[mapguide-commits] r5191 - in trunk/MgDev:
Server/src/Services/Feature Server/src/Wfs Web/src/HttpHandler
svn_mapguide at osgeo.org
Sun Sep 26 04:08:58 EDT 2010
Author: liuar
Date: 2010-09-26 08:08:58 +0000 (Sun, 26 Sep 2010)
New Revision: 5191
trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp
trunk/MgDev/Server/src/Wfs/1.0.0.xml.awd
trunk/MgDev/Web/src/HttpHandler/HttpWfsDescribeFeatureType.cpp
trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp
trunk/MgDev/Web/src/HttpHandler/WfsFeatures.cpp
ticket #1421 OGC WFS 1.1.0 Support
11. Test wfs:wfs-1.1.0-Basic-GetFeature-tc23.1 (s0001/d1e35137_1/d1e740_1/d1e25217_1/d1e6182_1)
Assertion: The following query parameters are required for all KVP-encoded service requests except !GetCapabilities: service, request, version.
For !GetFeature requests, if service or version parameter is not specified, MapGuide should response a WFS exception.
12. Test wfs:wfs-1.1.0-Basic-GetFeature-tc44.2 (s0001/d1e35137_1/d1e740_1/d1e25217_1/d1e6238_1)
Assertion: Version number specified in a given request must correspond to a version supported by the service.
For !GetFeature requests, if the version number specified in the request is not supported, MapGuide should generate a WFS exception.
13. Test wfs:wfs-1.1.0-Basic-GetFeature-tc32.1 (s0001/d1e35137_1/d1e740_1/d1e25217_1/d1e6226_1)
Assertion: An ogc:Literal element may include simple or complex content. If a child element appears it may belong to any target namespace, but a top-level declaration for the item must be available.
For property names in filter, there will be a prefix like "gml:" or user specified prefix. Those prefixes should be removed to make sure properties can be found by FDO API.
Modified: trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp
--- trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp 2010-09-24 05:22:10 UTC (rev 5190)
+++ trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp 2010-09-26 08:08:58 UTC (rev 5191)
@@ -153,6 +153,12 @@
else if (xmlcmp(wnm, L"PropertyName") == 0)
m_propName = process_identifier(root);
+ // This is a workaround for GML3. For Name and Description properties, there will be a "gml:" prefix
+ // Remove the prefix to make sure Name and Description properties can be found by FDO API.
+ size_t pos = m_propName.find_first_of(L":");
+ m_propName = m_propName.substr(pos+1);
return m_propName;
else if (xmlcmp(wnm, L"Literal") == 0)
Modified: trunk/MgDev/Server/src/Wfs/1.0.0.xml.awd
--- trunk/MgDev/Server/src/Wfs/1.0.0.xml.awd 2010-09-24 05:22:10 UTC (rev 5190)
+++ trunk/MgDev/Server/src/Wfs/1.0.0.xml.awd 2010-09-26 08:08:58 UTC (rev 5191)
@@ -265,11 +265,18 @@
<Response request="Exception" content-type="text/xml">
-<ServiceExceptionReport version="&TemplateVersion;" xmlns="http://www.opengis.net/ogc">
- <ServiceException code="&Exception.Type;">
- Request=&Request.request; resulted in an exception: &Exception.message;
- </ServiceException>
-</ServiceExceptionReport>
+<ows:ExceptionReport
+ version="&TemplateVersion;"
+ xmlns:ows="http://www.opengis.net/ows"
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+ xsi:schemaLocation="http://www.opengis.net/ows http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
+ <ows:Exception exceptionCode="&Exception.Type;" locator="&Exception.Locator;">
+ <ows:ExceptionText>
+ &Exception.message;
+ </ows:ExceptionText>
+ </ows:Exception>
+</ows:ExceptionReport>
</Response>
</Template>
Modified: trunk/MgDev/Web/src/HttpHandler/HttpWfsDescribeFeatureType.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpWfsDescribeFeatureType.cpp 2010-09-24 05:22:10 UTC (rev 5190)
