[mapguide-commits] r5691 - trunk/Tools/Maestro/Maestro.Base/Editor
svn_mapguide at osgeo.org
Mon Apr 11 05:59:00 EDT 2011
Author: jng
Date: 2011-04-11 02:58:59 -0700 (Mon, 11 Apr 2011)
New Revision: 5691
trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.resx
trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.resx
trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.resx
trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.resx
trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.resx
trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.resx
trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.resx
trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditorDialog.cs
#1656: Fix the implementation of Bind() for all top-level editors. This allows seamless transition and consistent behaviour when using the Edit As XML command.
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,31 +28,17 @@
/// </summary>
private void InitializeComponent()
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(DrawingSourceEditor));
- this.dsEditorCtrl = new Maestro.Editors.DrawingSource.DrawingSourceEditorCtrl();
- this.panelBody.SuspendLayout();
this.SuspendLayout();
- // panelBody
- this.panelBody.Controls.Add(this.dsEditorCtrl);
- // dsEditorCtrl
- resources.ApplyResources(this.dsEditorCtrl, "dsEditorCtrl");
- this.dsEditorCtrl.Name = "dsEditorCtrl";
// DrawingSourceEditor
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
this.Name = "DrawingSourceEditor";
- this.panelBody.ResumeLayout(false);
this.ResumeLayout(false);
#endregion
- private Maestro.Editors.DrawingSource.DrawingSourceEditorCtrl dsEditorCtrl;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -40,12 +40,23 @@
private IResource _res;
private IEditorService _edsvc;
+ private bool _init = false;
protected override void Bind(IEditorService service)
- _edsvc = service;
- _res = _edsvc.GetEditedResource();
- _edsvc.BeforeSave += new CancelEventHandler(OnBeforeSave);
- dsEditorCtrl.Bind(service);
+ if (!_init)
+ _edsvc = service;
+ _res = _edsvc.GetEditedResource();
+ //_edsvc.BeforeSave += new CancelEventHandler(OnBeforeSave);
+ _init = true;
+ var dsEditor = new DrawingSourceEditor();
+ dsEditor.Dock = DockStyle.Fill;
+ dsEditor.Controls.Add(dsEditor);
+ dsEditor.Bind(_edsvc);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.resx 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.resx 2011-04-11 09:58:59 UTC (rev 5691)
@@ -117,33 +117,6 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="dsEditorCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- <value>Fill</value>
- </data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
- <data name="dsEditorCtrl.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 0</value>
- </data>
- <data name="dsEditorCtrl.Size" type="System.Drawing.Size, System.Drawing">
- <value>614, 520</value>
- </data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="dsEditorCtrl.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>dsEditorCtrl.Name" xml:space="preserve">
- <value>dsEditorCtrl</value>
- </data>
- <data name=">>dsEditorCtrl.Type" xml:space="preserve">
- <value>Maestro.Editors.DrawingSource.DrawingSourceEditorCtrl, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
- </data>
- <data name=">>dsEditorCtrl.Parent" xml:space="preserve">
- <value>panelBody</value>
- </data>
- <data name=">>dsEditorCtrl.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
<data name=">>panelBody.Name" xml:space="preserve">
</data>
@@ -163,6 +136,6 @@
<value>DrawingSourceEditor</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Base.Editor.EditorContentBase, Maestro.Base, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Base.Editor.EditorContentBase, Maestro.Base, Version=3.0.0.5676, Culture=neutral, PublicKeyToken=null</value>
</data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -76,6 +76,8 @@
this.CanUpgrade = _svc.IsUpgradeAvailable;
Bind(_svc);
+ //Do dirty state check
