[mapguide-commits] r5219 - in sandbox/maestro-3.0/Maestro.Base: .
Commands Commands/Conditions Commands/SiteExplorer Editor
Properties Services UI UI/Preferences
svn_mapguide at osgeo.org
Thu Sep 30 01:23:02 EDT 2010
Author: jng
Date: 2010-09-30 05:23:01 +0000 (Thu, 30 Sep 2010)
New Revision: 5219
Added:
sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/CutCopyConditionEvaluator.cs
sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/PasteConditionEvaluator.cs
sandbox/maestro-3.0/Maestro.Base/Services/ClipboardService.cs
sandbox/maestro-3.0/Maestro.Base/Commands/CopyCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/CutCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/PasteCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/OpenResourceCommand.cs
sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs
sandbox/maestro-3.0/Maestro.Base/UI/Preferences/ConfigProperties.cs
sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
More 3.0 sandbox changes:
- Implement cut/copy/paste functionality
- Forward-port site explorer features from 2.x stream
- Highlight open resources
- Highlight open resources w/ dirty state
Added: sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/CutCopyConditionEvaluator.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/CutCopyConditionEvaluator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/CutCopyConditionEvaluator.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -0,0 +1,43 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+namespace Maestro.Base.Commands.Conditions
+ internal class CutCopyConditionEvaluator : IConditionEvaluator
+ public bool IsValid(object caller, Condition condition)
+ var wb = Workbench.Instance;
+ if (wb != null)
+ var exp = wb.ActiveSiteExplorer;
+ if (exp != null)
+ return exp.SelectedItems.Length > 0;
+ return false;
Added: sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/PasteConditionEvaluator.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/PasteConditionEvaluator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/Conditions/PasteConditionEvaluator.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -0,0 +1,36 @@
+#endregion
+using System;
+using System.Text;
+using Maestro.Base.Services;
+ internal class PasteConditionEvaluator : IConditionEvaluator
+ var svc = ServiceRegistry.GetService<ClipboardService>();
+ return svc.HasContent();
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/CopyCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/CopyCommand.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/CopyCommand.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -20,10 +20,76 @@
using System;
using System.Text;
+using Maestro.Base.UI;
- internal class CopyCommand : NotImplementedCommand
+ internal class CopyCommand : ClipboardCommand
+ public override void Run()
+ var clip = ServiceRegistry.GetService<ClipboardService>();
+ var omgr = ServiceRegistry.GetService<OpenResourceManager>();
+ ResetClipboardedItems(clip, omgr);
+ if (exp.SelectedItems.Length > 0)
+ var items = new List<RepositoryItem>();
+ foreach (var item in exp.SelectedItems)
+ item.ClipboardState = RepositoryItem.ClipboardAction.Copy;
+ items.Add(item);
+ clip.Put(items.ToArray());
+ LoggingService.InfoFormatted(Properties.Resources.ItemsCopied, items.Count);
+ internal abstract class ClipboardCommand : AbstractMenuCommand
+ protected static void ResetClipboardedItems(ClipboardService clip, OpenResourceManager omgr)
+ //Reset state of clipboarded items
+ if (clip.HasContent())
+ object o = clip.Get();
+ var r = o as RepositoryItem;
+ var rs = o as RepositoryItem[];
+ if (r != null)
+ ResetItem(omgr, r);
+ else if (rs != null)
+ ResetItems(omgr, rs);
+ protected static void ResetItems(OpenResourceManager omgr, IEnumerable<RepositoryItem> rs)
+ foreach (var ri in rs)
+ ResetItem(omgr, ri);
+ protected static void ResetItem(OpenResourceManager omgr, RepositoryItem ri)
