[mapguide-commits] r5685 - in trunk/Tools/Maestro:
Maestro.AddIn.ExtendedObjectModels/Templates
Maestro.Base/Commands Maestro.Base/Templates Maestro.Editors/Common
svn_mapguide at osgeo.org
Wed Apr 6 10:35:13 EDT 2011
Author: jng
Date: 2011-04-06 07:35:13 -0700 (Wed, 06 Apr 2011)
New Revision: 5685
trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SQLiteLoadProcedureItemTemplate.cs
trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SymbolDefinition110ItemTemplate.cs
trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer110ItemTemplate.cs
trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer120ItemTemplate.cs
trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer130ItemTemplate.cs
trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WebLayout110ItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Commands/NewItemCommand.cs
trunk/Tools/Maestro/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/DrawingLayerDefinitionItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/DrawingSourceItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/DwfLoadProcedureItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/FeatureSourceItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/MapDefinitionItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/PrintLayoutItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/VectorLayerDefinitionItemTemplate.cs
trunk/Tools/Maestro/Maestro.Base/Templates/WebLayoutItemTemplate.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs
Make any resource picking from the New Resource command much easier. Use the selected folder where the command was invoked from (if applicable) to be the starting point for the Resource Picker.
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SQLiteLoadProcedureItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SQLiteLoadProcedureItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SQLiteLoadProcedureItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -51,7 +51,7 @@
- public override IResource CreateItem(IServerConnection conn)
+ public override IResource CreateItem(string startPoint, IServerConnection conn)
using (var dlg = DialogFactory.OpenFile())
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SymbolDefinition110ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SymbolDefinition110ItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/SymbolDefinition110ItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -48,7 +48,7 @@
return ObjectFactory.CreateSimpleSymbol(conn, new Version(1, 1, 0), Res.DefaultSymbolName, Res.DefaultSymbolDescription);
@@ -73,7 +73,7 @@
return ObjectFactory.CreateCompoundSymbol(conn, new Version(1, 1, 0), Res.DefaultSymbolName, Res.DefaultSymbolDescription);
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer110ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer110ItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer110ItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -48,10 +48,11 @@
- public override OSGeo.MapGuide.MaestroAPI.Resource.IResource CreateItem(OSGeo.MapGuide.MaestroAPI.IServerConnection conn)
+ public override OSGeo.MapGuide.MaestroAPI.Resource.IResource CreateItem(string startPoint, OSGeo.MapGuide.MaestroAPI.IServerConnection conn)
using (var picker = new ResourcePicker(conn.ResourceService, ResourceTypes.FeatureSource, ResourcePickerMode.OpenResource))
+ picker.SetStartingPoint(startPoint);
if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
var lyr = ObjectFactory.CreateDefaultLayer(conn, OSGeo.MapGuide.ObjectModels.LayerDefinition.LayerType.Vector, new Version(1, 1, 0));
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer120ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer120ItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer120ItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -48,10 +48,11 @@
var lyr = ObjectFactory.CreateDefaultLayer(conn, OSGeo.MapGuide.ObjectModels.LayerDefinition.LayerType.Vector, new Version(1, 2, 0));
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer130ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer130ItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/VectorLayer130ItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -48,10 +48,11 @@
var lyr = ObjectFactory.CreateDefaultLayer(conn, OSGeo.MapGuide.ObjectModels.LayerDefinition.LayerType.Vector, new Version(1, 3, 0));
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WebLayout110ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WebLayout110ItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WebLayout110ItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -50,7 +50,7 @@
return ObjectFactory.CreateWebLayout(conn, new Version(1, 1, 0), string.Empty);
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/NewItemCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/NewItemCommand.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/NewItemCommand.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -54,7 +54,7 @@
var tpl = dlg.SelectedTemplate;
- var res = tpl.CreateItem(conn);
+ var res = tpl.CreateItem(startPoint, conn);
if (res != null)
res.ResourceID = "Session:" + conn.SessionID + "//" + Guid.NewGuid().ToString() + "." + res.ResourceType.ToString();
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -49,11 +49,12 @@
//This is to just ensure we have a functional template when it's created
using (var picker = new ResourcePicker(conn.ResourceService, ResourceTypes.MapDefinition, ResourcePickerMode.OpenResource))
