[mapguide-commits] r5157 -
trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls
svn_mapguide at osgeo.org
Mon Sep 20 03:08:58 EDT 2010
Author: jng
Date: 2010-09-20 07:08:58 +0000 (Mon, 20 Sep 2010)
New Revision: 5157
trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.resx
Fix #1441: Individual property selections were not saved because no change listeners were registered to the System.Windows.Forms.DataGrid (note DataGrid not DataGridView), and also the APIs to do this were very primitive
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs 2010-09-20 06:46:40 UTC (rev 5156)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs 2010-09-20 07:08:58 UTC (rev 5157)
@@ -379,6 +379,7 @@
this.dataGrid1.RowHeadersVisible = false;
this.dataGrid1.TableStyles.AddRange(new System.Windows.Forms.DataGridTableStyle[] {
this.dataGridTableStyle1});
+ this.dataGrid1.MouseUp += new System.Windows.Forms.MouseEventHandler(this.dataGrid1_MouseUp);
// dataGridTableStyle1
@@ -864,47 +865,52 @@
if (m_layer == null || m_layer.Item as OSGeo.MapGuide.MaestroAPI.VectorLayerDefinitionType == null || inUpdate)
return;
- OSGeo.MapGuide.MaestroAPI.VectorLayerDefinitionType vldef = m_layer.Item as OSGeo.MapGuide.MaestroAPI.VectorLayerDefinitionType;
+ UpdateLayerProperties();
- if (vldef.PropertyMapping == null)
- vldef.PropertyMapping = new NameStringPairTypeCollection();
+ private void UpdateLayerProperties()
+ OSGeo.MapGuide.MaestroAPI.VectorLayerDefinitionType vldef = m_layer.Item as OSGeo.MapGuide.MaestroAPI.VectorLayerDefinitionType;
- foreach(DataRow dr in ViewerPropertiesTable.Rows)
- string n = (string)dr["Name"];
- int i;
- for(i = 0; i < vldef.PropertyMapping.Count; i++)
- if (vldef.PropertyMapping[i].Name == n)
- break;
+ if (vldef.PropertyMapping == null)
+ vldef.PropertyMapping = new NameStringPairTypeCollection();
- if ((bool)dr["Visible"] == true)
- if (i >= vldef.PropertyMapping.Count)
- NameStringPairType ns = new NameStringPairType();
- ns.Name = n;
- ns.Value = (string)dr["Display"];
- vldef.PropertyMapping.Add(ns);
- else
- if (vldef.PropertyMapping[i].Value != (string)dr["Display"])
- vldef.PropertyMapping[i].Value = (string)dr["Display"];
- else
- if (i < vldef.PropertyMapping.Count)
- vldef.PropertyMapping.RemoveAt(i);
+ foreach (DataRow dr in ViewerPropertiesTable.Rows)
+ string n = (string)dr["Name"];
+ int i;
+ for (i = 0; i < vldef.PropertyMapping.Count; i++)
+ if (vldef.PropertyMapping[i].Name == n)
+ break;
- if (vldef.PropertyMapping.Count == 0)
- vldef.PropertyMapping = null;
+ if ((bool)dr["Visible"] == true)
+ if (i >= vldef.PropertyMapping.Count)
+ NameStringPairType ns = new NameStringPairType();
+ ns.Name = n;
+ ns.Value = (string)dr["Display"];
+ vldef.PropertyMapping.Add(ns);
+ else
+ if (vldef.PropertyMapping[i].Value != (string)dr["Display"])
+ vldef.PropertyMapping[i].Value = (string)dr["Display"];
+ else
+ if (i < vldef.PropertyMapping.Count)
+ vldef.PropertyMapping.RemoveAt(i);
- m_editor.HasChanged();
+ if (vldef.PropertyMapping.Count == 0)
+ vldef.PropertyMapping = null;
+ m_editor.HasChanged();
private void AddScaleRangeButton_Click(object sender, EventArgs e)
AddScaleRange(DefaultItemGenerator.CreateVectorScaleRangeType());
@@ -1138,6 +1144,24 @@
#endregion
+ //http://www.syncfusion.com/FAQ/windowsforms/faq_c44c.aspx#q945q
+ private void dataGrid1_MouseUp(object sender, MouseEventArgs e)
+ DataGrid.HitTestInfo hti = this.dataGrid1.HitTest(e.X, e.Y);
+ try
+ if (hti.Type == DataGrid.HitTestType.Cell &&
+ hti.Column == 0)
+ this.dataGrid1[hti.Row, hti.Column] = !(bool)this.dataGrid1[hti.Row, hti.Column];
+ catch (Exception ex)
+ MessageBox.Show(ex.ToString());
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.resx 2010-09-20 06:46:40 UTC (rev 5156)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.resx 2010-09-20 07:08:58 UTC (rev 5157)
@@ -136,7 +136,7 @@
<value>schemaSelector</value>
</data>
<data name=">>schemaSelector.Type" xml:space="preserve">
- <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.SchemaSelector, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4358, Culture=neutral, PublicKeyToken=null</value>
+ <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.SchemaSelector, OSGeo.MapGuide.Maestro.ResourceEditors, Version=2.1.1.5078, Culture=neutral, PublicKeyToken=null</value>
</data>
<data name=">>schemaSelector.Parent" xml:space="preserve">
<value>ResourceGroup</value>
@@ -416,270 +416,270 @@
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADK
- QAAAAk1TRnQBSQFMAgEBCwEAARQBAAEUAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
- AwABMAMAAQEBAAEgBgABMDoAAXsBlQGBAf8BWAGSAW8B/wFnAZEBdgH/AYEBqwGBAf8wAAF7AZUBgQH/
- AVgBkgFvAf8BZwGRAXYB/wGBAasBgQH/DAABxQLCAf8BwQK+Af8BwQK+Af8BvgK8Af8BvgK8Af8BvgK8
- Af8BvgK8Af8BvgK8Af8BhAGGAagB/wKBAbUB/wFhAXcBuwH/AXABgQG5Af8CgQGrAf8BsAGvAbQB/1gA
- AYEBngGBAf8BVwGFAXkB/wFAAYsBbQH/AUkBgQFdAf8BVwGjAXIB/wFWAdcBgQH/AYEB5gGfAf8BcQHd
- AYEB/wFYAbgBgQH/AXMBkAF8Af8EAAGLAdoB7QH/AYEB2AHrAf8BgQHYAesB/wGBAdgB6wH/AYEB2AHr
- Af8BgQHYAesB/wGBAdgB6wH/AYEB2AHqAf8BgQGkAYQB/wFXAaMBcgH/AVcB1wGBAf8BgQHmAZ8B/wFx
- Ad0BgQH/AVgBuAGBAf8BagGPAYAB/wGKAdIB3wH/BAABwQK+Af8B+gH1AfQB/wH3Ae8B7AH/AfcB7wHs
- Af8B9gHsAekB/wH2AewB6QH/AfYB7AHpAf8BgwGGAcIB/wFiAXwB0wH/AV4BgQH1Af8BWQGBAfwB/wFc
- AYEB+QH/AWIBgQHkAf8BdwGBAbAB/1QAAUQBiwFwAf8BPAHGAYEB/wE8AdwBgQH/AUABxwGBAf8BVwGU
- AWMB/wFcAcQBgQH/AV8B2AGBAf8B4wHyAekB/wGBAeABnwH/AV4BzAGBAf8BWwGnAW0B/wGBAasBgQH/
