[mapguide-commits] r5670 - in trunk/Tools/Maestro/Maestro.Base: .
Commands/Conditions Commands/SiteExplorer Properties Resources
svn_mapguide at osgeo.org
Mon Apr 4 07:40:45 EDT 2011
Author: jng
Date: 2011-04-04 04:40:45 -0700 (Mon, 04 Apr 2011)
New Revision: 5670
Added:
trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/ResourceTypeConditionEvaluator.cs
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/PurgeFeatureSourceCacheCommand.cs
trunk/Tools/Maestro/Maestro.Base/Resources/arrow-circle-double.png
trunk/Tools/Maestro/Maestro.Base/Resources/system-monitor.png
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
#1648: Implement a flush feature source cache command. This command only applies to Feature Sources and Layer Definitions
Added: trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/ResourceTypeConditionEvaluator.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/ResourceTypeConditionEvaluator.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/ResourceTypeConditionEvaluator.cs 2011-04-04 11:40:45 UTC (rev 5670)
@@ -0,0 +1,55 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+namespace Maestro.Base.Commands.Conditions
+ internal class ResourceTypeConditionEvaluator : IConditionEvaluator
+ public bool IsValid(object caller, Condition condition)
+ var types = condition.Properties["types"];
+ if (types != null)
+ var wb = Workbench.Instance;
+ if (wb != null)
+ if (wb.ActiveSiteExplorer != null)
+ var resTypes = new List<string>(types.Split(','));
+ if (resTypes.Count > 0)
+ var items = wb.ActiveSiteExplorer.SelectedItems;
+ foreach (var it in items)
+ if (resTypes.Contains(it.ResourceType))
+ return true;
+ return false;
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/PurgeFeatureSourceCacheCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/PurgeFeatureSourceCacheCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/PurgeFeatureSourceCacheCommand.cs 2011-04-04 11:40:45 UTC (rev 5670)
@@ -0,0 +1,70 @@
+#endregion
+using System;
+using System.Text;
+using Maestro.Base.Services;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class PurgeFeatureSourceCacheCommand : AbstractMenuCommand
+ public override void Run()
+ if (wb != null)
+ if (items.Length == 1)
+ var it = items[0];
+ if (it.ResourceType == "FeatureSource" || it.ResourceType == "LayerDefinition")
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+ var resId = it.ResourceId;
+ if (it.ResourceType == "LayerDefinition")
+ var res = (ILayerDefinition)conn.ResourceService.GetResource(resId);
+ resId = res.SubLayer.ResourceId;
+ //If selected item is a Layer, it must be pointing to a Feature Source and not a Drawing Source
+ if (resId.EndsWith("FeatureSource"))
+ using (var st = conn.ResourceService.GetResourceXmlData(resId))
+ //"Touching" the feature source is sufficient to invalidate any cached information about it
+ conn.ResourceService.SetResourceXmlData(resId, st);
+ MessageService.ShowMessage(string.Format(Properties.Resources.SchemaInformationPurged, resId));
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-03-31 11:19:12 UTC (rev 5669)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-04-04 11:40:45 UTC (rev 5670)
@@ -21,6 +21,7 @@
<ConditionEvaluator name="CanCutOrCopy" class="Maestro.Base.Commands.Conditions.CutCopyConditionEvaluator" />
<ConditionEvaluator name="MultipleSelected" class="Maestro.Base.Commands.Conditions.MultipleSelectedItemConditionEvaluator" />
<ConditionEvaluator name="HasDocuments" class="Maestro.Base.Commands.Conditions.NonZeroDocumentConditionEvaluator" />
+ <ConditionEvaluator name="ResourceType" class="Maestro.Base.Commands.Conditions.ResourceTypeConditionEvaluator" />
</Import>
</Runtime>
@@ -194,6 +195,7 @@
class="Maestro.Base.Commands.LocalFeatureSourcePreviewCommand"/>
<MenuItem id="ServerMonitor"
label="${res:ServerMonitor}"
+ icon="system_monitor"
class="Maestro.Base.Commands.ServerMonitorCommand"/>
<MenuItem id="CacheView"
label="${res:CacheView}"
@@ -491,6 +493,13 @@
label="${res:SiteExplorer_SelectedItem_Delete}"
class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
<MenuItem type="Separator" />
+ <Condition action="Disable" name="ResourceType" types="FeatureSource,LayerDefinition">
+ <MenuItem id="PurgeFsCache"
+ label="${res:SiteExplorer_PurgeFsCache}"
+ icon="arrow_circle_double"