var flex = ObjectFactory.CreateFlexibleLayout(conn, FusionTemplateNames.Slate);
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/DrawingLayerDefinitionItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/DrawingLayerDefinitionItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/DrawingLayerDefinitionItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -40,10 +40,11 @@
ResourceType = ResourceTypes.LayerDefinition.ToString();
using (var picker = new ResourcePicker(conn.ResourceService, ResourceTypes.DrawingSource, ResourcePickerMode.OpenResource))
var ldf = ObjectFactory.CreateDefaultLayer(conn, OSGeo.MapGuide.ObjectModels.LayerDefinition.LayerType.Drawing, new Version(1, 0, 0));
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/DrawingSourceItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/DrawingSourceItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/DrawingSourceItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -39,7 +39,7 @@
ResourceType = ResourceTypes.DrawingSource.ToString();
return ObjectFactory.CreateDrawingSource(conn);
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/DwfLoadProcedureItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/DwfLoadProcedureItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/DwfLoadProcedureItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -41,7 +41,7 @@
ResourceType = ResourceTypes.LoadProcedure.ToString();
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/FeatureSourceItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/FeatureSourceItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/FeatureSourceItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -40,7 +40,7 @@
ResourceType = ResourceTypes.FeatureSource.ToString();
var provider = GenericItemSelectionDialog.SelectItem(
Properties.Resources.SelectFdoProvider,
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -54,9 +54,10 @@
/// <summary>
/// Creates a new item from this template
/// </summary>
+ /// <param name="startFolder"></param>
/// <param name="conn">The server connection</param>
/// <returns>a new resource, null if the user cancelled during this process</returns>
- public abstract IResource CreateItem(IServerConnection conn);
+ public abstract IResource CreateItem(string startFolder, IServerConnection conn);
public int CompareTo(ItemTemplate other)
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/MapDefinitionItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/MapDefinitionItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/MapDefinitionItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -39,7 +39,7 @@
ResourceType = ResourceTypes.MapDefinition.ToString();
return ObjectFactory.CreateMapDefinition(conn, Properties.Resources.NewMap);
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/PrintLayoutItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/PrintLayoutItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/PrintLayoutItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -39,7 +39,7 @@
ResourceType = ResourceTypes.PrintLayout.ToString();
return ObjectFactory.CreatePrintLayout(conn);
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/RasterLayerDefinitionItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -49,10 +49,11 @@
var lyr = ObjectFactory.CreateDefaultLayer(conn, OSGeo.MapGuide.ObjectModels.LayerDefinition.LayerType.Raster, new Version(1, 0, 0));
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -41,7 +41,7 @@
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -41,7 +41,7 @@
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -47,7 +47,7 @@
return ObjectFactory.CreateSimpleSymbol(conn, new Version(1, 0, 0), Res.DefaultSymbolName, Res.DefaultSymbolDescription);
@@ -72,7 +72,7 @@
return ObjectFactory.CreateCompoundSymbol(conn, new Version(1, 0, 0), Res.DefaultSymbolName, Res.DefaultSymbolDescription);
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -59,7 +59,7 @@
this.ResourceType = _res.ResourceType.ToString();
IResource res = (IResource)_res.Clone();
res.CurrentConnection = conn;
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/VectorLayerDefinitionItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/VectorLayerDefinitionItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/VectorLayerDefinitionItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -41,10 +41,11 @@
var lyr = ObjectFactory.CreateDefaultLayer(conn, OSGeo.MapGuide.ObjectModels.LayerDefinition.LayerType.Vector, new Version(1, 0, 0));
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/WebLayoutItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/WebLayoutItemTemplate.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/WebLayoutItemTemplate.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -39,7 +39,7 @@
ResourceType = ResourceTypes.WebLayout.ToString();
return ObjectFactory.CreateWebLayout(conn, new Version(1, 0, 0), string.Empty);
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs 2011-04-06 14:05:46 UTC (rev 5684)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs 2011-04-06 14:35:13 UTC (rev 5685)
@@ -104,6 +104,9 @@
/// <param name="folderId">The folder id.</param>
public void SetStartingPoint(string folderId)
+ if (string.IsNullOrEmpty(folderId))
+ return;
if (!ResourceIdentifier.IsFolderResource(folderId))
throw new ArgumentException(string.Format(Properties.Resources.NotAFolder, folderId));
_model.NavigateTo(folderId);
More information about the mapguide-commits
