[mapguide-commits] r5703 - branches/2.2/Installer/scripts
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Apr 17 06:52:05 EDT 2011
Author: trevorwekel
Date: 2011-04-17 03:52:05 -0700 (Sun, 17 Apr 2011)
New Revision: 5703
   branches/2.2/Installer/scripts/build.sh
Build improvement for Linux - burn version information of all svn repos into build script
Modified: branches/2.2/Installer/scripts/build.sh
--- branches/2.2/Installer/scripts/build.sh	2011-04-17 10:08:47 UTC (rev 5702)
+++ branches/2.2/Installer/scripts/build.sh	2011-04-17 10:52:05 UTC (rev 5703)
@@ -12,10 +12,18 @@
 rm -rf ${MGSOURCE}
 rm -rf ${INSTALLROOT}
-REVISION=`svn info ${SVNROOT}/mapguide/branches/2.2/MgDev | perl revnum.pl`
+MGDEVREV=5624
+FUSIONREV=2366
+CSMAPREV=1964
+REVISION=`svn info ${SVNROOT}/mapguide/branches/2.2/Installer | perl revnum.pl`
 echo ${REVISION} > revnum.txt
 echo "Building Revision ${BUILDNUM}.${REVISION}"
-svn export -q -r ${REVISION} ${SVNROOT}/mapguide/branches/2.2/MgDev ${MGSOURCE}
+svn export --ignore-externals -r ${MGDEVREV}  svn://svn.bld.mgproto.net/mapguide/branches/2.2/MgDev ${MGSOURCE}
+svn export -r ${FUSIONREV} svn://svn.bld.mgproto.net/fusion/branches/fusion-2.2 ${MGSOURCE}/Oem/fusion
+svn export -r ${CSMAPREV} svn://svn.bld.mgproto.net/metacrs/csmap/branches/12.02/CsMapDev ${MGSOURCE}/Oem/CsMap
 cd ${MGSOURCE}
@@ -45,7 +53,8 @@
 make install
 # Prepare binaries for packaging by removing unnecessary
-# .la and .a files and stripping unneeded symbols from the binaries
+# .la and .a files.  Remove executable permission to make Debian packager happy
+# Keep symbols around for Debian packaging
 pushd ${INSTALLROOT}
 LIBDIRS="lib server/lib webserverextensions/lib"
 for libdir in ${LIBDIRS}
@@ -54,10 +63,9 @@
    rm -f ${libdir}/*.la
    rm -f ${libdir}/*.a
-   # Remove unneeded symbols from files in the lib directories
+   # Remove execute permission from files in lib directory
    for file in `find ${libdir}/lib*.so* -type f -print`
    do
-      strip --strip-unneeded ${file}
       chmod a-x ${file}
    done
 done
@@ -68,5 +76,27 @@
 if [ ! -d bin ]; then
    mkdir -p bin
 fi
+tar -zcf bin/mapguideopensource-${BUILDNUM}.${REVISION}_symbols.tar.gz ${INSTALLROOT} ${LOCKFILEDIR}
+popd
+# For the final executables, strip the symbols before tarballing
+pushd ${INSTALLROOT}
+LIBDIRS="lib server/lib webserverextensions/lib"
+for libdir in ${LIBDIRS}
+do
+   # Strip symbols from final executable
+   for file in `find ${libdir}/lib*.so* -type f -print`
+   do
+      strip --strip-unneeded ${file}
+   done
+done
+popd
+# Tarball the whole works and put it in a bin directory
+pushd ${BUILDROOT}
+if [ ! -d bin ]; then
+   mkdir -p bin
+fi
 tar -zcf bin/mapguideopensource-${BUILDNUM}.${REVISION}.tar.gz ${INSTALLROOT} ${LOCKFILEDIR}
 popd
More information about the mapguide-commits mailing list
