[mapguide-commits] r5208 - in sandbox/maestro-3.0: . Maestro
Maestro.Base Maestro.Base/Commands Maestro.Base/UI
Maestro.Editors Maestro.Editors/Properties Maestro.Packaging
Maestro.Packaging/Properties MaestroAPITests
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Capability
OSGeo.MapGuide.MaestroAPI/ObjectModels
OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org
Wed Sep 29 03:53:06 EDT 2010
Author: jng
Date: 2010-09-29 07:53:06 +0000 (Wed, 29 Sep 2010)
New Revision: 5208
Added:
sandbox/maestro-3.0/Maestro.Base/Commands/CreatePackageCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/LoadPackageCommand.cs
sandbox/maestro-3.0/Maestro.Packaging/
sandbox/maestro-3.0/Maestro.Packaging/Maestro.Packaging.csproj
sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs
sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.cs
sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.designer.cs
sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.resx
sandbox/maestro-3.0/Maestro.Packaging/Properties/
sandbox/maestro-3.0/Maestro.Packaging/Properties/AssemblyInfo.cs
sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Packaging/ResourceDataItem.cs
sandbox/maestro-3.0/Maestro.Packaging/ResourceItem.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourcePackageManifest.cs
Removed:
sandbox/maestro-3.0/Maestro.Base/Commands/Toggle/
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
sandbox/maestro-3.0/Maestro/Maestro.sln
sandbox/maestro-3.0/MaestroAPITests/CapabilityTests.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
More sandbox changes
- Fix NRE on Outbound Request Viewer when starting up and not connected.
- Add IsSupportedResourceType() capability API to determine whether a given resource type is supported
- Update unit tests to exercise this API
- Forward-port packaging APIs from 2.x stream
Modified: sandbox/maestro-3.0/Maestro/Maestro.sln
--- sandbox/maestro-3.0/Maestro/Maestro.sln 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/Maestro/Maestro.sln 2010-09-29 07:53:06 UTC (rev 5208)
@@ -50,6 +50,8 @@
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.AddIn.LayerDefinition-1.3.0", "..\Maestro.AddIn.LayerDefinition-1.3.0\Maestro.AddIn.LayerDefinition-1.3.0.csproj", "{A49487F7-FCDD-4818-8C7E-2CADABA51B06}"
EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.Packaging", "..\Maestro.Packaging\Maestro.Packaging.csproj", "{0EA33E36-9C33-4D60-B378-B87FADAA0F40}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
@@ -148,6 +150,10 @@
{A49487F7-FCDD-4818-8C7E-2CADABA51B06}.Debug|Any CPU.Build.0 = Debug|Any CPU
{A49487F7-FCDD-4818-8C7E-2CADABA51B06}.Release|Any CPU.ActiveCfg = Release|Any CPU
{A49487F7-FCDD-4818-8C7E-2CADABA51B06}.Release|Any CPU.Build.0 = Release|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {0EA33E36-9C33-4D60-B378-B87FADAA0F40}.Release|Any CPU.Build.0 = Release|Any CPU
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
Added: sandbox/maestro-3.0/Maestro.Base/Commands/CreatePackageCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/CreatePackageCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/CreatePackageCommand.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,15 @@
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+namespace Maestro.Base.Commands
+ internal class CreatePackageCommand : AbstractMenuCommand
+ public override void Run()
+ throw new NotImplementedException();
Added: sandbox/maestro-3.0/Maestro.Base/Commands/LoadPackageCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/LoadPackageCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/LoadPackageCommand.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,15 @@
+using System;
+using System.Text;
+ internal class LoadPackageCommand : AbstractMenuCommand
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-09-29 07:53:06 UTC (rev 5208)
@@ -119,15 +119,6 @@
icon="application_task"
class="Maestro.Base.Commands.NotImplementedCommand"/>
</MenuItem>
- <MenuItem id="Menu_View"
- type="Menu"
- label="${res:Menu_View}">
- <MenuItem id="Menu_View_MessageLog"
- icon="reports_stack"
- label="${res:Menu_View_MessageLog}"
- type="CheckBox"
- class="Maestro.Base.Commands.Toggle.ToggleMessagesCommand" />
- </MenuItem>
<MenuItem id="Menu_Help"
type="Menu"
label="${res:Menu_Help}">
@@ -252,7 +243,7 @@
<Condition action="Disable" name="SelectedItem">
<ToolbarItem id="DeleteItem"
icon="cross_script"
- class="Maestro.Base.Commands.NotImplementedCommand" />
+ class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
</Condition>
<ToolbarItem id="SiteExplorer_Refresh"
icon="arrow-circle-045-left"
@@ -282,10 +273,10 @@
<MenuItem type="Separator" />
<MenuItem id="CreatePackage"
label="${res:SiteExplorer_SelectedFolder_CreatePackage}"
+ class="Maestro.Base.Commands.CreatePackageCommand" />
<MenuItem id="LoadPackage"
label="${res:SiteExplorer_SelectedFolder_LoadPackage}"
+ class="Maestro.Base.Commands.LoadPackageCommand" />
<Condition action="Disable" name="IsNotRoot">
<MenuItem id="Copy"
@@ -315,7 +306,7 @@
<Condition action="Disable" name="MultipleSelected">
<MenuItem id="Delete"
label="${res:SiteExplorer_SelectedItem_Delete}"
@@ -401,7 +392,7 @@
<MenuItem id="Copy"
label="${res:SiteExplorer_SelectedItem_Copy}"
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-09-29 07:53:06 UTC (rev 5208)
@@ -50,7 +50,9 @@
<Compile Include="Commands\Conditions\SelectedItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedRootItemConditionEvaluator.cs" />
<Compile Include="Commands\CopyCommand.cs" />
+ <Compile Include="Commands\CreatePackageCommand.cs" />
<Compile Include="Commands\CutCommand.cs" />
+ <Compile Include="Commands\LoadPackageCommand.cs" />
<Compile Include="Commands\LoginCommand.cs" />
<Compile Include="Commands\LogoutCommand.cs" />
<Compile Include="Commands\NewItemCommand.cs" />
@@ -77,7 +79,6 @@
<Compile Include="Commands\Test\OpenSymbolBrowserCommand.cs" />
<Compile Include="Commands\Test\OpenUnmanagedResourceCommand.cs" />
<Compile Include="Commands\Test\SelectFdoProviderCommand.cs" />
- <Compile Include="Commands\Toggle\ToggleMessagesCommand.cs" />
<Compile Include="Commands\ValidateResourceCommand.cs" />
<Compile Include="Commands\XmlEditCommand.cs" />
<Compile Include="Editor\DrawingSourceEditor.cs">
Modified: sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -46,10 +46,12 @@
//TODO: Re-evaluate design when we decide to support multiple site connections
var wb = Workbench.Instance;
var exp = wb.ActiveSiteExplorer;
- var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
- var conn = connMgr.GetConnection(exp.ConnectionName);
- conn.RequestDispatched += new OSGeo.MapGuide.MaestroAPI.RequestEventHandler(OnRequestDispatched);
+ if (exp != null)
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ conn.RequestDispatched += new OSGeo.MapGuide.MaestroAPI.RequestEventHandler(OnRequestDispatched);
void OnRequestDispatched(object sender, OSGeo.MapGuide.MaestroAPI.RequestEventArgs e)
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-09-29 07:53:06 UTC (rev 5208)
@@ -35,6 +35,10 @@
<SpecificVersion>False</SpecificVersion>
<HintPath>..\Thirdparty\TreeViewAdv\Aga.Controls\obj\Debug\Aga.Controls.dll</HintPath>
</Reference>
+ <Reference Include="ICSharpCode.SharpZipLib, Version=0.85.4.369, Culture=neutral, PublicKeyToken=1b03e6acf1164f73, processorArchitecture=MSIL">
+ <SpecificVersion>False</SpecificVersion>
+ <HintPath>..\Thirdparty\SharpZipLib\ICSharpCode.SharpZipLib.dll</HintPath>
+ </Reference>
<Reference Include="System" />
<Reference Include="System.Data" />
<Reference Include="System.Design" />
@@ -821,6 +825,10 @@
</EmbeddedResource>
</ItemGroup>
<ItemGroup>
+ <ProjectReference Include="..\Maestro.Packaging\Maestro.Packaging.csproj">
+ <Project>{0EA33E36-9C33-4D60-B378-B87FADAA0F40}</Project>
+ <Name>Maestro.Packaging</Name>
+ </ProjectReference>
<ProjectReference Include="..\Maestro.Shared.UI\Maestro.Shared.UI.csproj">
<Project>{CFD19053-2172-41D3-8460-0FD2123A1E88}</Project>
<Name>Maestro.Shared.UI</Name>
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -60,6 +60,24 @@
+ /// <summary>
+ /// Looks up a localized string similar to All types.
+ /// </summary>
+ internal static string AllResourceTypes {
+ get {
+ return ResourceManager.GetString("AllResourceTypes", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to You must enter a alternate name, or remove the checkmark.
+ /// </summary>
+ internal static string AlternateNameMissing {
+ get {
+ return ResourceManager.GetString("AlternateNameMissing", resourceCulture);
internal static System.Drawing.Bitmap application__arrow {
get {
object obj = ResourceManager.GetObject("application--arrow", resourceCulture);
@@ -246,6 +264,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to The content file does not exist.
+ /// </summary>
+ internal static string ContentFileMissing {
+ get {
+ return ResourceManager.GetString("ContentFileMissing", resourceCulture);
internal static System.Drawing.Bitmap control {
get {
object obj = ResourceManager.GetObject("control", resourceCulture);
@@ -314,6 +341,15 @@
/// <summary>
+ /// Looks up a localized string similar to Do you want to remove the selected item?.
+ /// </summary>
+ internal static string DeleteConfirmation {
+ get {
+ return ResourceManager.GetString("DeleteConfirmation", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Diverging.
/// </summary>
internal static string DivergingName {
@@ -406,6 +442,15 @@
/// <summary>
+ /// Looks up a localized string similar to An error occured while copying file: {0}.
+ /// </summary>
+ internal static string FileCopyError {
+ get {
+ return ResourceManager.GetString("FileCopyError", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to File Downloaded.
/// </summary>
internal static string FileDownloaded {
@@ -415,6 +460,42 @@
/// <summary>
+ /// Looks up a localized string similar to Failed to validate the filenames: {0}.
+ /// </summary>
+ internal static string FilenameValidationError {
+ get {
+ return ResourceManager.GetString("FilenameValidationError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to All files ({0}).
+ /// </summary>
+ internal static string FiletypeAll {
+ get {
+ return ResourceManager.GetString("FiletypeAll", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to MapGuide Packages ({0}).