+ OnDirtyStateChanged(this, EventArgs.Empty);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.Designer.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.Designer.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,31 +28,17 @@
/// </summary>
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(FeatureSourceEditor));
- this.fsEditorCtrl = new Maestro.Editors.FeatureSource.FeatureSourceEditorCtrl();
- // panelBody
- this.panelBody.Controls.Add(this.fsEditorCtrl);
- // fsEditorCtrl
- resources.ApplyResources(this.fsEditorCtrl, "fsEditorCtrl");
- this.fsEditorCtrl.Name = "fsEditorCtrl";
// FeatureSourceEditor
this.Name = "FeatureSourceEditor";
#endregion
- private Maestro.Editors.FeatureSource.FeatureSourceEditorCtrl fsEditorCtrl;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,6 +28,7 @@
using Maestro.Editors;
using ICSharpCode.Core;
using OSGeo.MapGuide.ObjectModels.MapDefinition;
+using Maestro.Editors.FeatureSource;
namespace Maestro.Base.Editor
@@ -40,16 +41,29 @@
- _edsvc = service;
+ if (!_init)
+ _edsvc = service;
+ _init = true;
+ panelBody.Controls.Clear();
+ var fsEditor = new FeatureSourceEditorCtrl();
+ fsEditor.Dock = DockStyle.Fill;
+ panelBody.Controls.Add(fsEditor);
var fsOpts = new FsEditorOptionPanel();
fsOpts.Dock = DockStyle.Top;
- fsOpts.Bind(service);
- fsEditorCtrl.Controls.Add(fsOpts);
- fsEditorCtrl.Bind(service);
+ fsOpts.Bind(_edsvc);
+ fsEditor.Controls.Add(fsOpts);
+ fsEditor.Bind(_edsvc);
protected override void OnBeforeSave(object sender, CancelEventArgs e)
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.resx 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.resx 2011-04-11 09:58:59 UTC (rev 5691)
@@ -117,36 +117,6 @@
</resheader>
- <data name="fsEditorCtrl.AutoScroll" type="System.Boolean, mscorlib">
- <value>True</value>
- </data>
- <data name="fsEditorCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- </data>
- <data name="fsEditorCtrl.Location" type="System.Drawing.Point, System.Drawing">
- </data>
- <data name="fsEditorCtrl.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="fsEditorCtrl.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>fsEditorCtrl.Name" xml:space="preserve">
- <value>fsEditorCtrl</value>
- </data>
- <data name=">>fsEditorCtrl.Type" xml:space="preserve">
- <value>Maestro.Editors.FeatureSource.FeatureSourceEditorCtrl, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
- </data>
- <data name=">>fsEditorCtrl.Parent" xml:space="preserve">
- </data>
- <data name=">>fsEditorCtrl.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
</data>
@@ -166,6 +136,6 @@
<value>FeatureSourceEditor</value>
</data>
</data>
</root>
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.Designer.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.Designer.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,32 +28,17 @@
/// </summary>
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(FusionEditor));
- this.flexEditor = new Maestro.Editors.Fusion.FlexibleLayoutEditor();
- // panelBody
- this.panelBody.Controls.Add(this.flexEditor);
- // flexEditor
- resources.ApplyResources(this.flexEditor, "flexEditor");
- this.flexEditor.Name = "flexEditor";
// FusionEditor
- resources.ApplyResources(this, "$this");
this.Name = "FusionEditor";
#endregion
- private Maestro.Editors.Fusion.FlexibleLayoutEditor flexEditor;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -39,13 +39,24 @@
- _edsvc = service;
+ if (!_init)
+ _edsvc = service;
+ _init = true;
- flexEditor.Bind(service);
+ var flexEditor = new FlexibleLayoutEditor();
+ flexEditor.Dock = DockStyle.Fill;
+ panelBody.Controls.Add(flexEditor);
+ flexEditor.Bind(_edsvc);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.resx 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.resx 2011-04-11 09:58:59 UTC (rev 5691)
</resheader>
- <data name="flexEditor.AutoScroll" type="System.Boolean, mscorlib">
- </data>
- <data name="flexEditor.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- </data>