+ QAAAAk1TRnQBSQFMAgEBCwEAASwBAAEsAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ AwABMAMAAQEBAAEgBgABMDoAAXgBlQGBAf8BVQGSAWwB/wFkAZEBcwH/AYEBqwGBAf8wAAF4AZUBgQH/
+ AVUBkgFsAf8BZAGRAXMB/wGBAasBgQH/DAABxQLCAf8BwQK+Af8BwQK+Af8BvgK8Af8BvgK8Af8BvgK8
+ Af8BvgK8Af8BvgK8Af8BhAGGAagB/wKBAbUB/wFeAXQBuwH/AW0BgQG5Af8CgQGrAf8BsAGvAbQB/1gA
+ AYEBngGBAf8BVAGFAXYB/wE9AYsBagH/AUYBgQFaAf8BVAGjAW8B/wFTAdcBgQH/AYEB5gGfAf8BbgHd
+ AYEB/wFVAbgBgQH/AXABkAF5Af8EAAGLAdoB7QH/AYEB2AHrAf8BgQHYAesB/wGBAdgB6wH/AYEB2AHr
+ Af8BgQHYAesB/wGBAdgB6wH/AYEB2AHqAf8BgQGkAYQB/wFUAaMBbwH/AVQB1wGBAf8BgQHmAZ8B/wFu
+ Ad0BgQH/AVUBuAGBAf8BZwGPAYAB/wGKAdIB3wH/BAABwQK+Af8B+gH1AfQB/wH3Ae8B7AH/AfcB7wHs
+ Af8B9gHsAekB/wH2AewB6QH/AfYB7AHpAf8BgwGGAcIB/wFfAXkB0wH/AVsBgQH1Af8BVgGBAfwB/wFZ
+ AYEB+QH/AV8BgQHkAf8BdAGBAbAB/1QAAUEBiwFtAf8BOQHGAYEB/wE5AdwBgQH/AT0BxwGBAf8BVAGU
+ AWAB/wFZAcQBgQH/AVwB2AGBAf8B4wHyAekB/wGBAeABnwH/AVsBzAGBAf8BWAGnAWoB/wGBAasBgQH/
AYEB2AHrAf8BrAH/AfgB/wGsAf8B+AH/AawB/wH4Af8BrAH/AfgB/wGsAf8B+AH/AawB/wH4Af8BjgHf
- AcsB/wFYAZQBZAH/AVwBxAGBAf8BXwHYAYEB/wHjAfIB6QH/AYEB4AGfAf8BXgHMAYEB/wFbAacBbQH/
+ AcsB/wFVAZQBYQH/AVkBxAGBAf8BXAHYAYEB/wHjAfIB6QH/AYEB4AGfAf8BWwHMAYEB/wFYAacBagH/
AYEBpQGBAf8EAAHFAsIB/wH6AfUB9AH/AfQB5gHhAf8B9AHmAeEB/wHyAeQB3gH/AfIB5AHeAf8BxQG5
- AcgB/wFlAXQBygH/AWkBgQH3Af8BagGBAf4B/wFqAYEB/gH/AWoBgQH+Af8BawGBAfwB/wFoAXwB4QH/
- AYEBhQHFAf9MAAE+AaMBdwH/ATwB3AGBAf8BPAHrAYEB/wE8AfQBgQH/AUcBsgF2Af8BWwGnAW0B/wGB
- AcoBgQH/AYMB2AGYAf8B7gH2AfAB/wGyAeMBvgH/AYEB0wGPAf8BdAGzAYEB/wFpAY0BbwH/AYEB2AHr
- Af8BrAH/AfgB/wGsAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BgQG2AYYB/wFb
- AacBbQH/AYEBygGBAf8BgwHYAZkB/wHuAfYB8AH/AbIB4wG/Af8BgQHTAY8B/wF0AbMBgQH/AWkBjQFw
- Af8EAAHBAr4B/wH6AfUB9AH/AfcB7wHsAf8B7QHiAd4B/wHfAdMB0AH/Ad8B0wHQAf8CgQG3Af8BaAF8
- AeEB/wGBAYQB8wH/AY8BogH2Af8BjwGiAfYB/wGPAaUB9gH/AYwBmwH2Af8CgQHrAf8BcAGBAbkB/0gA
- AUQBiwFwAf8BPAHcAYEB/wE8AfQBgQH/AT4B/AGBAf8BQwH+AYEB/wFNAa4BdQH/AV8BqAFpAf8BwgHg
- AcUB/wHtAfIB7QH/A/4B/wHyAfYB8gH/Ae0B8gHtAf8BgQG8AYEB/wFaAYgBYgH/AYEB2AHqAf8BrAH/
- AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGsAf8B+AH/AaUB/wH4Af8BgQGuAYEB/wFfAagBaQH/
- AcIB4AHFAf8B7QHyAe0B/wP+Af8B8gH2AfIB/wHtAfIB7QH/AYEBvAGBAf8BWgGIAWIB/wQAAcUCwgH/
- AfoB9QH0Af8B+AHvAewB/wHuAeUB4gH/AeEB2QHWAf8B4QHWAdIB/wKBAbkB/wFuAXwB6AH/Ab4BwgHv
- Af8B6wHsAfUB/wHrAewB9QH/AesB7AH1Af8B6wHsAfUB/wKBAeoB/wFlAXEBuwH/RAABgQGZAYEB/wE8
- AcoBgQH/ATwB6wGBAf8BPgH8AYEB/wFGAf8BgQH/AUsB/wGBAf8BTQG/AYEB/wFmAaUBcAH/AYEByAGB
- Af8BgQHKAYEB/wHtAfIB7QH/AaIB2AGnAf8BgQHKAYEB/wF3AbQBgQH/AX0BlAGBAf8BgQHYAeoB/wGs
- Af8B+AH/AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGBAb8BmAH/AWYBpQFw
- Af8BgQHIAYEB/wGBAcoBgQH/Ae0B8gHtAf8BogHYAacB/wGBAcoBgQH/AXcBtAGBAf8BegGUAYEB/wQA
- AcUCwgH/AfoB9QH0Af8B+QHwAe0B/wHuAeUB4gH/AeEB2QHWAf8B4QHZAdYB/wKLAbkB/wF0AYEB3wH/
- AoEB/AH/AYEBigH+Af8BhAGOAf4B/wGEAY4B/gH/AoEB/gH/AoEB6wH/AoEBvAH/RAABTgGFAXMB/wE8
- AdwBgQH/ATwB9AGBAf8BQwH+AYEB/wFLAf8BgQH/AUsB/wGBAf8BTQHzAYEB/wFZAZABZwH/AYEBxQGB
- Af8BgQHTAYUB/wHVAeYB1gH/AaIB2AGnAf8BgQHMAYEB/wFwAaABeAH/BAABgQHYAeoB/wGsAf8B+AH/
- AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGKAegB4QH/AVoBigFtAf8BgQHF
- AYEB/wGBAdMBhQH/AdUB5gHWAf8BogHYAacB/wGBAcwBgQH/AXABoAF4Af8BgQGuAaEB/wQAAcUCwgH/
- AfoB9QH0Af8B+QHwAe0B/wH0AeYB4QH/AeQB3AHZAf8B5AHcAdkB/wHUAc0B0wH/AXABgQG5Af8CgQHx
- Af8BiQGTAf0B/wGRAZoB/gH/AYkBkwH9Af8BgQGGAfcB/wF8AYEB0wH/SAABPwGRAXAB/wE8AeMBgQH/
- AT0B+QGBAf8BQwH+AYEB/wFLAf8BgQH/AU4B/wGBAf8BTgH/AYEB/wFOAdoBgQH/AWsBmAF3Af8BgQHE
- AYEB/wGUAdUBmgH/AYcBzQGNAf8BgQGkAYEB/wFJAYEBXQH/BAABgQHYAeoB/wGsAf8B+AH/AaUB/wH4
- Af8BogH8AfYB/wGiAfwB9gH/AaUB/wH4Af8BpQH/AfgB/wGMAu4B/wGBAcQBtgH/AXUBmAGBAf8BgQHE
+ AcgB/wFiAXEBygH/AWYBgQH3Af8BZwGBAf4B/wFnAYEB/gH/AWcBgQH+Af8BaAGBAfwB/wFlAXkB4QH/
+ AYEBhQHFAf9MAAE7AaMBdAH/ATkB3AGBAf8BOQHrAYEB/wE5AfQBgQH/AUQBsgFzAf8BWAGnAWoB/wGB
+ AcoBgQH/AYMB2AGYAf8B7gH2AfAB/wGyAeMBvgH/AYEB0wGPAf8BcQGzAYEB/wFmAY0BbAH/AYEB2AHr
+ Af8BrAH/AfgB/wGsAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BgQG2AYYB/wFY
+ AacBagH/AYEBygGBAf8BgwHYAZkB/wHuAfYB8AH/AbIB4wG/Af8BgQHTAY8B/wFxAbMBgQH/AWYBjQFt
+ Af8EAAHBAr4B/wH6AfUB9AH/AfcB7wHsAf8B7QHiAd4B/wHfAdMB0AH/Ad8B0wHQAf8CgQG3Af8BZQF5
+ AeEB/wGBAYQB8wH/AY8BogH2Af8BjwGiAfYB/wGPAaUB9gH/AYwBmwH2Af8CgQHrAf8BbQGBAbkB/0gA
+ AUEBiwFtAf8BOQHcAYEB/wE5AfQBgQH/ATsB/AGBAf8BQAH+AYEB/wFKAa4BcgH/AVwBqAFmAf8BwgHg
+ AcUB/wHtAfIB7QH/A/4B/wHyAfYB8gH/Ae0B8gHtAf8BgQG8AYEB/wFXAYgBXwH/AYEB2AHqAf8BrAH/
+ AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGsAf8B+AH/AaUB/wH4Af8BgQGuAYEB/wFcAagBZgH/
+ AcIB4AHFAf8B7QHyAe0B/wP+Af8B8gH2AfIB/wHtAfIB7QH/AYEBvAGBAf8BVwGIAV8B/wQAAcUCwgH/
+ AfoB9QH0Af8B+AHvAewB/wHuAeUB4gH/AeEB2QHWAf8B4QHWAdIB/wKBAbkB/wFrAXkB6AH/Ab4BwgHv
+ Af8B6wHsAfUB/wHrAewB9QH/AesB7AH1Af8B6wHsAfUB/wKBAeoB/wFiAW4BuwH/RAABgQGZAYEB/wE5
+ AcoBgQH/ATkB6wGBAf8BOwH8AYEB/wFDAf8BgQH/AUgB/wGBAf8BSgG/AYEB/wFjAaUBbQH/AYEByAGB
+ Af8BgQHKAYEB/wHtAfIB7QH/AaIB2AGnAf8BgQHKAYEB/wF0AbQBgQH/AXoBlAGBAf8BgQHYAeoB/wGs
+ Af8B+AH/AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGBAb8BmAH/AWMBpQFt
+ Af8BgQHIAYEB/wGBAcoBgQH/Ae0B8gHtAf8BogHYAacB/wGBAcoBgQH/AXQBtAGBAf8BdwGUAYEB/wQA
+ AcUCwgH/AfoB9QH0Af8B+QHwAe0B/wHuAeUB4gH/AeEB2QHWAf8B4QHZAdYB/wKLAbkB/wFxAYEB3wH/
+ AoEB/AH/AYEBigH+Af8BhAGOAf4B/wGEAY4B/gH/AoEB/gH/AoEB6wH/AoEBvAH/RAABSwGFAXAB/wE5
+ AdwBgQH/ATkB9AGBAf8BQAH+AYEB/wFIAf8BgQH/AUgB/wGBAf8BSgHzAYEB/wFWAZABZAH/AYEBxQGB
+ Af8BgQHTAYUB/wHVAeYB1gH/AaIB2AGnAf8BgQHMAYEB/wFtAaABdQH/BAABgQHYAeoB/wGsAf8B+AH/
+ AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGKAegB4QH/AVcBigFqAf8BgQHF
+ AYEB/wGBAdMBhQH/AdUB5gHWAf8BogHYAacB/wGBAcwBgQH/AW0BoAF1Af8BgQGuAaEB/wQAAcUCwgH/