+ /// </summary>
+ internal static string FiletypeMGP {
+ get {
+ return ResourceManager.GetString("FiletypeMGP", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Zip files ({0}).
+ /// </summary>
+ internal static string FiletypeZip {
+ get {
+ return ResourceManager.GetString("FiletypeZip", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to All File Types (*.*)|*.*.
/// </summary>
internal static string FilterAll {
@@ -499,6 +580,15 @@
/// <summary>
+ /// Looks up a localized string similar to The folder must start with \"Library://\", do you want the starting folder to become:\n {0} ?.
+ /// </summary>
+ internal static string FolderMissingPrefix {
+ get {
+ return ResourceManager.GetString("FolderMissingPrefix", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Cannot Preview Font "{0}".
/// </summary>
internal static string FontPreviewError {
@@ -608,6 +698,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to The header file does not exist.
+ /// </summary>
+ internal static string HeaderFileMissing {
+ get {
+ return ResourceManager.GetString("HeaderFileMissing", resourceCulture);
internal static System.Drawing.Bitmap icon_back {
get {
object obj = ResourceManager.GetObject("icon_back", resourceCulture);
@@ -1195,6 +1294,15 @@
/// <summary>
+ /// Looks up a localized string similar to An error occured while validating the restore path: {0}\nIt should have the format: \"Libray://folder/folder/\"..
+ /// </summary>
+ internal static string InvalidRestorePathError {
+ get {
+ return ResourceManager.GetString("InvalidRestorePathError", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Invalid value.
/// </summary>
internal static string InvalidValueError {
@@ -1323,6 +1431,15 @@
/// <summary>
+ /// Looks up a localized string similar to New folder.
+ /// </summary>
+ internal static string NewFolder {
+ get {
+ return ResourceManager.GetString("NewFolder", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to No values found in selected column.
/// </summary>
internal static string NoColumnValuesError {
@@ -1332,6 +1449,35 @@
/// <summary>
+ /// Looks up a localized string similar to You have not selected a starting folder, do you want to back up the entire site?.
+ /// </summary>
+ internal static string NoFolderSelected {
+ get {
+ return ResourceManager.GetString("NoFolderSelected", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to You have selected to restore the package at another location, but not entered one.
+ ///This will cause the package to be restored a the root of the resource tree.
+ ///Are you sure this is what you want?.
+ /// </summary>
+ internal static string NoRestorePathWarning {
+ get {
+ return ResourceManager.GetString("NoRestorePathWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to You must select at least one type.
+ /// </summary>
+ internal static string NoTypesSelected {
+ get {
+ return ResourceManager.GetString("NoTypesSelected", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Operation Cancelled.
/// </summary>
internal static string OperationCancelled {
@@ -1349,6 +1495,42 @@
+ /// <summary>
+ /// Looks up a localized string similar to You must enter a full path to the output file.
+ /// </summary>
+ internal static string OutputFileMissing {
+ get {
+ return ResourceManager.GetString("OutputFileMissing", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to An error occured while building package: {0}.
+ /// </summary>
+ internal static string PackageBuildError {
+ get {
+ return ResourceManager.GetString("PackageBuildError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to create package, error message: {0}.
+ /// </summary>
+ internal static string PackageCreationFailedError {
+ get {
+ return ResourceManager.GetString("PackageCreationFailedError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to read package. Error message was: {0}.
+ /// </summary>
+ internal static string PackageReadError {
+ get {
+ return ResourceManager.GetString("PackageReadError", resourceCulture);
internal static System.Drawing.Bitmap plus_circle {
get {
object obj = ResourceManager.GetObject("plus-circle", resourceCulture);
@@ -1398,6 +1580,18 @@
+ /// <summary>
+ /// Looks up a localized string similar to You have selected to restore the package at the root.
+ ///You have also selected to delete the target before restoring.
+ ///This will result in the entire repository being deleted and replaced with this package.
+ ///Are you absolutely sure that is what you want?.
+ /// </summary>
+ internal static string RepositoryWipeWarning {
+ get {
+ return ResourceManager.GetString("RepositoryWipeWarning", resourceCulture);
internal static System.Drawing.Bitmap ruler {
get {
object obj = ResourceManager.GetObject("ruler", resourceCulture);
@@ -1438,6 +1632,15 @@
/// <summary>
+ /// Looks up a localized string similar to Select the package file to edit.
+ /// </summary>
+ internal static string SelectPackageFile {
+ get {
+ return ResourceManager.GetString("SelectPackageFile", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Sequential.
/// </summary>
internal static string SequentialName {
@@ -1619,6 +1822,24 @@
/// <summary>
+ /// Looks up a localized string similar to Unknown types.
+ /// </summary>
+ internal static string UnknownResourceTypes {
+ get {
+ return ResourceManager.GetString("UnknownResourceTypes", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to An error occured while validating the output file path: {0}.
+ /// </summary>
+ internal static string ValidateOutputfileError {
+ get {
+ return ResourceManager.GetString("ValidateOutputfileError", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Document is valid.
/// </summary>
internal static string XmlDocIsValid {
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-09-29 07:53:06 UTC (rev 5208)
@@ -769,4 +769,105 @@
<data name="FilterShp" xml:space="preserve">
<value>ESRI Shape File (*.shp)|*.*</value>
</data>
+ <data name="AllResourceTypes" xml:space="preserve">
+ <value>All types</value>
+ <comment>The list entry that represents all resource types</comment>
+ </data>
+ <data name="AlternateNameMissing" xml:space="preserve">
+ <value>You must enter a alternate name, or remove the checkmark</value>
+ <comment>A message displayed when the user has not entered an alternate name for a resource</comment>
+ </data>
+ <data name="ContentFileMissing" xml:space="preserve">
+ <value>The content file does not exist</value>
+ <comment>A message displayed when the user selects a non-existing file</comment>
+ </data>
+ <data name="DeleteConfirmation" xml:space="preserve">
+ <value>Do you want to remove the selected item?</value>
+ <comment>A confirmation message displayed when deleting a resource</comment>
+ </data>
+ <data name="FileCopyError" xml:space="preserve">
+ <value>An error occured while copying file: {0}</value>
+ <comment>A message displayed when a file copy fails</comment>
+ </data>
+ <data name="FilenameValidationError" xml:space="preserve">
+ <value>Failed to validate the filenames: {0}</value>
+ <comment>A message displayed when the user enters an invalid filename</comment>
+ </data>
+ <data name="FiletypeAll" xml:space="preserve">
+ <value>All files ({0})</value>
+ <comment>The text displayed when browsing for all file types</comment>
+ </data>
+ <data name="FiletypeMGP" xml:space="preserve">
+ <value>MapGuide Packages ({0})</value>
+ <comment>The text displayed when browsing for MGP files</comment>
+ </data>
+ <data name="FiletypeZip" xml:space="preserve">
+ <value>Zip files ({0})</value>
+ <comment>The text displayed when browsing for zip files</comment>
+ </data>
+ <data name="FolderMissingPrefix" xml:space="preserve">
+ <value>The folder must start with \"Library://\", do you want the starting folder to become:\n {0} ?</value>
+ <comment>A message that is displayed when the user has not entered a folder starting with Library://</comment>
+ </data>
+ <data name="HeaderFileMissing" xml:space="preserve">
+ <value>The header file does not exist</value>
+ </data>
+ <data name="InvalidRestorePathError" xml:space="preserve">
+ <value>An error occured while validating the restore path: {0}\nIt should have the format: \"Libray://folder/folder/\".</value>
+ <comment>A message that is displayed when the restore path does not validate</comment>
+ </data>
+ <data name="NewFolder" xml:space="preserve">
+ <value>New folder</value>
+ <comment>The default name of a new folder</comment>
+ </data>
+ <data name="NoFolderSelected" xml:space="preserve">
+ <value>You have not selected a starting folder, do you want to back up the entire site?</value>
+ <comment>A message that is displayed when the user has not selected a folder to create a folder from</comment>
+ </data>
+ <data name="NoRestorePathWarning" xml:space="preserve">
+ <value>You have selected to restore the package at another location, but not entered one.
+This will cause the package to be restored a the root of the resource tree.
+Are you sure this is what you want?</value>
+ <comment>A message displayed when the user has not entered a restore path</comment>
+ </data>
+ <data name="NoTypesSelected" xml:space="preserve">
+ <value>You must select at least one type</value>
+ <comment>A message that is displayed when the user has not selected any resource types</comment>
+ </data>
+ <data name="OutputFileMissing" xml:space="preserve">
+ <value>You must enter a full path to the output file</value>
+ <comment>A message that is displayed when the user has not entered an output file</comment>
+ </data>
+ <data name="PackageBuildError" xml:space="preserve">
+ <value>An error occured while building package: {0}</value>
+ <comment>A message displayed when the package creation fails</comment>
+ </data>
+ <data name="PackageCreationFailedError" xml:space="preserve">
+ <value>Failed to create package, error message: {0}</value>
+ </data>
+ <data name="PackageReadError" xml:space="preserve">
+ <value>Failed to read package. Error message was: {0}</value>
+ <comment>A message displayed when the package could not be read</comment>
+ </data>
+ <data name="RepositoryWipeWarning" xml:space="preserve">
+ <value>You have selected to restore the package at the root.
+You have also selected to delete the target before restoring.
+This will result in the entire repository being deleted and replaced with this package.