- <data name="flexEditor.Location" type="System.Drawing.Point, System.Drawing">
- </data>
- <data name="flexEditor.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="flexEditor.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>flexEditor.Name" xml:space="preserve">
- <value>flexEditor</value>
- </data>
- <data name=">>flexEditor.Type" xml:space="preserve">
- <value>Maestro.Editors.Fusion.FlexibleLayoutEditor, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
- </data>
- <data name=">>flexEditor.Parent" xml:space="preserve">
- </data>
- <data name=">>flexEditor.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
</data>
@@ -162,13 +132,10 @@
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
- <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
- <value>6, 13</value>
- </data>
<data name=">>$this.Name" xml:space="preserve">
<value>FusionEditor</value>
</data>
</data>
</root>
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -45,15 +45,20 @@
private ILayerDefinition _res;
protected override void Bind(Maestro.Editors.IEditorService service)
+ if (!_init)
+ _edsvc = service;
+ _res = service.GetEditedResource() as ILayerDefinition;
+ Debug.Assert(_res != null);
+ _init = true;
- _edsvc = service;
- _res = service.GetEditedResource() as ILayerDefinition;
- Debug.Assert(_res != null);
var vl = _res.SubLayer as IVectorLayerDefinition;
var gl = _res.SubLayer as IRasterLayerDefinition;
var dl = _res.SubLayer as IDrawingLayerDefinition;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,31 +28,17 @@
/// </summary>
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(LoadProcedureEditor));
- this.lpEditor = new Maestro.Editors.LoadProcedure.LoadProcedureEditorCtrl();
- // panelBody
- this.panelBody.Controls.Add(this.lpEditor);
- // lpEditor
- resources.ApplyResources(this.lpEditor, "lpEditor");
- this.lpEditor.Name = "lpEditor";
// LoadProcedureEditor
this.Name = "LoadProcedureEditor";
#endregion
- private Maestro.Editors.LoadProcedure.LoadProcedureEditorCtrl lpEditor;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -24,6 +24,7 @@
using System.Data;
using System.Text;
using System.Windows.Forms;
+using Maestro.Editors.LoadProcedure;
@@ -36,6 +37,12 @@
+ var lpEditor = new LoadProcedureEditorCtrl();
+ lpEditor.Dock = DockStyle.Fill;
+ panelBody.Controls.Add(lpEditor);
lpEditor.Bind(service);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.resx 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.resx 2011-04-11 09:58:59 UTC (rev 5691)
</resheader>
- <data name="lpEditor.AutoScroll" type="System.Boolean, mscorlib">
- </data>
- <data name="lpEditor.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- </data>
- <data name="lpEditor.Location" type="System.Drawing.Point, System.Drawing">
- </data>
- <data name="lpEditor.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="lpEditor.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>lpEditor.Name" xml:space="preserve">
- <value>lpEditor</value>
- </data>
- <data name=">>lpEditor.Type" xml:space="preserve">
- <value>Maestro.Editors.LoadProcedure.LoadProcedureEditorCtrl, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
- </data>
- <data name=">>lpEditor.Parent" xml:space="preserve">
- </data>
- <data name=">>lpEditor.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
</data>
@@ -166,6 +136,6 @@
<value>LoadProcedureEditor</value>
</data>
</data>
</root>
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,31 +28,17 @@
/// </summary>
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MapDefinitionEditor));
- this.mapEditorCtrl = new Maestro.Editors.MapDefinition.MapDefinitionEditorCtrl();
- // panelBody
- this.panelBody.Controls.Add(this.mapEditorCtrl);
- // mapEditorCtrl
- resources.ApplyResources(this.mapEditorCtrl, "mapEditorCtrl");
- this.mapEditorCtrl.Name = "mapEditorCtrl";
// MapDefinitionEditor
this.Name = "MapDefinitionEditor";
#endregion
- private Maestro.Editors.MapDefinition.MapDefinitionEditorCtrl mapEditorCtrl;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,6 +28,7 @@
