type="TilePositionType">
@@ -230,7 +230,7 @@
</xs:complexType>
<xs:simpleType name="UsageType">
<xs:annotation>
- <xs:documentation>The situation that watermark can be used.</xs:documentation>
+ <xs:documentation>The context in which the watermark can be used.</xs:documentation>
</xs:annotation>
<xs:enumeration value="WMS">
@@ -245,7 +245,7 @@
</xs:enumeration>
<xs:enumeration value="ALL">
<xs:annotation>
- <xs:documentation>Watermark can show in all situation.</xs:documentation>
+ <xs:documentation>Watermark can show in all situations.</xs:documentation>
</xs:annotation>
</xs:enumeration>
</xs:restriction>
@@ -265,9 +265,9 @@
<xs:documentation>A reference to an existing watermark definition.</xs:documentation>
</xs:annotation>
</xs:element>
- <xs:element name="Usage" type="UsageType" minOccurs="0" default="ALL">
+ <xs:element name="Usage" type="UsageType" minOccurs="0" default="All">
<xs:annotation>
- <xs:documentation>The situation that watermark can be used. The default value is ALL.</xs:documentation>
+ <xs:documentation>The context in which the watermark can be used. The default value is All.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="AppearanceOverrides" type="WatermarkAppearanceType" minOccurs="0">
@@ -299,7 +299,7 @@
</xs:complexType>
<xs:complexType name="WatermarkInstanceCollectionType">
<xs:annotation>
- <xs:documentation>A collection of watermark used by map or layer.</xs:documentation>
+ <xs:documentation>A collection of watermarks used by a map or layer.</xs:documentation>
</xs:annotation>
<xs:sequence>
<xs:element name="Watermark" type="WatermarkType" minOccurs="0" maxOccurs="unbounded">
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2010-09-17 20:23:27 UTC (rev 5147)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2010-09-17 22:23:54 UTC (rev 5148)
@@ -940,9 +940,11 @@
- if(renderingWatermark)
+ if (renderingWatermark)
- //Rendering watermark
+ // Rendering watermark
+ // TODO: Don't allocate objects on heap if unnecessary!!!!!!!!!!!!!!
Ptr<MgStringCollection> watermarkIds = new MgStringCollection(); //ID list to load watermark definition
auto_ptr<WatermarkInstanceCollection> watermarkInstances(
new WatermarkInstanceCollection()); //Watermark list to render
@@ -950,111 +952,115 @@
new WatermarkInstanceCollection()); //Used to reverse list
auto_ptr<WatermarkInstance> tempInstance;
- //Get watermark instance in map
+ // Get watermark instance in map
Ptr<MgResourceIdentifier> mapId = map->GetMapDefinition();
- if(mapId.p)
+ if (mapId.p)
- auto_ptr<MapDefinition> mdef(
- MgMapBase::GetMapDefinition(m_svcResource, mapId));
+ auto_ptr<MapDefinition> mdef(MgMapBase::GetMapDefinition(m_svcResource, mapId));
WatermarkInstanceCollection* mapWatermarks = mdef->GetWatermarks();
- for(int i = mapWatermarks->GetCount()-1; i>=0; i--)
+ for (int i=mapWatermarks->GetCount()-1; i>=0; i--)
tempWatermarkInstances->Adopt(mapWatermarks->OrphanAt(i));
- for(int i = tempWatermarkInstances->GetCount()-1; i>=0; i--)
+ for (int i=tempWatermarkInstances->GetCount()-1; i>=0; i--)
tempInstance.reset(tempWatermarkInstances->OrphanAt(i));
- if(!tempInstance.get()) continue;
- if(((map->GetWatermarkUsage() & MgMap::Viewer) != 0
+ if (!tempInstance.get())
+ continue;
+ if (((map->GetWatermarkUsage() & MgMap::Viewer) != 0
&& (tempInstance->GetUsage() & WatermarkInstance::Viewer) == 0)
|| ((map->GetWatermarkUsage() & MgMap::WMS) != 0
&& (tempInstance->GetUsage() & WatermarkInstance::WMS) == 0))
continue;
bool alreadyInList = false;
- for(int j = watermarkInstances->GetCount()-1; j >=0; j--)
+ for (int j=watermarkInstances->GetCount()-1; j >=0; j--)
- if(tempInstance->Equals(watermarkInstances->GetAt(j)))
+ if (tempInstance->Equals(watermarkInstances->GetAt(j)))
alreadyInList = true;
break;
- if(!alreadyInList)
+ if (!alreadyInList)
- watermarkIds->Add(tempInstance->GetWatermarkResourceID().c_str());
+ watermarkIds->Add(tempInstance->GetResourceId().c_str());
watermarkInstances->Adopt(tempInstance.release());
- //Get watermark instance in layer
+ // Get watermark instance in layer
const int layerCount = tempLayers->GetCount();
auto_ptr<LayerDefinition> ldf;
- for(int i = 0; i < layerCount; i++)
+ for (int i=0; i<layerCount; ++i)
Ptr<MgLayerBase> mapLayer(tempLayers->GetItem(i));
- //The layer resource content should be set during stylization.