+Are you absolutely sure that is what you want?</value>
+ <comment>A confirmation message displayed to the user, when creating a package that will completely wipe a repository</comment>
+ </data>
+ <data name="SelectPackageFile" xml:space="preserve">
+ <value>Select the package file to edit</value>
+ <comment>The title of the dialog that the is used to pick the package file to edit</comment>
+ </data>
+ <data name="UnknownResourceTypes" xml:space="preserve">
+ <value>Unknown types</value>
+ <comment>The list entry that represents unknown resource types</comment>
+ </data>
+ <data name="ValidateOutputfileError" xml:space="preserve">
+ <value>An error occured while validating the output file path: {0}</value>
+ <comment>A message that is displayed to the user when the output path is invalid</comment>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Packaging/Maestro.Packaging.csproj
--- sandbox/maestro-3.0/Maestro.Packaging/Maestro.Packaging.csproj (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/Maestro.Packaging.csproj 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,89 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <ProductVersion>9.0.30729</ProductVersion>
+ <SchemaVersion>2.0</SchemaVersion>
+ <ProjectGuid>{0EA33E36-9C33-4D60-B378-B87FADAA0F40}</ProjectGuid>
+ <OutputType>Library</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>Maestro.Packaging</RootNamespace>
+ <AssemblyName>Maestro.Packaging</AssemblyName>
+ <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+ <FileAlignment>512</FileAlignment>
+ <TargetFrameworkSubset>
+ </TargetFrameworkSubset>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+ <DebugSymbols>true</DebugSymbols>
+ <DebugType>full</DebugType>
+ <Optimize>false</Optimize>
+ <OutputPath>bin\Debug\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <ErrorReport>prompt</ErrorReport>
+ <WarningLevel>4</WarningLevel>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+ <DebugType>pdbonly</DebugType>
+ <Optimize>true</Optimize>
+ <OutputPath>bin\Release\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ </PropertyGroup>
+ <ItemGroup>
+ </Reference>
+ <Reference Include="System" />
+ <Reference Include="System.Windows.Forms" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="PackageBuilder.cs" />
+ <Compile Include="PackageProgress.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="PackageProgress.designer.cs">
+ <DependentUpon>PackageProgress.cs</DependentUpon>
+ </Compile>
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ <Compile Include="Properties\Resources.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DesignTime>True</DesignTime>
+ <DependentUpon>Resources.resx</DependentUpon>
+ </Compile>
+ <Compile Include="ResourceDataItem.cs" />
+ <Compile Include="ResourceItem.cs" />
+ </ItemGroup>
+ <ItemGroup>
+ <EmbeddedResource Include="PackageProgress.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="Properties\Resources.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+ </ItemGroup>
+ <ItemGroup>
+ <ProjectReference Include="..\Maestro.Shared.UI\Maestro.Shared.UI.csproj">
+ <Project>{CFD19053-2172-41D3-8460-0FD2123A1E88}</Project>
+ <Name>Maestro.Shared.UI</Name>
+ <ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
+ <Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
+ <Name>OSGeo.MapGuide.MaestroAPI</Name>
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
Added: sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs
--- sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/PackageBuilder.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,923 @@
+#region Disclaimer / License
+// Copyright (C) 2009, Kenneth Skovhede
+// http://www.hexad.dk, opensource at hexad.dk
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.ObjectModels.Common;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+namespace Maestro.Packaging
+ /// <summary>
+ /// Enumeration used to signal the type of operation currently running
+ /// </summary>
+ public enum ProgressType
+ /// <summary>
+ /// The file list is being fetched from MapGuide
+ /// </summary>
+ ReadingFileList,
+ /// <summary>
+ /// Files are downloaded in temporary folder
+ /// </summary>
+ PreparingFolder,
+ /// <summary>
+ /// Resource references are updated to use the new folder
+ /// </summary>
+ MovingResources,
+ /// <summary>
+ /// The files are being compressed
+ /// </summary>
+ Compressing,
+ /// <summary>
+ /// The package opertion has completed
+ /// </summary>
+ Done,
+ /// <summary>
+ /// The package is being uploaded
+ /// </summary>
+ Uploading,
+ /// <summary>
+ /// Extracting filenames from package
+ /// </summary>
+ ListingFiles
+ /// <summary>
+ /// Defines the type of entry
+ /// </summary>
+ public enum EntryTypeEnum
+ /// <summary>
+ /// The item already exists in the package
+ /// </summary>
+ Regular,
+ /// <summary>
+ /// The item is deleted from the package
+ /// </summary>
+ Deleted,
+ /// <summary>
+ /// The item is added to the package
+ /// </summary>
+ Added
+ /// <summary>
+ /// A delegate for reporting package creation progress
+ /// </summary>
+ /// <param name="type">The progress type that is currently running</param>
+ /// <param name="maxValue">The max value, meaning that when value equals maxValue, progress is equal to 100%</param>
+ /// <param name="value">The current item being progressed</param>
+ /// <param name="resourceId">The name of the resource being processed, if any</param>
+ public delegate void ProgressDelegate(ProgressType type, string resourceId, int maxValue, int value);
+ public class PackageBuilder
+ /// <summary>
+ /// The connection object
+ /// </summary>
+ private IServerConnection m_connection;
+ /// <summary>
+ /// Constructs a new package builder instance
+ /// </summary>
+ /// <param name="connection">The connection used to serialize and fetch items</param>
+ public PackageBuilder(IServerConnection connection)
+ if (connection == null)
+ throw new ArgumentNullException("connection");
+ m_connection = connection;
+ /// <summary>
+ /// This event is invoked to report progress to the caller
+ /// </summary>
+ public event ProgressDelegate Progress;
+ /// <summary>
+ /// Keep track of the last pg sent, to avoid excessive events
+ /// </summary>
+ private long m_lastPg = -1;
+ /// <summary>
+ /// Uploads a package to the server
+ /// </summary>
+ /// <param name="sourceFile"></param>
+ public void UploadPackage(string sourceFile)
+ if (Progress != null)
+ Progress(ProgressType.Uploading, sourceFile, 100, 0);
+ m_lastPg = -1;
+ m_connection.ResourceService.UploadPackage(sourceFile, new Utility.StreamCopyProgressDelegate(ProgressCallback_Upload));
+ Progress(ProgressType.Uploading, sourceFile, 100, 100);
+ private void ProgressCallback_Upload(long copied, long remain, long total)
+ if (m_lastPg < 0 || remain == 0 || copied - m_lastPg > 1024 * 50)
+ Progress(ProgressType.Uploading, "", (int)(total / 1024), (int)(copied / 1024));
+ m_lastPg = copied;
+ /// <summary>
+ /// Creates a package
+ /// </summary>
+ /// <param name="folderResourceId">The folder to create the package from</param>
+ /// <param name="zipfilename">The name of the output file to create</param>
+ /// <param name="allowedExtensions">A list of allowed extensions without leading dot, or null to include all file types. The special item "*" matches all unknown types.</param>
+ /// <param name="removeExistingFiles">A value indicating if a delete operation is included in the package to remove existing files before restoring the package</param>
+ /// <param name="alternateTargetResourceId">An optional target folder resourceId, use null or an empty string to restore the files at the original locations</param>
+ public void CreatePackage(string folderResourceId, string zipfilename, IList<string> allowedExtensions, bool removeExistingFiles, string alternateTargetResourceId)
+ Progress(ProgressType.ReadingFileList, folderResourceId, 100, 0);
+ ResourceList items = m_connection.ResourceService.GetRepositoryResources(folderResourceId);
+ List<ResourceListResourceDocument> files = new List<ResourceListResourceDocument>();
+ List<ResourceListResourceFolder> folders = new List<ResourceListResourceFolder>();
+ Dictionary<string, List<ResourceDataListResourceData>> resourceData = new Dictionary<string, List<ResourceDataListResourceData>>();
+ ResourcePackageManifest manifest = new ResourcePackageManifest();
+ manifest.Description = "MapGuide Package created with Maestro";
+ manifest.Operations = new ResourcePackageManifestOperations();
+ manifest.Operations.Operation = new System.ComponentModel.BindingList<ResourcePackageManifestOperationsOperation>();
+ //System.Collections.Hashtable knownTypes = ((ServerConnectionBase)m_connection).ResourceTypeLookup;
+ foreach (object o in items.Items)
+ if (o as ResourceListResourceDocument != null)
+ ResourceListResourceDocument doc = o as ResourceListResourceDocument;
+ var extension = ResourceIdentifier.GetResourceType(doc.ResourceId);
+ if (allowedExtensions == null || allowedExtensions.Count == 0)
+ files.Add(doc);
+ else if (m_connection.Capabilities.IsSupportedResourceType(extension) && allowedExtensions.Contains(extension.ToString()))
+ files.Add(doc);
+ else if (!m_connection.Capabilities.IsSupportedResourceType(extension) && allowedExtensions.Contains("*"))
+ files.Add(doc);
+ else if (o as ResourceListResourceFolder != null)
+ folders.Add(o as ResourceListResourceFolder);
+ Progress(ProgressType.ReadingFileList, folderResourceId, 100, 100);
+ Progress(ProgressType.PreparingFolder, "", files.Count + folders.Count + 1, 0);
+ string temppath = System.IO.Path.Combine(System.IO.Path.GetTempPath(), System.IO.Path.GetRandomFileName());
+ //All files have random names on disk, but a full path in the zip file
+ List<KeyValuePair<string, string>> filemap = new List<KeyValuePair<string, string>>();
+ try
+ System.IO.Directory.CreateDirectory(temppath);
+ int opno = 1;
+ foreach (ResourceListResourceFolder folder in folders)
+ Progress(ProgressType.PreparingFolder, folder.ResourceId, files.Count + folders.Count + 1, opno);
+ AddFolderResource(manifest, temppath, folder, removeExistingFiles, m_connection, filemap);
+ Progress(ProgressType.PreparingFolder, folder.ResourceId, files.Count + folders.Count + 1, opno++);
+ foreach (ResourceListResourceDocument doc in files)