+ AfoB9QH0Af8B+QHwAe0B/wH0AeYB4QH/AeQB3AHZAf8B5AHcAdkB/wHUAc0B0wH/AW0BgQG5Af8CgQHx
+ Af8BiQGTAf0B/wGRAZoB/gH/AYkBkwH9Af8BgQGGAfcB/wF5AYEB0wH/SAABPAGRAW0B/wE5AeMBgQH/
+ AToB+QGBAf8BQAH+AYEB/wFIAf8BgQH/AUsB/wGBAf8BSwH/AYEB/wFLAdoBgQH/AWgBmAF0Af8BgQHE
+ AYEB/wGUAdUBmgH/AYcBzQGNAf8BgQGkAYEB/wFGAYEBWgH/BAABgQHYAeoB/wGsAf8B+AH/AaUB/wH4
+ Af8BogH8AfYB/wGiAfwB9gH/AaUB/wH4Af8BpQH/AfgB/wGMAu4B/wGBAcQBtgH/AXIBmAGBAf8BgQHE
AYEB/wGVAdUBmgH/AYcBzQGNAf8BgQGkAYEB/wGBAbYBhgH/AYEBzQHeAf8EAAHFAsIB/wH6AfUB9AH/
AfkB8AHtAf8B7gHlAeIB/wHkAdwB2QH/AeQB3AHZAf8B9wHvAewB/wGwAa0BxQH/AoEBvgH/AYIBiwHo
- Af8BnAGjAfMB/wGPAZcB7gH/AoEBzwH/AoEBqwH/SAABPwGRAXAB/wE8AeMBgQH/AT0B+QGBAf8BRgH/
- AYEB/wFLAf8BgQH/AU4B/wGBAf8BTgH/AYEB/wFOAf8BgQH/AU0B8wGBAf8BTQG/AYEB/wFPAa8BeAH/
- AUcBsgF2Af8BQAHHAYEB/wFAAYsBbQH/BAABgQHYAeoB/wGsAf8B+AH/AaUB/wH4Af8BjALuAf8BhAHo
- AesB/wGlAf8B+AH/AaUB/wH4Af8BjALuAf8BhAHoAesB/wGYAfMB5wH/AYEBvwGYAf8BfQGpAYEB/wGA
+ Af8BnAGjAfMB/wGPAZcB7gH/AoEBzwH/AoEBqwH/SAABPAGRAW0B/wE5AeMBgQH/AToB+QGBAf8BQwH/
+ AYEB/wFIAf8BgQH/AUsB/wGBAf8BSwH/AYEB/wFLAf8BgQH/AUoB8wGBAf8BSgG/AYEB/wFMAa8BdQH/
+ AUQBsgFzAf8BPQHHAYEB/wE9AYsBagH/BAABgQHYAeoB/wGsAf8B+AH/AaUB/wH4Af8BjALuAf8BhAHo
+ AesB/wGlAf8B+AH/AaUB/wH4Af8BjALuAf8BhAHoAesB/wGYAfMB5wH/AYEBvwGYAf8BegGpAYEB/wGA
AawBgQH/AYEB3wHJAf8BogH8AfYB/wGBAc8B4AH/BAABxQLCAf8B+gH1AfQB/wH5AfAB7QH/Ae4B5QHi
Af8B5AHcAdkB/wHhAdkB1gH/AfQB5gHhAf8B1gHOAcwB/wHdAdYB3AH/ApoByAH/AoEBwwH/AoEBtwH/
- AcwByQHcAf8BvgK8Af9IAAFKAYQBcQH/ATwB3AGBAf8BPAH0AYEB/wFDAf4BgQH/AUsB/wGBAf8BSwH/
- AYEB/wFOAf8BgQH/AUsB/wGBAf8BTgH/AYEB/wFGAf8BgQH/AUMB/gGBAf8BPAH0AYEB/wE8AdwBgQH/
- AVcBhQF5Af8EAAGBAdgB6gH/AawB/wH4Af8BpQH/AfgB/wGMAu4B/wGEAegB6wH/AaUB/wH4Af8BpQH/
+ AcwByQHcAf8BvgK8Af9IAAFHAYQBbgH/ATkB3AGBAf8BOQH0AYEB/wFAAf4BgQH/AUgB/wGBAf8BSAH/
+ AYEB/wFLAf8BgQH/AUgB/wGBAf8BSwH/AYEB/wFDAf8BgQH/AUAB/gGBAf8BOQH0AYEB/wE5AdwBgQH/
+ AVQBhQF2Af8EAAGBAdgB6gH/AawB/wH4Af8BpQH/AfgB/wGMAu4B/wGEAegB6wH/AaUB/wH4Af8BpQH/
AfgB/wGMAu4B/wGEAegB6wH/AaUB/wH4Af8BmQH/AfcB/wGEAegB6wH/AYEB6AHrAf8BjQH/AfYB/wGZ
Af8B9wH/AYEBzQHeAf8EAAHFAsIB/wH7AfkB+AH/AfkB8AHtAf8B7gHlAeIB/wHkAdwB2QH/AeQB3AHZ
Af8B7gHlAeIB/wHZAdIBzwH/AfkB8AHtAf8B+QHwAe0B/wH3Ae8B7AH/AdYBzgHMAf8B+gH1AfQB/wG+
- ArwB/0gAAYEBlgGBAf8BPAHKAYEB/wE8AesBgQH/AT4B/AGBAf8BRgH/AYEB/wFLAf8BgQH/AUsB/wGB
- Af8BSwH/AYEB/wFLAf8BgQH/AUYB/wGBAf8BPgH8AYEB/wE8AesBgQH/ATwBxgGBAf8BgQGeAYEB/wQA
+ ArwB/0gAAYEBlgGBAf8BOQHKAYEB/wE5AesBgQH/ATsB/AGBAf8BQwH/AYEB/wFIAf8BgQH/AUgB/wGB
+ Af8BSAH/AYEB/wFIAf8BgQH/AUMB/wGBAf8BOwH8AYEB/wE5AesBgQH/ATkBxgGBAf8BgQGeAYEB/wQA
AYEB1gHpAf8BrAH/AfgB/wGlAf8B+AH/AYwC7gH/AYQB6AHrAf8BpQH/AfgB/wGlAf8B+AH/AYwC7gH/
AYEB6AHsAf8BnQH/AfcB/wGdAf8B9wH/AYEC7gH/AYEB6AHrAf8BjQH/AfYB/wGZAf8B9wH/AYEBzwHg
Af8EAAHIAsUB/wH6AfUB9AH/AfkB8AHtAf8B7gHlAeIB/wHkAdwB2QH/AeQB3AHZAf8B9gHsAekB/wHX
- AdABzQH/AfkB8AHtAf8B+QHwAe0B/wH4Ae8B7AH/AdcB0AHNAf8B+gH1AfQB/wG+ArwB/0wAAT8BkQFw
- Af8BPAHcAYEB/wE8AfQBgQH/AT4B/AGBAf8BQwH+AYEB/wFDAf4BgQH/AUYB/wGBAf8BQwH+AYEB/wE+
- AfwBgQH/ATwB9AGBAf8BPAHcAYEB/wFEAYsBcAH/CAABgQHYAeoB/wGsAf8B+AH/AaUB/wH4Af8BjALu
+ AdABzQH/AfkB8AHtAf8B+QHwAe0B/wH4Ae8B7AH/AdcB0AHNAf8B+gH1AfQB/wG+ArwB/0wAATwBkQFt
+ Af8BOQHcAYEB/wE5AfQBgQH/ATsB/AGBAf8BQAH+AYEB/wFAAf4BgQH/AUMB/wGBAf8BQAH+AYEB/wE7
+ AfwBgQH/ATkB9AGBAf8BOQHcAYEB/wFBAYsBbQH/CAABgQHYAeoB/wGsAf8B+AH/AaUB/wH4Af8BjALu
Af8BhAHoAesB/wGlAf8B+AH/AaIB/AH2Af8BjALuAf8BgQHoAewB/wGZAf8B9wH/AZMB/wH3Af8BgQHo
AewB/wGBAegB6QH/AY0B/wH2Af8BmQH/AfcB/wGBAc8B4AH/BAAByALFAf8B+gH1AfQB/wH5AfAB7QH/
Ae4B5QHiAf8B5AHcAdkB/wHhAdkB1gH/Ae4B5QHiAf8B1gHOAcwB/wHuAeUB4gH/Ae0B4gHeAf8B5AHc
- AdkB/wHIAcIBwAH/AeYB4QHgAf8BvgK8Af9MAAGBAasBigH/AT4BqgF6Af8BPAHcAYEB/wE8AesBgQH/
- ATwB9AGBAf8BPgH8AYEB/wE9AfkBgQH/ATwB9AGBAf8BPAHrAYEB/wE8AdwBgQH/AT4BowF3Af8MAAGB
+ AdkB/wHIAcIBwAH/AeYB4QHgAf8BvgK8Af9MAAGBAasBigH/ATsBqgF3Af8BOQHcAYEB/wE5AesBgQH/
+ ATkB9AGBAf8BOwH8AYEB/wE6AfkBgQH/ATkB9AGBAf8BOQHrAYEB/wE5AdwBgQH/ATsBowF0Af8MAAGB
AdYB6QH/AawB/wH4Af8BpQH/AfgB/wGMAu4B/wGEAegB6wH/AaUB/wH4Af8BogH8AfYB/wGMAu4B/wGB
AegB7AH/AZMB/wH3Af8BkwH/AfcB/wGBAu4B/wGBAegB6QH/AYkB/wH1Af8BogH8AfYB/wGBAc0B3gH/
BAAByALFAf8B+gH1AfQB/wH5AfAB7QH/Ae4B5QHiAf8B5AHcAdkB/wHkAdwB2QH/AfcB7wHsAf8B5AHc
- AdkB/wHhAdkB1gH/AeEB2QHWAf8BswKwAf8BswKwAf8BswKwAf8BsQKuAf9QAAGBAasBigH/AT8BkQFw
- Af8BPAHKAYEB/wE8AdwBgQH/ATwB4wGBAf8BPAHjAYEB/wE8AdwBgQH/ATwBygGBAf8BRAGLAXAB/xAA
+ AdkB/wHhAdkB1gH/AeEB2QHWAf8BswKwAf8BswKwAf8BswKwAf8BsQKuAf9QAAGBAasBigH/ATwBkQFt
+ Af8BOQHKAYEB/wE5AdwBgQH/ATkB4wGBAf8BOQHjAYEB/wE5AdwBgQH/ATkBygGBAf8BQQGLAW0B/xAA
AYEB1gHpAf8BrAH/AfgB/wGsAf8B+AH/AZEB7gHvAf8BjALuAf8BrAH/AfgB/wGsAf8B+AH/AYwC7gH/
AYQB6AHrAf8BpQH/AfgB/wGlAf8B+AH/AYQB6AHrAf8BgQHoAewB/wGZAf8B9wH/AaUB/wH4Af8BgQHN
Ad4B/wQAAcgCxQH/AfoB9QH0Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B9wHvAewB/wH3Ae8B7AH/
- AfgB7wHsAf8B+QHwAe0B/wH3Ae8B7AH/AcECvgH/AeEB2QHWAf8BsQKuAf9cAAGBAZYBgQH/AUoBhAFx
- Af8BPwGRAXAB/wE/AZEBcAH/AU4BhQFzAf8BgQGZAYEB/xQAAYIB1gHqAf8BgQHWAekB/wGBAc8B4AH/
+ AfgB7wHsAf8B+QHwAe0B/wH3Ae8B7AH/AcECvgH/AeEB2QHWAf8BsQKuAf9cAAGBAZYBgQH/AUcBhAFu
+ Af8BPAGRAW0B/wE8AZEBbQH/AUsBhQFwAf8BgQGZAYEB/xQAAYIB1gHqAf8BgQHWAekB/wGBAc8B4AH/
AYEBzQHhAf8BgQHNAeEB/wGBAdAB4wH/AYEBzwHgAf8BgQHNAeEB/wGBAckB3gH/AYEB0AHjAf8BgQHN
Ad4B/wGBAckB3gH/AYEByQHeAf8BgQHNAd4B/wGBAc0B3gH/AY0B0QHhAf8EAAHIAsUB/wH7AfkB+AH/
AfoB9QH0Af8B+gH1AfQB/wH6AfUB9AH/AfoB9QH0Af8B+gH1AfQB/wH6AfUB9AH/AfoB9QH0Af8B+gH1
AfQB/wG+ArwB/wGwAa8BtAH/0AAB1gHOAcwB/wHFAsIB/wHIAsUB/wHIAsUB/wHIAsUB/wHIAsUB/wHF
AsIB/wHIAsUB/wHFAsIB/wHFAsIB/wG7ArkB/5QAAcUCwgH/AcECvgH/AcECvgH/Ab4CvAH/Ab4CvAH/
- Ab4CvAH/Ab4CvAH/Ab4CvAH/AYEBmwGCAf8BewGTAYEB/wFYAZIBbwH/AWgBkQF3Af8BgQGUAYEB/wGw
