[mapguide-commits] r5687 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Wed Apr 6 12:44:54 EDT 2011
Author: brucedechant
Date: 2011-04-06 09:44:54 -0700 (Wed, 06 Apr 2011)
New Revision: 5687
trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
Fix for trac ticket 1600 - Threading error with CodeToWkt() method
http://trac.osgeo.org/mapguide/ticket/1600
Notes:
- Guard all CSepsg2adskCS() method calls
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2011-04-06 16:17:52 UTC (rev 5686)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2011-04-06 16:44:54 UTC (rev 5687)
@@ -812,7 +812,7 @@
throw new MgOutOfMemoryException(L"MgCoordinateSystemFormatConverter.CodeToDefinition", __LINE__, __WFILE__, NULL, L"", NULL);
- const char* szMsiName=NULL;
+ std::string szMsiName;
//if input is EPSG
bool bResult=false;
@@ -826,9 +826,20 @@
//viewed from the outside of the public API
//The mapping from Adsk name to Msi is done internally inside
//the method CSepsg2adskCS
- szMsiName=CSepsg2adskCS(lEpsg);
- if (szMsiName)
+ CriticalClass.Enter();
+ const char* szMsiNameTemp=NULL;
+ szMsiNameTemp=CSepsg2adskCS(lEpsg);
+ if(NULL == szMsiNameTemp)
+ szMsiName = "";
+ else
+ szMsiName = szMsiNameTemp;
+ CriticalClass.Leave();
+ if (!szMsiName.empty())
bResult=true;
@@ -847,9 +858,9 @@
//now get the definition
if (bResult)
- assert(szMsiName);
+ assert(!szMsiName.empty());
- wchar_t* wszMsiName=Convert_Ascii_To_Wide(szMsiName);
+ wchar_t* wszMsiName=Convert_Ascii_To_Wide(szMsiName.c_str());
if (!wszMsiName)
@@ -902,14 +913,26 @@
- const char* szMsiName=CSepsg2adskCS(lEpsg);
- if (szMsiName)
+ szMsiName = "";
+ else
//need to check if the system is in our dictionary
- bool bIsCoordinateSystem=IsCoordinateSystem(const_cast<char*>(szMsiName), NULL);
+ bool bIsCoordinateSystem=IsCoordinateSystem(const_cast<char*>(szMsiName.c_str()), NULL);
if (bIsCoordinateSystem)
- wchar_t *pwszCsDestination=Convert_Ascii_To_Wide(szMsiName);
+ wchar_t *pwszCsDestination=Convert_Ascii_To_Wide(szMsiName.c_str());
if (!pwszCsDestination)
throw new MgOutOfMemoryException(L"MgCoordinateSystemFormatConverter.CodeToCode", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -991,9 +1014,21 @@
- if (szMsiName)
+ szMsiName = "";
+ else
//we may have found an Msi name for a system
//but we still have to check if the system is in the dicionary
//in CS_epsg.c I found some systems that were present in the mapping
@@ -1002,7 +1037,7 @@
//if the system is in the dictionary since it takes care
//of mapping an MSI name to a valid ADSK name
//We'll check the existence of the system for additional security
- bIsPresent=IsCoordinateSystem(const_cast<char*>(szMsiName), NULL);
+ bIsPresent=IsCoordinateSystem(const_cast<char*>(szMsiName.c_str()), NULL);
More information about the mapguide-commits