+ Progress(ProgressType.PreparingFolder, doc.ResourceId, files.Count + folders.Count + 1, opno);
+ string filebase = CreateFolderForResource(doc.ResourceId, temppath);
+ resourceData[doc.ResourceId] = new List<ResourceDataListResourceData>();
+ ResourceDataList rdl = m_connection.ResourceService.EnumerateResourceData(doc.ResourceId);
+ foreach (ResourceDataListResourceData rd in rdl.ResourceData)
+ resourceData[doc.ResourceId].Add(rd);
+ int itemCount = resourceData[doc.ResourceId].Count + 1;
+ filemap.Add(new KeyValuePair<string, string>(filebase + "_CONTENT.xml", System.IO.Path.Combine(temppath, Guid.NewGuid().ToString())));
+ using (System.IO.FileStream fs = new System.IO.FileStream(filemap[filemap.Count - 1].Value, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ using (var s = m_connection.ResourceService.GetResourceXmlData(doc.ResourceId))
+ var data = Utility.StreamAsArray(s);
+ fs.Write(data, 0, data.Length);
+ AddFileResource(manifest, temppath, doc, filemap[filemap.Count - 1].Key, removeExistingFiles, m_connection, filemap);
+ filemap.Add(new KeyValuePair<string, string>(filebase + "_DATA_" + EncodeFilename(rd.Name), System.IO.Path.Combine(temppath, Guid.NewGuid().ToString())));
+ System.IO.FileInfo fi = new System.IO.FileInfo(filemap[filemap.Count - 1].Value);
+ using (System.IO.FileStream fs = new System.IO.FileStream(fi.FullName, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ m_connection.ResourceService.GetResourceData(doc.ResourceId, rd.Name).WriteTo(fs);
+ AddResourceData(manifest, temppath, doc, fi, filemap[filemap.Count - 1].Key, rd, m_connection);
+ Progress(ProgressType.PreparingFolder, doc.ResourceId, files.Count + folders.Count + 1, opno++);
+ Progress(ProgressType.PreparingFolder, Properties.Resources.ProgressDone, files.Count + folders.Count + 1, files.Count + folders.Count + 1);
+ if (!string.IsNullOrEmpty(alternateTargetResourceId))
+ Progress(ProgressType.MovingResources, Properties.Resources.ProgressUpdatingReferences, 100, 0);
+ RemapFiles(m_connection, manifest, temppath, folderResourceId, alternateTargetResourceId, filemap);
+ Progress(ProgressType.MovingResources, Properties.Resources.ProgressUpdatedReferences, 100, 100);
+ filemap.Add(new KeyValuePair<string, string>(System.IO.Path.Combine(temppath, "MgResourcePackageManifest.xml"), System.IO.Path.Combine(temppath, Guid.NewGuid().ToString())));
+ using (System.IO.FileStream fs = new System.IO.FileStream(filemap[filemap.Count - 1].Value, System.IO.FileMode.CreateNew, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ m_connection.ResourceService.SerializeObject(manifest, fs);
+ Progress(ProgressType.MovingResources, zipfilename, filemap.Count, 0);
+ ZipDirectory(zipfilename, temppath, "MapGuide Package created by Maestro", filemap);
+ Progress(ProgressType.MovingResources, zipfilename, filemap.Count, filemap.Count);
+ Progress(ProgressType.Done, "", filemap.Count, filemap.Count);
+ finally
+ try
+ if (System.IO.Directory.Exists(temppath))
+ System.IO.Directory.Delete(temppath, true);
+ catch
+ private void AddResourceData(ResourcePackageManifest manifest, string temppath, ResourceListResourceDocument doc, System.IO.FileInfo fi, string resourcePath, ResourceDataListResourceData rd, IServerConnection connection)
+ string contentType = "application/octet-stream";
+ try
+ if (connection as HttpServerConnection != null)
+ contentType = (connection as HttpServerConnection).LastResponseHeaders[System.Net.HttpResponseHeader.ContentType];
+ catch
+ string name = rd.Name;
+ string type = rd.Type.ToString();
+ string resourceId = doc.ResourceId;
+ string filename = RelativeName(resourcePath, temppath).Replace('\\', '/');
+ long size = fi.Length;
+ AddResourceData(manifest, resourceId, contentType, type, name, filename, size);
+ private void AddResourceData(ResourcePackageManifest manifest, string resourceId, string contentType, string type, string name, string filename, long size)
+ ResourcePackageManifestOperationsOperation op = new ResourcePackageManifestOperationsOperation();
+ op.Name = "SETRESOURCEDATA";
+ op.Version = "1.0.0";
+ op.Parameters = new ResourcePackageManifestOperationsOperationParameters();
+ op.Parameters.Parameter = new System.ComponentModel.BindingList<ResourcePackageManifestOperationsOperationParametersParameter>();
+ ResourcePackageManifestOperationsOperationParametersParameter param = new ResourcePackageManifestOperationsOperationParametersParameter();
+ param.Name = "DATA";
+ param.Value = filename;
+ param.ContentType = contentType;
+ op.Parameters.Parameter.Add(param);
+ param = new ResourcePackageManifestOperationsOperationParametersParameter();
+ param.Name = "DATALENGTH";
+ param.Value = size.ToString();
+ param.Name = "DATANAME";
+ param.Value = name;
+ param.Name = "DATATYPE";
+ param.Value = type;
+ param.Name = "RESOURCEID";
+ param.Value = resourceId;
+ manifest.Operations.Operation.Add(op);
+ private void AddFileResource(ResourcePackageManifest manifest, string temppath, ResourceListResourceDocument doc, string contentfilename, bool eraseFirst, IServerConnection connection, List<KeyValuePair<string, string>> filemap)
+ filemap.Add(new KeyValuePair<string, string>(filebase + "_HEADER.xml", System.IO.Path.Combine(temppath, Guid.NewGuid().ToString())));
+ connection.ResourceService.SerializeObject(connection.ResourceService.GetResourceHeader(doc.ResourceId), fs);
+ string headerpath = RelativeName(filemap[filemap.Count - 1].Key, temppath).Replace('\\', '/');
+ string contentpath = RelativeName(contentfilename, temppath).Replace('\\', '/');
+ AddFileResource(manifest, doc.ResourceId, headerpath, contentpath, eraseFirst);
+ private void AddFileResource(ResourcePackageManifest manifest, string resourceId, string headerpath, string contentpath, bool eraseFirst)
+ if (eraseFirst)
+ ResourcePackageManifestOperationsOperation delop = new ResourcePackageManifestOperationsOperation();
+ delop.Name = "DELETERESOURCE";
+ delop.Version = "1.0.0";
+ delop.Parameters = new ResourcePackageManifestOperationsOperationParameters();
+ delop.Parameters.Parameter = new System.ComponentModel.BindingList<ResourcePackageManifestOperationsOperationParametersParameter>();
+ ResourcePackageManifestOperationsOperationParametersParameter delparam = new ResourcePackageManifestOperationsOperationParametersParameter();
+ delparam.Name = "RESOURCEID";
+ delparam.Value = resourceId;
+ delop.Parameters.Parameter.Add(delparam);
+ manifest.Operations.Operation.Add(delop);
+ op.Name = "SETRESOURCE";
+ param.Name = "CONTENT";
+ param.Value = contentpath;
+ param.ContentType = "text/xml";
+ param.Name = "HEADER";
+ param.Value = headerpath;
+ private void AddFolderResource(ResourcePackageManifest manifest, string temppath, ResourceListResourceFolder folder, bool eraseFirst, IServerConnection connection, List<KeyValuePair<string, string>> filemap)
+ string filebase = System.IO.Path.GetDirectoryName(CreateFolderForResource(folder.ResourceId + "dummy.xml", temppath));
+ filemap.Add(new KeyValuePair<string, string>(System.IO.Path.Combine(filebase, "_HEADER.xml"), System.IO.Path.Combine(temppath, Guid.NewGuid().ToString())));
+ connection.ResourceService.SerializeObject(connection.ResourceService.GetFolderHeader(folder.ResourceId), fs);
+ if (!filebase.EndsWith(System.IO.Path.DirectorySeparatorChar.ToString()))
+ filebase += System.IO.Path.DirectorySeparatorChar;
+ string headerpath = RelativeName(filebase + "_HEADER.xml", temppath).Replace('\\', '/');
+ AddFolderResource(manifest, folder.ResourceId, headerpath, eraseFirst);
+ private void AddFolderResource(ResourcePackageManifest manifest, string resourceId, string headerpath, bool eraseFirst)
+ if (eraseFirst)
+ if (resourceId.EndsWith("//"))
+ op.Name = "UPDATEREPOSITORY";
+ else
+ private string RelativeName(string filebase, string temppath)
+ if (!filebase.StartsWith(temppath))
+ throw new Exception(string.Format(Properties.Resources.FilenameRelationInternalError, filebase, temppath));
+ if (!temppath.EndsWith(System.IO.Path.DirectorySeparatorChar.ToString()))
+ temppath += System.IO.Path.DirectorySeparatorChar;
+ return filebase.Substring(temppath.Length);
+ private System.Text.RegularExpressions.Regex m_filenameTransformer = new System.Text.RegularExpressions.Regex(@"[^A-Za-z0-9\.-\/]", System.Text.RegularExpressions.RegexOptions.Compiled);
+ //There are some problems with the Zip reader in MapGuide and international characters :(
+ private string EncodeFilename(string filename)
+ System.Text.RegularExpressions.Match m = m_filenameTransformer.Match(filename);
+ System.Text.StringBuilder sb = new System.Text.StringBuilder();
+ int previndex = 0;
+ while (m != null && m.Success)
+ string replaceval = string.Format("-x{0:x2}-", (int)m.Value[0]);
+ sb.Append(filename.Substring(previndex, m.Index - previndex));
+ sb.Append(replaceval);
+ previndex = m.Index + m.Value.Length;
+ m = m.NextMatch();
+ if (sb.Length == 0)
+ return filename;
+ else
+ sb.Append(filename.Substring(previndex));
+ return sb.ToString();
+ private string CreateFolderForResource(string resourceId, string temppath)
+ var rid = new ResourceIdentifier(resourceId);
+ string filebase = EncodeFilename(rid.Name);
+ string folder = "Library/" + EncodeFilename(rid.Path);
+ folder = folder.Substring(0, folder.Length - filebase.Length);
+ filebase += resourceId.Substring(resourceId.LastIndexOf('.'));
+ folder = folder.Replace('/', System.IO.Path.DirectorySeparatorChar);
+ folder = System.IO.Path.Combine(temppath, folder);
+ return System.IO.Path.Combine(folder, filebase);
+ private void RemapFiles(IServerConnection connection, ResourcePackageManifest manifest, string tempdir, string origpath, string newpath, List<KeyValuePair<string, string>> filemap)
+ if (!newpath.EndsWith("/"))
+ newpath += "/";
+ if (!origpath.EndsWith("/"))
+ origpath += "/";
+ Dictionary<string, string> lookup = new Dictionary<string, string>();
+ foreach (KeyValuePair<string, string> p in filemap)
+ lookup.Add(p.Key, p.Value);
+ foreach (ResourcePackageManifestOperationsOperation op in manifest.Operations.Operation)
+ op.Parameters.SetParameterValue("RESOURCEID", newpath + op.Parameters.GetParameterValue("RESOURCEID").Substring(origpath.Length));
+ if (op.Parameters.GetParameterValue("CONTENT") != null)
+ string path = System.IO.Path.Combine(tempdir, op.Parameters.GetParameterValue("CONTENT").Replace('/', System.IO.Path.DirectorySeparatorChar));
+ System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