+ class="Maestro.Base.Commands.SiteExplorer.PurgeFeatureSourceCacheCommand" />
+ </Condition>
+ <MenuItem type="Separator" />
<Condition action="Disable" name="CanCutOrCopy">
<MenuItem id="Copy"
icon="document_copy"
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-03-31 11:19:12 UTC (rev 5669)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-04-04 11:40:45 UTC (rev 5670)
@@ -78,6 +78,7 @@
<Compile Include="Commands\Conditions\NotConnectedConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\DebugModeConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\PasteConditionEvaluator.cs" />
+ <Compile Include="Commands\Conditions\ResourceTypeConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\SelectedRootItemConditionEvaluator.cs" />
<Compile Include="Commands\Conditions\NonZeroDocumentConditionEvaluator.cs" />
@@ -100,6 +101,7 @@
<Compile Include="Commands\SaveAllCommand.cs" />
<Compile Include="Commands\SaveResourceAsCommand.cs" />
<Compile Include="Commands\SaveResourceCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\PurgeFeatureSourceCacheCommand.cs" />
<Compile Include="Commands\SiteExplorer\SaveResourceContentToDiskCommand.cs" />
<Compile Include="Commands\ServerMonitorCommand.cs" />
<Compile Include="Commands\SiteAdministratorCommand.cs" />
@@ -361,6 +363,8 @@
</ItemGroup>
<ItemGroup>
<Content Include="Maestro.Base.addin" />
+ <None Include="Resources\arrow-circle-double.png" />
+ <None Include="Resources\system-monitor.png" />
<None Include="Resources\server--arrow.png" />
<None Include="Resources\document--arrow.png" />
<None Include="Resources\disks.png" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-03-31 11:19:12 UTC (rev 5669)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-04-04 11:40:45 UTC (rev 5670)
@@ -136,6 +136,13 @@
+ internal static System.Drawing.Bitmap arrow_circle_double {
+ get {
+ object obj = ResourceManager.GetObject("arrow_circle_double", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
internal static System.Drawing.Bitmap blueprints {
get {
object obj = ResourceManager.GetObject("blueprints", resourceCulture);
@@ -1457,6 +1464,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Schema information for {0} purged.
+ /// </summary>
+ internal static string SchemaInformationPurged {
+ get {
+ return ResourceManager.GetString("SchemaInformationPurged", resourceCulture);
internal static System.Drawing.Bitmap scissors_blue {
get {
object obj = ResourceManager.GetObject("scissors_blue", resourceCulture);
@@ -1623,6 +1639,15 @@
/// <summary>
+ /// Looks up a localized string similar to Purge Cached Schema Information.
+ /// </summary>
+ internal static string SiteExplorer_PurgeFsCache {
+ get {
+ return ResourceManager.GetString("SiteExplorer_PurgeFsCache", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Refresh.
/// </summary>
internal static string SiteExplorer_Refresh {
@@ -1748,6 +1773,13 @@
+ internal static System.Drawing.Bitmap system_monitor {
+ get {
+ object obj = ResourceManager.GetObject("system_monitor", resourceCulture);
/// <summary>
/// Looks up a localized string similar to Close this tab.
/// </summary>
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-03-31 11:19:12 UTC (rev 5669)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-04-04 11:40:45 UTC (rev 5670)
@@ -889,4 +889,16 @@
<data name="server__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\server--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="arrow_circle_double" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\arrow-circle-double.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="SiteExplorer_PurgeFsCache" xml:space="preserve">
+ <value>Purge Cached Schema Information</value>
+ </data>
+ <data name="system_monitor" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\system-monitor.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="SchemaInformationPurged" xml:space="preserve">
+ <value>Schema information for {0} purged</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/Resources/arrow-circle-double.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/arrow-circle-double.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Tools/Maestro/Maestro.Base/Resources/system-monitor.png
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/system-monitor.png
More information about the mapguide-commits