- AbIBrQH/LAABewGUAYEB/wFYAZIBbwH/AWcBkQF2Af8BgQGrAYEB/zAAAXsBlQGBAf8BWAGSAW8B/wFn
- AZEBdgH/AYEBqwGBAf8MAAGmAoEB/wGEAWcBUQH/AZABawFUAf8BlQFtAVYB/wGYAW8BVgH/AZgBbwFW
- Af8BmAFvAVYB/wGYAW8BVgH/AZgBbwFWAf8BmAFvAVYB/wGVAW0BVgH/AY8BawFUAf8BhAFnAVEB/wGu
+ Ab4CvAH/Ab4CvAH/Ab4CvAH/AYEBmwGCAf8BeAGTAYEB/wFVAZIBbAH/AWUBkQF0Af8BgQGUAYEB/wGw
+ AbIBrQH/LAABeAGUAYEB/wFVAZIBbAH/AWQBkQFzAf8BgQGrAYEB/zAAAXgBlQGBAf8BVQGSAWwB/wFk
+ AZEBcwH/AYEBqwGBAf8MAAGmAoEB/wGEAWQBTgH/AZABaAFRAf8BlQFqAVMB/wGYAWwBUwH/AZgBbAFT
+ Af8BmAFsAVMB/wGYAWwBUwH/AZgBbAFTAf8BmAFsAVMB/wGVAWoBUwH/AY8BaAFRAf8BhAFkAU4B/wGu
AYgBgQH/CAABwQK+Af8B+gH1AfQB/wH3Ae8B7AH/AfcB7wHsAf8B9gHsAegB/wH2AewB6AH/AfYB7AHo
- Af8BgQGpAYEB/wFXAaMBcgH/AVcB1wGBAf8BgQHmAZ8B/wFxAd0BgQH/AVgBuAGBAf8BbgGKAXYB/wgA
- AaYCgQH/AYQBZwFRAf8BkAFrAVQB/wGVAW0BVgH/AZkBbwFWAf8BmQFvAVYB/wGZAW8BVgH/AoEBVAH/
- AVcBowFyAf8BVwHWAYEB/wGBAeYBnwH/AXEB3QGBAf8BWAG3AYEB/wFzAZABfAH/CAACgQHGAf8YAAGB
- Aa8BhAH/AVcBowFyAf8BVgHXAYEB/wGBAeYBnwH/AXEB3QGBAf8BWAG4AYEB/wFzAZABfAH/CAABjwFr
- AVQB/wG+AYEBYAH/Ac0BgQFjAf8B1wGBAWYB/wHaAYEBZgH/AdoBgQFmAf8B2gGBAWYB/wHaAYEBZgH/
- AdoBgQFmAf8B2gGBAWYB/wHXAYEBZQH/Ac0BgQFjAf8BvgGBAWAB/wGEAWcBUQH/CAABxQLCAf8B+gH1
- AfQB/wH0AeYB4QH/AfQB5gHhAf8B8gHkAd4B/wHyAeQB3gH/AcMBxQGwAf8BWAGUAWQB/wFcAcQBgQH/
- AV8B2AGBAf8B4wHyAekB/wGBAeABnwH/AV4BzAGBAf8BWwGnAW0B/wGBAakBgQH/BAABiAFoAVIB/wG/
- AYEBYAH/Ac4BgQFjAf8B1wGBAWYB/wHcAYEBZwH/AdwBgQFnAf8BsgGBAWIB/wFYAZMBYwH/AVwBxAGB
- Af8BXwHYAYEB/wHjAfIB6QH/AYEB3wGfAf8BXgHMAYEB/wFbAacBbQH/AYEBqwGBAf8EAAE4ATYB0gH/
- AoEBtgH/FAABVwGTAWMB/wFcAcQBgQH/AV8B2AGBAf8B4wHyAekB/wGBAeABnwH/AV4BzAGBAf8BWwGn
- AW0B/wGBAasBgQH/BAABkAFrAVQB/wHOAYEBZAH/AdoBgQFmAf8B6QGBAWoB/wHpAYEBagH/AfQBgQFs
- Af8B6QGBAWoB/wH0AYEBbAH/AekBgQFqAf8B9AGBAWwB/wHpAYEBagH/AdoBgQFmAf8BzgGBAWQB/wGP
- AWsBVAH/CAABwQK+Af8B+gH1AfQB/wH3Ae8B7AH/AfYB7AHoAf8B9AHmAeEB/wHyAeQB3gH/AYEBqQGB
- Af8BWwGnAW0B/wGBAcoBgQH/AYMB2AGZAf8B7gH2AfAB/wGyAeMBvwH/AYEB0wGPAf8BdAGzAYEB/wFp
- AY4BbwH/BAABlQFuAVYB/wHOAYEBZAH/AdwBgQFnAf8B6QGBAWoB/wHpAYEBagH/Ae4BgQFrAf8CgQFg
- Af8BWwGnAW0B/wGBAcoBgQH/AYMB2AGYAf8B7gH1AfAB/wGyAeMBvgH/AYEB0wGPAf8BdAGyAYEB/wFp
- AY0BbwH/BAABTAFIAbYB/wE4ATYBygH/EAABhQGyAYgB/wFbAacBbQH/AYEBygGBAf8BgwHYAZkB/wHu
- AfYB8AH/AbIB4wG/Af8BgQHTAY8B/wF0AbMBgQH/AWkBjQFvAf8EAAGYAW8BVgH/AdoBgQFmAf8B6QGB
- AWoB/wH5AYEBbQH/AfoBgQFuAf8B+gGBAW4B/wH6AYEBbgH/AfoBgQFuAf8B+gGBAW4B/wH6AYEBbgH/
- AfQBgQFsAf8B6QGBAWoB/wHXAYEBZQH/AZABawFUAf8IAAHFAsIB/wHfAawBmwH/AccCgQH/AekBxgG6
- Af8B9wHvAewB/wH2AewB6AH/AYEBpQGBAf8BXAGlAWcB/wHCAeABxQH/Ae0B8gHtAf8D/gH/AfIB9gHy
- Af8B7QHyAe0B/wGBAbwBgQH/AVoBiAFiAf8EAAGZAW8BVgH/AdwBgQFnAf8B6QGBAWoB/wHuAYEBawH/
- Af4BgQFuAf8B/gGBAW4B/wKBAWEB/wFcAaUBZwH/AcIB4AHFAf8B7QHyAe0B/wP+Af8B8gH2AfIB/wHt
- AfIB7QH/AYEBvAGBAf8BWgGIAWIB/wgAAjYB3QH/AWcBYwGxAf8MAAGBAakBgQH/AV8BqAFpAf8BwgHg
- AcUB/wHtAfIB7QH/A/4B/wHyAfYB8gH/Ae0B8gHtAf8BgQG8AYEB/wFaAYgBYgH/BAABmAFvAVYB/wHg
- AYEBZwH/AekBgQFqAf8B+gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFu
- Af8B/gGBAW4B/wH6AYEBbgH/AekBgQFqAf8B2gGBAWYB/wGYAW8BVgH/CAABxQLCAf8B0wGKAYEB/wHc
- AaMBkAH/AfYB7AHoAf8B+AHuAeoB/wH4Ae4B6gH/AYwBnQGBAf8BZgGlAXAB/wGBAcgBgQH/AYEBygGB
- Af8B6QHxAeoB/wGiAdgBpwH/AYEBygGBAf8BdwG0AYEB/wF7AZMBgQH/BAABmQFvAVYB/wHcAYEBZwH/
- Ae4BgQFrAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8BmQGBAWMB/wFmAaUBcAH/AYEByAGBAf8BgQHK
- AYEB/wHtAfIB7QH/AaIB2AGnAf8BgQHKAYEB/wF3AbQBgQH/AXsBlAGBAf8IAAFYAVMBsgH/ATgBNgHS
- Af8MAAGBAYgBiwH/AWYBpAFwAf8BgQHIAYEB/wGBAcoBgQH/Ae0B8gHtAf8BogHYAacB/wGBAcoBgQH/
- AXcBtAGBAf8BfQGUAYEB/wQAAZ8BcgFYAf8B2gGBAWYB/wH0AYEBbAH/Af4BgQFuAf8B/gGBAW4B/wH+
- AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8B+gGBAW4B/wH0AYEBbAH/AdoBgQFm
- Af8BmAFvAVYB/wgAAcUCwgH/AdMBigGBAf8B5AG2AacB/wH5AfAB7QH/AfkB8AHtAf8B+AHuAeoB/wHe
- AcwBvgH/AWkBjgFvAf8BgQHFAYEB/wGBAdMBhQH/AdUB5gHWAf8BogHYAacB/wGBAcwBgQH/AXABoAF4
- Af8IAAGfAXIBWAH/AeABgQFnAf8B7gGBAWsB/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wHsAYEBbAH/
- AWoBhQFjAf8BgQHFAYEB/wGBAdMBhQH/AdUB5gHWAf8BogHYAacB/wGBAcwBgQH/AXABoAF4Af8QAAE4
- ATYB0gH/AVQBUAGyAf8IAAE9AUABsQH/AVcBgQFvAf8BgQHEAYEB/wGBAdMBhQH/AdUB5gHWAf8BogHY
- AacB/wGBAcwBgQH/AXABoAF4Af8IAAGfAXIBWAH/AeABgQFnAf8B6QGBAWoB/wH+AYEBbgH/Af4BgQFu
- Af8B/gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/AfoBgQFuAf8B6QGBAWoB/wHa
- AYEBZgH/AZgBbwFWAf8IAAHFAsIB/wHTAYoBgQH/AeQBtgGnAf8B+QHwAe0B/wH5AfAB7QH/AfkB8AHt
- Af8B2QGZAYQB/wGhAoEB/wF6AZUBgAH/AYEBxAGBAf8BlQHVAZoB/wGHAc0BjAH/AYEBpAGBAf8BgQGU
- AYEB/wgAAZ8BcgFYAf8B3AGBAWcB/wHpAYEBagH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFu
- Af8BxgGBAWgB/wF7AY0BcwH/AYEBxAGBAf8BlQHVAZoB/wGHAc0BjQH/AYEBpAGBAf8CgQFUAf8QAAFn
- AWMBsQH/AjYB4QH/AoEBxgH/AXUBcQGzAf8CNgHhAf8CgQGMAf8BawGGAXkB/wGBAcQBgQH/AZUB1QGa
- Af8BhwHNAY0B/wGBAaQBgQH/AYEBrwGEAf8IAAGfAXIBWAH/AdoBgQFmAf8B9AGBAWwB/wH+AYEBbgH/
- Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/AfoBgQFuAf8B9AGB
- AWwB/wHaAYEBZgH/AZgBbwFWAf8IAAHFAsIB/wHTAYoBgQH/AeMBtwGoAf8B+QHwAe0B/wH5AfAB7QH/
- AfgB7gHqAf8B8AHZAdEB/wHLAoEB/wHBAoEB/wGWAbcBkgH/AYEBqQGBAf8CgQF3Af8BvAGvAZYB/wG+
- ArwB/wgAAZkBbwFWAf8B4AGBAWcB/wHuAYEBawH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFu
- Af8B/gGBAW4B/wHsAYEBbAH/AZkBgQFjAf8CgQFkAf8CgQFgAf8BsgGBAWIB/wGZAW8BVgH/FAABOAE2
- AcoB/wE8ATkBvQH/ATgBNgHSAf8BXgFZAaoB/wQAAoEBswH/AUIBZwGJAf8BVwKBAf8BhAGuAY0B/xAA
- AZ8BcgFYAf8B2gGBAWYB/wHpAYEBagH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8B/gGB
- AW4B/wH+AYEBbgH/Af4BgQFuAf8B+gGBAW4B/wHpAYEBagH/AdoBgQFmAf8BmAFvAVYB/wgAAcUCwgH/
+ Af8BgQGpAYEB/wFUAaMBbwH/AVQB1wGBAf8BgQHmAZ8B/wFuAd0BgQH/AVUBuAGBAf8BawGKAXMB/wgA