+ doc.Load(lookup[path]);
+ ((ServerConnectionBase)connection).UpdateResourceReferences(doc, origpath, newpath, true);
+ System.IO.MemoryStream ms = new System.IO.MemoryStream();
+ doc.Save(ms);
+ System.IO.MemoryStream ms2 = Utility.RemoveUTF8BOM(ms);
+ if (ms2 != ms)
+ ms.Dispose();
+ ms2.Position = 0;
+ using (System.IO.FileStream fs = new System.IO.FileStream(lookup[path], System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ ms2.WriteTo(fs);
+ ms2.Dispose();
+ private void ZipDirectory(string zipfile, string folder, string comment, List<KeyValuePair<string, string>> filemap)
+ ICSharpCode.SharpZipLib.Zip.ZipConstants.DefaultCodePage = System.Text.Encoding.UTF8.CodePage;
+ ICSharpCode.SharpZipLib.Checksums.Crc32 crc = new ICSharpCode.SharpZipLib.Checksums.Crc32();
+ using (System.IO.FileStream ofs = new System.IO.FileStream(zipfile, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ using (ICSharpCode.SharpZipLib.Zip.ZipOutputStream zip = new ICSharpCode.SharpZipLib.Zip.ZipOutputStream(ofs))
+ try
+ zip.SetLevel(9);
+ if (!string.IsNullOrEmpty(comment))
+ zip.SetComment(comment);
+ int i = 0;
+ foreach (KeyValuePair<string, string> f in filemap)
+ Progress(ProgressType.Compressing, f.Key, filemap.Count, i);
+ System.IO.FileInfo fi = new System.IO.FileInfo(f.Value);
+ ICSharpCode.SharpZipLib.Zip.ZipEntry ze = new ICSharpCode.SharpZipLib.Zip.ZipEntry(RelativeName(f.Key, folder).Replace('\\', '/'));
+ ze.DateTime = fi.LastWriteTime;
+ ze.Size = fi.Length;
+ zip.PutNextEntry(ze);
+ using (System.IO.FileStream fs = new System.IO.FileStream(fi.FullName, System.IO.FileMode.Open, System.IO.FileAccess.Read, System.IO.FileShare.None))
+ Utility.CopyStream(fs, zip);
+ Progress(ProgressType.Compressing, f.Key, filemap.Count, i++);
+ zip.Finish();
+ finally
+ try { zip.Close(); }
+ catch { }
+ private const string DEFAULT_HEADER =
+ "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n" +
+ "<ResourceFolderHeader xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"ResourceFolderHeader-1.0.0.xsd\">\n" +
+ " <Security xsi:noNamespaceSchemaLocation=\"ResourceSecurity-1.0.0.xsd\">\n" +
+ " <Inherited>true</Inherited>\n" +
+ " </Security>\n" +
+ "</ResourceFolderHeader>";
+ private string MapResourcePathToFolder(string tempfolder, string resourcename)
+ return CreateFolderForResource(resourcename, tempfolder);
+ /// <summary>
+ /// Builds a package with the specified content
+ /// </summary>
+ /// <param name="sourcePackageFile">The MGP file to read existing items from</param>
+ /// <param name="items">The list of items that should be present in the new package</param>
+ /// <param name="insertEraseCommands">True if each resource should have a delete operation inserted before the actual operation, false otherwise</param>
+ /// <param name="targetfile">The output package filename</param>
+ public void RebuildPackage(string sourcePackageFile, List<ResourceItem> items, string targetfile, bool insertEraseCommands)
+ string tempfolder = System.IO.Path.GetTempPath();
+ int opno = 1;
+ try
+ Progress(ProgressType.ReadingFileList, sourcePackageFile, 100, 0);
+ //Step 1: Create the file system layout
+ if (!System.IO.Directory.Exists(tempfolder))
+ System.IO.Directory.CreateDirectory(tempfolder);
+ string zipfilecomment;
+ using (ICSharpCode.SharpZipLib.Zip.ZipFile zipfile = new ICSharpCode.SharpZipLib.Zip.ZipFile(sourcePackageFile))
+ zipfilecomment = zipfile.ZipFileComment;
+ Progress(ProgressType.ReadingFileList, sourcePackageFile, 100, 100);
+ Progress(ProgressType.PreparingFolder, "", items.Count, 0);
+ foreach (ResourceItem ri in items)
+ Progress(ProgressType.PreparingFolder, ri.ResourcePath, items.Count, opno);
+ string filebase;
+ if (ri.IsFolder)
+ filebase = System.IO.Path.GetDirectoryName(MapResourcePathToFolder(tempfolder, ri.ResourcePath + "dummy.xml"));
+ else
+ filebase = MapResourcePathToFolder(tempfolder, ri.ResourcePath);
+ string headerpath = filebase + "_HEADER.xml";
+ string contentpath = filebase + "_CONTENT.xml";
+ if (ri.EntryType == EntryTypeEnum.Added)
+ if (string.IsNullOrEmpty(ri.Headerpath))
+ filemap.Add(new KeyValuePair<string, string>(headerpath, System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
+ byte[] data = System.Text.Encoding.UTF8.GetBytes(DEFAULT_HEADER);
+ else if (!ri.IsFolder)
+ filemap.Add(new KeyValuePair<string, string>(headerpath, ri.Headerpath));
+ System.IO.File.Copy(ri.Headerpath, headerpath);
+ if (!string.IsNullOrEmpty(ri.Contentpath))
+ filemap.Add(new KeyValuePair<string, string>(contentpath, ri.Contentpath));
+ else if (ri.EntryType == EntryTypeEnum.Regular)
+ else
+ int index = FindZipEntry(zipfile, ri.Headerpath);
+ if (index < 0)
+ throw new Exception(string.Format(Properties.Resources.FileMissingError, ri.Headerpath));
+ Utility.CopyStream(zipfile.GetInputStream(index), fs);
+ if (!ri.IsFolder)
+ int index = FindZipEntry(zipfile, ri.Contentpath);
+ if (index < 0)
+ throw new Exception(string.Format(Properties.Resources.FileMissingError, ri.Contentpath));
+ filemap.Add(new KeyValuePair<string, string>(contentpath, System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
+ ri.Headerpath = headerpath;
+ ri.Contentpath = contentpath;
+ foreach (ResourceDataItem rdi in ri.Items)
+ string targetpath = filebase + "_DATA_" + EncodeFilename(rdi.ResourceName);
+ if (rdi.EntryType == EntryTypeEnum.Added)
+ filemap.Add(new KeyValuePair<string, string>(targetpath, System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
+ else
+ int index = FindZipEntry(zipfile, rdi.Filename);
+ if (index < 0)
+ throw new Exception(string.Format(Properties.Resources.FileMissingError, rdi.Filename));
+ rdi.Filename = targetpath;
+ Progress(ProgressType.PreparingFolder, ri.ResourcePath, items.Count, opno++);
+ int i = 0;
+ Dictionary<string, string> filemap_lookup = new Dictionary<string, string>();
+ foreach (KeyValuePair<string, string> kv in filemap)
+ filemap_lookup[kv.Key] = kv.Value;
+ //Step 2: Repoint all resources with respect to the update
+ Progress(ProgressType.MovingResources, Properties.Resources.ProgressUpdatingResources, items.Count, i);
+ if (ri.OriginalResourcePath != ri.ResourcePath)
+ foreach (ResourceItem rix in items)
+ if (!rix.IsFolder)
+ doc.Load(filemap_lookup[rix.Contentpath]);
+ ((ServerConnectionBase)m_connection).UpdateResourceReferences(doc, ri.OriginalResourcePath, ri.ResourcePath, ri.IsFolder);
+ doc.Save(ms);
+ if (ms2 != ms)
+ ms.Dispose();
+ ms2.Position = 0;
+ using (System.IO.FileStream fs = new System.IO.FileStream(filemap_lookup[rix.Contentpath], System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ ms2.WriteTo(fs);
+ ms2.Dispose();
+ Progress(ProgressType.MovingResources, Properties.Resources.ProgressUpdatingResources, items.Count, i++);
+ Progress(ProgressType.MovingResources, Properties.Resources.ProgressUpdatedResources, items.Count, items.Count);
+ //Step 3: Create an updated definition file
+ manifest.Description = "MapGuide Package created by Maestro";
+ if (ri.IsFolder)
+ manifest,
+ ri.ResourcePath,
+ RelativeName(ri.Headerpath, tempfolder).Replace('\\', '/'),
+ insertEraseCommands);
+ else
+ AddFileResource(
+ manifest,
+ ri.ResourcePath,
+ RelativeName(ri.Contentpath, tempfolder).Replace('\\', '/'),
+ AddResourceData(
+ manifest,
+ ri.ResourcePath,
+ rdi.ContentType,
+ rdi.DataType,
+ rdi.ResourceName,
+ RelativeName(rdi.Filename, tempfolder).Replace('\\', '/'),
+ new System.IO.FileInfo(filemap_lookup[rdi.Filename]).Length);
+ filemap.Add(new KeyValuePair<string, string>(System.IO.Path.Combine(tempfolder, "MgResourcePackageManifest.xml"), System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString())));
+ Progress(ProgressType.Compressing, Properties.Resources.ProgressCompressing, 100, 0);
+ //Step 4: Create the zip file
+ ZipDirectory(targetfile, tempfolder, zipfilecomment, filemap);
+ Progress(ProgressType.Compressing, Properties.Resources.ProgressCompressed, 100, 100);
+ finally
+ try { System.IO.Directory.Delete(tempfolder, true); }
+ catch { }
+ private int FindZipEntry(ICSharpCode.SharpZipLib.Zip.ZipFile file, string path)
+ string p = path.Replace('\\', '/');
+ foreach (ICSharpCode.SharpZipLib.Zip.ZipEntry ze in file)
+ if (ze.Name.Replace('\\', '/').Equals(p))
+ return (int)ze.ZipFileIndex;
+ return -1;
+ /// <summary>
+ /// Reads the contents of a package file
+ /// </summary>
+ /// <param name="packageFile">The file to read</param>
+ /// <returns>A dictionary of items, the key is the resourceId</returns>
+ public Dictionary<string, ResourceItem> ListPackageContents(string packageFile)
+ Progress(ProgressType.ListingFiles, packageFile, 100, 0);
+ Dictionary<string, ResourceItem> resourceList = new Dictionary<string, ResourceItem>();
+ ResourcePackageManifest manifest;
+ using (ICSharpCode.SharpZipLib.Zip.ZipFile zipfile = new ICSharpCode.SharpZipLib.Zip.ZipFile(packageFile))
+ int index = FindZipEntry(zipfile, "MgResourcePackageManifest.xml");
+ if (index < 0)
+ throw new Exception(Properties.Resources.InvalidPackageFileError);
+ manifest = m_connection.ResourceService.DeserializeObject<ResourcePackageManifest>(zipfile.GetInputStream(index));
+ int i = 0;
+ Progress(ProgressType.ListingFiles, packageFile, manifest.Operations.Operation.Count, i);
+ //TODO: Much of this assumes that the package is correctly constructed, ea.: no SETRESOURCEDATA, before a SETRESOURCE and so on.
+ Progress(ProgressType.ListingFiles, packageFile, manifest.Operations.Operation.Count, i++);
+ if (op.Name.ToLower().Equals("setresource"))
+ string id = op.Parameters.GetParameterValue("RESOURCEID");
+ string header;
+ if (op.Parameters.GetParameterValue("HEADER") != null)
+ header = op.Parameters.GetParameterValue("HEADER");
+ else
+ header = null;
+ string content = op.Parameters.GetParameterValue("CONTENT") == null ? null : op.Parameters.GetParameterValue("CONTENT");
+ resourceList.Add(id, new ResourceItem(id, header, content));
+ else if (op.Name.ToLower().Equals("setresourcedata"))
+ ResourceItem ri = resourceList[id];
+ string name = op.Parameters.GetParameterValue("DATANAME");
+ string file = op.Parameters.GetParameterValue("DATA");
+ string contentType = op.Parameters.GetParameterValue("DATA");
+ string dataType = op.Parameters.GetParameterValue("DATATYPE");
+ ri.Items.Add(new ResourceDataItem(name, contentType, file, dataType));
+ //TODO: What to do with "DELETERESOURCE" ?