- if(mapLayer->GetLayerResourceContent() == L"")
+ // the layer resource content should be set during stylization
+ if (mapLayer->GetLayerResourceContent() == L"")
continue;
ldf.reset(MgLayerBase::GetLayerDefinition(mapLayer->GetLayerResourceContent()));
WatermarkInstanceCollection* layerWatermarks = ldf->GetWatermarks();
- for(int j = layerWatermarks->GetCount()-1; j>=0; j--)
+ for (int j=layerWatermarks->GetCount()-1; j>=0; j--)
tempWatermarkInstances->Adopt(layerWatermarks->OrphanAt(j));
- for(int j = tempWatermarkInstances->GetCount()-1; j>=0; j--)
+ for (int j=tempWatermarkInstances->GetCount()-1; j>=0; j--)
tempInstance.reset(tempWatermarkInstances->OrphanAt(j));
+ continue;
continue;
- for(int k = watermarkInstances->GetCount()-1; k >=0; k--)
+ for (int k=watermarkInstances->GetCount()-1; k>=0; k--)
- if(tempInstance->Equals(watermarkInstances->GetAt(k)))
+ if (tempInstance->Equals(watermarkInstances->GetAt(k)))
break;
assert(tempWatermarkInstances->GetCount() == 0);
- //Load watermark source
- if(watermarkIds->GetCount() != 0)
+ // load watermark source
+ if (watermarkIds->GetCount() != 0)
Ptr<MgStringCollection> wdefs = m_svcResource->GetResourceContents(watermarkIds, NULL);
- for(int i = watermarkIds->GetCount() - 1; i >= 0; i--)
+ for (int i=watermarkIds->GetCount()-1; i>=0; i--)
- for(int j = watermarkInstances->GetCount() - 1; j >= 0; j--)
+ for (int j=watermarkInstances->GetCount()-1; j>=0; j--)
WatermarkInstance* instance = watermarkInstances->GetAt(j);
- if(instance->GetWatermarkResourceID() == watermarkIds->GetItem(i))
+ if (instance->GetResourceId() == watermarkIds->GetItem(i))
- instance->AdoptWatermarkDefinition(
- MgWatermark::GetWatermarkDefinition(wdefs->GetItem(i)));
+ instance->AdoptWatermarkDefinition(MgWatermark::GetWatermarkDefinition(wdefs->GetItem(i)));
- for(int i = watermarkInstances->GetCount()-1; i>=0; i--)
+ for (int i=watermarkInstances->GetCount()-1; i>=0; i--)
WatermarkInstance* instance = watermarkInstances->GetAt(i);
WatermarkDefinition* wdef = instance->GetWatermarkDefinition();
- if(instance->GetPositionOverride())
+ if (instance->GetPositionOverride())
wdef->AdoptPosition(instance->OrphanPositionOverride());
- if(instance->GetAppearanceOverride())
+ if (instance->GetAppearanceOverride())
wdef->AdoptAppearance(instance->GetAppearanceOverride());
More information about the mapguide-commits
