[mapguide-commits] r5708 - in trunk/Tools/Maestro: . Maestro
Properties
svn_mapguide at osgeo.org
Tue Apr 19 07:39:13 EDT 2011
Author: jng
Date: 2011-04-19 04:39:13 -0700 (Tue, 19 Apr 2011)
New Revision: 5708
Added:
trunk/Tools/Maestro/Maestro/Schemas/
trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
trunk/Tools/Maestro/build.bat
Prep RC1 release
Modified: trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-04-19 11:37:07 UTC (rev 5707)
+++ trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-04-19 11:39:13 UTC (rev 5708)
@@ -35,5 +35,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("3.0.0.5676")]
-[assembly: AssemblyFileVersion("3.0.0.5676")]
+[assembly: AssemblyVersion("3.0.0.5708")]
+[assembly: AssemblyFileVersion("3.0.0.5708")]
Modified: trunk/Tools/Maestro/build.bat
--- trunk/Tools/Maestro/build.bat 2011-04-19 11:37:07 UTC (rev 5707)
+++ trunk/Tools/Maestro/build.bat 2011-04-19 11:39:13 UTC (rev 5708)
@@ -2,7 +2,7 @@
SET TYPEACTION=build
SET TYPEBUILD=Release
SET PLATFORM=Any CPU
-SET RELEASE_VERSION=3.0b3
+SET RELEASE_VERSION=3.0rc1
SET OLDPATH=%PATH%
SET PATH=%PATH%;%CD%\Thirdparty\NSIS;C:\Windows\Microsoft.NET\Framework\v3.5
More information about the mapguide-commits