+ AaYCgQH/AYQBZAFOAf8BkAFoAVEB/wGVAWoBUwH/AZkBbAFTAf8BmQFsAVMB/wGZAWwBUwH/AoEBUQH/
+ AVQBowFvAf8BVAHWAYEB/wGBAeYBnwH/AW4B3QGBAf8BVQG3AYEB/wFwAZABeQH/CAACgQHGAf8YAAGB
+ Aa8BhAH/AVQBowFvAf8BUwHXAYEB/wGBAeYBnwH/AW4B3QGBAf8BVQG4AYEB/wFwAZABeQH/CAABjwFo
+ AVEB/wG+AYEBXQH/Ac0BgQFgAf8B1wGBAWMB/wHaAYEBYwH/AdoBgQFjAf8B2gGBAWMB/wHaAYEBYwH/
+ AdoBgQFjAf8B2gGBAWMB/wHXAYEBYgH/Ac0BgQFgAf8BvgGBAV0B/wGEAWQBTgH/CAABxQLCAf8B+gH1
+ AfQB/wH0AeYB4QH/AfQB5gHhAf8B8gHkAd4B/wHyAeQB3gH/AcMBxQGwAf8BVQGUAWEB/wFZAcQBgQH/
+ AVwB2AGBAf8B4wHyAekB/wGBAeABnwH/AVsBzAGBAf8BWAGnAWoB/wGBAakBgQH/BAABiAFlAU8B/wG/
+ AYEBXQH/Ac4BgQFgAf8B1wGBAWMB/wHcAYEBZAH/AdwBgQFkAf8BsgGBAV8B/wFVAZMBYAH/AVkBxAGB
+ Af8BXAHYAYEB/wHjAfIB6QH/AYEB3wGfAf8BWwHMAYEB/wFYAacBagH/AYEBqwGBAf8EAAE1ATMB0gH/
+ AoEBtgH/FAABVAGTAWAB/wFZAcQBgQH/AVwB2AGBAf8B4wHyAekB/wGBAeABnwH/AVsBzAGBAf8BWAGn
+ AWoB/wGBAasBgQH/BAABkAFoAVEB/wHOAYEBYQH/AdoBgQFjAf8B6QGBAWcB/wHpAYEBZwH/AfQBgQFp
+ Af8B6QGBAWcB/wH0AYEBaQH/AekBgQFnAf8B9AGBAWkB/wHpAYEBZwH/AdoBgQFjAf8BzgGBAWEB/wGP
+ AWgBUQH/CAABwQK+Af8B+gH1AfQB/wH3Ae8B7AH/AfYB7AHoAf8B9AHmAeEB/wHyAeQB3gH/AYEBqQGB
+ Af8BWAGnAWoB/wGBAcoBgQH/AYMB2AGZAf8B7gH2AfAB/wGyAeMBvwH/AYEB0wGPAf8BcQGzAYEB/wFm
+ AY4BbAH/BAABlQFrAVMB/wHOAYEBYQH/AdwBgQFkAf8B6QGBAWcB/wHpAYEBZwH/Ae4BgQFoAf8CgQFd
+ Af8BWAGnAWoB/wGBAcoBgQH/AYMB2AGYAf8B7gH1AfAB/wGyAeMBvgH/AYEB0wGPAf8BcQGyAYEB/wFm
+ AY0BbAH/BAABSQFFAbYB/wE1ATMBygH/EAABhQGyAYgB/wFYAacBagH/AYEBygGBAf8BgwHYAZkB/wHu
+ AfYB8AH/AbIB4wG/Af8BgQHTAY8B/wFxAbMBgQH/AWYBjQFsAf8EAAGYAWwBUwH/AdoBgQFjAf8B6QGB
+ AWcB/wH5AYEBagH/AfoBgQFrAf8B+gGBAWsB/wH6AYEBawH/AfoBgQFrAf8B+gGBAWsB/wH6AYEBawH/
+ AfQBgQFpAf8B6QGBAWcB/wHXAYEBYgH/AZABaAFRAf8IAAHFAsIB/wHfAawBmwH/AccCgQH/AekBxgG6
+ Af8B9wHvAewB/wH2AewB6AH/AYEBpQGBAf8BWQGlAWQB/wHCAeABxQH/Ae0B8gHtAf8D/gH/AfIB9gHy
+ Af8B7QHyAe0B/wGBAbwBgQH/AVcBiAFfAf8EAAGZAWwBUwH/AdwBgQFkAf8B6QGBAWcB/wHuAYEBaAH/
+ Af4BgQFrAf8B/gGBAWsB/wKBAV4B/wFZAaUBZAH/AcIB4AHFAf8B7QHyAe0B/wP+Af8B8gH2AfIB/wHt
+ AfIB7QH/AYEBvAGBAf8BVwGIAV8B/wgAAjMB3QH/AWQBYAGxAf8MAAGBAakBgQH/AVwBqAFmAf8BwgHg
+ AcUB/wHtAfIB7QH/A/4B/wHyAfYB8gH/Ae0B8gHtAf8BgQG8AYEB/wFXAYgBXwH/BAABmAFsAVMB/wHg
+ AYEBZAH/AekBgQFnAf8B+gGBAWsB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFr
+ Af8B/gGBAWsB/wH6AYEBawH/AekBgQFnAf8B2gGBAWMB/wGYAWwBUwH/CAABxQLCAf8B0wGKAYEB/wHc
+ AaMBkAH/AfYB7AHoAf8B+AHuAeoB/wH4Ae4B6gH/AYwBnQGBAf8BYwGlAW0B/wGBAcgBgQH/AYEBygGB
+ Af8B6QHxAeoB/wGiAdgBpwH/AYEBygGBAf8BdAG0AYEB/wF4AZMBgQH/BAABmQFsAVMB/wHcAYEBZAH/
+ Ae4BgQFoAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFrAf8BmQGBAWAB/wFjAaUBbQH/AYEByAGBAf8BgQHK
+ AYEB/wHtAfIB7QH/AaIB2AGnAf8BgQHKAYEB/wF0AbQBgQH/AXgBlAGBAf8IAAFVAVABsgH/ATUBMwHS
+ Af8MAAGBAYgBiwH/AWMBpAFtAf8BgQHIAYEB/wGBAcoBgQH/Ae0B8gHtAf8BogHYAacB/wGBAcoBgQH/
+ AXQBtAGBAf8BegGUAYEB/wQAAZ8BbwFVAf8B2gGBAWMB/wH0AYEBaQH/Af4BgQFrAf8B/gGBAWsB/wH+
+ AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFrAf8B+gGBAWsB/wH0AYEBaQH/AdoBgQFj
+ Af8BmAFsAVMB/wgAAcUCwgH/AdMBigGBAf8B5AG2AacB/wH5AfAB7QH/AfkB8AHtAf8B+AHuAeoB/wHe
+ AcwBvgH/AWYBjgFsAf8BgQHFAYEB/wGBAdMBhQH/AdUB5gHWAf8BogHYAacB/wGBAcwBgQH/AW0BoAF1
+ Af8IAAGfAW8BVQH/AeABgQFkAf8B7gGBAWgB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wHsAYEBaQH/
+ AWcBhQFgAf8BgQHFAYEB/wGBAdMBhQH/AdUB5gHWAf8BogHYAacB/wGBAcwBgQH/AW0BoAF1Af8QAAE1
+ ATMB0gH/AVEBTQGyAf8IAAE6AT0BsQH/AVQBgQFsAf8BgQHEAYEB/wGBAdMBhQH/AdUB5gHWAf8BogHY
+ AacB/wGBAcwBgQH/AW0BoAF1Af8IAAGfAW8BVQH/AeABgQFkAf8B6QGBAWcB/wH+AYEBawH/Af4BgQFr
+ Af8B/gGBAWsB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/AfoBgQFrAf8B6QGBAWcB/wHa
+ AYEBYwH/AZgBbAFTAf8IAAHFAsIB/wHTAYoBgQH/AeQBtgGnAf8B+QHwAe0B/wH5AfAB7QH/AfkB8AHt
+ Af8B2QGZAYQB/wGhAoEB/wF3AZUBgAH/AYEBxAGBAf8BlQHVAZoB/wGHAc0BjAH/AYEBpAGBAf8BgQGU
+ AYEB/wgAAZ8BbwFVAf8B3AGBAWQB/wHpAYEBZwH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFr
+ Af8BxgGBAWUB/wF4AY0BcAH/AYEBxAGBAf8BlQHVAZoB/wGHAc0BjQH/AYEBpAGBAf8CgQFRAf8QAAFk
+ AWABsQH/AjMB4QH/AoEBxgH/AXIBbgGzAf8CMwHhAf8CgQGMAf8BaAGGAXYB/wGBAcQBgQH/AZUB1QGa
+ Af8BhwHNAY0B/wGBAaQBgQH/AYEBrwGEAf8IAAGfAW8BVQH/AdoBgQFjAf8B9AGBAWkB/wH+AYEBawH/
+ Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/AfoBgQFrAf8B9AGB
+ AWkB/wHaAYEBYwH/AZgBbAFTAf8IAAHFAsIB/wHTAYoBgQH/AeMBtwGoAf8B+QHwAe0B/wH5AfAB7QH/
+ AfgB7gHqAf8B8AHZAdEB/wHLAoEB/wHBAoEB/wGWAbcBkgH/AYEBqQGBAf8CgQF0Af8BvAGvAZYB/wG+
+ ArwB/wgAAZkBbAFTAf8B4AGBAWQB/wHuAYEBaAH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFr
+ Af8B/gGBAWsB/wHsAYEBaQH/AZkBgQFgAf8CgQFhAf8CgQFdAf8BsgGBAV8B/wGZAWwBUwH/FAABNQEz
+ AcoB/wE5ATYBvQH/ATUBMwHSAf8BWwFWAaoB/wQAAoEBswH/AT8BZAGJAf8BVAKBAf8BhAGuAY0B/xAA
+ AZ8BbwFVAf8B2gGBAWMB/wHpAYEBZwH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFrAf8B/gGB
+ AWsB/wH+AYEBawH/Af4BgQFrAf8B+gGBAWsB/wHpAYEBZwH/AdoBgQFjAf8BmAFsAVMB/wgAAcUCwgH/
AdMBigGBAf8B4wG3AagB/wH5AfAB7QH/AfkB8AHtAf8BxwKBAf8B4wG3AagB/wHcAaMBkAH/AcsCgQH/
- AfkB8AHtAf8B+AHuAeoB/wHTAYoBgQH/AeMBtwGoAf8BvgK8Af8IAAGfAXIBWAH/AdwBgQFnAf8B7gGB
- AWsB/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/
- Af4BgQFuAf8B6QGBAWoB/wHcAYEBZwH/AZkBbwFWAf8UAAF1AXEBswH/AjcB6AH/ATgBNgHKAf8MAAFU
- AVABsgH/ATgBNgHKAf8UAAGYAW8BVgH/AeABgQFnAf8B6QGBAWoB/wH6AYEBbgH/Af4BgQFuAf8B/gGB
- AW4B/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/AfoBgQFuAf8B6QGBAWoB/wHgAYEBZwH/
- AZgBbwFWAf8IAAHIAsUB/wHXAZYBgQH/AbwBgQFaAf8B6QHGAboB/wH4Ae4B6gH/AeMBtwGoAf8BzAKB
- Af8BzgKBAf8B8gHeAdcB/wH5AfAB7QH/AdwBowGQAf8BugF8AVUB/wHmAb4BsAH/Ab4CvAH/CAABnwFy
- AVgB/wHcAYEBZwH/AekBgQFqAf8B/gGBAW4B/wH+AYEBbgH/Af4BgQFuAf8B/gGBAW4B/wH+AYEBbgH/
- Af4BgQFuAf8B/gGBAW4B/wH5AYEBbQH/AekBgQFqAf8B3AGBAWcB/wGZAW8BVgH/GAABOgE4AcMB/wKB