+ ri.Reset();
+ if (omgr.IsOpen(ri.ResourceId))
+ ri.IsOpen = true;
+ var ed = omgr.GetOpenEditor(ri.ResourceId);
+ if (ed.IsDirty)
+ ri.IsDirty = true;
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/CutCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/CutCommand.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/CutCommand.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -20,10 +20,70 @@
using System;
using System.Text;
- internal class CutCommand : NotImplementedCommand
+ internal class CutCommand : ClipboardCommand
+ item.ClipboardState = RepositoryItem.ClipboardAction.Cut;
+ items.Add(item);
+ LoggingService.InfoFormatted(Properties.Resources.ItemsCut, items.Count);
+ private static void ResetClipboardedItems(ClipboardService clip, OpenResourceManager omgr)
+ if (r != null)
+ r.Reset();
+ if (omgr.IsOpen(r.ResourceId))
+ r.IsOpen = true;
+ var ed = omgr.GetOpenEditor(r.ResourceId);
+ if (ed.IsDirty)
+ r.IsDirty = true;
+ ri.Reset();
+ ri.IsOpen = true;
+ if (ed.IsDirty)
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/PasteCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/PasteCommand.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/PasteCommand.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -20,10 +20,97 @@
using System;
using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using Maestro.Shared.UI;
- internal class PasteCommand : NotImplementedCommand
+ internal class PasteCommand : ClipboardCommand
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ if (!clip.HasContent())
+ return;
+ if (exp.SelectedItems.Length != 1)
+ return;
+ if (!exp.SelectedItems[0].IsFolder)
+ return;
+ var itemsToPaste = GetItems(clip);
+ if (itemsToPaste.Length == 0)
+ return;
+ var folder = exp.SelectedItems[0];
+ //.net FX 2.0 hack to compensate for lack of set collection
+ Dictionary<string, string> folders = new Dictionary<string, string>();
+ foreach (var item in itemsToPaste)
+ LoggingService.InfoFormatted("{0} item {1} into {2}", item.ClipboardState, item.ResourceId, folder.ResourceId); //LOCALIZEME
+ //Keep testing until we find a target resource identifier that
+ //doesn't already exists
+ var name = ResourceIdentifier.GetName(item.ResourceId) + "." + ResourceIdentifier.GetResourceType(item.ResourceId).ToString();
+ var resId = folder.ResourceId + name;
+ int counter = 0;
+ while (conn.ResourceService.ResourceExists(resId))
+ counter++;
+ var rname = name.Substring(0, name.IndexOf("."));
+ var type = name.Substring(name.IndexOf("."));
+ rname += " (" + counter + ")";
+ resId = folder.ResourceId + rname + type;
+ if (item.ClipboardState == RepositoryItem.ClipboardAction.Copy)
+ conn.ResourceService.CopyResource(item.ResourceId, resId, false);
+ else if (item.ClipboardState == RepositoryItem.ClipboardAction.Cut)
+ //TODO: Should we prompt? That may be equivalent to saying
+ //"Shall I break your resources because you're moving" isn't it?
+ var res = conn.ResourceService.MoveResourceWithReferences(item.ResourceId, resId, null, null);
+ if (!res)
+ LoggingService.InfoFormatted("Failed to move {0} to {1}", item.ResourceId, resId); //LOCALIZEME
+ else
+ folders[item.Parent.ResourceId] = item.Parent.ResourceId;
+ ResetItems(omgr, itemsToPaste);
+ exp.RefreshModel(folder.ResourceId);
+ foreach (var f in folders.Keys)
+ exp.RefreshModel(f);
+ private static RepositoryItem[] GetItems(ClipboardService clip)
+ if (o == null)
+ return new RepositoryItem[0];
+ else if (o is RepositoryItem[])
+ return (RepositoryItem[])o;
+ else if (o is RepositoryItem)
+ return new RepositoryItem[] { (RepositoryItem)o };
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/OpenResourceCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/OpenResourceCommand.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/OpenResourceCommand.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -39,19 +39,21 @@
_conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