+ return resourceList;
Added: sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.cs
--- sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,309 @@
+#endregion
+using System;
+using System.ComponentModel;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI.Services;
+ public partial class PackageProgress : Form
+ /// <summary>
+ /// The stages required to build a package
+ /// </summary>
+ private readonly static ProgressType[] BUILD_STAGES = null;
+ static PackageProgress()
+ BUILD_STAGES =
+ new ProgressType[] {
+ ProgressType.ReadingFileList,
+ ProgressType.PreparingFolder,
+ ProgressType.MovingResources,
+ ProgressType.Compressing
+ private bool m_allowClose = true;
+ private volatile System.Threading.Thread m_thread;
+ private PackageBuilder m_invokeObj = null;
+ private object[] m_invokeArgs = null;
+ private System.Reflection.MethodInfo m_invokeMethod = null;
+ private object m_invokeResult = null;
+ /// <summary>
+ /// Lets the user choose a file to upload, and then transfers it
+ /// </summary>
+ /// <param name="owner">The owner form</param>
+ /// <param name="con">The connection to use</param>
+ /// <returns>A DialogResult object that indicates the upload result</returns>
+ public static DialogResult UploadPackage(Form owner, IServerConnection con)
+ OpenFileDialog dlg = Maestro.Shared.UI.DialogFactory.OpenFile();
+ //Mono does NOT like this one
+ //dlg.AutoUpgradeEnabled = true;
+ dlg.CheckFileExists = true;
+ dlg.CheckPathExists = true;
+ dlg.DefaultExt = ".mgp";
+ dlg.Filter = Properties.Resources.UploadPackageDialogFilter;
+ dlg.FilterIndex = 0;
+ dlg.Multiselect = false;
+ dlg.ValidateNames = true;
+ dlg.Title = Properties.Resources.UploadPackageDialogTitle;
+ if (dlg.ShowDialog(owner) == DialogResult.OK)
+ return UploadPackage(owner, con, dlg.FileName);
+ else
+ return DialogResult.Cancel;
+ /// <summary>
+ /// Lists the contents of a package
+ /// </summary>
+ /// <param name="connection">The connection used to deserialize the items</param>
+ /// <param name="packageFile">The package file to read</param>
+ /// <returns>A list of resources in the package</returns>
+ public static Dictionary<string, ResourceItem> ListPackageContents(Form owner, IServerConnection connection, string packageFile)
+ PackageProgress pkgp = new PackageProgress();
+ pkgp.m_invokeArgs = new object[] { packageFile };
+ pkgp.m_invokeObj = new PackageBuilder(connection);
+ pkgp.m_invokeMethod = pkgp.m_invokeObj.GetType().GetMethod("ListPackageContents");
+ if (pkgp.ShowDialog(owner) == DialogResult.OK)
+ return (Dictionary<string, ResourceItem>)pkgp.m_invokeResult;
+ else
+ return null;
+ /// <summary>
+ /// Uploads a package file to the server
+ /// </summary>
+ /// <param name="connection">The connection used to upload the package</param>
+ /// <param name="packageFile">The package file to upload</param>
+ /// <returns>A DialogResult object that indicates the result of the operation</returns>
+ public static DialogResult UploadPackage(Form owner, IServerConnection connection, string packageFile)
+ pkgp.m_invokeMethod = pkgp.m_invokeObj.GetType().GetMethod("UploadPackage");
+ return pkgp.ShowDialog(owner);
+ /// <summary>
+ /// Rebuilds a package
+ /// </summary>
+ /// <param name="connection">The connection used to serialize the items</param>
+ /// <param name="sourcePackageFile">The package file that the new file is based on</param>
+ /// <param name="items">The items that describes the layout of the new package</param>
+ /// <param name="targetfile">The output package file</param>
+ public static DialogResult RebuildPackage(Form owner, IServerConnection connection, string sourcePackageFile, List<ResourceItem> items, string targetfile, bool insertEraseCommands)
+ pkgp.m_invokeArgs = new object[] { sourcePackageFile, items, targetfile, insertEraseCommands };
+ pkgp.m_invokeMethod = pkgp.m_invokeObj.GetType().GetMethod("RebuildPackage");
+ /// <summary>
+ /// Creates a new package from a server folder
+ /// </summary>
+ /// <param name="connection">The connection used to retrieve the resources</param>
+ /// <param name="zipfilename">The name of the output package file</param>
+ /// <param name="allowedExtensions">A list of allowed extensions, set to null for all types. The special value "*" matches all unknown extensions.</param>
+ /// <param name="removeExistingFiles">A flag indicating if the package should contain a delete instruction to delete the target area before restore</param>
+ /// <param name="alternateTargetResourceId">The folder path where the package should be restore, set to null or empty string to use the source path</param>
+ /// <returns></returns>
+ public static DialogResult CreatePackage(Form owner, IServerConnection connection, string folderResourceId, string zipfilename, List<string> allowedExtensions, bool removeExistingFiles, string alternateTargetResourceId)
+ pkgp.m_invokeArgs = new object[] {folderResourceId, zipfilename, allowedExtensions, removeExistingFiles, alternateTargetResourceId };
+ pkgp.m_invokeMethod = pkgp.m_invokeObj.GetType().GetMethod("CreatePackage");
+ private PackageProgress()
+ InitializeComponent();
+ private void PackageProgress_Load(object sender, EventArgs e)
+ m_allowClose = false;
+ backgroundWorker.RunWorkerAsync();
+ m_invokeObj.Progress += new ProgressDelegate(SetCurrentProgress);
+ private void PackageProgress_FormClosing(object sender, FormClosingEventArgs e)
+ if (m_thread != null && !m_allowClose && e.CloseReason == CloseReason.UserClosing)
+ if (MessageBox.Show(this, Properties.Resources.CancelConfirmation, Application.ProductName, MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button3) == DialogResult.Yes)
+ try { m_thread.Abort(); }
+ catch { }
+ else
+ e.Cancel = true;
+ private delegate void SetCurrentProgressDelegate(ProgressType type, string resource, int total, int pg);
+ private void SetCurrentProgress(ProgressType type, string resource, int total, int pg)
+ if (this.InvokeRequired)
+ this.Invoke(new SetCurrentProgressDelegate(SetCurrentProgress), new object[] { type, resource, total, pg });
+ else
+ int span = this.CurrentProgress.Maximum - this.CurrentProgress.Minimum;
+ double v = (((double)pg / total) * span) + this.CurrentProgress.Minimum;
+ this.CurrentProgress.Value = (int)Math.Max(Math.Min(v, this.CurrentProgress.Maximum), this.CurrentProgress.Minimum);
+ OperationLabel.Text = resource;
+ int largePg = (int)Array.IndexOf(BUILD_STAGES, type);
+ if (largePg >= 0)
+ this.TotalProgress.Maximum = 100;
+ this.TotalProgress.Minimum = 0;
+ double tick = 100 / BUILD_STAGES.Length;
+ double lv = (tick * largePg) + (tick * ((double)pg / total));
+ this.TotalProgress.Value = (int)Math.Max(Math.Min((int)lv, this.TotalProgress.Maximum), this.TotalProgress.Minimum);
+ if (type == ProgressType.Uploading)
+ HideTotal();
+ if (pg == total)
+ OperationLabel.Text = Properties.Resources.ProgressWaitingForServer;
+ CurrentProgress.Style = ProgressBarStyle.Marquee;
+ else
+ OperationLabel.Text = string.Format(Properties.Resources.ProgressUploading, ((double)pg / 1024), ((double)total / 1024));
+ this.Refresh();
+ else if (type == ProgressType.ListingFiles)
+ HideTotal();
+ OperationLabel.Text = Properties.Resources.ProgressReadingPackage;
+ else if (type == ProgressType.Compressing)
+ OperationLabel.Text = Properties.Resources.ProgressCompressing;
+ else if (type == ProgressType.MovingResources)
+ OperationLabel.Text = Properties.Resources.ProgressUpdatingReferences;
+ else if (type == ProgressType.PreparingFolder)
+ private void HideTotal()
+ if (TotalProgress.Visible)
+ this.Height -= TotalProgress.Height;
+ TotalProgress.Visible = false;
+ TotalLabel.Visible = false;
+ private void backgroundWorker_DoWork(object sender, DoWorkEventArgs e)
+ try
+ m_thread = System.Threading.Thread.CurrentThread;
+ e.Result = m_invokeMethod.Invoke(m_invokeObj, m_invokeArgs);
+ catch (System.Threading.ThreadAbortException)
+ System.Threading.Thread.ResetAbort();
+ e.Cancel = true;
+ catch (System.Reflection.TargetInvocationException tai)
+ throw tai.InnerException;
+ finally
+ m_thread = null;
+ private void backgroundWorker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
+ m_allowClose = true;
+ if (e.Cancelled)
+ this.DialogResult = DialogResult.Cancel;
+ this.Close();
+ return;
+ else if (e.Error != null)
+ throw e.Error;
+ m_invokeResult = e.Result;
+ this.DialogResult = DialogResult.OK;
+ this.Close();
+ private void CancelBtn_Click(object sender, EventArgs e)
+ FormClosingEventArgs ev = new FormClosingEventArgs(CloseReason.UserClosing, false);
+ PackageProgress_FormClosing(sender, ev);
+ if (!ev.Cancel)
+ catch { }
Added: sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.designer.cs
--- sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.designer.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,119 @@
+ partial class PackageProgress
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(PackageProgress));
+ this.CurrentProgress = new System.Windows.Forms.ProgressBar();
+ this.TotalProgress = new System.Windows.Forms.ProgressBar();
+ this.label1 = new System.Windows.Forms.Label();
+ this.TotalLabel = new System.Windows.Forms.Label();
+ this.label3 = new System.Windows.Forms.Label();
+ this.OperationLabel = new System.Windows.Forms.Label();
+ this.CancelBtn = new System.Windows.Forms.Button();
+ this.backgroundWorker = new System.ComponentModel.BackgroundWorker();
+ this.SuspendLayout();
+ // CurrentProgress
+ resources.ApplyResources(this.CurrentProgress, "CurrentProgress");
+ this.CurrentProgress.Name = "CurrentProgress";
+ // TotalProgress
+ resources.ApplyResources(this.TotalProgress, "TotalProgress");
+ this.TotalProgress.Name = "TotalProgress";
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // TotalLabel
+ resources.ApplyResources(this.TotalLabel, "TotalLabel");
+ this.TotalLabel.Name = "TotalLabel";
+ // label3
+ resources.ApplyResources(this.label3, "label3");
+ this.label3.Name = "label3";
+ // OperationLabel
+ resources.ApplyResources(this.OperationLabel, "OperationLabel");
+ this.OperationLabel.AutoEllipsis = true;
+ this.OperationLabel.Name = "OperationLabel";
+ // CancelBtn
+ resources.ApplyResources(this.CancelBtn, "CancelBtn");
+ this.CancelBtn.Name = "CancelBtn";
+ this.CancelBtn.UseVisualStyleBackColor = true;
+ this.CancelBtn.Click += new System.EventHandler(this.CancelBtn_Click);
+ // backgroundWorker
+ this.backgroundWorker.WorkerSupportsCancellation = true;
+ this.backgroundWorker.DoWork += new System.ComponentModel.DoWorkEventHandler(this.backgroundWorker_DoWork);
+ this.backgroundWorker.RunWorkerCompleted += new System.ComponentModel.RunWorkerCompletedEventHandler(this.backgroundWorker_RunWorkerCompleted);