- AawB/xAAATgBNgHKAf8BWAFTAbIB/xAAAZgBbwFWAf8B2gGBAWYB/wHpAYEBagH/AfQBgQFsAf8B+gGB
- AW4B/wH+AYEBbgH/Af4BgQFuAf8B+QGBAW0B/wH+AYEBbgH/AfQBgQFsAf8B9AGBAWwB/wHpAYEBagH/
- AdoBgQFmAf8BlQFtAVYB/wgAAcgCxQH/AfsB+QH4Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B+QHw
+ AfkB8AHtAf8B+AHuAeoB/wHTAYoBgQH/AeMBtwGoAf8BvgK8Af8IAAGfAW8BVQH/AdwBgQFkAf8B7gGB
+ AWgB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/
+ Af4BgQFrAf8B6QGBAWcB/wHcAYEBZAH/AZkBbAFTAf8UAAFyAW4BswH/AjQB6AH/ATUBMwHKAf8MAAFR
+ AU0BsgH/ATUBMwHKAf8UAAGYAWwBUwH/AeABgQFkAf8B6QGBAWcB/wH6AYEBawH/Af4BgQFrAf8B/gGB
+ AWsB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/AfoBgQFrAf8B6QGBAWcB/wHgAYEBZAH/
+ AZgBbAFTAf8IAAHIAsUB/wHXAZYBgQH/AbwBgQFXAf8B6QHGAboB/wH4Ae4B6gH/AeMBtwGoAf8BzAKB
+ Af8BzgKBAf8B8gHeAdcB/wH5AfAB7QH/AdwBowGQAf8BugF5AVIB/wHmAb4BsAH/Ab4CvAH/CAABnwFv
+ AVUB/wHcAYEBZAH/AekBgQFnAf8B/gGBAWsB/wH+AYEBawH/Af4BgQFrAf8B/gGBAWsB/wH+AYEBawH/
+ Af4BgQFrAf8B/gGBAWsB/wH5AYEBagH/AekBgQFnAf8B3AGBAWQB/wGZAWwBUwH/GAABNwE1AcMB/wKB
+ AawB/xAAATUBMwHKAf8BVQFQAbIB/xAAAZgBbAFTAf8B2gGBAWMB/wHpAYEBZwH/AfQBgQFpAf8B+gGB
+ AWsB/wH+AYEBawH/Af4BgQFrAf8B+QGBAWoB/wH+AYEBawH/AfQBgQFpAf8B9AGBAWkB/wHpAYEBZwH/
+ AdoBgQFjAf8BlQFqAVMB/wgAAcgCxQH/AfsB+QH4Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B+QHw
Ae0B/wH5AfAB7QH/AfkB8AHtAf8B+QHwAe0B/wH4Ae4B6gH/Ae8B5wHkAf8B4wHcAdkB/wHmAeEB4AH/
- Ab4CvAH/CAABmQFvAVYB/wHcAYEBZwH/AekBgQFqAf8B9QGBAWwB/wH1AYEBbAH/Af4BgQFuAf8B/gGB
- AW4B/wH+AYEBbgH/AfkBgQFtAf8B/gGBAW4B/wHuAYEBawH/AekBgQFqAf8B3AGBAWcB/wGVAW0BVgH/
- GAACgQG9Af8UAAKBAbQB/wI2AeEB/wKBAcEB/wwAAZgBbwFWAf8B1wGBAWUB/wHaAYEBZgH/AekBgQFq
- Af8B6QGBAWoB/wH0AYEBbAH/AekBgQFqAf8B6QGBAWoB/wH0AYEBbAH/AekBgQFqAf8B6QGBAWoB/wHg
- AYEBZwH/Ac4BgQFkAf8BkAFrAVQB/wgAAcgCxQH/AfoB9QH0Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHt
+ Ab4CvAH/CAABmQFsAVMB/wHcAYEBZAH/AekBgQFnAf8B9QGBAWkB/wH1AYEBaQH/Af4BgQFrAf8B/gGB
+ AWsB/wH+AYEBawH/AfkBgQFqAf8B/gGBAWsB/wHuAYEBaAH/AekBgQFnAf8B3AGBAWQB/wGVAWoBUwH/
+ GAACgQG9Af8UAAKBAbQB/wIzAeEB/wKBAcEB/wwAAZgBbAFTAf8B1wGBAWIB/wHaAYEBYwH/AekBgQFn
+ Af8B6QGBAWcB/wH0AYEBaQH/AekBgQFnAf8B6QGBAWcB/wH0AYEBaQH/AekBgQFnAf8B6QGBAWcB/wHg
+ AYEBZAH/Ac4BgQFhAf8BkAFoAVEB/wgAAcgCxQH/AfoB9QH0Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHt
Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B+QHwAe0B/wH4Ae4B6gH/AcECvgH/AbcBswGyAf8BsAKt
- Af8BsAKtAf8IAAGVAW4BVgH/Ac4BgQFkAf8B3AGBAWcB/wHpAYEBagH/AekBgQFqAf8B6QGBAWoB/wHp
- AYEBagH/Ae4BgQFrAf8B6QGBAWoB/wHpAYEBagH/Ae4BgQFrAf8B4AGBAWcB/wHOAYEBYwH/AZABawFU
- Af80AAFHAUQBuAH/AToBOAHDAf8MAAGPAWsBVAH/Ab4BgQFgAf8B1wGBAWUB/wHXAYEBZgH/AdoBgQFm
- Af8B2gGBAWYB/wHgAYEBZwH/AdoBgQFmAf8B2gGBAWYB/wHgAYEBZwH/AdoBgQFmAf8BzgGBAWQB/wG+
- AYEBYAH/AYQBZwFRAf8IAAHIAsUB/wH7AfkB+AH/AfkB8AHtAf8B+QHwAe0B/wH5AfAB7QH/AfkB8AHt
- Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B+AHuAeoB/wHBAr4B/wHbAdoB2wH/AbACrQH/DAABiAFo
- AVIB/wHAAYEBYAH/Ac4BgQFkAf8B3AGBAWcB/wHcAYEBZwH/AeABgQFnAf8B3AGBAWcB/wHgAYEBZwH/
- AeABgQFnAf8B3AGBAWcB/wHcAYEBZwH/Ac4BgQFjAf8BvwGBAWAB/wGEAWcBUQH/OAABOAE2AdIB/wFu
- AWkBrwH/CAABngKBAf8BhAFnAVEB/wGYAW8BVgH/AZgBbwFWAf8BnwFyAVgB/wGfAXIBWAH/AZ8BcgFY
- Af8BnwFyAVgB/wGfAXIBWAH/AZgBbwFWAf8BmAFvAVYB/wGYAW8BVgH/AY8BawFUAf8BpgKBAf8IAAHI
+ Af8BsAKtAf8IAAGVAWsBUwH/Ac4BgQFhAf8B3AGBAWQB/wHpAYEBZwH/AekBgQFnAf8B6QGBAWcB/wHp
+ AYEBZwH/Ae4BgQFoAf8B6QGBAWcB/wHpAYEBZwH/Ae4BgQFoAf8B4AGBAWQB/wHOAYEBYAH/AZABaAFR
+ Af80AAFEAUEBuAH/ATcBNQHDAf8MAAGPAWgBUQH/Ab4BgQFdAf8B1wGBAWIB/wHXAYEBYwH/AdoBgQFj
+ Af8B2gGBAWMB/wHgAYEBZAH/AdoBgQFjAf8B2gGBAWMB/wHgAYEBZAH/AdoBgQFjAf8BzgGBAWEB/wG+
+ AYEBXQH/AYQBZAFOAf8IAAHIAsUB/wH7AfkB+AH/AfkB8AHtAf8B+QHwAe0B/wH5AfAB7QH/AfkB8AHt
+ Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B+AHuAeoB/wHBAr4B/wHbAdoB2wH/AbACrQH/DAABiAFl
+ AU8B/wHAAYEBXQH/Ac4BgQFhAf8B3AGBAWQB/wHcAYEBZAH/AeABgQFkAf8B3AGBAWQB/wHgAYEBZAH/
+ AeABgQFkAf8B3AGBAWQB/wHcAYEBZAH/Ac4BgQFgAf8BvwGBAV0B/wGEAWQBTgH/OAABNQEzAdIB/wFr
+ AWYBrwH/CAABngKBAf8BhAFkAU4B/wGYAWwBUwH/AZgBbAFTAf8BnwFvAVUB/wGfAW8BVQH/AZ8BbwFV
+ Af8BnwFvAVUB/wGfAW8BVQH/AZgBbAFTAf8BmAFsAVMB/wGYAWwBUwH/AY8BaAFRAf8BpgKBAf8IAAHI
AsUB/wH7AfkB+AH/AfoB9QH0Af8B+gH1AfQB/wH6AfUB9AH/AfoB9QH0Af8B+gH1AfQB/wH6AfUB9AH/
- AfoB9QH0Af8B+gH1AfQB/wG+ArwB/wGwAq0B/xAAAZ4CgQH/AYgBaAFSAf8BmQFvAVYB/wGZAW8BVgH/
- AZkBbwFWAf8BnwFyAVgB/wGfAXIBWAH/AZ8BcgFYAf8BmQFvAVYB/wGfAXIBWAH/AZkBbwFWAf8BlQFu
- AVYB/wGIAWgBUgH/AaYCgQH/OAABcwFuAaoB/wKBAaoB/0gAAc8CzQH/AcgCxQH/AcgCxQH/AcgCxQH/
+ AfoB9QH0Af8B+gH1AfQB/wG+ArwB/wGwAq0B/xAAAZ4CgQH/AYgBZQFPAf8BmQFsAVMB/wGZAWwBUwH/
+ AZkBbAFTAf8BnwFvAVUB/wGfAW8BVQH/AZ8BbwFVAf8BmQFsAVMB/wGfAW8BVQH/AZkBbAFTAf8BlQFr
+ AVMB/wGIAWUBTwH/AaYCgQH/OAABcAFrAaoB/wKBAaoB/0gAAc8CzQH/AcgCxQH/AcgCxQH/AcgCxQH/
AcgCxQH/AcgCxQH/AcUCwgH/AcgCxQH/AcUCwgH/AcUCwgH/Ab4CvAH/1AABxQLCAf8BwQK+Af8BwQK+
Af8BvgK8Af8BvgK8Af8BvgK8Af8BvgK8Af8BvgK8Af8BvgK8Af8BvgK8Af8BugK4Af8BvgK8Af8BvgK8
Af8BugK4Af+EAAGLAdoB7QH/AYEB2AHrAf8BgQHYAesB/wGBAdgB6wH/AYEB2AHrAf8BgQHYAesB/wGB
AdgB6wH/AYEB2AHrAf8BgQHWAeoB/wGBAdYB6gH/AYEB1gHqAf8BgQHWAeoB/wGBAdYB6gH/AYEB1gHq
Af8BgQHUAecB/wGLAdoB7QH/BAABwQK+Af8B+gH1AfQB/wH3Ae8B7AH/AfcB7wHsAf8B9gHsAegB/wH2
AewB6AH/AfYB7AHoAf8B9AHmAeEB/wH0AeYB4QH/AfQB5gHhAf8B9AHmAeEB/wH0AeYB4QH/AfcB7wHs
- Af8BugK4Af8YAAGBAZ4BgQH/AVcBhQF5Af8BQAGLAW0B/wFAAYsBbQH/AVcBhQF5Af8BgQGiAYEB/xgA
+ Af8BugK4Af8YAAGBAZ4BgQH/AVQBhQF2Af8BPQGLAWoB/wE9AYsBagH/AVQBhQF2Af8BgQGiAYEB/xgA
AoEBxgH/OAABgQHYAesB/wGsAf8B+AH/AawB/wH4Af8BrAH/AfgB/wGsAf8B+AH/AawB/wH4Af8BrAH/
AfgB/wGsAf8B+AH/AawB/wH4Af8BrAH/AfgB/wGsAf8B+AH/AawB/wH4Af8BrAH/AfgB/wGlAf8B+AH/