- if (items.Length == 1)
+ if (items.Length > 0)
- var item = items[0];
- if (!item.IsFolder)
+ foreach (var item in items)
- if (openMgr.IsOpen(item.ResourceId))
+ if (!item.IsFolder)
- openMgr.GetOpenEditor(item.ResourceId).Activate();
+ if (openMgr.IsOpen(item.ResourceId))
+ openMgr.GetOpenEditor(item.ResourceId).Activate();
+ else
+ openMgr.Open(item.ResourceId, _conn, false, exp);
- else
- openMgr.Open(item.ResourceId, _conn, false, exp);
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -98,10 +98,20 @@
+ public event EventHandler DirtyStateChanged;
+ private bool _dirty;
public bool IsDirty
- get;
- private set;
+ get { return _dirty; }
+ set
+ _dirty = value;
+ var handler = this.DirtyStateChanged;
+ if (handler != null)
+ handler(this, EventArgs.Empty);
public virtual bool CanProfile
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -76,5 +76,10 @@
/// <param name="mapguideRootUrl"></param>
/// <returns></returns>
string SetupPreviewUrl(string mapguideRootUrl);
+ /// <summary>
+ /// Raised when the value of <see cref="IsDirty"/> changes
+ /// </summary>
+ event EventHandler DirtyStateChanged;
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-09-30 05:23:01 UTC (rev 5219)
@@ -17,6 +17,8 @@
<ConditionEvaluator name="EditorFunction" class="Maestro.Base.Commands.Conditions.ActiveEditorConditionEvaluator" />
<ConditionEvaluator name="CanClose" class="Maestro.Base.Commands.Conditions.CloseableDocumentConditionEvaluator" />
<ConditionEvaluator name="SelectedItem" class="Maestro.Base.Commands.Conditions.SelectedItemConditionEvaluator" />
+ <ConditionEvaluator name="CanPaste" class="Maestro.Base.Commands.Conditions.PasteConditionEvaluator" />
+ <ConditionEvaluator name="CanCutOrCopy" class="Maestro.Base.Commands.Conditions.CutCopyConditionEvaluator" />
<ConditionEvaluator name="MultipleSelected" class="Maestro.Base.Commands.Conditions.MultipleSelectedItemConditionEvaluator" />
</Import>
</Runtime>
@@ -150,6 +152,7 @@
<!-- Application-level services -->
<Path name="/Maestro/ApplicationServices">
+ <Class id="ClipboardService" class="Maestro.Base.Services.ClipboardService" />
<Class id="ServerConnectionManager" class="Maestro.Base.Services.ServerConnectionManager" />
<Class id="UrlLauncher" class="Maestro.Base.Services.UrlLauncherService" />
<Class id="OpenResourceManager" class="Maestro.Base.Services.OpenResourceManager" />
@@ -180,18 +183,22 @@
tooltip="${res:Menu_File_NewResource}"
class="Maestro.Base.Commands.NewItemCommand" />
<ToolbarItem type="Separator" />
- <ToolbarItem id="CopyItem"
- icon="document_copy"
- tooltip="${res:Menu_Edit_Copy}"
- class="Maestro.Base.Commands.NotImplementedCommand" />
- <ToolbarItem id="CutItem"
- icon="scissors_blue"
- tooltip="${res:Menu_Edit_Cut}"
- <ToolbarItem id="PasteItem"
- icon="clipboard_paste"
- tooltip="${res:Menu_Edit_Paste}"
+ <Condition action="Disable" name="CanCutOrCopy">
+ <ToolbarItem id="CopyItem"
+ icon="document_copy"
+ tooltip="${res:Menu_Edit_Copy}"
+ class="Maestro.Base.Commands.CopyCommand" />
+ <ToolbarItem id="CutItem"
+ icon="scissors_blue"
+ tooltip="${res:Menu_Edit_Cut}"
+ class="Maestro.Base.Commands.CutCommand" />
+ </Condition>
+ <Condition action="Disable" name="CanPaste">
+ <ToolbarItem id="PasteItem"
+ icon="clipboard_paste"
+ tooltip="${res:Menu_Edit_Paste}"
+ class="Maestro.Base.Commands.PasteCommand" />
+ </Condition>
</Condition>
<Condition action="Disable" name="EditorFunction">
@@ -291,16 +298,20 @@
class="Maestro.Base.Commands.CreatePackageCommand" />
<MenuItem type="Separator" />
<Condition action="Disable" name="IsNotRoot">
- <MenuItem id="Copy"
- label="${res:SiteExplorer_SelectedItem_Copy}"
- <MenuItem id="Cut"
- label="${res:SiteExplorer_SelectedItem_Cut}"
+ <MenuItem id="Copy"
+ label="${res:SiteExplorer_SelectedItem_Copy}"
+ <MenuItem id="Cut"
+ label="${res:SiteExplorer_SelectedItem_Cut}"
+ </Condition>
</Condition>