+ // PackageProgress
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.CancelBtn);
+ this.Controls.Add(this.OperationLabel);
+ this.Controls.Add(this.label3);
+ this.Controls.Add(this.TotalLabel);
+ this.Controls.Add(this.label1);
+ this.Controls.Add(this.TotalProgress);
+ this.Controls.Add(this.CurrentProgress);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedToolWindow;
+ this.MaximizeBox = false;
+ this.MinimizeBox = false;
+ this.Name = "PackageProgress";
+ this.Load += new System.EventHandler(this.PackageProgress_Load);
+ this.FormClosing += new System.Windows.Forms.FormClosingEventHandler(this.PackageProgress_FormClosing);
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.ProgressBar TotalProgress;
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Label TotalLabel;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.Label OperationLabel;
+ private System.Windows.Forms.Button CancelBtn;
+ public System.Windows.Forms.ProgressBar CurrentProgress;
+ private System.ComponentModel.BackgroundWorker backgroundWorker;
Added: sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.resx
--- sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/PackageProgress.resx 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,327 @@
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="CurrentProgress.Location" type="System.Drawing.Point, System.Drawing">
+ <value>88, 40</value>
+ </data>
+ <data name="CurrentProgress.Size" type="System.Drawing.Size, System.Drawing">
+ <value>384, 23</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="CurrentProgress.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>CurrentProgress.Name" xml:space="preserve">
+ <value>CurrentProgress</value>
+ </data>
+ <data name=">>CurrentProgress.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ProgressBar, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>CurrentProgress.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>CurrentProgress.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="TotalProgress.Location" type="System.Drawing.Point, System.Drawing">
+ <value>88, 72</value>
+ </data>
+ <data name="TotalProgress.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="TotalProgress.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>TotalProgress.Name" xml:space="preserve">
+ <value>TotalProgress</value>
+ </data>
+ <data name=">>TotalProgress.Type" xml:space="preserve">
+ </data>
+ <data name=">>TotalProgress.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TotalProgress.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 40</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>23, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>File</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="TotalLabel.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="TotalLabel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 72</value>
+ </data>
+ <data name="TotalLabel.Size" type="System.Drawing.Size, System.Drawing">
+ <value>31, 13</value>
+ </data>
+ <data name="TotalLabel.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="TotalLabel.Text" xml:space="preserve">
+ <value>Total</value>
+ </data>
+ <data name=">>TotalLabel.Name" xml:space="preserve">
+ <value>TotalLabel</value>
+ </data>
+ <data name=">>TotalLabel.Type" xml:space="preserve">
+ </data>
+ <data name=">>TotalLabel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TotalLabel.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 8</value>
+ </data>
+ <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>53, 13</value>
+ </data>
+ <data name="label3.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="label3.Text" xml:space="preserve">
+ <value>Operation</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="OperationLabel.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="OperationLabel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>88, 8</value>
+ </data>
+ <data name="OperationLabel.Size" type="System.Drawing.Size, System.Drawing">
+ <value>384, 13</value>
+ </data>
+ <data name="OperationLabel.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="OperationLabel.Text" xml:space="preserve">
+ <value>OperationLabel</value>
+ </data>
+ <data name=">>OperationLabel.Name" xml:space="preserve">
+ </data>
+ <data name=">>OperationLabel.Type" xml:space="preserve">
+ </data>
+ <data name=">>OperationLabel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>OperationLabel.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom</value>
+ </data>
+ <data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
+ <value>184, 112</value>
+ </data>
+ <data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
+ <value>112, 24</value>
+ </data>
+ <data name="CancelBtn.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="CancelBtn.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>CancelBtn.Name" xml:space="preserve">
+ <value>CancelBtn</value>
+ </data>
+ <data name=">>CancelBtn.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>CancelBtn.Parent" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="backgroundWorker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>489, 146</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Building package</value>
+ </data>
+ <data name=">>backgroundWorker.Name" xml:space="preserve">
+ <value>backgroundWorker</value>
+ </data>
+ <data name=">>backgroundWorker.Type" xml:space="preserve">
+ <value>System.ComponentModel.BackgroundWorker, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>PackageProgress</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Added: sandbox/maestro-3.0/Maestro.Packaging/Properties/AssemblyInfo.cs
--- sandbox/maestro-3.0/Maestro.Packaging/Properties/AssemblyInfo.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/Properties/AssemblyInfo.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("Maestro.Packaging")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("Microsoft")]
+[assembly: AssemblyProduct("Maestro.Packaging")]
+[assembly: AssemblyCopyright("Copyright © Microsoft 2010")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("898031bf-637e-4c1b-a87a-3d0e5403cb2c")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.Designer.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,225 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:2.0.50727.4952
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace Maestro.Packaging.Properties {
+ using System;
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Resources {
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Resources() {
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("Maestro.Packaging.Properties.Resources", typeof(Resources).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
+ return resourceCulture;
+ set {
+ resourceCulture = value;
+ /// <summary>
+ /// Looks up a localized string similar to Do you want to cancel?.
+ /// </summary>
+ internal static string CancelConfirmation {
+ get {
+ return ResourceManager.GetString("CancelConfirmation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to find file {0} in archive.
+ /// </summary>
+ internal static string FileMissingError {
+ get {
+ return ResourceManager.GetString("FileMissingError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Filename "{0}" is not relative to "{1}".
+ /// </summary>
+ internal static string FilenameRelationInternalError {
+ get {
+ return ResourceManager.GetString("FilenameRelationInternalError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to locate file MgResourcePackageManifest.xml in zip file. Most likely the file is not a MapGuide package..
+ /// </summary>
+ internal static string InvalidPackageFileError {
+ get {
+ return ResourceManager.GetString("InvalidPackageFileError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Compressed.
+ /// </summary>
+ internal static string ProgressCompressed {
+ get {
+ return ResourceManager.GetString("ProgressCompressed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Compressing ....
+ /// </summary>
+ internal static string ProgressCompressing {
+ get {
+ return ResourceManager.GetString("ProgressCompressing", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Compressing files ....
+ /// </summary>
+ internal static string ProgressCompressing1 {
+ get {
+ return ResourceManager.GetString("ProgressCompressing1", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Done.
+ /// </summary>
+ internal static string ProgressDone {
+ get {
+ return ResourceManager.GetString("ProgressDone", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Reading package contents ....
+ /// </summary>
+ internal static string ProgressReadingPackage {
+ get {
+ return ResourceManager.GetString("ProgressReadingPackage", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Updated references.
+ /// </summary>
+ internal static string ProgressUpdatedReferences {
+ get {
+ return ResourceManager.GetString("ProgressUpdatedReferences", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Updated resources.
+ /// </summary>
+ internal static string ProgressUpdatedResources {
+ get {
+ return ResourceManager.GetString("ProgressUpdatedResources", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Updating references ....
+ /// </summary>
+ internal static string ProgressUpdatingReferences {
+ get {
+ return ResourceManager.GetString("ProgressUpdatingReferences", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Updating resource references ....
+ /// </summary>
+ internal static string ProgressUpdatingReferences1 {
+ get {
+ return ResourceManager.GetString("ProgressUpdatingReferences1", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Updating resources ....
+ /// </summary>
+ internal static string ProgressUpdatingResources {
+ get {
+ return ResourceManager.GetString("ProgressUpdatingResources", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Uploading, {0:0.00} of {1:0.00} mb ....
+ /// </summary>
+ internal static string ProgressUploading {
+ get {
+ return ResourceManager.GetString("ProgressUploading", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Awating server processing ....
+ /// </summary>
+ internal static string ProgressWaitingForServer {
+ get {
+ return ResourceManager.GetString("ProgressWaitingForServer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to MapGuide Packages (*.mgp)|*.mgp|Zip files (*.zip)|*.zip|All files (*.*)|*.*.
+ /// </summary>
+ internal static string UploadPackageDialogFilter {
+ get {
+ return ResourceManager.GetString("UploadPackageDialogFilter", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Select the package to upload.