AawB/wH4Af8BgQHUAecB/wQAAcUCwgH/AfoB9QH0Af8B9AHmAeEB/wH0AeYB4QH/AfIB5AHeAf8B8gHk
Ad4B/wHvAdsB1AH/Ae8B2wHUAf8B7wHbAdQB/wHtAdYBzgH/Ae0B1gHOAf8B7QHWAc4B/wH0AeYB4QH/
- Ab4CvAH/FAABRAGLAXAB/wE8AcYBgQH/ATwB3AGBAf8BPAHiAYEB/wE8AeIBgQH/ATwB3AGBAf8BPAHG
- AYEB/wFGAYgBcAH/FAABOAE2AdIB/wKBAbYB/zQAAYEB2AHrAf8BrAH/AfgB/wGsAf8B+AH/AaUB/wH4
+ Ab4CvAH/FAABQQGLAW0B/wE5AcYBgQH/ATkB3AGBAf8BOQHiAYEB/wE5AeIBgQH/ATkB3AGBAf8BOQHG
+ AYEB/wFDAYgBbQH/FAABNQEzAdIB/wKBAbYB/zQAAYEB2AHrAf8BrAH/AfgB/wGsAf8B+AH/AaUB/wH4
Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGl
Af8B9wH/AaUB/wH4Af8BngH/AfgB/wGqAf8B+AH/AYEB1AHnAf8EAAHBAr4B/wH6AfUB9AH/AfcB7wHs
Af8B9gHsAegB/wH0AeYB4QH/AfQB5gHhAf8B8gHkAd4B/wHyAeQB3gH/Ae8B2wHUAf8B7wHbAdQB/wHv
- AdsB1AH/Ae0B1gHOAf8B8gHkAd4B/wG+ArwB/xAAAT4BowF3Af8BPAHcAYEB/wE8AewBgQH/ATwB9AGB
- Af8BPQH4AYEB/wE9AfgBgQH/ATwB9AGBAf8BPAHsAYEB/wE8AdsBgQH/AT8BnQF0Af8QAAFMAUgBtgH/
- ATgBNgHKAf80AAGBAdgB6wH/AawB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BrAH/AfgB/wGl
+ AdsB1AH/Ae0B1gHOAf8B8gHkAd4B/wG+ArwB/xAAATsBowF0Af8BOQHcAYEB/wE5AewBgQH/ATkB9AGB
+ Af8BOgH4AYEB/wE6AfgBgQH/ATkB9AGBAf8BOQHsAYEB/wE5AdsBgQH/ATwBnQFxAf8QAAFJAUUBtgH/
+ ATUBMwHKAf80AAGBAdgB6wH/AawB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BrAH/AfgB/wGl
Af8B+AH/AaUB/wH3Af8BpQH/AfcB/wGlAf8B+AH/AaUB/wH3Af8BpQH/AfgB/wGeAf8B+AH/AZ0B/wH3
Af8BpQH/AfcB/wGBAdQB5wH/BAABxQLCAf8B3wGsAZsB/wHHAoEB/wHpAcYBugH/AfcB7wHsAf8B9gHs
AegB/wH0AeYB4QH/AfIB5AHeAf8B8gHkAd4B/wHwAd4B1wH/AdkBngGKAf8BxwKBAf8B5gG+AbAB/wG+
- ArwB/wwAAUQBiwFwAf8BPAHcAYEB/wE8AfQBgQH/AT4B+wGBAf8BQwH+AYEB/wFDAf4BgQH/AUYB/wGB
- Af8BQwH+AYEB/wE+AfsBgQH/ATwB7AGBAf8BPAHbAYEB/wFGAYgBcAH/EAACNgHdAf8BZwFjAbEB/xAA
- AVkBUgGaAf8cAAGBAdgB6wH/AawB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGl
+ ArwB/wwAAUEBiwFtAf8BOQHcAYEB/wE5AfQBgQH/ATsB+wGBAf8BQAH+AYEB/wFAAf4BgQH/AUMB/wGB
+ Af8BQAH+AYEB/wE7AfsBgQH/ATkB7AGBAf8BOQHbAYEB/wFDAYgBbQH/EAACMwHdAf8BZAFgAbEB/xAA
+ AVYBTwGaAf8cAAGBAdgB6wH/AawB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGl
Af8B+AH/AYoC7gH/AYIB6AHrAf8BpQH/AfgB/wGlAf8B9wH/AaUB/wH4Af8BngH/AfgB/wGVAf8B9wH/
AaUB/wH3Af8BgQHUAecB/wQAAcUCwgH/AdMBigGBAf8B3AGjAZAB/wH2AewB6AH/AfgB7gHqAf8B+AHu
AeoB/wHhAbEBoQH/AegBwwG3Af8B9AHmAeEB/wH0AeYB4QH/Ae8B2wHUAf8BywKBAf8B3wGsAZsB/wG+
- ArwB/wgAAYEBmQGBAf8BPAHKAYEB/wE8AewBgQH/AT4B+wGBAf8BRgH/AYEB/wFKAf8BgQH/AUoB/wGB
- Af8BSgH/AYEB/wFKAf8BgQH/AUYB/wGBAf8BPgH7AYEB/wE8AewBgQH/ATwBxgGBAf8BgQGiAYEB/wwA
- AVgBUwGyAf8BOAE2AdIB/wwAAoEBwAH/AjYB4QH/AXEBbQGzAf8YAAGBAdgB6wH/AaUB/wH4Af8BpQH/
+ ArwB/wgAAYEBmQGBAf8BOQHKAYEB/wE5AewBgQH/ATsB+wGBAf8BQwH/AYEB/wFHAf8BgQH/AUcB/wGB
+ Af8BRwH/AYEB/wFHAf8BgQH/AUMB/wGBAf8BOwH7AYEB/wE5AewBgQH/ATkBxgGBAf8BgQGiAYEB/wwA
+ AVUBUAGyAf8BNQEzAdIB/wwAAoEBwAH/AjMB4QH/AW4BagGzAf8YAAGBAdgB6wH/AaUB/wH4Af8BpQH/
AfgB/wGlAf8B+AH/AaUB/wH4Af8BpQH/AfgB/wGlAf8B+AH/AYoC7gH/AYIB6AHrAf8BpQH/AfcB/wGl
Af8B+AH/AZ4B/wH4Af8BnQH/AfcB/wGVAf8B9wH/AaUB/wH3Af8BgQHPAeAB/wQAAcUCwgH/AdMBigGB
Af8B4QGxAaEB/wH6AfUB9AH/AfgB7gHqAf8B+AHuAeoB/wHqAcoBvgH/Ae0B1gHOAf8B9gHsAegB/wH2
- AewB6AH/AfIB5AHeAf8B0AGEAYEB/wHiAbUBpgH/Ab4CvAH/CAABTgGFAXMB/wE8AdwBgQH/ATwB9AGB
- Af8BQwH+AYEB/wFKAf8BgQH/AU4B/wGBAf8BTgH/AYEB/wFOAf8BgQH/AUoB/wGBAf8BSgH/AYEB/wFD
- Af4BgQH/ATwB9AGBAf8BPAHcAYEB/wFXAYUBeQH/EAABOAE2AdIB/wFUAVABsgH/CAABPAE6AcEB/wI2
- Ad0B/wE4ATYB0gH/GAABgQHYAesB/wGsAf8B+AH/AaUB/wH4Af8BpQH/AfcB/wGlAf8B9wH/AaUB/wH4
+ AewB6AH/AfIB5AHeAf8B0AGEAYEB/wHiAbUBpgH/Ab4CvAH/CAABSwGFAXAB/wE5AdwBgQH/ATkB9AGB
+ Af8BQAH+AYEB/wFHAf8BgQH/AUsB/wGBAf8BSwH/AYEB/wFLAf8BgQH/AUcB/wGBAf8BRwH/AYEB/wFA
+ Af4BgQH/ATkB9AGBAf8BOQHcAYEB/wFUAYUBdgH/EAABNQEzAdIB/wFRAU0BsgH/CAABOQE3AcEB/wIz
+ Ad0B/wE1ATMB0gH/GAABgQHYAesB/wGsAf8B+AH/AaUB/wH4Af8BpQH/AfcB/wGlAf8B9wH/AaUB/wH4
Af8BrAH/AfgB/wGKAu4B/wGCAegB6wH/AaUB/wH3Af8BpQH/AfgB/wGVAf8B9wH/AZUB/wH3Af8BlQH/
AfcB/wGeAf8B+AH/AYEB1AHnAf8EAAHFAsIB/wHTAYoBgQH/AeMBtwGoAf8B+AHuAeoB/wH5AfAB7QH/
AfkB8AHtAf8B2QGZAYQB/wHYAZcBgQH/AfgB7gHqAf8B9gHsAegB/wH2AewB6AH/AdIBhgGBAf8B4gG1
- AaYB/wG+ArwB/wgAAT8BkQFwAf8BPAHiAYEB/wE9AfgBgQH/AUMB/gGBAf8BSgH/AYEB/wFOAf8BgQH/
- AU4B/wGBAf8BTgH/AYEB/wFOAf8BgQH/AUoB/wGBAf8BRgH/AYEB/wE8AfQBgQH/ATwB4gGBAf8BRAGL
- AXAB/xAAAWcBYwGxAf8CNgHhAf8CgQHGAf8BdQFxAbMB/wI2AeEB/wKBAaAB/wE8AToBwQH/AUcBRAG4
+ AaYB/wG+ArwB/wgAATwBkQFtAf8BOQHiAYEB/wE6AfgBgQH/AUAB/gGBAf8BRwH/AYEB/wFLAf8BgQH/
+ AUsB/wGBAf8BSwH/AYEB/wFLAf8BgQH/AUcB/wGBAf8BQwH/AYEB/wE5AfQBgQH/ATkB4gGBAf8BQQGL
+ AW0B/xAAAWQBYAGxAf8CMwHhAf8CgQHGAf8BcgFuAbMB/wIzAeEB/wKBAaAB/wE5ATcBwQH/AUQBQQG4
Af8UAAGBAdgB6wH/AaUB/wH4Af8BpQH/AfgB/wGKAu4B/wGCAegB6wH/AaUB/wH4Af8BpQH/AfgB/wGK
Au4B/wGEAegB6wH/AaUB/wH4Af8BngH/AfgB/wGEAegB6wH/AYEB6AHrAf8BjQH/AfYB/wGlAf8B9wH/
AYEBzQHeAf8EAAHFAsIB/wHTAYoBgQH/AeQBtgGnAf8B+QHwAe0B/wH5AfAB7QH/AfgB7gHqAf8B7wHb
- AdQB/wHLAoEB/wHSAYYBgQH/AfgB7gHqAf8B+AHuAeoB/wHSAYgBgQH/AeEBsQGhAf8BvgK8Af8IAAE/
- AZEBcAH/ATwB4gGBAf8BPQH4AYEB/wFGAf8BgQH/AUoB/wGBAf8BTgH/AYEB/wFOAf8BgQH/AU4B/wGB
- Af8BSgH/AYEB/wFOAf8BgQH/AUMB/gGBAf8BPgH7AYEB/wE8AeIBgQH/AUABiwFtAf8UAAE4ATYBygH/
- ATwBOQG9Af8BOAE2AdIB/wFeAVkBqgH/BAACgQG9Af8CNgHdAf8CgQG5Af8QAAGBAdgB6wH/AaUB/wH4
+ AdQB/wHLAoEB/wHSAYYBgQH/AfgB7gHqAf8B+AHuAeoB/wHSAYgBgQH/AeEBsQGhAf8BvgK8Af8IAAE8
+ AZEBbQH/ATkB4gGBAf8BOgH4AYEB/wFDAf8BgQH/AUcB/wGBAf8BSwH/AYEB/wFLAf8BgQH/AUsB/wGB
+ Af8BRwH/AYEB/wFLAf8BgQH/AUAB/gGBAf8BOwH7AYEB/wE5AeIBgQH/AT0BiwFqAf8UAAE1ATMBygH/
+ ATkBNgG9Af8BNQEzAdIB/wFbAVYBqgH/BAACgQG9Af8CMwHdAf8CgQG5Af8QAAGBAdgB6wH/AaUB/wH4
Af8BpQH/AfgB/wGKAu4B/wGCAegB6wH/AaUB/wH4Af8BrAH/AfgB/wGKAu4B/wGEAegB6wH/AaUB/wH4
Af8BngH/AfgB/wGBAu4B/wGBAegB6wH/AY0B/wH2Af8BnQH/AfcB/wGBAc0B3gH/BAABxQLCAf8B0wGK
AYEB/wHjAbcBqAH/AfkB8AHtAf8B+QHwAe0B/wHHAoEB/wHjAbcBqAH/AdwBowGQAf8BzAKBAf8B+QHw