- <MenuItem id="Paste"
- label="${res:SiteExplorer_SelectedFolder_Paste}"
+ <MenuItem id="Paste"
+ label="${res:SiteExplorer_SelectedFolder_Paste}"
+ </Condition>
<MenuItem id="Delete"
@@ -316,12 +327,14 @@
<!-- Site Explorer Context Menu -->
<Path name="/Maestro/Shell/SiteExplorer/SelectedFolders">
<Condition action="Disable" name="MultipleSelected">
+ </Condition>
<MenuItem id="Validate"
label="${res:SiteExplorer_ValidateResources}"
class="Maestro.Base.Commands.SiteExplorer.ValidateCommand" />
@@ -348,12 +361,14 @@
label="${res:SiteExplorer_SelectedItem_Delete}"
class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
+ </Condition>
@@ -370,17 +385,19 @@
<MenuItem id="Open"
label="${res:SiteExplorer_SelectedItem_Open}"
+ class="Maestro.Base.Commands.SiteExplorer.OpenResourceCommand" />
+ class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
+ </Condition>
@@ -392,17 +409,19 @@
<MenuItem id="Open"
- class="Maestro.Base.Commands.NotImplementedCommand" />s
+ class="Maestro.Base.SiteExplorer.OpenResourceCommand" />
+ class="Maestro.Base.SiteExplorer.DeleteSelectedItemsCommand" />
+ </Condition>
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-09-30 05:23:01 UTC (rev 5219)
@@ -43,10 +43,12 @@
<Compile Include="Commands\CloseActiveDocumentCommand.cs" />
<Compile Include="Commands\Conditions\ActiveEditorConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\CloseableDocumentConditionEvaluator.cs" />
+ <Compile Include="Commands\Conditions\CutCopyConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\IsConnectedConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\MultipleSelectedItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\NotConnectedConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\DebugModeConditionEvaluator.cs" />
+ <Compile Include="Commands\Conditions\PasteConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedRootItemConditionEvaluator.cs" />
<Compile Include="Commands\CopyCommand.cs" />
@@ -153,6 +155,7 @@
<DesignTime>True</DesignTime>
<DependentUpon>Resources.resx</DependentUpon>
</Compile>
+ <Compile Include="Services\ClipboardService.cs" />
<Compile Include="Services\NewItemTemplateService.cs" />
<Compile Include="Services\OpenResourceManager.cs" />
<Compile Include="Services\ServerConnectionManager.cs" />
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -506,6 +506,24 @@
+ /// <summary>
+ /// Looks up a localized string similar to {0} items copied and placed in clipboard.
+ /// </summary>
+ internal static string ItemsCopied {
+ get {
+ return ResourceManager.GetString("ItemsCopied", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} items cut and placed in clipboard.
+ /// </summary>
+ internal static string ItemsCut {
+ get {
+ return ResourceManager.GetString("ItemsCut", resourceCulture);
internal static System.Drawing.Bitmap layer {
get {
object obj = ResourceManager.GetObject("layer", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-09-30 05:23:01 UTC (rev 5219)
@@ -664,4 +664,10 @@
<data name="PrefsRestartRequired" xml:space="preserve">
<value>A restart is required for some changes to take effect</value>
</data>
+ <data name="ItemsCopied" xml:space="preserve">
+ <value>{0} items copied and placed in clipboard</value>
+ </data>
+ <data name="ItemsCut" xml:space="preserve">
+ <value>{0} items cut and placed in clipboard</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Base/Services/ClipboardService.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/ClipboardService.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/ClipboardService.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -0,0 +1,108 @@
+#endregion
+using System;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI;
+namespace Maestro.Base.Services
+ /// <summary>
+ /// Clipboard service. This simulates the behaviour of a clipboard, it does
+ /// not actually put and retrieve data from the system clipboard.