+ /// </summary>
+ internal static string UploadPackageDialogTitle {
+ get {
+ return ResourceManager.GetString("UploadPackageDialogTitle", resourceCulture);
Added: sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/Properties/Resources.resx 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,192 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="CancelConfirmation" xml:space="preserve">
+ <value>Do you want to cancel?</value>
+ <comment>A confirmation message displayed when the user presses the cancel button</comment>
+ </data>
+ <data name="FileMissingError" xml:space="preserve">
+ <value>Failed to find file {0} in archive</value>
+ <comment>An error message that is displayed if a file is missing in a package</comment>
+ </data>
+ <data name="FilenameRelationInternalError" xml:space="preserve">
+ <value>Filename "{0}" is not relative to "{1}"</value>
+ <comment>An internal error that is displayed when a filename inconsistency is encountered</comment>
+ </data>
+ <data name="InvalidPackageFileError" xml:space="preserve">
+ <value>Failed to locate file MgResourcePackageManifest.xml in zip file. Most likely the file is not a MapGuide package.</value>
+ <comment>An error message that is displayed if the package file is invalid</comment>
+ </data>
+ <data name="ProgressCompressed" xml:space="preserve">
+ <value>Compressed</value>
+ <comment>A progress message that is displayed when the files are compressed</comment>
+ </data>
+ <data name="ProgressCompressing" xml:space="preserve">
+ <value>Compressing ...</value>
+ <comment>A progress message that is displayed while compressing files</comment>
+ </data>
+ <data name="ProgressCompressing1" xml:space="preserve">
+ <value>Compressing files ...</value>
+ <comment>A message that is displayed while compressing files</comment>
+ </data>
+ <data name="ProgressDone" xml:space="preserve">
+ <value>Done</value>
+ <comment>A progress message that is displayed when the operation is done</comment>
+ </data>
+ <data name="ProgressReadingPackage" xml:space="preserve">
+ <value>Reading package contents ...</value>
+ <comment>A message that is displayed while reading the package contents</comment>
+ </data>
+ <data name="ProgressUpdatedReferences" xml:space="preserve">
+ <value>Updated references</value>
+ <comment>A progress message that is displayed when references are updated</comment>
+ </data>
+ <data name="ProgressUpdatedResources" xml:space="preserve">
+ <value>Updated resources</value>
+ <comment>A progress message that is displayed when resources are updated</comment>
+ </data>
+ <data name="ProgressUpdatingReferences" xml:space="preserve">
+ <value>Updating references ...</value>
+ <comment>A progress message that is displayed while updating references</comment>
+ </data>
+ <data name="ProgressUpdatingReferences1" xml:space="preserve">
+ <value>Updating resource references ...</value>
+ <comment>A message that is displayed while updating resource references</comment>
+ </data>
+ <data name="ProgressUpdatingResources" xml:space="preserve">
+ <value>Updating resources ...</value>
+ <comment>A progress message that is displayed while updating resources</comment>
+ </data>
+ <data name="ProgressUploading" xml:space="preserve">
+ <value>Uploading, {0:0.00} of {1:0.00} mb ...</value>
+ <comment>A message that is displayed while uploading the file</comment>
+ </data>
+ <data name="ProgressWaitingForServer" xml:space="preserve">
+ <value>Awating server processing ...</value>
+ <comment>A message that is displayed after the file is uploaded, and the server restores the file</comment>
+ </data>
+ <data name="UploadPackageDialogFilter" xml:space="preserve">
+ <value>MapGuide Packages (*.mgp)|*.mgp|Zip files (*.zip)|*.zip|All files (*.*)|*.*</value>
+ <comment>A filename filter for selecting a MapGuide package</comment>
+ </data>
+ <data name="UploadPackageDialogTitle" xml:space="preserve">
+ <value>Select the package to upload</value>
+ <comment>The title for the file browse dialog when uploading a package</comment>
+ </data>
+</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Packaging/ResourceDataItem.cs
--- sandbox/maestro-3.0/Maestro.Packaging/ResourceDataItem.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/ResourceDataItem.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,85 @@
+#region Disclaimer / License
+// Copyright (C) 2009, Kenneth Skovhede
+// http://www.hexad.dk, opensource at hexad.dk
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+ /// <summary>
+ /// Represents a data item on a resource
+ /// </summary>
+ public class ResourceDataItem
+ private string m_resourceName;
+ private string m_contentType;
+ private string m_filename;
+ private string m_dataType;
+ private EntryTypeEnum m_entryType;
+ public ResourceDataItem(string resourceName, string contentType, string filename, string dataType)
+ m_resourceName = resourceName;
+ m_contentType = contentType;
+ m_filename = filename;
+ m_dataType = dataType;
+ m_entryType = EntryTypeEnum.Regular;
+ public ResourceDataItem(ResourceDataItem rdi)
+ m_resourceName = rdi.m_resourceName;
+ m_contentType = rdi.m_contentType;
+ m_filename = rdi.m_filename;
+ m_dataType = rdi.m_dataType;
+ m_entryType = rdi.m_entryType;
+ public string ResourceName
+ get { return m_resourceName; }
+ set { m_resourceName = value; }
+ public string ContentType
+ get { return m_contentType; }
+ set { m_contentType = value; }
+ public string Filename
+ get { return m_filename; }
+ set { m_filename = value; }
+ public EntryTypeEnum EntryType
+ get { return m_entryType; }
+ set { m_entryType = value; }
+ public string DataType
+ get { return m_dataType; }
+ set { m_dataType = value; }
Added: sandbox/maestro-3.0/Maestro.Packaging/ResourceItem.cs
--- sandbox/maestro-3.0/Maestro.Packaging/ResourceItem.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Packaging/ResourceItem.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,106 @@
+#endregion
+using System;
+using System.Text;
+ /// <summary>
+ /// Represents a resource item from a package
+ /// </summary>
+ public class ResourceItem
+ public ResourceItem(string resourcePath, string headerPath, string contentPath)
+ m_originalResourcePath = m_resourcePath = resourcePath;
+ m_headerpath = headerPath;
+ m_contentpath = contentPath;
+ m_items = new List<ResourceDataItem>();
+ m_isFolder = m_originalResourcePath.EndsWith("/");
+ public ResourceItem(ResourceItem ri)
+ m_originalResourcePath = ri.m_originalResourcePath;
+ m_headerpath = ri.m_headerpath;
+ m_contentpath = ri.m_contentpath;
+ m_resourcePath = ri.m_resourcePath;
+ m_entryType = ri.m_entryType;
+ m_isFolder = ri.m_isFolder;
+ foreach (ResourceDataItem rdi in ri.m_items)
+ m_items.Add(new ResourceDataItem(rdi));
+ private string m_originalResourcePath;
+ private string m_headerpath;
+ private string m_contentpath;
+ private string m_resourcePath;
+ private List<ResourceDataItem> m_items;
+ private bool m_isFolder;
+ public bool IsFolder
+ get { return m_isFolder; }
+ set { m_isFolder = true; }
+ public List<ResourceDataItem> Items
+ get { return m_items; }
+ set { m_items = value; }
+ public string OriginalResourcePath
+ get { return m_originalResourcePath; }
+ set { m_originalResourcePath = value; }
+ public string ResourcePath
+ get { return m_resourcePath; }
+ set { m_resourcePath = value; }
+ public string Contentpath
+ get { return m_contentpath; }
+ set { m_contentpath = value; }
+ public string Headerpath
+ get { return m_headerpath; }
+ set { m_headerpath = value; }
Modified: sandbox/maestro-3.0/MaestroAPITests/CapabilityTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/CapabilityTests.cs 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/MaestroAPITests/CapabilityTests.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -161,6 +161,14 @@
break;
+ foreach (ResourceTypes rt in Enum.GetValues(typeof(ResourceTypes)))
+ if (rt != ResourceTypes.ApplicationDefinition && rt != ResourceTypes.SymbolDefinition)
+ Assert.IsTrue(caps.IsSupportedResourceType(rt), rt.ToString());
+ else
+ Assert.IsFalse(caps.IsSupportedResourceType(rt), rt.ToString());
[Test]
@@ -290,6 +298,14 @@
break;
+ else
[Test]
@@ -412,6 +428,14 @@
break;
+ if (rt != ResourceTypes.ApplicationDefinition)
+ else
[Test]
@@ -527,6 +551,11 @@
break;
[Test]
@@ -642,6 +671,11 @@
break;
[Test]
@@ -757,6 +791,11 @@
break;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -51,5 +51,12 @@
get { return false; }
+ public abstract bool IsSupportedResourceType(string resourceType);
+ public bool IsSupportedResourceType(ResourceTypes resType)
+ return IsSupportedResourceType(resType.ToString());
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -51,5 +51,19 @@
/// Indicates whether previewing capabilities are possible with this connection
/// </summary>
bool SupportsResourcePreviews { get; }
+ /// <summary>
+ /// Indicates if this current connection supports the specified resource type
+ /// </summary>
+ /// <param name="resType"></param>
+ bool IsSupportedResourceType(string resType);
+ /// <summary>
+ /// </summary>
+ bool IsSupportedResourceType(ResourceTypes resType);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-09-29 07:53:06 UTC (rev 5208)
@@ -198,6 +198,7 @@
<Compile Include="ObjectModels\PrintLayout.cs" />
<Compile Include="ObjectModels\ResourceItems.cs" />
<Compile Include="ObjectModels\ResourceList.cs" />
+ <Compile Include="ObjectModels\ResourcePackageManifest.cs" />
<Compile Include="ObjectModels\SymbolDefinition.cs" />
<Compile Include="ObjectModels\SymbolLibrary.cs" />
<Compile Include="ObjectModels\UnmanagedDataList.cs" />
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourcePackageManifest.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourcePackageManifest.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ResourcePackageManifest.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -0,0 +1,45 @@
+using System;
+using System.Text;
+namespace OSGeo.MapGuide.ObjectModels.Common
+ partial class ResourcePackageManifestOperationsOperationParameters
+ public string GetParameterValue(string name)
+ if (this.parameterField != null)
+ foreach (var p in this.parameterField)
+ if (p.Name.Equals(name))
+ return p.Value;
+ return null;
+ public void SetParameterValue(string name, string value)
+ if (this.parameterField == null)
+ this.parameterField = new System.ComponentModel.BindingList<ResourcePackageManifestOperationsOperationParametersParameter>();
+ p.Value = value;
+ return;
+ this.parameterField.Add(new ResourcePackageManifestOperationsOperationParametersParameter()
+ Name = name,
+ Value = value
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs 2010-09-29 05:53:44 UTC (rev 5207)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs 2010-09-29 07:53:06 UTC (rev 5208)
@@ -22,10 +22,11 @@
using System.Text;
using OSGeo.MapGuide.MaestroAPI.Exceptions;
+using OSGeo.MapGuide.MaestroAPI.Capability;
namespace OSGeo.MapGuide.MaestroAPI.Http
- internal class HttpCapabilities : IConnectionCapabilities
+ internal class HttpCapabilities : ConnectionCapabilities
private IServerConnection _parent;
@@ -34,7 +35,7 @@
_parent = parent;
- public Version GetMaxSupportedResourceVersion(ResourceTypes resourceType)
+ public override Version GetMaxSupportedResourceVersion(ResourceTypes resourceType)
Version ver = new Version(1, 0, 0);
switch (resourceType)
@@ -109,7 +110,7 @@
return new Version(1, 0, 0);
- public int[] SupportedCommands
+ public override int[] SupportedCommands
get
@@ -121,7 +122,7 @@
- public int[] SupportedServices
+ public override int[] SupportedServices
get
@@ -149,14 +150,30 @@
- public bool SupportsResourcePreviews
+ public override bool SupportsResourcePreviews
get { return true; }
- public bool IsMultithreaded
+ public override bool IsMultithreaded
+ public override bool IsSupportedResourceType(string resourceType)
+ Check.NotEmpty(resourceType, "resourceType");
+ var ver = _parent.SiteVersion;
+ var rt = (ResourceTypes)Enum.Parse(typeof(ResourceTypes), resourceType);
+ switch (rt)
+ case ResourceTypes.ApplicationDefinition: //Introduced in 2.0.0
+ return (ver >= new Version(2, 0));
+ case ResourceTypes.SymbolDefinition: //Introduced in 1.2.0
+ return (ver >= new Version(1, 2));
+ return true;
More information about the mapguide-commits
