[mapguide-commits] r5696 - in trunk/Tools/Maestro/Maestro.Editors:
FeatureSource Properties
svn_mapguide at osgeo.org
Tue Apr 12 07:54:43 EDT 2011
Author: jng
Date: 2011-04-12 04:54:43 -0700 (Tue, 12 Apr 2011)
New Revision: 5696
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
#1659: Port over advanced coordinate system override features from Maestro 2.x.
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.Designer.cs 2011-04-12 11:24:26 UTC (rev 5695)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.Designer.cs 2011-04-12 11:54:43 UTC (rev 5696)
@@ -33,6 +33,9 @@
this.btnAdd = new System.Windows.Forms.ToolStripButton();
this.btnEdit = new System.Windows.Forms.ToolStripButton();
this.btnDelete = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnApplyAll = new System.Windows.Forms.ToolStripButton();
+ this.btnLoadFromSc = new System.Windows.Forms.ToolStripButton();
this.grdOverrides = new System.Windows.Forms.DataGridView();
this.COL_SOURCE = new System.Windows.Forms.DataGridViewTextBoxColumn();
this.COL_TARGET = new System.Windows.Forms.DataGridViewTextBoxColumn();
@@ -52,7 +55,10 @@
this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
this.btnAdd,
this.btnEdit,
- this.btnDelete});
+ this.btnDelete,
+ this.toolStripSeparator1,
+ this.btnApplyAll,
+ this.btnLoadFromSc});
resources.ApplyResources(this.toolStrip1, "toolStrip1");
this.toolStrip1.Name = "toolStrip1";
@@ -77,6 +83,25 @@
this.btnDelete.Name = "btnDelete";
this.btnDelete.Click += new System.EventHandler(this.btnDelete_Click);
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ resources.ApplyResources(this.toolStripSeparator1, "toolStripSeparator1");
+ // btnApplyAll
+ resources.ApplyResources(this.btnApplyAll, "btnApplyAll");
+ this.btnApplyAll.Image = global::Maestro.Editors.Properties.Resources.globe__arrow;
+ this.btnApplyAll.Name = "btnApplyAll";
+ this.btnApplyAll.Click += new System.EventHandler(this.btnApplyAll_Click);
+ // btnLoadFromSc
+ this.btnLoadFromSc.Image = global::Maestro.Editors.Properties.Resources.globe__plus;
+ resources.ApplyResources(this.btnLoadFromSc, "btnLoadFromSc");
+ this.btnLoadFromSc.Name = "btnLoadFromSc";
+ this.btnLoadFromSc.Click += new System.EventHandler(this.btnLoadFromSc_Click);
// grdOverrides
this.grdOverrides.AllowUserToAddRows = false;
@@ -132,5 +157,8 @@
private System.Windows.Forms.ToolStripButton btnEdit;
private System.Windows.Forms.DataGridViewTextBoxColumn COL_SOURCE;
private System.Windows.Forms.DataGridViewTextBoxColumn COL_TARGET;
+ private System.Windows.Forms.ToolStripButton btnApplyAll;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
+ private System.Windows.Forms.ToolStripButton btnLoadFromSc;
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.cs 2011-04-12 11:24:26 UTC (rev 5695)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.cs 2011-04-12 11:54:43 UTC (rev 5696)
@@ -76,6 +76,7 @@
grdOverrides.Rows[e.RowIndex].Selected = true;
+ btnApplyAll.Enabled = grdOverrides.SelectedRows.Count > 0;
private void grdOverrides_SelectionChanged(object sender, EventArgs e)
@@ -112,5 +113,45 @@
OnResourceChanged();
+ private void btnApplyAll_Click(object sender, EventArgs e)
+ string wkt = _ed.GetCoordinateSystem();
+ if (!string.IsNullOrEmpty(wkt))
+ foreach (DataGridViewRow row in grdOverrides.SelectedRows)
+ var sci = (ISpatialContextInfo)row.DataBoundItem;
+ sci.CoordinateSystem = wkt;
+ UpdateSpatialContextList();
+ private void btnLoadFromSc_Click(object sender, EventArgs e)
+ if (grdOverrides.Rows.Count > 0)
+ if (MessageBox.Show(Properties.Resources.QuestionResetFsOverrideList, Properties.Resources.TitleQuestion, MessageBoxButtons.YesNo) == DialogResult.Yes)
+ var sco = new List<ISpatialContextInfo>(_fs.SupplementalSpatialContextInfo);
+ foreach (var s in sco)
+ _fs.RemoveSpatialContextOverride(s);
+ else
+ return;
+ var scList = _fs.GetSpatialInfo(false);
+ foreach (var sc in scList.SpatialContext)