+using Maestro.Editors.MapDefinition;
@@ -40,11 +41,22 @@
- _edsvc = service;
+ if (!_init)
+ _edsvc = service;
+ _init = true;
+ var mapEditorCtrl = new MapDefinitionEditorCtrl();
+ mapEditorCtrl.Dock = DockStyle.Fill;
+ panelBody.Controls.Add(mapEditorCtrl);
mapEditorCtrl.Bind(service);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.resx 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.resx 2011-04-11 09:58:59 UTC (rev 5691)
</resheader>
- <data name="mapEditorCtrl.AutoScroll" type="System.Boolean, mscorlib">
- </data>
- <data name="mapEditorCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- </data>
- <data name="mapEditorCtrl.Location" type="System.Drawing.Point, System.Drawing">
- </data>
- <data name="mapEditorCtrl.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="mapEditorCtrl.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>mapEditorCtrl.Name" xml:space="preserve">
- <value>mapEditorCtrl</value>
- </data>
- <data name=">>mapEditorCtrl.Type" xml:space="preserve">
- <value>Maestro.Editors.MapDefinition.MapDefinitionEditorCtrl, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
- </data>
- <data name=">>mapEditorCtrl.Parent" xml:space="preserve">
- </data>
- <data name=">>mapEditorCtrl.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
</data>
@@ -166,6 +136,6 @@
<value>MapDefinitionEditor</value>
</data>
</data>
</root>
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.Designer.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.Designer.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,31 +28,17 @@
/// </summary>
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(PrintLayoutEditor));
- this.printLayoutEditorCtrl = new Maestro.Editors.PrintLayout.PrintLayoutEditorCtrl();
- // panelBody
- this.panelBody.Controls.Add(this.printLayoutEditorCtrl);
- // printLayoutEditorCtrl
- resources.ApplyResources(this.printLayoutEditorCtrl, "printLayoutEditorCtrl");
- this.printLayoutEditorCtrl.Name = "printLayoutEditorCtrl";
// PrintLayoutEditor
this.Name = "PrintLayoutEditor";
#endregion
- private Maestro.Editors.PrintLayout.PrintLayoutEditorCtrl printLayoutEditorCtrl;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -24,6 +24,7 @@
using System.Data;
using System.Text;
+using Maestro.Editors.PrintLayout;
@@ -36,6 +37,12 @@
+ var printLayoutEditorCtrl = new PrintLayoutEditorCtrl();
+ printLayoutEditorCtrl.Dock = DockStyle.Fill;
+ panelBody.Controls.Add(printLayoutEditorCtrl);
printLayoutEditorCtrl.Bind(service);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.resx 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.resx 2011-04-11 09:58:59 UTC (rev 5691)
</resheader>
- <data name="printLayoutEditorCtrl.AutoScroll" type="System.Boolean, mscorlib">
- </data>
- <data name="printLayoutEditorCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- </data>
- <data name="printLayoutEditorCtrl.Location" type="System.Drawing.Point, System.Drawing">
- </data>
- <data name="printLayoutEditorCtrl.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="printLayoutEditorCtrl.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>printLayoutEditorCtrl.Name" xml:space="preserve">
- <value>printLayoutEditorCtrl</value>
- </data>
- <data name=">>printLayoutEditorCtrl.Type" xml:space="preserve">
- <value>Maestro.Editors.PrintLayout.PrintLayoutEditorCtrl, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
- </data>
- <data name=">>printLayoutEditorCtrl.Parent" xml:space="preserve">
- </data>
- <data name=">>printLayoutEditorCtrl.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
</data>
@@ -166,6 +136,6 @@
<value>PrintLayoutEditor</value>
</data>
</data>
</root>
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.Designer.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.Designer.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -28,32 +28,18 @@
/// </summary>
- System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(WebLayoutEditor));