+ /// </summary>
+ public class ClipboardService : ServiceBase
+ public override void Initialize()
+ base.Initialize();
+ private object _item;
+ public bool HasContent()
+ lock (_clipLock)
+ return _item != null;
+ public void Put(object item)
+ Check.NotNull(item, "item");
+ lock (_clipLock)
+ _item = item;
+ public object Get()
+ if (!HasContent())
+ return null;
+ lock (_clipLock)
+ return _item;
+ private readonly object _clipLock = new object();
+ internal RepositoryItem.ClipboardAction GetClipboardState(string resId)
+ Check.NotEmpty(resId, "resId");
+ var state = RepositoryItem.ClipboardAction.None;
+ object o = null;
+ lock (_clipLock)
+ o = _item;
+ if (o == null)
+ state = RepositoryItem.ClipboardAction.None;
+ foreach (RepositoryItem r in (RepositoryItem[])o)
+ if (resId.Equals(r.ResourceId))
+ state = r.ClipboardState;
+ break;
+ var r = ((RepositoryItem)o);
+ return state;
Modified: sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -102,9 +102,15 @@
ed.ViewContentClosing += (sender, e) =>
_openItems.Remove(resourceId);
+ siteExp.FlagNode(resourceId, NodeFlagAction.None);
+ ed.DirtyStateChanged += (sender, e) =>
+ siteExp.FlagNode(resourceId, ed.IsDirty ? NodeFlagAction.HighlightDirty : NodeFlagAction.HighlightOpen);
_openItems[resourceId].Activate();
+ siteExp.FlagNode(resourceId, NodeFlagAction.HighlightOpen);
/// <summary>
Modified: sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -54,8 +54,40 @@
void SelectNode(string resourceId);
/// <summary>
+ /// Flags the node indicated by the specified action
+ /// </summary>
+ /// <param name="resourceId"></param>
+ /// <param name="action"></param>
+ void FlagNode(string resourceId, NodeFlagAction action);
+ /// <summary>
/// Gets the items currently selected
/// </summary>
RepositoryItem[] SelectedItems { get; }
+ public enum NodeFlagAction
+ /// <summary>
+ /// Indicate that the node has been cut and placed on the clipboard
+ /// </summary>
+ IndicateCut,
+ /// <summary>
+ /// Indicate that the node has been copied and placed on the clipboard
+ /// </summary>
+ IndicateCopy,*/
+ /// <summary>
+ /// Highlight the affected node with a pre-defined back color to indicate open
+ /// </summary>
+ HighlightOpen,
+ /// <summary>
+ /// Highlight the affected node with a pre-defined back color to indicate dirty state
+ /// </summary>
+ HighlightDirty,
+ /// <summary>
+ /// Reset node to default styles
+ /// </summary>
+ None
Modified: sandbox/maestro-3.0/Maestro.Base/UI/Preferences/ConfigProperties.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/Preferences/ConfigProperties.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/UI/Preferences/ConfigProperties.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -23,6 +23,7 @@
using Props = ICSharpCode.Core.PropertyService;
using System.IO;
+using System.Drawing;
namespace Maestro.Base.UI.Preferences
@@ -32,6 +33,8 @@
public const string UserTemplatesDirectory = "General.UserTemplatesDirectory";
public const string ShowMessages = "General.ShowMessages";
public const string ShowOutboundRequests = "General.ShowOutboundRequests";
+ public const string OpenColor = "General.OpenColor";
+ public const string DirtyColor = "General.DirtyColor";
internal static void ApplyDefaults()
@@ -39,6 +42,8 @@
Props.Set(ConfigProperties.UserTemplatesDirectory, Path.Combine(FileUtility.ApplicationRootPath, "UserTemplates"));
Props.Set(ConfigProperties.ShowMessages, true);
Props.Set(ConfigProperties.ShowOutboundRequests, false);
+ Props.Set(ConfigProperties.OpenColor, Color.LightGreen);
+ Props.Set(ConfigProperties.DirtyColor, Color.Pink);
Modified: sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -27,6 +27,7 @@
using System.Diagnostics;
using System.Collections.ObjectModel;
@@ -297,6 +298,59 @@
_children.Clear();
+ private bool _open = false;
+ private bool _dirty = false;
+ private bool _clipboarded = false;
