[mapguide-commits] r5150 - trunk/MgDev/Common/Schema
svn_mapguide at osgeo.org
Fri Sep 17 19:20:07 EDT 2010
Author: waltweltonlair
Date: 2010-09-17 23:20:07 +0000 (Fri, 17 Sep 2010)
New Revision: 5150
trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd
One more watermark schema cleanup: change ALL to All in Usage enumeration.
Modified: trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd
--- trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd 2010-09-17 22:37:36 UTC (rev 5149)
+++ trunk/MgDev/Common/Schema/WatermarkDefinition-1.0.0.xsd 2010-09-17 23:20:07 UTC (rev 5150)
@@ -155,7 +155,7 @@
<xs:sequence>
<xs:element name="Transparency" minOccurs="0" default="0">
<xs:annotation>
- <xs:documentation>The transparency of a watermark (0 -100). The default value is 0 (opaque).</xs:documentation>
+ <xs:documentation>The transparency of a watermark (0-100). The default value is 0 (opaque).</xs:documentation>
</xs:annotation>
<xs:simpleType>
<xs:restriction base="xs:double">
@@ -208,7 +208,7 @@
</xs:element>
<xs:element name="Position">
<xs:annotation>
- <xs:documentation>The position of the watermark</xs:documentation>
+ <xs:documentation>The position of the watermark.</xs:documentation>
</xs:annotation>
<xs:complexType>
<xs:choice>
@@ -219,7 +219,7 @@
</xs:element>
<xs:element name="TilePosition" type="TilePositionType">
<xs:annotation>
- <xs:documentation>Tile position.</xs:documentation>
+ <xs:documentation>Tile position</xs:documentation>
</xs:annotation>
</xs:element>
</xs:choice>
@@ -243,7 +243,7 @@
<xs:documentation>Watermark can show in AJAX viewer or Fusion viewer.</xs:documentation>
</xs:annotation>
</xs:enumeration>
- <xs:enumeration value="ALL">
+ <xs:enumeration value="All">
<xs:annotation>
<xs:documentation>Watermark can show in all situations.</xs:documentation>
</xs:annotation>
More information about the mapguide-commits