- this.webLayoutEditorCtrl = new Maestro.Editors.WebLayout.WebLayoutEditorCtrl();
- // panelBody
- this.panelBody.Controls.Add(this.webLayoutEditorCtrl);
- // webLayoutEditorCtrl
- resources.ApplyResources(this.webLayoutEditorCtrl, "webLayoutEditorCtrl");
- this.webLayoutEditorCtrl.Name = "webLayoutEditorCtrl";
// WebLayoutEditor
this.Name = "WebLayoutEditor";
#endregion
- private Maestro.Editors.WebLayout.WebLayoutEditorCtrl webLayoutEditorCtrl;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -24,6 +24,7 @@
using System.Data;
using System.Text;
+using Maestro.Editors.WebLayout;
@@ -34,11 +35,14 @@
InitializeComponent();
- private Maestro.Editors.IEditorService _edSvc;
- _edSvc = service;
+ var webLayoutEditorCtrl = new WebLayoutEditorCtrl();
+ webLayoutEditorCtrl.Dock = DockStyle.Fill;
+ panelBody.Controls.Add(webLayoutEditorCtrl);
webLayoutEditorCtrl.Bind(service);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.resx 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.resx 2011-04-11 09:58:59 UTC (rev 5691)
</resheader>
- <data name="webLayoutEditorCtrl.AutoScroll" type="System.Boolean, mscorlib">
- </data>
- <data name="webLayoutEditorCtrl.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- </data>
- <data name="webLayoutEditorCtrl.Location" type="System.Drawing.Point, System.Drawing">
- </data>
- <data name="webLayoutEditorCtrl.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="webLayoutEditorCtrl.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>webLayoutEditorCtrl.Name" xml:space="preserve">
- <value>webLayoutEditorCtrl</value>
- </data>
- <data name=">>webLayoutEditorCtrl.Type" xml:space="preserve">
- <value>Maestro.Editors.WebLayout.WebLayoutEditorCtrl, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
- </data>
- <data name=">>webLayoutEditorCtrl.Parent" xml:space="preserve">
- </data>
- <data name=">>webLayoutEditorCtrl.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
</data>
@@ -166,6 +136,6 @@
<value>WebLayoutEditor</value>
</data>
</data>
</root>
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -91,6 +91,9 @@
+ //NOTE: This is exempt from #1656 requirements because this will never be called when returing
+ //from an XML editor because IT IS the xml editor!
_edSvc = service;
_edSvc.RegisterCustomNotifier(editor);
editor.Bind(_edSvc);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditorDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditorDialog.cs 2011-04-07 14:47:30 UTC (rev 5690)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditorDialog.cs 2011-04-11 09:58:59 UTC (rev 5691)
@@ -32,7 +32,7 @@
- public partial class XmlEditorDialog : Form
+ public partial class XmlEditorDialog : Form, INotifyResourceChanged
private XmlEditorCtrl _ed;
private IEditorService _edSvc;
@@ -50,8 +50,25 @@
: this()
_edSvc = edsvc;
+ _edSvc.RegisterCustomNotifier(this);
+ this.Disposed += new EventHandler(OnDisposed);
+ void OnDisposed(object sender, EventArgs e)
+ //Same as EditorBindableCollapsiblePanel.UnsubscribeEventHandlers()
+ var handler = this.ResourceChanged;
+ if (handler != null)
+ foreach (var h in handler.GetInvocationList())
+ this.ResourceChanged -= (EventHandler)h;
+ //In case we left out something (shouldn't be)
+ this.ResourceChanged = null;
protected override void OnLoad(EventArgs e)
if (_edSvc != null)
@@ -116,13 +133,15 @@
_enableResourceTypeValidation = true;
+ private string _lastSnapshot;
/// <summary>
/// Gets or sets the XML content for this dialog.
/// </summary>
public string XmlContent
get { return _ed.XmlContent; }
- set { _ed.XmlContent = value; }
+ set { _ed.XmlContent = _lastSnapshot = value; }
private void btnCancel_Click(object sender, EventArgs e)
@@ -132,7 +151,18 @@
private void btnSave_Click(object sender, EventArgs e)
+ if (_lastSnapshot != _ed.XmlContent)
+ OnResourceChanged();
this.DialogResult = DialogResult.OK;
+ private void OnResourceChanged()
+ handler(this, EventArgs.Empty);
+ public event EventHandler ResourceChanged;
More information about the mapguide-commits