+++ trunk/MgDev/Web/src/HttpHandler/HttpWfsDescribeFeatureType.cpp 2010-09-26 08:08:58 UTC (rev 5191)
@@ -71,17 +71,6 @@
// Instance a server-lette
MgOgcWfsServer Wfs(Parms,Out);
- // In order to validate request we have to invoke the ProcessRequest
- if(!Wfs.ProcessRequest(this))
- // Obtain the response byte reader
- Ptr<MgByteReader> errorResponse = Out.Stream().GetReader();
- // Set the result
- hResult->SetResultObject(errorResponse, errorResponse->GetMimeType());
- return;
// Determine required feature types
CPSZ pszFeatureTypes = Wfs.RequestParameter(MgHttpResourceStrings::reqWfsTypeName.c_str());
STRING sFeatureTypes = pszFeatureTypes? pszFeatureTypes : _("");
@@ -106,6 +95,17 @@
MgWfsFeatureDefinitions oFeatureTypes(pResourceService,pFeatureService,featureTypeList);
Wfs.SetFeatureDefinitions(&oFeatureTypes);
+ // In order to validate request we have to invoke the ProcessRequest
+ if(!Wfs.ProcessRequest(this))
+ // Obtain the response byte reader
+ Ptr<MgByteReader> errorResponse = Out.Stream().GetReader();
+ // Set the result
+ hResult->SetResultObject(errorResponse, errorResponse->GetMimeType());
+ return;
// This is a comma-sep a list. If empty, == all.
// If it's just one feature (no comma sep found) let's do
// a single response, else let's recursively enumerate the features.
@@ -152,7 +152,7 @@
MyLog.Write(_("WFS::DescribeFeatureType\r\n"));
#endif
// Execute the request
- Wfs.ProcessRequest(this);
+ //Wfs.ProcessRequest(this);
// Slurp the results.
Ptr<MgByteReader> capabilities = Out.Stream().GetReader();
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp
--- trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp 2010-09-24 05:22:10 UTC (rev 5190)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWfsServer.cpp 2010-09-26 08:08:58 UTC (rev 5191)
@@ -63,6 +63,7 @@
CPSZ kpszExceptionMessageUnknownTypeName = _("Expected valid typeName argument, as enumerated by GetCapabilities. (Instead, found typeName='&Request.TypeName;'.)"); // Localize
CPSZ kpszExceptionMessageWfsGetFeatureMissingFeatureType = _("A WFS GetFeature request requires at least one feature type to be specified."); // Localize
CPSZ kpszExceptionMessageWfsVersionNegotiationFailed = _("Requested version is unsupported in AcceptVersions"); //Localize
+CPSZ kpszExceptionMessageWfsInvalidVersion = _("Version number specified must correspond to a version supported by the service."); // Localize
CPSZ kpszExceptionMessageWfsInvalidService = _("Invalid parameter value for SERVICE"); //Localize
CPSZ kpszInternalErrorMissingGetFeatureRequestParams = _("Internal Error: Missing WFS GetFeature request parameters."); // Localize
@@ -259,7 +260,8 @@
if(sAcceptVersions.find(sVersion) != STRING::npos)
- return true;
+ bSupported = true;
+ break;
@@ -286,20 +288,60 @@
return false;
+ // If all the validation passed, we add the FeatureTypeList into definition to
+ // make ProcedureEnumFeatureTypes happy.
+ AddDefinition(kpszDefinitionSectionFeatureTypeList,kpszOmittedValue);
return true;
bool MgOgcWfsServer::ValidateGetFeatureRequest()
CPSZ pVersion = RequestParameter(kpszQueryStringVersion);
- if(pVersion == NULL)
+ if(pVersion == NULL || STRING(pVersion).empty())
ServiceExceptionReportResponse(MgOgcWfsException(MgOgcWfsException::kpszMissingRequestParameter,
kpszExceptionMessageWfsMissingVersion,
kpszQueryStringVersion));
return false;
+ else
+ // OGC CITE: Test wfs:wfs-1.1.0-Basic-GetFeature-tc44.2 (s0001/d1e35137_1/d1e740_1/d1e25217_1/d1e6238_1)
+ // Assertion: Version number specified in a given request must correspond to a version supported by the service.
