[mapguide-commits] r5152 -
trunk/MgDev/Common/MapGuideCommon/Services
svn_mapguide at osgeo.org
Sun Sep 19 01:50:38 EDT 2010
Author: liuar
Date: 2010-09-19 05:50:38 +0000 (Sun, 19 Sep 2010)
New Revision: 5152
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
Submit on behalf of Mars Wu
It's for ticket 1443: MgProxyFeatureService::GetCapabilities is using a fixed api version 1.0.0
http://trac.osgeo.org/mapguide/ticket/1443
Steps: - Run WebTier? tests:Feature/GetCapabilities. It will get the capabilites for a certain FDO provider. - Keep the initial values for the test page except for changing the version to be 2.0.0 - Submit the request
You will find the response is always for 1.0.0 instead of 2.0.0.
The reason is like following:
MgByteReader * MgProxyFeatureService::GetCapabilities?(CREFSTRING providerName, CREFSTRING connectionString)
MgCommand? cmd;
cmd.ExecuteCommand?(m_connProp, // Connection
MgCommand::knObject, // Return type expected
MgFeatureServiceOpId::GetCapabilities?_Id, // Command Code
2, // No of arguments
Feature_Service, // Service Id
BUILD_VERSION(1,0,0), // Operation version
MgCommand::knString, &providerName, // Argument#1
MgCommand::knString, &connectionString, // Argument#2
MgCommand::knNone); // End of argument
SetWarning?(cmd.GetWarningObject?());
return (MgByteReader?*)cmd.GetReturnValue?().val.m_obj;
The version is a fixed one: BUILD_VERSION(1,0,0) instead of the requested version
This submission changes BUILD_VERSION(1,0,0) to be m_connProp->GetUserInfo()->GetApiVersion()
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2010-09-18 07:34:36 UTC (rev 5151)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2010-09-19 05:50:38 UTC (rev 5152)
@@ -289,7 +289,7 @@
MgFeatureServiceOpId::GetCapabilities_Id, // Command Code
- BUILD_VERSION(1,0,0), // Operation version
+ m_connProp->GetUserInfo()->GetApiVersion(), // Operation version
More information about the mapguide-commits