+ _fs.AddSpatialContextOverride(sc.Name, sc.CoordinateSystemWkt);
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.resx 2011-04-12 11:24:26 UTC (rev 5695)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.resx 2011-04-12 11:54:43 UTC (rev 5696)
@@ -195,6 +195,36 @@
<data name="btnDelete.Text" xml:space="preserve">
<value>Delete</value>
</data>
+ <data name="toolStripSeparator1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>6, 25</value>
+ </data>
+ <data name="btnApplyAll.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnApplyAll.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnApplyAll.Size" type="System.Drawing.Size, System.Drawing">
+ <value>104, 22</value>
+ </data>
+ <data name="btnApplyAll.Text" xml:space="preserve">
+ <value>Apply CS to all</value>
+ </data>
+ <data name="btnApplyAll.ToolTipText" xml:space="preserve">
+ <value>Apply the same coordinate system to all selected overrides</value>
+ </data>
+ <data name="btnLoadFromSc.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnLoadFromSc.Size" type="System.Drawing.Size, System.Drawing">
+ <value>99, 22</value>
+ </data>
+ <data name="btnLoadFromSc.Text" xml:space="preserve">
+ <value>Load Defaults</value>
+ </data>
+ <data name="btnLoadFromSc.ToolTipText" xml:space="preserve">
+ <value>Load overrides from current list of spatial contexts</value>
+ </data>
<data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 0</value>
</data>
@@ -258,6 +288,24 @@
<data name=">>btnDelete.Type" xml:space="preserve">
<value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
+ <data name=">>toolStripSeparator1.Name" xml:space="preserve">
+ <value>toolStripSeparator1</value>
+ </data>
+ <data name=">>toolStripSeparator1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnApplyAll.Name" xml:space="preserve">
+ <value>btnApplyAll</value>
+ </data>
+ <data name=">>btnApplyAll.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnLoadFromSc.Name" xml:space="preserve">
+ <value>btnLoadFromSc</value>
+ </data>
+ <data name=">>btnLoadFromSc.Type" xml:space="preserve">
+ </data>
<data name=">>COL_SOURCE.Name" xml:space="preserve">
<value>COL_SOURCE</value>
</data>
@@ -274,6 +322,6 @@
<value>CoordSysOverrideCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.0.0.5676, Culture=neutral, PublicKeyToken=null</value>
</data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-04-12 11:24:26 UTC (rev 5695)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-04-12 11:54:43 UTC (rev 5696)
@@ -2173,6 +2173,15 @@
/// <summary>
+ /// Looks up a localized string similar to Reset Feature Source override list?.
+ /// </summary>
+ internal static string QuestionResetFsOverrideList {
+ get {
+ return ResourceManager.GetString("QuestionResetFsOverrideList", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to RDBMS Feature Source.
/// </summary>
internal static string RdbmsFeatureSource {
@@ -2515,6 +2524,15 @@
/// <summary>
+ /// Looks up a localized string similar to Question.
+ /// </summary>
+ internal static string TitleQuestion {
+ get {
+ return ResourceManager.GetString("TitleQuestion", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to The selected column contains more than {0} different values, and thus cannot be used for theming with individual values.
/// </summary>
internal static string TooManyIndiviualValuesError {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-04-12 11:24:26 UTC (rev 5695)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-04-12 11:54:43 UTC (rev 5696)
@@ -1160,4 +1160,10 @@
<data name="PreviewUrlNotAvailable" xml:space="preserve">
<value>The Preview URL is not currently available</value>
</data>
+ <data name="QuestionResetFsOverrideList" xml:space="preserve">
+ <value>Reset Feature Source override list?</value>
+ </data>
+ <data name="TitleQuestion" xml:space="preserve">
+ <value>Question</value>
+ </data>
</root>
More information about the mapguide-commits