+ CPSZ pszSupportedVersions = Definition(kpszDictionarySupportedVersions);
+ // Pass out a NULL, which caller must use to tickle an exception.
+ if(pszSupportedVersions == NULL)
+ return false;
+ MgXmlParser SupportedVersions(pszSupportedVersions);
+ STRING sVersion;
+ bool bSupported = false;
+ while(SupportedVersions.Next())
+ if(SupportedVersions.Current().Type() == keBeginElement)
+ MgXmlBeginElement& Begin = (MgXmlBeginElement&)SupportedVersions.Current();
+ if(Begin.Name() == kpszElementVersion && Begin.GetAttribute(kpszAttributeNumber,sVersion))
+ if(SZ_EQI(pVersion,sVersion.c_str()))
+ break;
+ if(!bSupported)
+ ServiceExceptionReportResponse(MgOgcWfsException(MgOgcWfsException::kpszInvalidParameterValue,
+ kpszExceptionMessageWfsInvalidVersion,
+ kpszQueryStringVersion));
+ return false;
if(m_pGetFeatureParams == NULL)
// The request params are missing
@@ -450,18 +492,22 @@
ProcessExpandableTextIntoString(sSubset,sSubset);
int iNum = 0;
+ if(NULL != m_pFeatures)
+ while(m_pFeatures->Next())
+ // We ensure that each feature gets its own stack frame
+ // so definitions don't get carried over to the next feature.
+ CDictionaryStackFrame ForEachFeature(this);
+ m_pFeatures->GenerateDefinitions(*m_pTopOfDefinitions);
- while(m_pFeatures->Next()) {
- // We ensure that each feature gets its own stack frame
- // so definitions don't get carried over to the next feature.
- CDictionaryStackFrame ForEachFeature(this);
- m_pFeatures->GenerateDefinitions(*m_pTopOfDefinitions);
- CPSZ pszIsPublished = this->Definition(_("Feature.IsPublished"));
- if(pszIsPublished != NULL && SZ_EQ(pszIsPublished,_("1")))
- if(IsIterationInSubset(++iNum,sSubset,kpszPiDefinitionFeatureIteration)) {
- ProcessExpandableText(sFormat);
+ CPSZ pszIsPublished = this->Definition(_("Feature.IsPublished"));
+ if(pszIsPublished != NULL && SZ_EQ(pszIsPublished,_("1")))
+ if(IsIterationInSubset(++iNum,sSubset,kpszPiDefinitionFeatureIteration)) {
+ ProcessExpandableText(sFormat);
@@ -480,15 +526,18 @@
int iNum = 0;
if(m_pFeatureSet != NULL) {
- while(m_pFeatureSet->Next()) {
+ while(m_pFeatureSet->Next())
m_pFeatureSet->GenerateDefinitions(*m_pTopOfDefinitions);
+ if(IsIterationInSubset(++iNum,sSubset,kpszPiDefinitionFeatureIteration) && (*m_pTopOfDefinitions)[L"Feature.OuterXml"] )
Modified: trunk/MgDev/Web/src/HttpHandler/WfsFeatures.cpp
--- trunk/MgDev/Web/src/HttpHandler/WfsFeatures.cpp 2010-09-24 05:22:10 UTC (rev 5190)
+++ trunk/MgDev/Web/src/HttpHandler/WfsFeatures.cpp 2010-09-26 08:08:58 UTC (rev 5191)
@@ -119,7 +119,7 @@
void MgWfsFeatures::GenerateDefinitions(MgUtilDictionary& Dictionary)
- if(m_bOk) {
+ if(m_bOk && !m_sCurrentFeature.empty()) {
Dictionary.AddDefinition(L"Feature.OuterXml", m_sCurrentFeature);
Dictionary.AddDefinition(L"Feature.InnerXml", m_sCurrentFeature.substr(m_iCurrentInnerContent,m_iCurrentInnerLength));
Dictionary.AddDefinition(L"Feature.EndElement", m_sCurrentFeature.substr(m_iCurrentInnerContent+m_iCurrentInnerLength));
More information about the mapguide-commits
