[mapguide-commits] r5678 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org
Tue Apr 5 07:38:05 EDT 2011
Author: jng
Date: 2011-04-05 04:38:05 -0700 (Tue, 05 Apr 2011)
New Revision: 5678
trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
Bind F2 to rename command in the Site Explorer. This only applies when one item is selected. Multiple selected items will do nothing
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-04-04 15:36:31 UTC (rev 5677)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-04-05 11:38:05 UTC (rev 5678)
@@ -495,6 +495,10 @@
new DeleteSelectedItemsCommand().Run();
+ else if (e.KeyCode == Keys.F2)
+ new RenameCommand().Run();
private void trvResources_KeyDown(object sender, KeyEventArgs e)
More information about the mapguide-commits
