[mapguide-commits] r5223 - in sandbox/maestro-3.0/Maestro.Base: .
Commands
svn_mapguide at osgeo.org
Thu Sep 30 06:52:47 EDT 2010
Author: jng
Date: 2010-09-30 10:52:47 +0000 (Thu, 30 Sep 2010)
New Revision: 5223
sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
More 3.0 sandbox changes
- Update repository tree model when newly created resource is saved
- Fix bad context menu entries
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs 2010-09-30 10:49:59 UTC (rev 5222)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs 2010-09-30 10:52:47 UTC (rev 5223)
@@ -25,6 +25,7 @@
using Maestro.Shared.UI;
using Maestro.Editors.Generic;
using Maestro.Base.Services;
+using OSGeo.MapGuide.MaestroAPI.Resource;
namespace Maestro.Base.Commands
@@ -47,6 +48,9 @@
using (new WaitCursor(wb))
ed.EditorService.SaveAs(picker.ResourceID);
+ var rid = new ResourceIdentifier(picker.ResourceID);
+ exp.RefreshModel(rid.ParentFolder);
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-09-30 10:49:59 UTC (rev 5222)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-09-30 10:52:47 UTC (rev 5223)
@@ -415,10 +415,10 @@
<Condition action="Disable" name="MultipleSelected">
<MenuItem id="Open"
label="${res:SiteExplorer_SelectedItem_Open}"
- class="Maestro.Base.SiteExplorer.OpenResourceCommand" />
+ class="Maestro.Base.Commands.SiteExplorer.OpenResourceCommand" />
<MenuItem id="Delete"
label="${res:SiteExplorer_SelectedItem_Delete}"
- class="Maestro.Base.SiteExplorer.DeleteSelectedItemsCommand" />
+ class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
<MenuItem type="Separator" />
<Condition action="Disable" name="CanCutOrCopy">
<MenuItem id="Copy"
More information about the mapguide-commits