+ internal bool IsOpen
+ get { return _open; }
+ set
+ _open = value;
+ _dirty = !value;
+ this.NotifyNodesChanged();
+ internal bool IsDirty
+ set
+ _dirty = value;
+ _open = !value;
+ public enum ClipboardAction
+ Copy,
+ Cut,
+ None
+ private ClipboardAction _action = ClipboardAction.None;
+ public ClipboardAction ClipboardState
+ get { return _action; }
+ set
+ _action = value;
+ internal void Reset()
+ _action = ClipboardAction.None;
+ _dirty = false;
+ _open = false;
public class RepositoryItemToolTipProvider : IToolTipProvider
@@ -323,12 +377,16 @@
private string _connectionName;
private IServerConnection _conn;
+ private OpenResourceManager _openResMgr;
+ private ClipboardService _clip;
- public RepositoryTreeModel(IServerConnection conn, TreeViewAdv tree, string connName)
+ public RepositoryTreeModel(IServerConnection conn, TreeViewAdv tree, string connName, OpenResourceManager openResMgr, ClipboardService clip)
_conn = conn;
_tree = tree;
_connectionName = connName;
+ _openResMgr = openResMgr;
+ _clip = clip;
private System.Collections.IEnumerable GetSorted(ResourceList list)
@@ -355,6 +413,22 @@
+ /// <summary>
+ /// Restores node ui state from before refresh
+ /// </summary>
+ /// <param name="item"></param>
+ private void ApplyCurrentItemState(RepositoryItem item)
+ if (_openResMgr.IsOpen(item.ResourceId))
+ item.IsOpen = true;
+ var ed = _openResMgr.GetOpenEditor(item.ResourceId);
+ if (ed.IsDirty)
+ item.IsDirty = true;
+ item.ClipboardState = _clip.GetClipboardState(item.ResourceId);
public override System.Collections.IEnumerable GetChildren(TreePath treePath)
if (treePath.IsEmpty())
@@ -379,6 +453,7 @@
foreach (RepositoryItem item in GetSorted(list))
node.AddChildWithoutNotification(item);
+ ApplyCurrentItemState(item);
yield return item;
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs 2010-09-30 02:30:40 UTC (rev 5218)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs 2010-09-30 05:23:01 UTC (rev 5219)
@@ -29,6 +29,8 @@
+using Maestro.Base.UI.Preferences;
@@ -44,6 +46,7 @@
InitializeComponent();
Application.Idle += new EventHandler(OnIdle);
ndResource.ToolTipProvider = new RepositoryItemToolTipProvider();
+ ndResource.DrawText += new EventHandler<Aga.Controls.Tree.NodeControls.DrawEventArgs>(OnNodeDrawText);
void OnIdle(object sender, EventArgs e)
@@ -79,7 +82,9 @@
var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
_conn = mgr.GetConnection(this.ConnectionName);
- _model = new RepositoryTreeModel(_conn, trvResources, this.ConnectionName);
+ _model = new RepositoryTreeModel(_conn, trvResources, this.ConnectionName, omgr, clip);
trvResources.Model = _model;
@@ -256,5 +261,55 @@
+ public void FlagNode(string resourceId, NodeFlagAction action)
+ var path = _model.GetPathFromResourceId(resourceId);
+ if (path != null)
+ var node = trvResources.FindNode(path, true);
+ if (node != null)
+ var item = (RepositoryItem)node.Tag;
+ switch (action)
+ //case NodeFlagAction.IndicateCopy:
+ //case NodeFlagAction.IndicateCut:
+ // item.IsClipboarded = true;
+ // break;
+ case NodeFlagAction.HighlightDirty:
+ break;
+ case NodeFlagAction.HighlightOpen:
+ break;
+ case NodeFlagAction.None:
+ item.Reset();
+ break;
+ void OnNodeDrawText(object sender, Aga.Controls.Tree.NodeControls.DrawEventArgs e)
+ if (e.Node.Tag == null)
+ return;
+ var ocolor = PropertyService.Get(ConfigProperties.OpenColor, Color.LightGreen);
+ var dcolor = PropertyService.Get(ConfigProperties.DirtyColor, Color.Pink);
+ var item = (RepositoryItem)e.Node.Tag;
+ var ctx = e.Context;
+ if (item.ClipboardState != RepositoryItem.ClipboardAction.None)
+ var oldFont = e.Font;
+ e.Font = new Font(oldFont.FontFamily, oldFont.Size, oldFont.Style | FontStyle.Italic);
+ if (item.IsDirty)
+ e.BackgroundBrush = new SolidBrush(dcolor);
+ else if (item.IsOpen)
+ e.BackgroundBrush = new SolidBrush(ocolor);
More information about the mapguide-commits