- Ae0B/wH4Ae4B6gH/AdMBigGBAf8B4wG3AagB/wG+ArwB/wgAAUYBiAFwAf8BPAHcAYEB/wE9AfgBgQH/
- AUMB/gGBAf8BSgH/AYEB/wFKAf8BgQH/AU4B/wGBAf8BTgH/AYEB/wFOAf8BgQH/AUoB/wGBAf8BQwH+
- AYEB/wE8AfQBgQH/ATwB3AGBAf8BVwGFAXkB/xQAAXUBcQGzAf8CNwHoAf8BOAE2AcoB/wwAAVQBUAGy
- Af8BOAE2AcoB/xAAAYEB1gHpAf8BrAH/AfgB/wGlAf8B+AH/AYoC7gH/AYIB6AHrAf8BrAH/AfgB/wGl
+ Ae0B/wH4Ae4B6gH/AdMBigGBAf8B4wG3AagB/wG+ArwB/wgAAUMBiAFtAf8BOQHcAYEB/wE6AfgBgQH/
+ AUAB/gGBAf8BRwH/AYEB/wFHAf8BgQH/AUsB/wGBAf8BSwH/AYEB/wFLAf8BgQH/AUcB/wGBAf8BQAH+
+ AYEB/wE5AfQBgQH/ATkB3AGBAf8BVAGFAXYB/xQAAXIBbgGzAf8CNAHoAf8BNQEzAcoB/wwAAVEBTQGy
+ Af8BNQEzAcoB/xAAAYEB1gHpAf8BrAH/AfgB/wGlAf8B+AH/AYoC7gH/AYIB6AHrAf8BrAH/AfgB/wGl
Af8B+AH/AYoC7gH/AYQB6AHrAf8BngH/AfgB/wGVAf8B9wH/AYEC7gH/AYEB6AHrAf8BjQH/AfYB/wGd
- Af8B9wH/AYEBzQHeAf8EAAHIAsUB/wHYAZcBgQH/AbwBgQFaAf8B6QHGAboB/wH4Ae4B6gH/AeMBtwGo
- Af8BzAKBAf8BzgKBAf8B7wHbAdQB/wH5AfAB7QH/AdwBowGQAf8BugF8AVUB/wHmAb4BsAH/Ab4CvAH/
- CAABgQGWAYEB/wE8AcoBgQH/ATwB7AGBAf8BPgH7AYEB/wFGAf8BgQH/AUoB/wGBAf8BSgH/AYEB/wFK
- Af8BgQH/AUoB/wGBAf8BSgH/AYEB/wE9AfgBgQH/ATwB7AGBAf8BPAHGAYEB/wGBAZ4BgQH/GAABPAE6
- AcEB/wKBAawB/xAAATgBNgHKAf8BWAFTAbIB/wwAAYEB2AHrAf8BpQH/AfgB/wGlAf8B+AH/AYoC7gH/
+ Af8B9wH/AYEBzQHeAf8EAAHIAsUB/wHYAZcBgQH/AbwBgQFXAf8B6QHGAboB/wH4Ae4B6gH/AeMBtwGo
+ Af8BzAKBAf8BzgKBAf8B7wHbAdQB/wH5AfAB7QH/AdwBowGQAf8BugF5AVIB/wHmAb4BsAH/Ab4CvAH/
+ CAABgQGWAYEB/wE5AcoBgQH/ATkB7AGBAf8BOwH7AYEB/wFDAf8BgQH/AUcB/wGBAf8BRwH/AYEB/wFH
+ Af8BgQH/AUcB/wGBAf8BRwH/AYEB/wE6AfgBgQH/ATkB7AGBAf8BOQHGAYEB/wGBAZ4BgQH/GAABOQE3
+ AcEB/wKBAawB/xAAATUBMwHKAf8BVQFQAbIB/wwAAYEB2AHrAf8BpQH/AfgB/wGlAf8B+AH/AYoC7gH/
AYQB6AHrAf8BpQH/AfgB/wGlAf8B9wH/AYoC7gH/AYEC7gH/AZ0B/wH3Af8BlQH/AfcB/wGBAu4B/wGB
AegB6QH/AY0B/wH2Af8BnQH/AfcB/wGBAc0B3gH/BAAByALFAf8B+gH1AfQB/wH5AfAB7QH/AfkB8AHt
Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B+QHwAe0B/wH5AfAB7QH/AfgB7gHqAf8B8gHkAd4B/wHj
- AdwB2QH/AeYB4QHgAf8BvgK8Af8MAAE/AZEBcAH/ATwB3AGBAf8BPAH0AYEB/wFDAf4BgQH/AUMB/gGB
- Af8BRgH/AYEB/wFGAf8BgQH/AUMB/gGBAf8BPQH4AYEB/wE8AfQBgQH/ATwB3AGBAf8BRAGLAXAB/xwA
- AoEBvQH/FAACgQG0Af8CNgHhAf8CgQHBAf8IAAGBAdYB6QH/AawB/wH4Af8BpQH/AfgB/wGRAe4B7wH/
+ AdwB2QH/AeYB4QHgAf8BvgK8Af8MAAE8AZEBbQH/ATkB3AGBAf8BOQH0AYEB/wFAAf4BgQH/AUAB/gGB
+ Af8BQwH/AYEB/wFDAf8BgQH/AUAB/gGBAf8BOgH4AYEB/wE5AfQBgQH/ATkB3AGBAf8BQQGLAW0B/xwA
+ AoEBvQH/FAACgQG0Af8CMwHhAf8CgQHBAf8IAAGBAdYB6QH/AawB/wH4Af8BpQH/AfgB/wGRAe4B7wH/
AYQB6AHrAf8BpQH/AfgB/wGlAf8B9wH/AYoC7gH/AYEB6AHrAf8BlQH/AfcB/wGVAf8B9wH/AYEC7gH/
AYEB6AHpAf8BiQH/AfUB/wGdAf8B9wH/AYEBzQHeAf8EAAHIAsUB/wH6AfUB9AH/AfkB8AHtAf8B+QHw
Ae0B/wH5AfAB7QH/AfkB8AHtAf8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B9wHvAewB/wHBAr4B/wG3
- AbMBsgH/AbACrQH/AbACrQH/DAABgQGrAYoB/wE+AaoBegH/ATwB3AGBAf8BPAHsAYEB/wE8AfQBgQH/
- AT0B+AGBAf8BPQH4AYEB/wE8AfQBgQH/ATwB8AGBAf8BPAHcAYEB/wE+AaMBdwH/PAABRwFEAbgB/wE8
- AToBwQH/CAABgQHWAekB/wGsAf8B+AH/AawB/wH4Af8BkQHuAe8B/wGKAu4B/wGqAf8B+AH/AawB/wH4
+ AbMBsgH/AbACrQH/AbACrQH/DAABgQGrAYoB/wE7AaoBdwH/ATkB3AGBAf8BOQHsAYEB/wE5AfQBgQH/
+ AToB+AGBAf8BOgH4AYEB/wE5AfQBgQH/ATkB8AGBAf8BOQHcAYEB/wE7AaMBdAH/PAABRAFBAbgB/wE5
+ ATcBwQH/CAABgQHWAekB/wGsAf8B+AH/AawB/wH4Af8BkQHuAe8B/wGKAu4B/wGqAf8B+AH/AawB/wH4
Af8BigLuAf8BggHoAesB/wGlAf8B+AH/AaUB/wH4Af8BhAHoAesB/wGBAu4B/wGdAf8B9wH/AaUB/wH4
Af8BgQHNAd4B/wQAAcgCxQH/AfoB9QH0Af8B+QHwAe0B/wH5AfAB7QH/AfkB8AHtAf8B+QHwAe0B/wH5
AfAB7QH/AfkB8AHtAf8B+QHwAe0B/wH4Ae4B6gH/AcECvgH/AdsB2gHbAf8BsAKtAf8UAAGBAasBigH/
- AT8BkQFwAf8BPAHKAYEB/wE8AdwBgQH/ATwB4gGBAf8BPAHiAYEB/wE8AeIBgQH/ATwBygGBAf8BRAGL
- AXAB/0QAAjYB3QH/AW4BaQGvAf8EAAGCAdYB6gH/AYEB1gHqAf8BgQHUAecB/wGBAc0B4QH/AYEBzQHh
+ ATwBkQFtAf8BOQHKAYEB/wE5AdwBgQH/ATkB4gGBAf8BOQHiAYEB/wE5AeIBgQH/ATkBygGBAf8BQQGL
+ AW0B/0QAAjMB3QH/AWsBZgGvAf8EAAGCAdYB6gH/AYEB1gHqAf8BgQHUAecB/wGBAc0B4QH/AYEBzQHh
Af8BgQHPAeAB/wGBAdQB5wH/AYEBzQHeAf8BgQHJAd4B/wGBAc8B4AH/AYEBzwHgAf8BgQHJAd4B/wGB
AccB2wH/AYEBzQHeAf8BgQHNAd4B/wGNAdEB4QH/BAAByALFAf8B+wH5AfgB/wH6AfUB9AH/AfoB9QH0
Af8B+gH1AfQB/wH6AfUB9AH/AfoB9QH0Af8B+gH1AfQB/wH6AfUB9AH/AfoB9QH0Af8BvgK8Af8BsAKt
- Af8gAAGBAZYBgQH/AUYBiAFwAf8BPwGRAXAB/wE/AZEBcAH/AU4BhQFzAf8BgQGZAYEB/0gAAXMBbgGq
+ Af8gAAGBAZYBgQH/AUMBiAFtAf8BPAGRAW0B/wE8AZEBbQH/AUsBhQFwAf8BgQGZAYEB/0gAAXABawGq
Af8CgQGqAf9IAAHPAs0B/wHIAsUB/wHIAsUB/wHIAsUB/wHIAsUB/wHIAsUB/wHFAsIB/wHIAsUB/wHF
AsIB/wHFAsIB/wG+ArwB/5AAAUIBTQE+BwABPgMAASgDAAFAAwABMAMAAQEBAAEBBQABgAEBFgAD/wEA
Af8BwwH/AcMBgAEBAgAB+AEBAgABgAEBAgAB8AMAAYADAAHgAwABgAMAAcADAAGAAwABgAMAAYADAAGA
@@ -747,7 +747,7 @@
<value>0</value>
</data>
<metadata name="toolStrip2.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 54</value>
+ <value>3, 16</value>
</metadata>
<data name="SelectAllButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -914,7 +914,7 @@
<value>scaleRangeList</value>
</data>
<data name=">>scaleRangeList.Type" xml:space="preserve">
- <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ScaleRangeList, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4358, Culture=neutral, PublicKeyToken=null</value>
+ <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayerEditorControls.ScaleControls.ScaleRangeList, OSGeo.MapGuide.Maestro.ResourceEditors, Version=2.1.1.5078, Culture=neutral, PublicKeyToken=null</value>
</data>
<data name=">>scaleRangeList.Parent" xml:space="preserve">
<value>panel1</value>
@@ -923,7 +923,7 @@
<value>0</value>
</data>
<metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>809, 17</value>
+ <value>0, 0</value>
</metadata>
<data name="AddScaleRangeButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
More information about the mapguide-commits
