[mapguide-commits] r5204 - sandbox/maestro-3.0/Maestro.Base/UI
svn_mapguide at osgeo.org
Tue Sep 28 11:23:43 EDT 2010
Author: jng
Date: 2010-09-28 15:23:43 +0000 (Tue, 28 Sep 2010)
New Revision: 5204
sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs
add missing LGPL header
Modified: sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs 2010-09-28 15:21:37 UTC (rev 5203)
+++ sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs 2010-09-28 15:23:43 UTC (rev 5204)
@@ -1,4 +1,23 @@
-using System;
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Drawing;
More information about the mapguide-commits
